[GRASS-SVN] r39423 - in grass/trunk/visualization/nviz: scripts src
svn_grass at osgeo.org
Tue Oct 6 01:52:53 EDT 2009
Author: marisn
Date: 2009-10-06 01:52:51 -0400 (Tue, 06 Oct 2009)
New Revision: 39423
Removed:
grass/trunk/visualization/nviz/src/site_attr_commands.c
grass/trunk/visualization/nviz/src/site_highlight_commands.c
grass/trunk/visualization/nviz/scripts/panel_site.tcl
grass/trunk/visualization/nviz/scripts/panel_vquery.tcl
grass/trunk/visualization/nviz/src/map_obj.c
grass/trunk/visualization/nviz/src/nviz_init.c
Ugly hack to fix nviz compilation as requested by bug #772 and other developers. Leaving some site_attr code for probable reuse.
Modified: grass/trunk/visualization/nviz/scripts/panel_site.tcl
--- grass/trunk/visualization/nviz/scripts/panel_site.tcl 2009-10-05 22:02:56 UTC (rev 39422)
+++ grass/trunk/visualization/nviz/scripts/panel_site.tcl 2009-10-06 05:52:51 UTC (rev 39423)
@@ -173,16 +173,6 @@
pack $row1 $row2 $row3 $row4 $row5 -anchor w -side top -expand no -fill none -pady 2
pack $mid1 -side top -padx 3
- # frame for thematic point mapping
- set site_attr(FIELD_ATTR_PANEL) 0
- checkbutton $row4.themechk -text "thematic mapping for vector points" \
- -variable site_attr(FIELD_ATTR_PANEL) -command "if {$curr!=0} {site_attr_gui $row5 $bottom $curr}" \
- -offvalue 0 -onvalue 1
- pack $row4.themechk -side left -anchor nw
return $panel
Modified: grass/trunk/visualization/nviz/scripts/panel_vquery.tcl
--- grass/trunk/visualization/nviz/scripts/panel_vquery.tcl 2009-10-05 22:02:56 UTC (rev 39422)
+++ grass/trunk/visualization/nviz/scripts/panel_vquery.tcl 2009-10-06 05:52:51 UTC (rev 39423)
@@ -64,12 +64,12 @@
set highlight(SIZE_VALUE) 1.5
set highlight(MARKER_VALUE) 4
- Nsite_highlight_set_default size $highlight(SIZE)
- Nsite_highlight_set_default color $highlight(COLOR)
- Nsite_highlight_set_default marker $highlight(MARKER)
- Nsite_highlight_set_default_value color $highlight(COLOR_VALUE)
- Nsite_highlight_set_default_value size $highlight(SIZE_VALUE)
- Nsite_highlight_set_default_value marker $highlight(MARKER_VALUE)
+ #Nsite_highlight_set_default size $highlight(SIZE)
+ #Nsite_highlight_set_default color $highlight(COLOR)
+ #Nsite_highlight_set_default marker $highlight(MARKER)
+ #Nsite_highlight_set_default_value color $highlight(COLOR_VALUE)
+ #Nsite_highlight_set_default_value size $highlight(SIZE_VALUE)
+ #Nsite_highlight_set_default_value marker $highlight(MARKER_VALUE)
# make main frames for panel
set query [frame $BASE.query]
Modified: grass/trunk/visualization/nviz/src/map_obj.c
--- grass/trunk/visualization/nviz/src/map_obj.c 2009-10-05 22:02:56 UTC (rev 39422)
+++ grass/trunk/visualization/nviz/src/map_obj.c 2009-10-06 05:52:51 UTC (rev 39423)
@@ -495,9 +495,6 @@
new_id = GP_new_site();
- /* ACS_MODIFY One line (added) - site_attr management ************************* */
- site_attr_init(new_id);
/* See if there is a default file name specified */
if ((argc >= 3) && (strncmp(argv[2], "name=", 5))) {
arglist[2] = argv[2];
@@ -512,7 +509,7 @@
/* Initialize display parameters */
- GP_set_sitemode(new_id, ST_ATT_NONE, 0xFF0000, 2, 100, ST_X);
+ GP_set_style(new_id, 0xFF0000, 2, 100, ST_X);
surf_list = GS_get_surf_list(&num_surfs);
if (num_surfs) {
for (i = 0; i < num_surfs; i++) {
@@ -1609,7 +1606,7 @@
float size;
char temp[128], *tempname;
- GP_get_sitemode(id, &atmod, &color, &width, &size, &marker);
+ GP_get_style(id, &color, &width, &size, &marker);
GP_get_zmode(id, &use_z);
switch (sv_att_atoi(argv[2])) {
case ATT_COLOR:
@@ -1644,13 +1641,7 @@
Tcl_SetResult(interp, temp, TCL_VOLATILE);
END original code */
- geosite *gp;
- if ((gp = gp_get_site(id))) {
- if (TCL_OK !=
- site_attr_get(interp, gp, atoi(argv[3])))
return (TCL_ERROR);
/* result should be in interp */
@@ -1864,7 +1855,7 @@
return (TCL_ERROR);
- GP_get_sitemode(id, &useatt, &col, &width, &size, &marker);
+ GP_get_style(id, &col, &width, &size, &marker);
col =
(strcmp(argv[2], "color")) ? col : tcl_color_to_int(argv[3]);
width = (strcmp(argv[2], "width")) ? width : atoi(argv[3]);
@@ -1886,7 +1877,7 @@
- if (!strcmp(argv[2], "useatt")) {
+ /*if (!strcmp(argv[2], "useatt")) {
geosite *gp;
@@ -1906,11 +1897,11 @@
useatt |= ST_ATT_MARKER;
/*** ACS_MODIFY END - site_attr management *************************************/
- GP_set_sitemode(id, useatt, col, width, size, marker);
+ GP_set_style(id, col, width, size, marker);
break;
@@ -1979,9 +1970,9 @@
if (type == SITE) {
if (!strcmp(argv[2], "useatt") && argc == 5) {
- site_attr_unset(interp, gp, atoi(argv[3]), argv[4]);
+/* site_attr_unset(interp, gp, atoi(argv[3]), argv[4]);
if (!strcmp(argv[3], "size")) {
useatt &= ~ST_ATT_SIZE;
@@ -1992,8 +1983,9 @@
else if (!strcmp(argv[3], "marker")) {
useatt &= ~ST_ATT_MARKER;
return TCL_OK;
Modified: grass/trunk/visualization/nviz/src/nviz_init.c
--- grass/trunk/visualization/nviz/src/nviz_init.c 2009-10-05 22:02:56 UTC (rev 39422)
+++ grass/trunk/visualization/nviz/src/nviz_init.c 2009-10-06 05:52:51 UTC (rev 39423)
@@ -525,12 +525,6 @@
/*** ACS_MODIFY pick ONE LINE ************************************************/
pick_init_tcl(interp, &data);
-/*** ACS_MODIFY site_attr ONE LINE ************************************************/
- site_attr_init_tcl(interp, &data);
-/*** ACS_MODIFY site_highlight ONE LINE ************************************************/
- site_highlight_init_tcl(interp, &data);
if (!script_mode)
Tcl_Eval(interp, nviz_script); *//* source nviz_script to start main window */
Deleted: grass/trunk/visualization/nviz/src/site_attr_commands.c
--- grass/trunk/visualization/nviz/src/site_attr_commands.c 2009-10-05 22:02:56 UTC (rev 39422)
+++ grass/trunk/visualization/nviz/src/site_attr_commands.c 2009-10-06 05:52:51 UTC (rev 39423)
@@ -1,1247 +0,0 @@
- * MODULE: site_attr_commands.c 1.0
- * AUTHOR(S): ACS - Massimo Cuomo - m.cuomo at acsys.it
- * PURPOSE: To manage color and site attributes for each
- * point in a single site.
