[GRASS-SVN] r39406 - grass/trunk/gui/wxpython/gui_modules
    svn_grass at osgeo.org
    Mon Oct  5 03:58:29 EDT 2009
Author: martinl
Date: 2009-10-05 03:58:25 -0400 (Mon, 05 Oct 2009)
New Revision: 39406
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
   grass/trunk/gui/wxpython/gui_modules/toolbars.py
   grass/trunk/gui/wxpython/gui_modules/vdigit.py
use vdigit's PseudoDC only during digitize session
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2009-10-05 07:43:17 UTC (rev 39405)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2009-10-05 07:58:25 UTC (rev 39406)
@@ -1,4 +1,4 @@
 @package mapdisp.py
 @brief GIS map display canvas, with toolbar for various display
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py	2009-10-05 07:43:17 UTC (rev 39405)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py	2009-10-05 07:58:25 UTC (rev 39406)
@@ -41,7 +41,7 @@
 from vdigit import VDigitCategoryDialog
 from vdigit import VDigitZBulkDialog
 from vdigit import VDigitDuplicatesDialog
-from vdigit import PseudoDC
+from vdigit import PseudoDC as VDigitPseudoDC
 class MapWindow(object):
@@ -225,14 +225,7 @@
         # platforms at initialization, but little harm done.
         ### self.OnSize(None)
-        # create PseudoDC used for background map, map decorations like scales and legends
-        self.pdc = PseudoDC()
-        # used for digitization tool
-        self.pdcVector = None
-        # decorations (region box, etc.)
-        self.pdcDec = PseudoDC()
-        # pseudoDC for temporal objects (select box, measurement tool, etc.)
-        self.pdcTmp = PseudoDC()
+        self.DefinePseudoDC()
         # redraw all pdc's, pdcTmp layer is redrawn always (speed issue)
         self.redrawAll = True
@@ -245,6 +238,25 @@
         self.dragid   = -1
         self.lastpos  = (0, 0)
+    def DefinePseudoDC(self, vdigit = False):
+        """!Define PseudoDC class to use
+        @vdigit True to use PseudoDC from vdigit
+        if vdigit:
+            PseudoDC = VDigitPseudoDC
+        else:
+            PseudoDC = wx.PseudoDC
+        # create PseudoDC used for background map, map decorations like scales and legends
+        self.pdc = PseudoDC()
+        # used for digitization tool
+        self.pdcVector = None
+        # decorations (region box, etc.)
+        self.pdcDec = PseudoDC()
+        # pseudoDC for temporal objects (select box, measurement tool, etc.)
+        self.pdcTmp = PseudoDC()
     def Draw(self, pdc, img=None, drawid=None, pdctype='image', coords=[0, 0, 0, 0]):
         Draws map and overlay decorations
@@ -677,8 +689,9 @@
             # re-calculate threshold for digitization tool
             self.parent.digit.driver.GetThreshold()
             # draw map
-            self.pdcVector.Clear()
-            self.pdcVector.RemoveAll()
+            if self.pdcVector:
+                self.pdcVector.Clear()
+                self.pdcVector.RemoveAll()
             try:
                 item = self.tree.FindItemByData('maplayer', digitToolbar.GetLayer())
             except TypeError:
@@ -2543,15 +2556,15 @@
             if l.type == 'raster':
                 rast.append(l.name)
             elif l.type == 'vector':
-                if self.parent.digit and l.name == self.parent.digit.map and \
-                        self.parent.digit.type == 'vdigit':
+                digitToolbar = self.parent.toolbars['vdigit']
+                if digitToolbar and digitToolbar.GetLayer() == l.name:
                     w, s, b, e, n, t = self.parent.digit.driver.GetMapBoundingBox()
                     self.Map.GetRegion(n=n, s=s, w=w, e=e,
                                        update=True)
                     updated = True
                 else:
                     vect.append(l.name)
         if not updated:
             self.Map.GetRegion(rast = rast,
                                vect = vect,
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py	2009-10-05 07:43:17 UTC (rev 39405)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py	2009-10-05 07:58:25 UTC (rev 39406)
@@ -1109,16 +1109,17 @@
         ### self.parent.MapWindow.EraseMap()
         # unset background map if needed
-        if UserSettings.Get(group='vdigit', key='bgmap',
-                            subkey='value', internal=True) == mapLayer.GetName():
-            UserSettings.Set(group='vdigit', key='bgmap',
-                             subkey='value', value='', internal=True)
+        if mapLayer:
+            if UserSettings.Get(group='vdigit', key='bgmap',
+                                subkey='value', internal=True) == mapLayer.GetName():
+                UserSettings.Set(group='vdigit', key='bgmap',
+                                 subkey='value', value='', internal=True)
+            self.parent.statusbar.SetStatusText(_("Please wait, "
+                                                  "opening vector map <%s> for editing...") % \
+                                                    mapLayer.GetName(),
+                                                0)
-        self.parent.statusbar.SetStatusText(_("Please wait, "
-                                              "opening vector map <%s> for editing...") % \
-                                                mapLayer.GetName(),
-                                            0)
         # reload vdigit module
         reload(vdigit)
         from vdigit import Digit as Digit
@@ -1131,9 +1132,13 @@
             self.parent.digit.SetMapName(mapLayer.GetName())
         except gcmd.DigitError, e:
             self.mapLayer = None
+            self.StopEditing()
             print >> sys.stderr, e # wxMessageBox
             return False
+        # use vdigit's PseudoDC
+        self.parent.MapWindow.DefinePseudoDC(vdigit = True)
         # update toolbar
         self.combo.SetValue(mapLayer.GetName())
         self.parent.toolbars['map'].combo.SetValue (_('Digitize'))
@@ -1158,42 +1163,43 @@
         return True
-    def StopEditing (self):
+    def StopEditing(self):
         """!Stop editing of selected vector map layer.
