[GRASS-SVN] r39485 - grass/trunk/vector/v.out.ogr
svn_grass at osgeo.org
Sun Oct 11 07:36:32 EDT 2009
Author: martinl
Date: 2009-10-11 07:36:31 -0400 (Sun, 11 Oct 2009)
New Revision: 39485
Added:
grass/trunk/vector/v.out.ogr/args.c
grass/trunk/vector/v.out.ogr/attrb.c
grass/trunk/vector/v.out.ogr/list.c
grass/trunk/vector/v.out.ogr/local_proto.h
grass/trunk/vector/v.out.ogr/main.c
v.out.ogr: initial code reorganization
Added: grass/trunk/vector/v.out.ogr/args.c
--- grass/trunk/vector/v.out.ogr/args.c (rev 0)
+++ grass/trunk/vector/v.out.ogr/args.c 2009-10-11 11:36:31 UTC (rev 39485)
@@ -0,0 +1,90 @@
+#include <grass/glocale.h>
+#include "local_proto.h"
+void parse_args(int argc, char **argv,
+ struct Options* options, struct Flags *flags)
+ options->input = G_define_standard_option(G_OPT_V_INPUT);
+ options->type = G_define_standard_option(G_OPT_V3_TYPE);
+ options->type->description =
+ _("Feature type(s). Combination of types is not supported "
+ "by all output formats. Default is to use first type found in input map.");
+ options->type->guisection = _("Input");
+ options->dsn = G_define_option();
+ options->dsn->key = "dsn";
+ options->dsn->type = TYPE_STRING;
+ options->dsn->required = YES;
+ options->dsn->label = _("OGR output datasource name");
+ options->dsn->description =
+ _("For example: ESRI Shapefile: filename or directory for storage");
+ options->layer = G_define_option();
+ options->layer->key = "olayer";
+ options->layer->type = TYPE_STRING;
+ options->layer->required = NO;
+ options->layer->label =
+ _("OGR layer name. If not specified, input name is used.");
+ options->layer->description = _("For example: ESRI Shapefile: shapefile name");
+ options->layer->guisection = _("Creation");
+ options->field = G_define_standard_option(G_OPT_V_FIELD);
+ options->field->guisection = _("Input");
+ options->format = G_define_option();
+ options->format->key = "format";
+ options->format->type = TYPE_STRING;
+ options->format->required = NO;
+ options->format->multiple = NO;
+ options->format->answer = "ESRI_Shapefile";
+ options->format->options = OGR_list_write_drivers();
+ options->format->description = _("OGR format");
+ options->format->guisection = _("Creation");
+ options->dsco = G_define_option();
+ options->dsco->key = "dsco";
+ options->dsco->type = TYPE_STRING;
+ options->dsco->required = NO;
+ options->dsco->multiple = YES;
+ options->dsco->answer = "";
+ options->dsco->description =
+ _("OGR dataset creation option (format specific, NAME=VALUE)");
+ options->dsco->guisection = _("Creation");
+ options->lco = G_define_option();
+ options->lco->key = "lco";
+ options->lco->type = TYPE_STRING;
+ options->lco->required = NO;
+ options->lco->multiple = YES;
+ options->lco->answer = "";
+ options->lco->description =
+ _("OGR layer creation option (format specific, NAME=VALUE)");
+ options->lco->guisection = _("Creation");
+ flags->update = G_define_flag();
+ flags->update->key = 'u';
+ flags->update->description = _("Open an existing datasource for update");
+ flags->nocat = G_define_flag();
+ flags->nocat->key = 's';
+ flags->nocat->description = _("Skip export of GRASS category ID ('cat') attribute");
+ flags->cat = G_define_flag();
+ flags->cat->key = 'c';
+ flags->cat->description = _("Also export features without category (not labeled). "
+ "Otherwise only features with category are exported.");
+ flags->esristyle = G_define_flag();
+ flags->esristyle->key = 'e';
+ flags->esristyle->description = _("Use ESRI-style .prj file format "
+ "(applies to Shapefile output only)");
+ flags->poly = G_define_flag();
+ flags->poly->key = 'p';
+ flags->poly->description = _("Export lines as polygons");
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
Property changes on: grass/trunk/vector/v.out.ogr/args.c
___________________________________________________________________
Added: svn:mime-type