- * REQUIREMENTS: Many modifications in many files:
- * see following README section
- * COPYRIGHT: (C) 2005 by the ACS / GRASS Development Team
- * This program is free software under the
- * GNU General Public License (>=v2).
- * Read the file COPYING that comes with GRASS
- * for details.
-#if 0
- *********************FILE MAP
- /* init function called by nviz_init.c **************************************** */
-/*** Tcl commands definition ***************************************************/
- /* Map Tcl commands: related to a specific map, but not to a specific field *** */
- Nsite_attr_get_fields_name_cmd
- Nsite_attr_get_fields_type_cmd Nsite_attr_get_fields_name_and_type_cmd
- /* Field Tcl commands: related to a specific map *AND* to a specific field (by its index) */
- Nsite_attr_get_field_values_cmd Nsite_attr_get_field_not_emtpy_cats_cmd
- /* Field Tcl commands: related to a specific map *AND* to a specific record (by its category) */
- Nsite_attr_get_record_values_cmd
- /* General Tcl commands: not related to any specific map ********************** */
- Nsite_attr_get_GPT_MAX_ATTR_cmd
- /* Functions used by set_att in map_obj.c to set the geosite attributes from DB */
-/******************* Open / Close Map structures *******************************/
- site_attr_open_map
- site_attr_close_map
- site_attr_init
- site_attr_set
- site_attr_unset
- site_attr_set_color
- site_attr_set_size
- site_attr_set_fixed_color
- site_attr_set_fixed_size site_attr_set_fixed_marker
- /* Interpolation and evaluation functions definitions ************************* */
- /* Interpolation Tcl command ************************************************** */
- Nsite_attr_get_interpolated_values_cmd
- /* Color conversion functions ************************************************* */
- attr_get_int_BBGGRR attr_get_RRGGBB attr_get_char_RRGGBB
-/************************* interp **********************************************/
- attr_interp_entries
- attr_interp_entries_string attr_interp_colors attr_interp_colors_string
-/************************* eval ************************************************/
-attr_eval_entry attr_eval_entry_string attr_eval_color attr_eval_color_string ******************************************************************************* ********************site_attr "README" *************************************** *******************************************************************************Files involved:
--src(mod) visualization / nviz / src / Makefile
- (new) visualization / nviz / src / site_attr_commands.c
- (mod) visualization / nviz / src / nviz_init.c
- (mod) visualization / nviz / src / map_obj.c
- - ogsf
- (mod) lib / ogsf / gstypes.h
- (mod) lib / ogsf / Gp3.c
- (mod) lib / ogsf / gpd.c
- (mod) lib / ogsf / gsd_objs.c
- - sites
- (mod) lib / sites / sites.c
- - script
- (mod) visualization / nviz / scripts / panel_site.tcl
- (mod) visualization / nviz / scripts / colorPopup.tcl
- (new) visualization / nviz / scripts / site_attr.tcl
- (mod) visualization / nviz / scripts / ACS_utils.tcl
- - src
- (mod) visualization / nviz / src / Makefile
- added compilation for site_attr_commands
- .c(new) visualization / nviz / src / site_attr_commands.c this file that contains:
- -all c functions for getting
- fields values and setting attributes
- - interpolation / evaluation functions used for color
- and entries that could be put in a separate file if used
- also by others(mod) visualization / nviz / src / nviz_init.c added call to function:site_attr_init_tcl(interp,
- &data);
-to intialize all the Tcl commands(mod) visualization / nviz / src /
- map_obj.c added function:site_attr_init for each created site added set /
- unset useatt functions - ogsf(mod)
- lib / ogsf / gstypes.h added:
-#define GPT_MAX_ATTR 8
- in typedef struct g_point
- ... int cat;
- int color[GPT_MAX_ATTR];
- float size[GPT_MAX_ATTR];
- int marker[GPT_MAX_ATTR];
- ...} geopoint;
-in typedef struct g_site
- ... int use_attr[GPT_MAX_ATTR]; /* ST_ATT_COLOR, ST_ATT_MARKER, ST_ATT_SIZE, ST_ATT_NONE, for multiple attr's */
-...} geosite;
-(mod) lib / ogsf / Gp3.c added line:
-gpt->cat = nextsite->ccat;
-in order to get the link at the site cat
- added gpd_obj_site_attr in place of gpd_obj to manage multiple attributes
- added the "box" drawing for histograms even if it should better stayed
- in file gsd_objs.c - sites(mod)
- lib / sites / sites.c
- - managing Map_info structure for sites - script(mod)
- visualization / nviz / scripts / panel_site.tcl
- added site_attr.tcl calls
- all the GUI and calls to site_attr_commands.c functions
- added line
- setScales $w.top.left $color
- to solve that the scales and $w.top.
