[GRASS-SVN] r39841 - grass/trunk/lib/gis
Sat Nov 28 00:46:18 EST 2009
Author: glynn
Date: 2009-11-28 00:46:17 -0500 (Sat, 28 Nov 2009)
New Revision: 39841
   grass/trunk/lib/gis/parser.c
   grass/trunk/lib/gis/parser_help.c
   grass/trunk/lib/gis/parser_html.c
   grass/trunk/lib/gis/parser_interface.c
   grass/trunk/lib/gis/parser_local_proto.h
   grass/trunk/lib/gis/parser_script.c
   grass/trunk/lib/gis/parser_wps.c
Clean up parser refactoring
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c	2009-11-27 23:48:44 UTC (rev 39840)
+++ grass/trunk/lib/gis/parser.c	2009-11-28 05:46:17 UTC (rev 39841)
@@ -84,7 +84,7 @@
 static int contains(const char *, int);
 static int is_option(const char *);
 static int set_option(const char *);
-static int check_opts();
+static int check_opts(void);
 static int check_an_opt(const char *, int, const char *, const char **, char **);
 static int check_int(const char *, const char **);
 static int check_double(const char *, const char **);
@@ -419,28 +419,28 @@
 	/* If first arg is "--interface-description" then print out
 	 * a xml description of the task */
 	if (strcmp(argv[1], "--interface-description") == 0) {
-	    usage_xml();
+	    G__usage_xml();
 	    exit(EXIT_SUCCESS);
 	/* If first arg is "--html-description" then print out
 	 * a html description of the task */
 	if (strcmp(argv[1], "--html-description") == 0) {
-	    usage_html();
+	    G__usage_html();
 	    exit(EXIT_SUCCESS);
 	/* If first arg is "--wps-process-description" then print out
 	 * the wps process description of the task */
 	if (strcmp(argv[1], "--wps-process-description") == 0) {
-	    wps_print_process_description();
+	    G__wps_print_process_description();
 	    exit(EXIT_SUCCESS);
 	/* If first arg is "--script" then then generate
 	 * g.parser boilerplate */
 	if (strcmp(argv[1], "--script") == 0) {
-	    script();
+	    G__script();
 	    exit(EXIT_SUCCESS);
@@ -683,7 +683,7 @@
-int uses_new_gisprompt(void)
+int G__uses_new_gisprompt(void)
     struct Option *opt;
     char age[KEYLENGTH];
@@ -710,7 +710,7 @@
     return 0;
-void print_keywords(FILE *fd, void (*format)(FILE *, const char *))
+void G__print_keywords(FILE *fd, void (*format)(FILE *, const char *))
     int i;
@@ -1291,7 +1291,7 @@
     return (error);
-void split_gisprompt(const char *gisprompt, char *age, char *element,
+static void split_gisprompt(const char *gisprompt, char *age, char *element,
 			    char *desc)
     const char *ptr1;
Modified: grass/trunk/lib/gis/parser_help.c
--- grass/trunk/lib/gis/parser_help.c	2009-11-27 23:48:44 UTC (rev 39840)
+++ grass/trunk/lib/gis/parser_help.c	2009-11-28 05:46:17 UTC (rev 39841)
@@ -33,7 +33,7 @@
     int len, n;
     int new_prompt = 0;
-    new_prompt = uses_new_gisprompt();
+    new_prompt = G__uses_new_gisprompt();
     if (!st->pgm_name)		/* v.dave && r.michael */
 	st->pgm_name = G_program_name();
@@ -49,7 +49,7 @@
     if (st->module_info.keywords) {
 	fprintf(stderr, _("\nKeywords:\n "));
-	print_keywords(stderr, NULL);
+	G__print_keywords(stderr, NULL);
 	fprintf(stderr, "\n");
Modified: grass/trunk/lib/gis/parser_html.c
--- grass/trunk/lib/gis/parser_html.c	2009-11-27 23:48:44 UTC (rev 39840)
+++ grass/trunk/lib/gis/parser_html.c	2009-11-28 05:46:17 UTC (rev 39841)
@@ -6,14 +6,14 @@
   \brief Print module usage description in HTML format.