+ text/x-csrc
Added: svn:keywords
+ Author Date Id
Added: svn:eol-style
+ native
Added: grass/trunk/vector/v.out.ogr/attrb.c
--- grass/trunk/vector/v.out.ogr/attrb.c (rev 0)
+++ grass/trunk/vector/v.out.ogr/attrb.c 2009-10-11 11:36:31 UTC (rev 39485)
@@ -0,0 +1,118 @@
+int mk_att(int cat, struct field_info *Fi, dbDriver *Driver, int ncol,
+ int doatt, int nocat, OGRFeatureH Ogr_feature, int *noatt, int *fout)
+ int j, ogrfieldnum;
+ char buf[2000];
+ int colsqltype, colctype, more;
+ dbTable *Table;
+ dbString dbstring;
+ dbColumn *Column;
+ dbCursor cursor;
+ dbValue *Value;
+ G_debug(2, "mk_att() cat = %d, doatt = %d", cat, doatt);
+ db_init_string(&dbstring);
+ /* Attributes */
+ /* Reset */
+ if (!doatt) {
+ ogrfieldnum = OGR_F_GetFieldIndex(Ogr_feature, "cat");
+ OGR_F_UnsetField(Ogr_feature, ogrfieldnum);
+ /* doatt reset moved into have cat loop as the table needs to be
+ open to know the OGR field ID. Hopefully this has no ill consequences */
+ /* Read & set attributes */
+ if (cat >= 0) { /* Line with category */
+ if (doatt) {
+ sprintf(buf, "SELECT * FROM %s WHERE %s = %d", Fi->table, Fi->key,
+ cat);
+ G_debug(2, "SQL: %s", buf);
+ db_set_string(&dbstring, buf);
+ if (db_open_select_cursor
+ (Driver, &dbstring, &cursor, DB_SEQUENTIAL) != DB_OK) {
+ G_fatal_error(_("Cannot select attributes for cat = %d"),
+ cat);
+ else {
+ if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK)
+ G_fatal_error(_("Unable to fetch data from table"));
+ if (!more) {
+ /* G_warning ("No database record for cat = %d", cat); */
+ /* Set at least key column to category */
+ if (!nocat) {
+ ogrfieldnum = OGR_F_GetFieldIndex(Ogr_feature, Fi->key);
+ OGR_F_SetFieldInteger(Ogr_feature, ogrfieldnum, cat);
+ (*noatt)++;
+ } else {
+ G_fatal_error (_("No database record for cat = %d and export of 'cat' disabled"),
+ cat);
+ else {
+ Table = db_get_cursor_table(&cursor);
+ for (j = 0; j < ncol; j++) {
+ Column = db_get_table_column(Table, j);
+ Value = db_get_column_value(Column);
+ db_convert_column_value_to_string(Column, &dbstring); /* for debug only */
+ G_debug(2, "col %d : val = %s", j,
+ db_get_string(&dbstring));
+ colsqltype = db_get_column_sqltype(Column);
+ colctype = db_sqltype_to_Ctype(colsqltype);
+ G_debug(2, " colctype = %d", colctype);
+ db_get_column_name(Column));
+ /* Reset */
+ /* prevent writing NULL values */
+ if (!db_test_value_isnull(Value)) {
+ switch (colctype) {
+ case DB_C_TYPE_INT:
+ db_get_value_int(Value));
+ break;
+ case DB_C_TYPE_DOUBLE:
+ OGR_F_SetFieldDouble(Ogr_feature, ogrfieldnum,
+ db_get_value_double(Value));
+ break;
+ case DB_C_TYPE_STRING:
+ OGR_F_SetFieldString(Ogr_feature, ogrfieldnum,
+ db_get_value_string(Value));
+ break;
+ case DB_C_TYPE_DATETIME:
+ &dbstring);
+ break;
+ db_close_cursor (&cursor);
+ else { /* Use cat only */
+ else {
+ /* G_warning ("Line without cat of layer %d", field); */
+ nocat++;
+ (*fout)++;
+ db_free_string(&dbstring);
+ return 1;
Property changes on: grass/trunk/vector/v.out.ogr/attrb.c
+ text/x-csrc
Added: svn:keywords
+ Author Date Id
+ native
Added: grass/trunk/vector/v.out.ogr/list.c
--- grass/trunk/vector/v.out.ogr/list.c (rev 0)
+++ grass/trunk/vector/v.out.ogr/list.c 2009-10-11 11:36:31 UTC (rev 39485)
@@ -0,0 +1,35 @@
+/* to print available drivers in help text */
+char *OGR_list_write_drivers(void)
+ int drn, i;
+ OGRSFDriverH Ogr_driver;
+ char buf[2000];
+ char OGRdrivers[2000];
+ OGRdrivers[0] = '\0';
+ /* Open OGR DSN */
+ OGRRegisterAll();
+ G_debug(2, "driver count = %d", OGRGetDriverCount());
+ drn = -1;
+ for (i = 0; i < OGRGetDriverCount(); i++) {
+ /* only fetch read/write drivers */
+ if (OGR_Dr_TestCapability(OGRGetDriver(i), ODrCCreateDataSource)) {
+ Ogr_driver = OGRGetDriver(i);
+ G_debug(2, "driver %d/%d : %s", i, OGRGetDriverCount(),
+ OGR_Dr_GetName(Ogr_driver));
+ /* chg white space to underscore in OGR driver names */