- color are set to white next time after a color button(not sliders)
- has been used,
- regardless $color(mod) visualization / nviz / scripts /
- ACS_utils.tcl added function:modal_edit_list_plain use in site_attr.tcl
-#endif
-#include <stdio.h>
-#include <string.h>
-#include <stdlib.h>
-#include <grass/vector.h>
-#include <grass/site.h>
-#include "interface.h"
-#define R_G_B_2_RGB(r,g,b) ((b) & 0xff) | (((g) & 0xff) << 8) | (((r) & 0xff) << 16)
-/* Tcl commands declaration and initialization ******************************** */
-int Nsite_attr_get_value_cmd(Nv_data * data, Tcl_Interp * interp, int argc,
- char **argv);
-int Nsite_attr_get_fields_name_cmd(Nv_data * data, Tcl_Interp * interp,
- int argc, char **argv);
-int Nsite_attr_get_fields_type_cmd(Nv_data * data, Tcl_Interp * interp,
-int Nsite_attr_get_fields_name_and_type_cmd(Nv_data * data,
- Tcl_Interp * interp, int argc,
- char **argv);
-int Nsite_attr_get_field_values_cmd(Nv_data * data, Tcl_Interp * interp,
-int Nsite_attr_get_field_not_emtpy_cats_cmd(Nv_data * data,
- char **argv);
-int Nsite_attr_get_record_values_cmd(Nv_data * data, Tcl_Interp * interp,
-int Nget_interpolated_values_cmd(Nv_data * data, Tcl_Interp * interp,
-/* init function called by nviz_init.c **************************************** */
-void site_attr_init_tcl(Tcl_Interp * interp, Nv_data * data)
- Tcl_CreateCommand(interp, "Nsite_attr_get_value",
- (Tcl_CmdProc *) Nsite_attr_get_value_cmd, data, NULL);
- Tcl_CreateCommand(interp, "Nsite_attr_get_fields_name",
- (Tcl_CmdProc *) Nsite_attr_get_fields_name_cmd, data,
- NULL);
- Tcl_CreateCommand(interp, "Nsite_attr_get_fields_type",
- (Tcl_CmdProc *) Nsite_attr_get_fields_type_cmd, data,
- NULL);
- Tcl_CreateCommand(interp, "Nsite_attr_get_fields_name_and_type",
- (Tcl_CmdProc *) Nsite_attr_get_fields_name_and_type_cmd,
- data, NULL);
- Tcl_CreateCommand(interp, "Nsite_attr_get_field_values",
- (Tcl_CmdProc *) Nsite_attr_get_field_values_cmd, data,
- NULL);
- Tcl_CreateCommand(interp, "Nsite_attr_get_field_not_emtpy_cats",
- (Tcl_CmdProc *) Nsite_attr_get_field_not_emtpy_cats_cmd,
- data, NULL);
- Tcl_CreateCommand(interp, "Nsite_attr_get_record_values",
- (Tcl_CmdProc *) Nsite_attr_get_record_values_cmd, data,
- NULL);
- Tcl_CreateCommand(interp, "Nget_interpolated_values",
- (Tcl_CmdProc *) Nget_interpolated_values_cmd, data,
- NULL);
-/* Internal functions declaration ********************************************* */
- These following functions will better stay in appropriate .h files if
- these functions will be put in separate files
-int attr_interp_entries(int n, const char **argvX, const char **argvY,
- float **x, float **y, float **m);
-int attr_interp_colors(int n, const char **argvX, const char **argvY,
- float **x, float **yr, float **yg, float **yb,
- float **mr, float **mg, float **mb);
-float attr_eval_entry(float xvalue, int n, float *x, float *y, float *m);
-int attr_eval_color(float xvalue, int n, float *x,
- float *yr, float *yg, float *yb,
- float *mr, float *mg, float *mb);
-/* better move to ../../../include/P_site.h */
-struct site_att *G_sites_get_atts(struct Map_info *ptr, int *cat);
- Map Tcl commands: related to a specific map, but not to a specific field
- argv[1] map filename
- returns: list of fields name
-int Nsite_attr_get_fields_name_cmd(data, interp, argc, argv)
- Nv_data *data;
- Tcl_Interp *interp; /* Current interpreter. */
- int argc; /* Number of arguments. */
- char **argv; /* Argument strings. */
- struct Map_info *Map;
- int *ctypes;
- char **cnames;
- int *ndx;
- int ncols, i;
- char buf[1024];
- if (argc != 2)
- return (TCL_ERROR);
- Map =
- (struct Map_info *)G_sites_open_old(argv[1],
- G_find_vector2(argv[1], ""));
- ncols = G_sites_get_fields(Map, &cnames, &ctypes, &ndx);
- for (i = 0; i < ncols; i++) {
- sprintf(buf, "%s", cnames[i]);
- Tcl_AppendElement(interp, buf);
- if (ncols > 0)
- G_sites_free_fields(ncols, cnames, ctypes, ndx);
- G_sites_close(Map);
- return (TCL_OK);
- returns: list of fields type
-int Nsite_attr_get_fields_type_cmd(data, interp, argc, argv)
- Nv_data *data;
- int *ctypes;
- char **cnames;
- int *ndx;
- int ncols, i;
- char buf[1024];
- if (argc != 2)
- Map = G_sites_open_old(argv[1], G_find_vector2(argv[1], ""));
- sprintf(buf, "%c", ctypes[i]);
- if (ncols > 0)
- return (TCL_OK);
- returns: list of fields name and type
-int Nsite_attr_get_fields_name_and_type_cmd(data, interp, argc, argv)
- Nv_data *data;
- int *ctypes;
- char **cnames;
- int *ndx;
- int ncols, i;
- char buf[2048];
- if (argc != 2)
- if (ncols > 0)
- return (TCL_OK);
- Field Tcl commands: related to a specific map *AND* to a specific
- field (by its index)
- argv[2] field index
- returns: list of values of the given field index for all records of the whole site
-int Nsite_attr_get_field_values_cmd(data, interp, argc, argv)
- Nv_data *data;
- int *ctypes;
- char **cnames;
- int *ndx;
- int ncols, i, index;
- char buf[9182];
- struct site_att *sa;
- if (argc != 3)
- index = atoi(argv[2]);
- for (i = 0; i < Map->n_site_att; i++) {
