[GRASS-SVN] r39413 - in grass/branches/develbranch_6/gui/wxpython:
. xml
svn_grass at osgeo.org
Mon Oct 5 17:11:36 EDT 2009
Author: martinl
Date: 2009-10-05 17:11:36 -0400 (Mon, 05 Oct 2009)
New Revision: 39413
grass/branches/develbranch_6/gui/wxpython/wxgui.py
grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
fix rulescmd (menu tree item)
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py 2009-10-05 20:08:48 UTC (rev 39412)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py 2009-10-05 21:11:36 UTC (rev 39413)
@@ -994,18 +994,19 @@
self.curr_page = None
- def RulesCmd(self, event):
+ def RulesCmd(self, event, cmd = ''):
Launches dialog for commands that need rules
input and processes rules
- command = self.GetMenuCmd(event)
+ if event:
+ cmd = self.GetMenuCmd(event)
- if command[0] == 'r.colors' or command[0] == 'vcolors':
- ctable = colorrules.ColorTable(self, cmd=command[0])
+ if cmd[0] == 'r.colors' or cmd[0] == 'vcolors':
+ ctable = colorrules.ColorTable(self, cmd=cmd[0])
ctable.Show()
else:
- dlg = rules.RulesText(self, cmd=command)
+ dlg = rules.RulesText(self, cmd=cmd)
dlg.CenterOnScreen()
if dlg.ShowModal() == wx.ID_OK:
gtemp = utils.GetTempfile()
@@ -1015,7 +1016,7 @@
finally:
output.close()
- cmdlist = [command[0],
+ cmdlist = [cmd[0],
'input=%s' % dlg.inmap,
'output=%s' % dlg.outmap,
'rules=%s' % gtemp]
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2009-10-05 20:08:48 UTC (rev 39412)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2009-10-05 21:11:36 UTC (rev 39413)
@@ -1426,7 +1426,7 @@
<menuitem>
<label>Reclassify interactively</label>
<help>Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer.</help>
- <keywords>raster</keywords>
+ <keywords>raster,statistics,aggregation</keywords>
<handler>self.RulesCmd</handler>
<command>r.reclass</command>
</menuitem>