-void usage_html(void)
+void G__usage_html(void)
     struct Option *opt;
     struct Flag *flag;
     const char *type;
     int new_prompt = 0;
@@ -47,7 +47,7 @@
     fprintf(stdout, "<h2>%s</h2>\n", _("KEYWORDS"));
-	print_keywords(stdout, NULL);
+	G__print_keywords(stdout, NULL);
 	fprintf(stdout, "\n");
     fprintf(stdout, "<h2>%s</h2>\n", _("SYNOPSIS"));
Modified: grass/trunk/lib/gis/parser_interface.c
--- grass/trunk/lib/gis/parser_interface.c	2009-11-27 23:48:44 UTC (rev 39840)
+++ grass/trunk/lib/gis/parser_interface.c	2009-11-28 05:46:17 UTC (rev 39841)
@@ -7,7 +7,7 @@
  * \param[in,out] fp file to write to
  * \param str string to write
-void print_escaped_for_xml(FILE * fp, const char *str)
+static void print_escaped_for_xml(FILE * fp, const char *str)
     for (; *str; str++) {
 	switch (*str) {
@@ -29,7 +29,7 @@
   \brief Print module usage description in XML format.
-void usage_xml(void)
+void G__usage_xml(void)
     struct Option *opt;
     struct Flag *flag;
@@ -39,7 +39,7 @@
     char *encoding;
     int new_prompt = 0;
     /* gettext converts strings to encoding returned by nl_langinfo(CODESET) */
@@ -81,7 +81,7 @@
 	fprintf(stdout, "\t<keywords>\n\t\t");
-	print_keywords(stdout, print_escaped_for_xml);
+	G__print_keywords(stdout, print_escaped_for_xml);
 	fprintf(stdout, "\n\t</keywords>\n");
Modified: grass/trunk/lib/gis/parser_local_proto.h
--- grass/trunk/lib/gis/parser_local_proto.h	2009-11-27 23:48:44 UTC (rev 39840)
+++ grass/trunk/lib/gis/parser_local_proto.h	2009-11-28 05:46:17 UTC (rev 39841)
@@ -28,7 +28,7 @@
     struct Item *next_item;
-typedef struct state {
+struct state {
     int no_interactive;
     int n_opts;
     int n_flags;
@@ -52,10 +52,10 @@
     struct Item first_item;
     struct Item *current_item;
     int n_items;
-}state_type;
-extern state_type *st;
+extern struct state *st;
 #define BAD_SYNTAX    1
 #define OUT_OF_RANGE  2
@@ -66,12 +66,12 @@
 /* functions which are used by several parser functions in different files */
-void usage_xml(void);
-void usage_html(void);
-void script(void);
-void wps_print_process_description(void);
-void print_escaped_for_xml(FILE * fp, const char *str);
-int  uses_new_gisprompt(void);
-void print_keywords(FILE *fd, void (*format)(FILE *, const char *));
+void G__usage_xml(void);
+void G__usage_html(void);
+void G__script(void);
+void G__wps_print_process_description(void);
+int  G__uses_new_gisprompt(void);
+void G__print_keywords(FILE *fd, void (*format)(FILE *, const char *));
-#endif
\ No newline at end of file
+#endif
Modified: grass/trunk/lib/gis/parser_script.c
--- grass/trunk/lib/gis/parser_script.c	2009-11-27 23:48:44 UTC (rev 39840)
+++ grass/trunk/lib/gis/parser_script.c	2009-11-28 05:46:17 UTC (rev 39841)
@@ -1,6 +1,6 @@
 #include "parser_local_proto.h"
-void script(void)
     FILE *fp = stdout;
     char *type;
@@ -40,7 +40,7 @@
 	fprintf(fp, "#%% description: %s\n", st->module_info.description);
 	fprintf(fp, "#%% keywords: ");
-	print_keywords(fp, NULL);
+	G__print_keywords(fp, NULL);
 	fprintf(fp, "\n");
     fprintf(fp, "#%%end\n");
Modified: grass/trunk/lib/gis/parser_wps.c
--- grass/trunk/lib/gis/parser_wps.c	2009-11-27 23:48:44 UTC (rev 39840)
+++ grass/trunk/lib/gis/parser_wps.c	2009-11-28 05:46:17 UTC (rev 39841)
@@ -36,6 +36,25 @@
                                 const char *, const char *, const char *, int ,
                                 const char **, int , const char *, int );
+    for (; *str; str++) {
+	switch (*str) {
+	case '&':
+	    fputs("&amp;", fp);
+	    break;
+	case '<':
+	    fputs("&lt;", fp);
+	    break;
+	case '>':
+	    fputs("&gt;", fp);
+	    break;
+	default:
+	    fputc(*str, fp);
  * \brief Print the WPS 1.0.0 process description XML document to stdout
@@ -53,7 +72,7 @@
-void wps_print_process_description()
     struct Option *opt;
     struct Flag *flag;
@@ -73,7 +92,7 @@
     int min = 0, max = 0;
     int num_keywords = 0;
     int found_output = 0;