- sa = &(Map->site_att[i]);
- switch (ctypes[index]) {
- case 'c': /* category */
- sprintf(buf, "%d", sa->cat);
- break;
- case 'd': /* double */
- sprintf(buf, "%f", sa->dbl[ndx[index]]);
- break;
- case 's': /* string */
- sprintf(buf, "%s", sa->str[ndx[index]]);
- break;
- if (ncols > 0)
- return (TCL_OK);
- returns: list of cats, if the given field index is not empty, for all records of the whole site
-int Nsite_attr_get_field_not_emtpy_cats_cmd(data, interp, argc, argv)
- Nv_data *data;
- int *ctypes;
- char **cnames;
- int *ndx;
- char buf[9182];
- if (argc != 3)
- /* printf("@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ i=%d cat=%d field=%s\n", i, sa->cat, sa->str[ndx[index]]); */
- if (strlen(sa->str[ndx[index]]) > 0) {
- break;
- if (ncols > 0)
- return (TCL_OK);
- record (by its category)
- argv[2] cat
- returns: list of record values with category "cat"
-int Nsite_attr_get_record_values_cmd(data, interp, argc, argv)
- Nv_data *data;
- int *ctypes;
- char **cnames;
- int *ndx;
- int ncols, i, cat;
- char buf[9182];
- if (argc != 3)
- cat = atoi(argv[2]);
- if ((sa = (struct site_att *) G_sites_get_atts(Map, &cat)) == NULL)
- switch (ctypes[i]) {
- break;
- sprintf(buf, "%f", sa->dbl[ndx[i]]);
- break;
- sprintf(buf, "%s", sa->str[ndx[i]]);
- break;
- if (ncols > 0)
- return (TCL_OK);
-/* General Tcl commands: not related to any specific map ************************* */
- Get GPT_MAX_ATTR, ST_ATT_COLOR, ST_ATT_MARKER, ST_ATT_SIZE values Tcl command
- no input argument
- returns the value of GPT_MAX_ATTR defined in gstypes.h
-int Nsite_attr_get_value_cmd(data, interp, argc, argv)
- Nv_data *data;
- char buf[1024];
- if (!strcmp(argv[1], "GPT_MAX_ATTR"))
- sprintf(buf, "%d", GPT_MAX_ATTR);
- else if (!strcmp(argv[1], "ST_ATT_COLOR"))
- sprintf(buf, "%d", ST_ATT_COLOR);
- else if (!strcmp(argv[1], "ST_ATT_MARKER"))
- sprintf(buf, "%d", ST_ATT_MARKER);
- else if (!strcmp(argv[1], "ST_ATT_SIZE"))
- sprintf(buf, "%d", ST_ATT_SIZE);
- else
- return (TCL_OK);
- Functions used by set_att in map_obj.c to set the geosite attributes from DB
- site_attr_init, site_attr_set, site_attr_unset
-int site_attr_open_map(geosite * gp, int index,
- struct Map_info **Map, int *ncols, char ***cnames,
- int **ctypes, int **ndx)
- const char *function_name = "site_attr_open_map";
- *Map = G_sites_open_old(gp->filename, G_find_vector2(gp->filename, ""));
- /* this is needed to find association between names and proper indexes/types */
- *ncols = G_sites_get_fields(*Map, cnames, ctypes, ndx);
- if (*ncols <= 0) {
- printf("WARNING / \"%s()\": site \"%s\" database error\n",
- function_name, gp->filename);
- return (-1);
- return (0);
-void site_attr_close_map(struct Map_info *Map, int ncols, char **cnames,
- int *ctypes, int *ndx)
- if (ncols > 0)
-/* declarations of following functions */
-int site_attr_set_color(geosite * gp, int nattr, int index, int n,
- const char **argvX, const char **argvY);
-int site_attr_set_size(geosite * gp, int nattr, int index, int n,
-int site_attr_set_fixed_color(geosite * gp, int nattr, unsigned int color);
-int site_attr_set_fixed_size(geosite * gp, int nattr, float size);
-int site_attr_set_fixed_marker(geosite * gp, int nattr, int marker);
-void site_attr_init(int id)
- geosite *gp;
- int i;
- gp = gp_get_site(id);
- for (i = 0; i < GPT_MAX_ATTR; i++)
- gp->use_attr[i] = ST_ATT_NONE;
-int site_attr_set(Tcl_Interp * interp, geosite * gp, int nattr, char *attr,
- int index, char *xlist, char *ylist)
- int argcPtrX, argcPtrY;
- const char **argvPtrX, **argvPtrY;
- if (nattr >= GPT_MAX_ATTR) {
- } /* too many */
- argvPtrX = NULL;
- argvPtrY = NULL;
- if (index >= 0) {
- /* if index < 0, then fixed values */
- if (TCL_OK != Tcl_SplitList(interp, xlist, &argcPtrX, &argvPtrX))
- goto error;
- if (TCL_OK != Tcl_SplitList(interp, ylist, &argcPtrY, &argvPtrY))
- goto error;
- if (argcPtrX != argcPtrY) {
- printf("WARNING: elements in lists are different\n");
- goto error;
- if (argcPtrX < 2) {
- printf("WARNING: elements in list are too few\n");
- goto error;
- if (!strcmp(attr, "size")) {
- if (index < 0) {
- site_attr_set_fixed_size(gp, nattr, atof(xlist));
- else {
- if (0 >
- site_attr_set_size(gp, nattr, index, argcPtrX, argvPtrX,
- argvPtrY))
- goto error;
- gp->use_attr[nattr] |= ST_ATT_SIZE;
- else if (!strcmp(attr, "color")) {
- if (index < 0) {
- site_attr_set_fixed_color(gp, nattr, attr_get_int_BBGGRR(xlist));
- else {
- if (0 >
- site_attr_set_color(gp, nattr, index, argcPtrX, argvPtrX,
- argvPtrY))
- goto error;
- gp->use_attr[nattr] |= ST_ATT_COLOR;
- else if (!strcmp(attr, "marker")) {
- site_attr_set_fixed_marker(gp, nattr, atoi(xlist));
- gp->use_attr[nattr] |= ST_ATT_MARKER;
- if (argvPtrX)
- Tcl_Free((char *)argvPtrX);
- if (argvPtrY)
- Tcl_Free((char *)argvPtrY);
- return (TCL_OK);
- error:
- if (argvPtrX)
- if (argvPtrY)
-int site_attr_unset(Tcl_Interp * interp, geosite * gp, int nattr, char *attr)
- /* See if we have to empty the vectors or not */
- gp->use_attr[nattr] &= ~ST_ATT_SIZE;
- gp->use_attr[nattr] &= ~ST_ATT_COLOR;