+ sprintf(buf, "%s", OGR_Dr_GetName(Ogr_driver));
+ G_strchg(buf, ' ', '_');
+ strcat(OGRdrivers, buf);
+ if (i < OGRGetDriverCount() - 1)
+ strcat(OGRdrivers, ",");
+ G_debug(2, "all drivers: %s", OGRdrivers);
+ return G_store(OGRdrivers);
Property changes on: grass/trunk/vector/v.out.ogr/list.c
+ text/x-csrc
Added: svn:keywords
+ Author Date Id
+ native
Added: grass/trunk/vector/v.out.ogr/local_proto.h
--- grass/trunk/vector/v.out.ogr/local_proto.h (rev 0)
+++ grass/trunk/vector/v.out.ogr/local_proto.h 2009-10-11 11:36:31 UTC (rev 39485)
@@ -0,0 +1,26 @@
+#include <grass/gis.h>
+#include <grass/vector.h>
+#include <grass/dbmi.h>
+#include "ogr_api.h"
+#include "cpl_string.h"
+struct Options {
+ struct Option *input, *dsn, *layer, *type, *format,
+ *field, *dsco, *lco;
+struct Flags {
+ struct Flag *cat, *esristyle, *poly, *update, *nocat;
+/* args.c */
+void parse_args(int, char **,
+ struct Options*, struct Flags *);
+/* attributes.c */
+ int ncol, int doatt, int nocat, OGRFeatureH Ogr_feature, int *, int *);
+/* list.c */
+char *OGR_list_write_drivers();
Property changes on: grass/trunk/vector/v.out.ogr/local_proto.h
+ text/x-chdr
Added: svn:keywords
+ Author Date Id
+ native
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c 2009-10-11 09:58:21 UTC (rev 39484)
+++ grass/trunk/vector/v.out.ogr/main.c 2009-10-11 11:36:31 UTC (rev 39485)
@@ -5,46 +5,37 @@
* AUTHOR(S): Radim Blazek
* Some extensions: Markus Neteler, Benjamin Ducke
+ * Uodate for GRASS 7 by Martin Landa <landa.martin gmail.com>
- * PURPOSE: Category manipulations
+ * PURPOSE: Converts GRASS vector to one of supported OGR vector formats.
* COPYRIGHT: (C) 2001-2009 by the GRASS Development Team
- * This program is free software under the
- * GNU General Public License (>=v2).
- * Read the file COPYING that comes with GRASS
- * for details.
+ * This program is free software under the GNU General
+ * Public License (>=v2). Read the file COPYING that
+ * comes with GRASS for details.
#include <stdlib.h>
#include <string.h>
-#include <grass/gis.h>
-#include <grass/dbmi.h>
-#include <grass/vector.h>
#include <grass/config.h>
#include <grass/gprojects.h>
-#include "ogr_api.h"
-#include "cpl_string.h"
-int fout, fskip; /* features written/ skip */
-int nocat, noatt, nocatskip; /* number of features without cats/atts written/skip */
-int mk_att(int cat, struct field_info *Fi, dbDriver *Driver,
- int ncol, int doatt, int nocat, OGRFeatureH Ogr_feature);
-char *OGR_list_write_drivers();
-char OGRdrivers[2000];
int main(int argc, char *argv[])
int i, j, k, centroid, otype, donocat;
int num_to_export;
int field;
struct GModule *module;
- struct Option *in_opt, *dsn_opt, *layer_opt, *type_opt, *frmt_opt,
- *field_opt, *dsco, *lco;
- struct Flag *cat_flag, *esristyle, *poly_flag, *update_flag, *nocat_flag;
+ struct Options options;
+ struct Flags flags;
char buf[2000];
char key1[200], key2[200];
struct Key_Value *projinfo, *projunits;
@@ -66,6 +57,9 @@
dbString dbstring;
dbColumn *Column;
+ int fout, fskip; /* features written/ skip */
+ int nocat, noatt, nocatskip; /* number of features without cats/atts written/skip */
/* OGR */
int drn, ogr_ftype = OFTInteger;
OGRDataSourceH Ogr_ds;
@@ -90,120 +84,38 @@
module->description =
_("Converts GRASS vector map to one of the supported OGR vector formats.");
+ /* parse & read options */
+ parse_args(argc, argv,
+ &options, &flags);
+ field = atoi(options.field->answer);
- in_opt = G_define_standard_option(G_OPT_V_INPUT);
- type_opt = G_define_standard_option(G_OPT_V3_TYPE);
- type_opt->description =
- _("Feature type(s). Combination of types is not supported "
- "by all output formats. Default is to use first type found in input map.");
- type_opt->guisection = _("Input");
- dsn_opt = G_define_option();
- dsn_opt->key = "dsn";
- dsn_opt->type = TYPE_STRING;
- dsn_opt->required = YES;
