[GRASS-SVN] r39459 - in grass/trunk/scripts: m.proj v.out.gps
svn_grass at osgeo.org
Sat Oct 10 02:25:29 EDT 2009
Author: hamish
Date: 2009-10-10 02:25:28 -0400 (Sat, 10 Oct 2009)
New Revision: 39459
grass/trunk/scripts/m.proj/m.proj.py
grass/trunk/scripts/v.out.gps/v.out.gps.py
fix v.out.gps, m.proj default is to read from stdin
Modified: grass/trunk/scripts/m.proj/m.proj.py
--- grass/trunk/scripts/m.proj/m.proj.py 2009-10-10 06:21:17 UTC (rev 39458)
+++ grass/trunk/scripts/m.proj/m.proj.py 2009-10-10 06:25:28 UTC (rev 39459)
@@ -34,6 +34,7 @@
#% type: string
#% gisprompt: old_file,file,file
#% description: Input coordinate file ('-' to read from stdin)
+#% answer: -
#% required : yes
#% key_desc : filename
#%end
Modified: grass/trunk/scripts/v.out.gps/v.out.gps.py
--- grass/trunk/scripts/v.out.gps/v.out.gps.py 2009-10-10 06:21:17 UTC (rev 39458)
+++ grass/trunk/scripts/v.out.gps/v.out.gps.py 2009-10-10 06:25:28 UTC (rev 39459)
@@ -217,7 +217,7 @@
tmp_proj = tmp + ".proj"
tf = open(tmp_proj, 'w')
p1 = grass.pipe_command('v.out.ascii', input = inmap, format = 'standard')
- p2 = grass.feed_command('m.proj', flags = 'od', quiet = True, stdout = tf)
+ p2 = grass.feed_command('m.proj', input = '-', flags = 'od', quiet = True, stdout = tf)
tf.close()
lineno = 0