- gp->use_attr[nattr] &= ~ST_ATT_MARKER;
- return (TCL_OK);
-int site_attr_get(Tcl_Interp * interp, geosite * gp, int nattr)
- char buf[1024];
- sprintf(buf, "%d", gp->use_attr[nattr]);
- return (TCL_OK);
- geopoint *gpt;
- int *ctypes;
- char **cnames;
- int *ndx;
- int ncols;
- float *x, *yr, *yg, *yb, *mr, *mg, *mb;
- if (0 >
- site_attr_open_map(gp, index, &Map, &ncols, &cnames, &ctypes, &ndx))
- return (-1);
- if (ctypes[index] == 's') {
- if (0 > attr_interp_colors_string(n, argvY, &yr, &yg, &yb))
- return (-1);
- else {
- if (0 >
- attr_interp_colors(n, argvX, argvY, &x, &yr, &yg, &yb, &mr, &mg,
- &mb))
- return (-1);
- for (gpt = gp->points; gpt; gpt = gpt->next) {
- if (ctypes[index] == 'c') {
- gpt->color[nattr] =
- attr_eval_color(gpt->cat, n, x, yr, yg, yb, mr, mg, mb);
- else if (ctypes[index] == 'd') {
- if ((sa =
- (struct site_att *) G_sites_get_atts(Map, &(gpt->cat))) == NULL)
- continue;
- else
- attr_eval_color(sa->dbl[ndx[index]], n, x, yr, yg, yb, mr,
- mg, mb);
- else {
- if ((sa =
- continue;
- else
- attr_eval_color_string(sa->str[ndx[index]], n, argvX, yr,
- yg, yb);
- free(yr);
- free(yg);
- free(yb);
- else {
- free(x);
- free(yr);
- free(yg);
- free(yb);
- free(mr);
- free(mg);
- free(mb);
- site_attr_close_map(Map, ncols, cnames, ctypes, ndx);
- return (0);
- geopoint *gpt;
- int *ctypes;
- char **cnames;
- int *ndx;
- int ncols;
- float *x, *y, *m;
- if (0 >
- return (-1);
- if (0 > attr_interp_entries_string(n, argvY, &y))
- return (-1);
- else {
- if (0 > attr_interp_entries(n, argvX, argvY, &x, &y, &m))
- return (-1);
- gpt->size[nattr] = attr_eval_entry(gpt->cat, n, x, y, m);
- if ((sa =
- continue;
- else
- attr_eval_entry(sa->dbl[ndx[index]], n, x, y, m);
- else {
- if ((sa =
- continue;
- else
- attr_eval_entry_string(sa->str[ndx[index]], n, argvX, y);
- free(y);
- else {
- free(x);
- free(y);
- free(m);
- return (0);
- geopoint *gpt;
- gpt->color[nattr] = color;
- return (0);
- geopoint *gpt;
- gpt->size[nattr] = size;
- return (0);
- geopoint *gpt;
- gpt->marker[nattr] = marker;
- return (0);
- The following section doesn't depends from sites.
- It is only color conversion, interpolation and evaluation of color/entries.
- Hence they are not called site_attr_XXX, but only attr_XXX.
- They can be put in a separate file, but are kept here to not increase too much the
- total file number.
-/* Color conversion functions ************************************************* */
-int attr_get_int_BBGGRR(const char *rrggbb)
- /* rrggbb is in the form of #RRGGBB (first char is skipped) */
- char strbuf[16];
- memcpy(strbuf + 0, rrggbb + 5, 2);
- memcpy(strbuf + 2, rrggbb + 3, 2);
- memcpy(strbuf + 4, rrggbb + 1, 2);
- memset(strbuf + 6, 0, 1);
- return (strtol(strbuf, NULL, 16));
-float attr_get_RRGGBB(const char *rrggbb, float *r, float *g, float *b)
- char strbuf[16];
- memcpy(strbuf, rrggbb + 1, 2);
- memset(strbuf + 2, 0, 1);
- *r = (float)strtol(strbuf, NULL, 16);
- memcpy(strbuf, rrggbb + 3, 2);
- *g = (float)strtol(strbuf, NULL, 16);
- memcpy(strbuf, rrggbb + 5, 2);
- *b = (float)strtol(strbuf, NULL, 16);
- return (*r * 65536.0f + *g * 256.0f + *b);
-void attr_get_char_RRGGBB(char *rrggbb, float bbggrr)
- char strbuf[16];
- sprintf(strbuf, "%06x", (int)bbggrr);
- memset(rrggbb + 0, '#', 1);
- memcpy(rrggbb + 1, strbuf + 4, 2);
- memcpy(rrggbb + 3, strbuf + 2, 2);
- memcpy(rrggbb + 5, strbuf + 0, 2);
- memset(rrggbb + 7, 0, 1);
- Interpolation Tcl command
- argv[1] attr
- argv[2] list of X values
- argv[3] list of X interpolation points
- argv[4] list of Y interpolation points
- returns the list of Y interpolated values
-int Nget_interpolated_values_cmd(data, interp, argc, argv)
- Nv_data *data;
- int i, n;
- char buf[1024];
- float *x, *y, *m, *yr, *yg, *yb, *mr, *mg, *mb, xvalue, yvalue;
- if (argc != 5)
- if (TCL_OK != Tcl_SplitList(interp, argv[3], &argcPtrX, &argvPtrX))
- if (TCL_OK != Tcl_SplitList(interp, argv[4], &argcPtrY, &argvPtrY))
- n = argcPtrX;
- if (!strcmp(argv[1], "color")) {
- if (0 <
- attr_interp_colors(n, argvPtrX, argvPtrY, &x, &yr, &yg, &yb, &mr,
- &mg, &mb))
- else if (!strcmp(argv[1], "size")) {
- if (0 < attr_interp_entries(n, argvPtrX, argvPtrY, &x, &y, &m))
- if (TCL_OK != Tcl_SplitList(interp, argv[2], &argcPtrX, &argvPtrX))
- for (i = 0; i < argcPtrX; i++) {
- xvalue = atof(argvPtrX[i]);
- yvalue = attr_eval_color(xvalue, n, x, yr, yg, yb, mr, mg, mb);
- attr_get_char_RRGGBB(buf, yvalue);
- free(x);
- free(yr);
- free(yg);
- free(yb);
- free(mr);
- free(mg);
- free(mb);
- yvalue = attr_eval_entry(xvalue, n, x, y, m);
- sprintf(buf, "%f", yvalue);
- free(x);
- free(y);
- free(m);
- return (TCL_OK);
-/* Interpolation and evaluation functions definitions ************************* */
- - argvX and argvY are X and Y of the points used to buil the intepolation
- - argvX and argvY must have the same number (n) of values
- - argvX elements must be ordered
- - n must be more than 2 (at least 2 points for interpolation)
- - the interpolation is piecewise linear
- - values outside the first/last X interval will be kept constant at