         @return True on success
         @return False on failure
-        if not self.mapLayer:
-            return False
+        # use wx's PseudoDC
+        self.parent.MapWindow.DefinePseudoDC(vdigit = False)
-        Debug.msg (4, "VDigitToolbar.StopEditing(): layer=%s" % self.mapLayer.GetName())
         self.combo.SetValue (_('Select vector map'))
         # save changes
-        if UserSettings.Get(group='vdigit', key='saveOnExit', subkey='enabled') is False:
-            if self.parent.digit.GetUndoLevel() > 0:
-                dlg = wx.MessageDialog(parent=self.parent,
-                                       message=_("Do you want to save changes "
-                                                 "in vector map <%s>?") % self.mapLayer.GetName(),
-                                       caption=_("Save changes?"),
-                                       style=wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
-                if dlg.ShowModal() == wx.ID_NO:
-                    # revert changes
-                    self.parent.digit.Undo(0)
-                dlg.Destroy()
+        if self.mapLayer:
+            Debug.msg (4, "VDigitToolbar.StopEditing(): layer=%s" % self.mapLayer.GetName())
+            if UserSettings.Get(group='vdigit', key='saveOnExit', subkey='enabled') is False:
+                if self.parent.digit.GetUndoLevel() > 0:
+                    dlg = wx.MessageDialog(parent=self.parent,
+                                           message=_("Do you want to save changes "
+                                                     "in vector map <%s>?") % self.mapLayer.GetName(),
+                                           caption=_("Save changes?"),
+                                           style=wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
+                    if dlg.ShowModal() == wx.ID_NO:
+                        # revert changes
+                        self.parent.digit.Undo(0)
+                    dlg.Destroy()
-                                              "closing and rebuilding topology of "
-                                              "vector map <%s>...") % self.mapLayer.GetName(),
-                                            0)
+                                                  "closing and rebuilding topology of "
+                                                  "vector map <%s>...") % self.mapLayer.GetName(),
+                                                0)
-        self.parent.digit.SetMapName(None) # -> close map
+            self.parent.digit.SetMapName(None) # -> close map
-        # re-active layer
-        item = self.parent.tree.FindItemByData('maplayer', self.mapLayer)
-        if item and self.parent.tree.IsItemChecked(item):
-            self.mapcontent.ChangeLayerActive(self.mapLayer, True)
+            # re-active layer
+            item = self.parent.tree.FindItemByData('maplayer', self.mapLayer)
+            if item and self.parent.tree.IsItemChecked(item):
+                self.mapcontent.ChangeLayerActive(self.mapLayer, True)
         # change cursor
         self.parent.MapWindow.SetCursor(self.parent.cursors["default"])
Modified: grass/trunk/gui/wxpython/gui_modules/vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/vdigit.py	2009-10-05 07:43:17 UTC (rev 39405)
+++ grass/trunk/gui/wxpython/gui_modules/vdigit.py	2009-10-05 07:58:25 UTC (rev 39406)
@@ -34,6 +34,7 @@
 import string
 import copy
 import textwrap
+import traceback
 from threading import Thread
@@ -122,9 +123,9 @@
             ret = self.driver.Reset(self.map)
         except StandardError, e:
             raise gcmd.DigitError(parent=self.mapWindow.parent,
-                                  message="%s %s (%s)" % (_('Unable to initialize display driver, '
-                                                            'see README file for more information.\n\n'
-                                                            'Details:'), e, errorMsg))
+                                  message="%s %s (%s)" % (_("Unable to initialize display driver of vector "
+                                                            "digitizer. See 'Command output' for details.\n\n"
+                                                            "Details:"), e, errorMsg))
         if map and ret == -1:
@@ -232,15 +233,22 @@
         @param settings  initial settings of digitization tool
         AbstractDigit.__init__(self, mapwindow)
+        if not mapwindow.parent.IsStandalone():
+            self.log = mapwindow.parent.GetLayerManager().goutput.cmd_stderr
+        else:
+            self.log = sys.stderr
+        self.toolbar = mapwindow.parent.toolbars['vdigit']
         try:
             self.digit = wxvdigit.Digit(self.driver.GetDevice(),
                                         mapwindow)
-        except (ImportError, NameError):
+        except (ImportError, NameError, TypeError):
+            # print traceback
+            traceback.print_exc(file = self.log)
             self.digit = None
-        self.toolbar = mapwindow.parent.toolbars['vdigit']
         self.UpdateSettings()
     def __del__(self):
@@ -699,6 +707,9 @@
     def GetUndoLevel(self):
         """!Get undo level (number of active changesets)"""
+        if not self.digit:
+            return -1
         return self.digit.GetUndoLevel()
     def UpdateSettings(self):
@@ -841,7 +852,8 @@
         @param pdc wx.PseudoDC instance
-        self.__display.SetDevice(pdc)
+        if self.__display:
+            self.__display.SetDevice(pdc)
     def Reset(self, map):
         """!Reset map
@@ -879,6 +891,9 @@
         @return wx.Image instance
+        if not self.__display:
+            return 0
         nlines = self.__display.DrawMap(True) # force
         Debug.msg(3, "CDisplayDriver.DrawMap(): nlines=%d" % nlines)
@@ -931,6 +946,9 @@
         @param grassId if grassId is True returns GRASS ids, otherwise
         internal ids of objects drawn in PseudoDC"""
+            return list()
         if grassId:
             selected = self.__display.GetSelected(True)
         else:
@@ -1017,6 +1035,8 @@
         """!Set geographical region
         Needed for 'cell2pixel' conversion"""
+            return
         map = self.mapwindow.Map
         reg = map.region
