[GRASS-SVN] r39428 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Oct 7 14:21:41 EDT 2009
Author: cmbarton
Date: 2009-10-07 14:21:40 -0400 (Wed, 07 Oct 2009)
New Revision: 39428
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/georect.py
Fixed bugs in georectifying vectors code.
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/georect.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/georect.py 2009-10-07 18:11:27 UTC (rev 39427)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/georect.py 2009-10-07 18:21:40 UTC (rev 39428)
@@ -94,7 +94,6 @@
line = line.replace('\n', '').strip()
if len(line) < 1:
continue
- print line
key, value = line.split(':', 1)
self.gisrc_dict[key.strip()] = value.strip()
finally:
@@ -519,7 +518,7 @@
"""Process i.group"""
# update the page
if dcmd:
- gcmd.Command(dcmd, stderr=None)
+ gcmd.Command(dcmd)
self.OnEnterPage()
self.Update()
@@ -626,6 +625,7 @@
def OnSelection(self,event):
"""Map to display selected"""
global xy_map
+ global maptype
xy_map = event.GetString()
@@ -634,6 +634,18 @@
else:
wx.FindWindowById(wx.ID_FORWARD).Enable(True)
+ try:
+ # set computational region to match selected map and zoom display to region
+ if maptype == 'cell':
+ p = gcmd.Command(['g.region', 'rast=xy_map'])
+ elif maptype == 'vector':
+ p = gcmd.Command(['g.region', 'vect=xy_map'])
+ if p.returncode == 0:
+ self.parent.Map.region = self.parent.Map.GetRegion()
+ except:
+ pass
def OnPageChanging(self, event=None):
global xy_map
@@ -690,6 +702,7 @@
self.xymapset = self.grwiz.gisrc_dict['MAPSET']
self.xygroup = self.grwiz.grouppage.xygroup
self.extension = self.grwiz.grouppage.extension
+ self.VectGRList = []
self.file = {
'points' : os.path.join(self.grassdatabase,
@@ -1052,8 +1065,6 @@
global maptype
self.SaveGCPs(None)
- cmd_stdout = ''
- cmd_stderr = ''
if self.CheckGCPcount(msg=True) == False:
return
@@ -1064,26 +1075,22 @@
'extension=%s' % self.extension,'order=%s' % self.gr_order]
if self.clip_to_region:
cmdlist.append('-c')
- print 'the command run = ',str(cmdlist)
- p = gcmd.Command(cmdlist, stdout=cmd_stdout, stderr=cmd_stderr)
+ p = gcmd.Command(cmdlist)
output = p.ReadStdOutput()
error = p.ReadErrOutput()
# printing to console
for i in error:
- i = i.split(':')
- if len(i) >1:
- if i[0] == 'GRASS_INFO_PERCENT':
- print i[1]+'% completed'
- else:
- print i[1]
+ try:
+ msgtype, msg = i.split(':')
+ if msgtype != 'GRASS_INFO_PERCENT':
+ self.parent.goutput.WriteLog(text = _(msg), switchPage = True)
+ except:
+ continue
for i in output:
- i = i.split(':')
- if len(i) >1:
- else:
- print i[1]
wx.MessageBox('Maps in group %s georectified successfully' % self.xygroup)
@@ -1094,8 +1101,23 @@
self.grwiz.SwitchEnv('original')
+ outmsg = ''
# loop through all vectors in VREF
# and move resulting vector to target location
+ # make sure current mapset has a vector folder
+ if not os.path.isdir(os.path.join(self.grassdatabase,
+ self.currentlocation,
+ self.currentmapset,
+ 'vector')):
+ os.mkdir(os.path.join(self.grassdatabase,
+ 'vector'))
+ self.grwiz.SwitchEnv('new')
+ # make list of vectors to georectify from VREF
f = open(self.file['vgrp'])
vectlist = []
try:
@@ -1106,82 +1128,87 @@
vectlist.append(vect)
finally:
f.close()
+ # georectify each vector in VREF using v.transform
for vect in vectlist:
- self.grwiz.SwitchEnv('new')
self.outname = vect + '_' + self.extension
self.parent.goutput.WriteLog(text = _('Transforming <%s>...') % vect,
switchPage = True)
- xyLayer = []
- for layer in vector.vector_db(map = vect).itervalues():