- corresponding Y values
- - caller must free x, y, m
- There is difference between numerics and strings:
- - numerics really interpolate
- - string do not: values are kept constant and change when there is a new one
- const char *function_name = "attr_interp_entries";
- int i;
- *x = (float *)malloc(n * sizeof(float));
- *y = (float *)malloc(n * sizeof(float));
- *m = (float *)malloc((n - 1) * sizeof(float));
- (*x)[0] = atof(argvX[0]);
- (*y)[0] = atof(argvY[0]);
- for (i = 1; i < n; i++) {
- (*x)[i] = atof(argvX[i]);
- (*y)[i] = atof(argvY[i]);
- if ((*x)[i] == (*x)[i - 1]) {
- printf("WARNING / \"%s()\": x elements in list cannot be equal\n",
- function_name);
- return (-4);
- (*m)[i - 1] = ((*y)[i] - (*y)[i - 1]) / ((*x)[i] - (*x)[i - 1]);
- return (0);
-int attr_interp_entries_string(int n, const char **argvY, float **y)
- int i;
- for (i = 0; i < n; i++)
- return (0);
- const char *function_name = "attr_interp_colors";
- int i;
- float dx;
- *yr = (float *)malloc(n * sizeof(float));
- *mr = (float *)malloc((n - 1) * sizeof(float));
- *yg = (float *)malloc(n * sizeof(float));
- *mg = (float *)malloc((n - 1) * sizeof(float));
- *yb = (float *)malloc(n * sizeof(float));
- *mb = (float *)malloc((n - 1) * sizeof(float));
- /* argv[0] is in #BBGGRR */
- attr_get_RRGGBB(argvY[0], &((*yb)[0]), &((*yg)[0]), &((*yr)[0]));
- /* argvY[i] is in #BBGGRR */
- attr_get_RRGGBB(argvY[i], &((*yb)[i]), &((*yg)[i]), &((*yr)[i]));
- function_name);
- return (-4);
- dx = (*x)[i] - (*x)[i - 1];
- (*mr)[i - 1] = ((*yr)[i] - (*yr)[i - 1]) / dx;
- (*mg)[i - 1] = ((*yg)[i] - (*yg)[i - 1]) / dx;
- (*mb)[i - 1] = ((*yb)[i] - (*yb)[i - 1]) / dx;
- return (0);
-int attr_interp_colors_string(int n, const char **argvY,
- float **yr, float **yg, float **yb)
- int i;
- for (i = 0; i < n; i++) {
- return (0);
- int i;
- if (xvalue <= x[0])
- return (y[0]);
- else if (xvalue >= x[n - 1])
- return (y[n - 1]);
- else {
- for (i = 1; i < n && xvalue > x[i]; i++) ;
- /* now: x[i-1] < value <= x[i] && i >= 1 */
- return (m[i - 1] * (xvalue - x[i - 1]) + y[i - 1]);
-float attr_eval_entry_string(const char *xvalue, int n, const char **x,
- float *y)
- int i;
- if (strcmp(xvalue, x[0]) <= 0)
- return (y[0]);
- else if (strcmp(xvalue, x[n - 1]) >= 0)
- else {
- for (i = 1; i < n && (strcmp(xvalue, x[i]) > 0); i++) ;
- return (y[i - 1]);
- int i;
- float r, g, b, dx;
- return (R_G_B_2_RGB((int)(yr[0]), (int)(yg[0]), (int)(yb[0])));
- ((int)(yr[n - 1]), (int)(yg[n - 1]), (int)(yb[n - 1])));
- else {
- dx = xvalue - x[i - 1];
- r = dx * mr[i - 1] + yr[i - 1];
- g = dx * mg[i - 1] + yg[i - 1];
- b = dx * mb[i - 1] + yb[i - 1];
- return (R_G_B_2_RGB((int)(r), (int)(g), (int)(b)));
-int attr_eval_color_string(const char *xvalue, int n, const char **x,
- float *yr, float *yg, float *yb)
- int i;
- else {
- ((int)(yr[i - 1]), (int)(yg[i - 1]), (int)(yb[i - 1])));
Deleted: grass/trunk/visualization/nviz/src/site_highlight_commands.c
--- grass/trunk/visualization/nviz/src/site_highlight_commands.c 2009-10-05 22:02:56 UTC (rev 39422)
+++ grass/trunk/visualization/nviz/src/site_highlight_commands.c 2009-10-06 05:52:51 UTC (rev 39423)
@@ -1,687 +0,0 @@
- * MODULE: site_highlight_commands.c 1.0
- * PURPOSE: Tcl commands created:
- * Sites depending commands
- * Nsite_highlight "what" "site_id" "cat" ["value"]
- * - highlights a specific geopoint -
- * what = color/size/marker/default
- * default: panel highlight type and values are used instead of "value"
- * site_id = (string range map_name 5 end)
- * cat = DB category associated to the specific geopoint
- * [value] (optional) = #rrggbb for color
- * float for size
- * int for marker
- * when omitted default value is used
- * Nsite_highlight_list "what" "site_id" "catlist" ["value"]
- * - highlights a list of geopoints -
- * catlist = list of DB category associated to the each geopoint
- * float for size
- * int for marker
- * Nsite_unhighlight "what" "site_id" "cat"
- * - unhighlights a specific geopoint -
- * Nsite_unhighlight_list "what" "site_id" "catlist"
- * - unhighlights a list of geopoints -
- * Nsite_unhighlight_all "what" "site_id"
- * - unhighlights all site geopoints -
- * what = color/size/marker/all
- * all: unhighlights color, size and marker
- * Sites independent commands (for panel_highlight.tcl)
- * Nsite_highlight_set_default "what" "value"
- * - sets highlight default type -
- * value = 1/0 (1: turns ON / 0 turns OFF color/size/marker highlight)
- * Nsite_highlight_get_default "what"
- * - returns highlight default type -
- * Nsite_highlight_set_default_value "what" "value"
- * - sets highlight default value -
- * value = color/size/marker value to set
- * Nsite_highlight_get_default_value "what"
- * - returns highlight default value -
- * REQUIREMENTS: external files with needed modifications:
- * - visualization/src
- * visualization/nviz/src/Makefile
- * visualization/nviz/src/nviz_init.c
- * - lib/ogsf
- * lib/ogsf/gstypes.h
- * lib/ogsf/Gp3.c
- * lib/ogsf/gpd.c
- * See following "README" section for details
- * for details.