- dsn_opt->label = _("OGR output datasource name");
- dsn_opt->description =
- _("For example: ESRI Shapefile: filename or directory for storage");
- layer_opt = G_define_option();
- layer_opt->key = "olayer";
- layer_opt->type = TYPE_STRING;
- layer_opt->required = NO;
- layer_opt->label =
- _("OGR layer name. If not specified, input name is used.");
- layer_opt->description = _("For example: ESRI Shapefile: shapefile name");
- layer_opt->guisection = _("Creation");
- field_opt = G_define_standard_option(G_OPT_V_FIELD);
- field_opt->guisection = _("Input");
- frmt_opt = G_define_option();
- frmt_opt->key = "format";
- frmt_opt->type = TYPE_STRING;
- frmt_opt->required = NO;
- frmt_opt->multiple = NO;
- frmt_opt->answer = "ESRI_Shapefile";
- frmt_opt->options = OGR_list_write_drivers();
- frmt_opt->description = _("OGR format");
- frmt_opt->guisection = _("Creation");
- dsco = G_define_option();
- dsco->key = "dsco";
- dsco->type = TYPE_STRING;
- dsco->required = NO;
- dsco->multiple = YES;
- dsco->answer = "";
- dsco->description =
- _("OGR dataset creation option (format specific, NAME=VALUE)");
- dsco->guisection = _("Creation");
- lco = G_define_option();
- lco->key = "lco";
- lco->type = TYPE_STRING;
- lco->required = NO;
- lco->multiple = YES;
- lco->answer = "";
- lco->description =
- _("OGR layer creation option (format specific, NAME=VALUE)");
- lco->guisection = _("Creation");
- update_flag = G_define_flag();
- update_flag->key = 'u';
- update_flag->description = _("Open an existing datasource for update");
- nocat_flag = G_define_flag();
- nocat_flag->key = 's';
- nocat_flag->description = _("Skip export of GRASS category ID ('cat') attribute");
- cat_flag = G_define_flag();
- cat_flag->key = 'c';
- cat_flag->description = _("Also export features without category (not labeled). "
- "Otherwise only features with category are exported.");
- esristyle = G_define_flag();
- esristyle->key = 'e';
- esristyle->description = _("Use ESRI-style .prj file format "
- "(applies to Shapefile output only)");
- poly_flag = G_define_flag();
- poly_flag->key = 'p';
- poly_flag->description = _("Export lines as polygons");
- if (G_parser(argc, argv))
- exit(EXIT_FAILURE);
- /* read options */
- field = atoi(field_opt->answer);
- /* open input vector */
+ /* open input vector (topology required) */
Vect_set_open_level(2);
- Vect_open_old(&In, in_opt->answer, "");
+ Vect_open_old(&In, options.input->answer, "");
If no output type specified: determine one automatically.
- Centroids, Boundaries and Kernels always have to be
- exported explicitely, using the "type=" option.
+ Centroids, Boundaries and Kernels always have to be exported
+ explicitely, using the "type=" option.
- if (!strcmp(type_opt->answer, "auto" )) {
+ if (!strcmp(options.type->answer, "auto" )) {
G_debug(2, "Automatic type determination." );
- type_opt->answers = G_malloc (sizeof(char*) * 100); /* should be big enough forever ;) */
+ options.type->answers = G_malloc (sizeof(char*) * 100); /* should be big enough forever ;) */
for (i=0;i<100;i++) {
- type_opt->answers[i] = NULL;
+ options.type->answers[i] = NULL;
num_types = 0;
if ( Vect_get_num_primitives ( &In, GV_POINT ) > 0 ) {
- type_opt->answers[num_types] = strdup ( "point" );
+ options.type->answers[num_types] = strdup ( "point" );
G_debug(3, "Adding points to export list." );
num_types ++;
if ( Vect_get_num_primitives ( &In, GV_LINE ) > 0 ) {
- type_opt->answers[num_types] = strdup ( "line" );
+ options.type->answers[num_types] = strdup ( "line" );
G_debug(3, "Adding lines to export list." );
num_types ++;
@@ -215,7 +127,7 @@
if ( Vect_get_num_areas ( &In ) > 0 ) {
- type_opt->answers[num_types] = strdup ( "area" );
+ options.type->answers[num_types] = strdup ( "area" );
G_debug(3, "Adding areas to export list." );
num_types ++;
@@ -224,7 +136,7 @@
For now, volumes will just be exported as sets of faces.
