[GRASS-SVN] r39854 - grass/trunk/scripts/v.what.vect
svn_grass at osgeo.org
Sun Nov 29 05:13:58 EST 2009
Author: neteler
Date: 2009-11-29 05:13:58 -0500 (Sun, 29 Nov 2009)
New Revision: 39854
grass/trunk/scripts/v.what.vect/v.what.vect.html
grass/trunk/scripts/v.what.vect/v.what.vect.py
works also with polygon maps
Modified: grass/trunk/scripts/v.what.vect/v.what.vect.html
--- grass/trunk/scripts/v.what.vect/v.what.vect.html 2009-11-29 10:12:45 UTC (rev 39853)
+++ grass/trunk/scripts/v.what.vect/v.what.vect.html 2009-11-29 10:13:58 UTC (rev 39854)
@@ -9,15 +9,19 @@
The upload <b>column</b>, into which the query results are stored, must be
present in the <b>vector</b> map. Use <em>v.db.addcolumn</em> to add one if needed.
<p>
-Use dmax parameter to control query distance tolerance (how far points can be from
-<b>qvector</b> features). For more options, use
+Use dmax parameter to control query distance tolerance (how far points/centroids
+can be from <b>qvector</b> features). For more options, use
<em>v.distance</em> instead.
<P>
In case of a multipoint input <b>vector</b> map, with several points having the
same category number, it can happen, that the query result is NULL, if the same
category number falls into different <b>qvector</b> polygons.
+<P>
+When transferring attributes from a point map to a polygon map, usually <b>dmax</b>
+has to be larger than zero (determined by distance between query points and
+polygon centroids).
-<h2>EXAMPLE</h2>
+<h2>EXAMPLES</h2>
In this example, the 'archsites' point map in the Spearfish location is copied
to the current mapset, a new attribute column is added and the owner
@@ -31,8 +35,27 @@
# verification:
v.db.select myarchsites
</pre></div>
+<P>
+In this example, city names, population data and more from
+<a href="http://download.geonames.org/export/dump/">Geonames.org country files</a> are
+transferred to selected EU CORINE landuse/landcover classes
+("Continuous urban fabric", 111, and "Discontinuous urban fabric", 112).
+Note: Example in UTM projection to which the input maps have been projected
+beforehand to have metric distances support:
+<div class="code"><pre>
+# extract populated places from geonames
+v.extract geonames_IT where="featurecla='P'" out=geonames_IT_cities
+# add new column
+v.db.addcol corine_code111_112_cities col="gnameid double precision"
+# transfer geonameid (3000m maximal distance between points and centroids)
+v.what.vect corine_code111_112_cities qvect=geonames_IT_cities col=gnameid \
+ qcol=geonameid dmax=3000
+# now gnameid can be used for v.db.join to join further
+# attributes in from Geonames.org
+</pre></div>
<h2>SEE ALSO</h2>
<em>
Modified: grass/trunk/scripts/v.what.vect/v.what.vect.py
--- grass/trunk/scripts/v.what.vect/v.what.vect.py 2009-11-29 10:12:45 UTC (rev 39853)
+++ grass/trunk/scripts/v.what.vect/v.what.vect.py 2009-11-29 10:13:58 UTC (rev 39854)
@@ -25,7 +25,7 @@
#% type: string
#% key_desc: name
#% gisprompt: old,vector,vector
-#% description: Points vector map to modify
+#% description: Vector map to modify
#% required : yes
#%end
#%option