-#if 0
-******************************************************************************* ********************site_highlight "README" ********************************** *******************************************************************************Files involved:
- (new) visualization / nviz / src / site_highlight_commands.c
- - ogsf
- - script
- (new) visualization / nviz / scripts / panel_highlight.tcl
- - src
- added compilation for site_highlight_commands
- .c(new) visualization / nviz / src / site_highlight_commands.c this file: creates Tcl commands(mod) visualization / nviz / src / nviz_init.c added call to function:site_highlight_init_tcl(interp,
- &data);
-to intialize all the Tcl commands -
- ogsf(mod) lib / ogsf /
- gstypes.h added in struct g_point:... int highlight_color;
-int highlight_size;
-int highlight_marker;
-TRUE / FALSE flags to enable / disable proper highlight
- int highlight_color_value;
-float highlight_size_value;
-int highlight_marker_value;
-...proper highlight values used for each
- geopoint(mod) lib / ogsf / Gp3.c added line:
- gpt->highlight_color = gpt->highlight_size = gpt->highlight_marker =
- FALSE;
-in order to get the proper initializations(mod) lib / ogsf /
- gpd.c added:if (gpt->highlight_color)
- color = gpt->highlight_color_value;
-if (gpt->highlight_size)
- marker = gpt->highlight_marker_value;
-if (gpt->highlight_marker)
- size *= gpt->highlight_size_value;
-in function "gpd_obj_site_attr"(that replaces function "gpd_obj")
-- script
- to panelIndex file add:"highlight"
- to tclIndex file add:set auto_index(mkhighlightPanel)
- "source $dir/panel_highlight.tcl"
- ********************end site_highlight "README"
-#endif
-#include <stdio.h>
-#define SITE_HIGHLIGHT_ALL 0
-#define SITE_HIGHLIGHT_COLOR 1
-#define SITE_HIGHLIGHT_SIZE 2
-#define SITE_HIGHLIGHT_MARKER 3
- static int default_highlight_color_value = 0xffffff; /* white */
- static float default_highlight_size_value = 1.2f;
- static int default_highlight_marker_value = 9; /* ST_GYRO */
- static int default_highlight_color = 1;
- static int default_highlight_size = 0;
- static int default_highlight_marker = 0;
-/* Color conversion function */
- int site_highlight_get_int_BBGGRR(char *rrggbb)
- char strbuf[16];
-int Nsite_highlight_cmd(Nv_data * data, Tcl_Interp * interp, int argc,
- char **argv);
-int Nsite_highlight_list_cmd(Nv_data * data, Tcl_Interp * interp, int argc,
- char **argv);
-int Nsite_unhighlight_list_cmd(Nv_data * data, Tcl_Interp * interp, int argc,
- char **argv);
-int Nsite_unhighlight_cmd(Nv_data * data, Tcl_Interp * interp, int argc,
- char **argv);
-int Nsite_unhighlight_all_cmd(Nv_data * data, Tcl_Interp * interp, int argc,
- char **argv);
-int Nsite_highlight_set_default_cmd(Nv_data * data, Tcl_Interp * interp,
-int Nsite_highlight_get_default_cmd(Nv_data * data, Tcl_Interp * interp,
-int Nsite_highlight_set_default_value_cmd(Nv_data * data, Tcl_Interp * interp,
-int Nsite_highlight_get_default_value_cmd(Nv_data * data, Tcl_Interp * interp,
-/* called by nviz_init.c */
-void site_highlight_init_tcl(Tcl_Interp * interp, Nv_data * data)
- Tcl_CreateCommand(interp, "Nsite_highlight",
- (Tcl_CmdProc *) Nsite_highlight_cmd, data, NULL);
- Tcl_CreateCommand(interp, "Nsite_unhighlight",
- (Tcl_CmdProc *) Nsite_unhighlight_cmd, data, NULL);
- Tcl_CreateCommand(interp, "Nsite_highlight_list",
- (Tcl_CmdProc *) Nsite_highlight_list_cmd, data, NULL);
- Tcl_CreateCommand(interp, "Nsite_unhighlight_list",
- (Tcl_CmdProc *) Nsite_unhighlight_list_cmd, data, NULL);
- Tcl_CreateCommand(interp, "Nsite_unhighlight_all",
- (Tcl_CmdProc *) Nsite_unhighlight_all_cmd, data, NULL);
- Tcl_CreateCommand(interp, "Nsite_highlight_set_default",
- (Tcl_CmdProc *) Nsite_highlight_set_default_cmd, data,
- NULL);
- Tcl_CreateCommand(interp, "Nsite_highlight_get_default",
- (Tcl_CmdProc *) Nsite_highlight_get_default_cmd, data,
- NULL);
- Tcl_CreateCommand(interp, "Nsite_highlight_set_default_value",
- (Tcl_CmdProc *) Nsite_highlight_set_default_value_cmd,
- data, NULL);
- Tcl_CreateCommand(interp, "Nsite_highlight_get_default_value",
- (Tcl_CmdProc *) Nsite_highlight_get_default_value_cmd,
- data, NULL);
-/*not used for now */
-geosite *site_highlight_get_geosite(char *name)
- geosite *gp;
- int i, n, *id;
- id = GP_get_site_list(&n);
- gp = gp_get_site(id[i]);
- if (!strcmp(gp->filename, name)) {
- free(id);
- return gp;
- free(id);
- return NULL;
-geopoint *site_highlight_get_geopoint(geosite * gp, int cat)
- geopoint *gpt;
- if (gpt->cat == cat)
- return gpt;
- return NULL;
-int site_highlight_loop(geosite * gp, const char **argvPtr, int argcPtr,
- int what, int flag, float value)