- xyLayer.append((layer['driver'],
- layer['database'],
- layer['table']))
- self.parent.goutput.RunCmd(['v.transform',
- '--o',
- 'input=%s' % vect,
- 'output=%s' % self.outname,
- 'pointsfile=%s' % self.file['points']],
- switchPage = True,
- onDone = self.OnGeorectDone)
+ p = gcmd.Command(['v.transform',
+ '--o',
+ 'input=%s' % vect,
+ 'output=%s' % self.outname,
+ 'points=%s' % self.file['points']])
- dbConnect = db.db_connection()
- for layer in xyLayer:
- self.parent.goutput.RunCmd(['db.copy',
- '--q',
- '--o',
- 'from_driver=%s' % layer[0],
- 'from_database=%s' % layer[1],
- 'from_table=%s' % layer[2],
- 'to_driver=%s' % dbConnect['driver'],
- 'to_database=%s' % dbConnect['database'],
- 'to_table=%s' % layer[2] + '_' + self.extension])
+ output = p.ReadStdOutput()
+ error = p.ReadErrOutput()
+ # printing to console
+ for i in error:
+ try:
+ except:
+ continue
+ for i in output:
+ self.parent.goutput.WriteLog(text = _(i), switchPage = True)
+ self.VectGRList.append(self.outname)
+ else:
+ self.parent.goutput.WriteError(_('Georectification of vector map <%s> failed') %
+ self.outname)
+ # FIXME
+ # Copying database information not working.
+ # Does not copy from xy location to current location
+# xyLayer = []
+# for layer in grass.vector_db(map = vect).itervalues():
+# xyLayer.append((layer['driver'],
+# layer['database'],
+# layer['table']))
+# dbConnect = grass.db_connection()
+# print 'db connection =', dbConnect
+# for layer in xyLayer:
+# self.parent.goutput.RunCmd(['db.copy',
+# '--q',
+# '--o',
+# 'from_driver=%s' % layer[0],
+# 'from_database=%s' % layer[1],
+# 'from_table=%s' % layer[2],
+# 'to_driver=%s' % dbConnect['driver'],
+# 'to_database=%s' % dbConnect['database'],
+# 'to_table=%s' % layer[2] + '_' + self.extension])
+ # copy all georectified vectors from source location to current location
+ for name in self.VectGRList:
+ xyvpath = os.path.join(self.grassdatabase,
+ self.xylocation,
+ self.xymapset,
+ 'vector',
+ name)
+ vpath = os.path.join(self.grassdatabase,
+ 'vector',
+ name)
+ if os.path.isdir(vpath):
+ self.parent.goutput.WriteWarning(_('Vector map <%s> already exists. '
+ 'Change extension name and '
+ 'georectify again.') % self.outname)
+ break
+ else:
+ shutil.move(xyvpath, vpath)
+ wx.MessageBox('For all vector maps georectified successfully, ' + '\n' +
+ 'you will need to copy any associated attribute tables' + '\n' +
+ 'and reconnect them to the georectified vectors')
- def OnGeorectDone(self, **kargs):
- """Print final message"""
- global maptype
- if maptype == 'cell':
- return
- returncode = kargs['returncode']
- xyvpath = os.path.join(self.grassdatabase,
- self.xylocation,
- self.xymapset,
- 'vector',
- self.outname)
- vpath = os.path.join(self.grassdatabase,
- self.currentlocation,
- self.currentmapset,
- 'vector',
- self.outname)
- if os.path.isdir(vpath):
- self.parent.goutput.WriteWarning(_('Vector map <%s> already exists. '
- 'Change extension name and '
- 'georectify again.') % self.outname)
- else:
- if returncode == 0:
- if not os.path.isdir(os.path.join(self.grassdatabase,
- 'vector')):
- os.mkdir(os.path.join(self.grassdatabase,
- 'vector'))
- shutil.move(xyvpath, vpath)
- self.parent.goutput.WriteCmdLog(_('Vector map <%s> georectified '
- 'successfully') % self.outname)
- # copy attributes
- self.parent.goutput.WriteLog(_('Copying attributes...'))
- else:
- self.parent.goutput.WriteError(_('Georectification of vector map <%s> failed') %
- self.outname)
- del self.outname
def OnSettings(self, event):