- geopoint *gpt;
- int i;
- switch (what) {
- case SITE_HIGHLIGHT_SIZE:
- for (i = 0; i < argcPtr; i++) {
- if ((gpt =
- site_highlight_get_geopoint(gp, atoi(argvPtr[i]))) == NULL)
- return (0);
- gpt->highlight_size = flag;
- gpt->highlight_size_value = value;
- break;
- case SITE_HIGHLIGHT_COLOR:
- if ((gpt =
- return (0);
- gpt->highlight_color = flag;
- gpt->highlight_color_value = (int)value;
- break;
- case SITE_HIGHLIGHT_MARKER:
- if ((gpt =
- return (0);
- gpt->highlight_marker = flag;
- gpt->highlight_marker_value = (int)value;
- break;
- case SITE_HIGHLIGHT_ALL:
- if ((gpt =
- return (0);
- break;
- return (1);
-/* Tcl Commands */
- char **argv)
- /* argv[1] = what (color/size/marker) / argv[2] = id / argv[3] = category / [argv[4] = color] */
- geosite *gp;
- geopoint *gpt;
- if (argc < 4)
- if ((gp = gp_get_site(atoi(argv[2]))) == NULL)
- if ((gpt = site_highlight_get_geopoint(gp, atoi(argv[3]))) == NULL)
- if (!strcmp(argv[1], "size")) {
- if (argc == 5)
- gpt->highlight_size_value = atof(argv[4]);
- else
- gpt->highlight_size_value = default_highlight_size_value;
- gpt->highlight_size = TRUE;
- else if (!strcmp(argv[1], "color")) {
- if (argc == 5)
- site_highlight_get_int_BBGGRR(argv[4]);
- else
- gpt->highlight_color_value = default_highlight_color_value;
- gpt->highlight_color = TRUE;
- else if (!strcmp(argv[1], "marker")) {
- if (argc == 5)
- gpt->highlight_marker_value = atoi(argv[4]);
- else
- gpt->highlight_marker_value = default_highlight_marker_value;
- gpt->highlight_marker = TRUE;
- else if (!strcmp(argv[1], "default")) {
- if (default_highlight_size != 0) {
- if (default_highlight_color != 0) {
- if (default_highlight_marker != 0) {
- else
- return (TCL_OK);
- char **argv)
- /* argv[1] = what (color/size/marker) / argv[2] = id / argv[3] = list of categories / [argv[4] = color] */
- int argcPtr;
- const char **argvPtr;
- float value;
- geosite *gp;
- if (argc < 4)
- if (TCL_OK != Tcl_SplitList(interp, argv[3], &argcPtr, &argvPtr))
- if (argc == 5)
- value = atof(argv[4]);
- else
- value = default_highlight_size_value;
- if (site_highlight_loop
- (gp, argvPtr, argcPtr, SITE_HIGHLIGHT_SIZE, TRUE, value) == 0)
- goto error;
- if (argc == 5)
- value = (float)site_highlight_get_int_BBGGRR(argv[4]);
- else
- value = (float)default_highlight_color_value;
- (gp, argvPtr, argcPtr, SITE_HIGHLIGHT_COLOR, TRUE, value) == 0)
- goto error;
- if (argc == 5)
- value = (float)atoi(argv[4]);
- else
- value = (float)default_highlight_marker_value;
- (gp, argvPtr, argcPtr, SITE_HIGHLIGHT_MARKER, TRUE, value) == 0)
- goto error;
- goto error;
- value) == 0)
- goto error;
- value) == 0)
- goto error;
- else
- goto error;
- Tcl_Free((char *)argvPtr);
- return (TCL_OK);
- error:
- if (argvPtr)
- char **argv)
- /* argv[1] = what (color/size/marker/all) / argv[2] = id / argv[3] = category */
- geosite *gp;
- geopoint *gpt;
- if (argc < 4)
- gpt->highlight_size = FALSE;
- gpt->highlight_color = FALSE;
- gpt->highlight_marker = FALSE;
- else if (!strcmp(argv[1], "all")) {
- else
- return (TCL_OK);
- char **argv)
- int argcPtr;
- geosite *gp;
- if (argc < 4)
- (gp, argvPtr, argcPtr, SITE_HIGHLIGHT_SIZE, FALSE, 0.0) == 0)
- goto error;
- (gp, argvPtr, argcPtr, SITE_HIGHLIGHT_COLOR, FALSE, 0.0) == 0)
- goto error;
- (gp, argvPtr, argcPtr, SITE_HIGHLIGHT_MARKER, FALSE, 0.0) == 0)
- goto error;
- (gp, argvPtr, argcPtr, SITE_HIGHLIGHT_ALL, FALSE, 0.0) == 0)
- goto error;
- else
- goto error;
- return (TCL_OK);
- error:
- if (argvPtr)
- char **argv)
- /* argv[1] = what (color/size/marker/all) / argv[2] = id */
- geosite *gp;
- geopoint *gpt;
- if (argc < 3)
- else
- return (TCL_OK);
- Commands for highlight panel, not depending from sites
- /* argv[1] = what (color/size/marker) / argv[2] = value */
- if (argc < 3)
- default_highlight_size_value = atof(argv[2]);
- default_highlight_color_value =
- site_highlight_get_int_BBGGRR(argv[2]);
- default_highlight_marker_value = atoi(argv[2]);
- else
- return (TCL_OK);
- /* argv[1] = what (color/size/marker) */
- char buf[256];
- if (argc < 2)
- sprintf(buf, "%.1f", default_highlight_size_value);
- sprintf(buf, "#%x", default_highlight_color_value);
- sprintf(buf, "%d", default_highlight_marker_value);
- else
- Tcl_SetResult(interp, buf, TCL_VOLATILE);
- return (TCL_OK);
- if (argc < 3)
- default_highlight_size = atoi(argv[2]);
- default_highlight_color = atoi(argv[2]);
- default_highlight_marker = atoi(argv[2]);
- else
- return (TCL_OK);
- char buf[256];
- if (argc < 2)
- sprintf(buf, "%d", default_highlight_size);
- sprintf(buf, "%d", default_highlight_color);
- sprintf(buf, "%d", default_highlight_marker);
- else
- return (TCL_OK);