if ( Vect_get_num_primitives ( &In, GV_FACE ) > 0 ) {
- type_opt->answers[num_types] = strdup ( "face" );
+ options.type->answers[num_types] = strdup ( "face" );
G_debug(3, "Adding faces to export list." );
num_types ++;
@@ -233,13 +145,13 @@
G_warning(_("Volumes will be exported as sets of faces."));
if ( num_types == 0 ) {
/* no other types yet? */
- type_opt->answers[num_types] = strdup ( "volume" );
+ options.type->answers[num_types] = strdup ( "volume" );
G_debug(3, "Adding volumes to export list." );
num_types ++;
} else {
- if ( strcmp ( type_opt->answers[num_types-1], "face" ) ) {
+ if ( strcmp ( options.type->answers[num_types-1], "face" ) ) {
/* only put faces on export list if that's not the case already */
num_types ++;
@@ -251,15 +163,15 @@
/* Check output type */
- otype = Vect_option_to_types(type_opt);
+ otype = Vect_option_to_types(options.type);
- if (!layer_opt->answer) {
+ if (!options.layer->answer) {
char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
- if (G_name_is_fully_qualified(in_opt->answer, xname, xmapset))
- layer_opt->answer = G_store(xname);
+ if (G_name_is_fully_qualified(options.input->answer, xname, xmapset))
+ options.layer->answer = G_store(xname);
else
- layer_opt->answer = G_store(in_opt->answer);
+ options.layer->answer = G_store(options.input->answer);
if (otype & GV_POINTS)
@@ -273,7 +185,7 @@
else if (otype & GV_VOLUME)
wkbtype = wkbPolygon25D;
- if (poly_flag->answer)
+ if (flags.poly->answer)
wkbtype = wkbPolygon;
if (((GV_POINTS & otype) && (GV_LINES & otype)) ||
@@ -297,7 +209,7 @@
wkbtype = wkbUnknown;
- if (cat_flag->answer)
+ if (flags.cat->answer)
donocat = 1;
else
donocat = 0;
@@ -305,7 +217,7 @@
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
- if ((GV_AREA & otype) && Vect_get_num_islands(&In) > 0 && cat_flag->answer)
+ if ((GV_AREA & otype) && Vect_get_num_islands(&In) > 0 && flags.cat->answer)
G_warning(_("The map contains islands. With the -c flag, "
"islands will appear as filled areas, not holes in the output map."));
@@ -317,8 +229,8 @@
projinfo = G_get_projinfo();
projunits = G_get_projunits();
Ogr_projection = GPJ_grass_to_osr(projinfo, projunits);
- if (esristyle->answer &&
- (strcmp(frmt_opt->answer, "ESRI_Shapefile") == 0))
+ if (flags.esristyle->answer &&
+ (strcmp(options.format->answer, "ESRI_Shapefile") == 0))
OSRMorphToESRI(Ogr_projection);
@@ -331,42 +243,42 @@
- if (strcmp(buf, frmt_opt->answer) == 0) {
+ if (strcmp(buf, options.format->answer) == 0) {
drn = i;
G_debug(2, " -> driver = %d", drn);
if (drn == -1)
- G_fatal_error(_("OGR driver <%s> not found"), frmt_opt->answer);
+ G_fatal_error(_("OGR driver <%s> not found"), options.format->answer);
Ogr_driver = OGRGetDriver(drn);
/* parse dataset creation options */
i = 0;
- while (dsco->answers[i]) {
- tokens = G_tokenize(dsco->answers[i], "=");
+ while (options.dsco->answers[i]) {
+ tokens = G_tokenize(options.dsco->answers[i], "=");
if (G_number_of_tokens(tokens))
papszDSCO = CSLSetNameValue(papszDSCO, tokens[0], tokens[1]);
G_free_tokens(tokens);
i++;
- if (update_flag->answer) {
+ if (flags.update->answer) {
G_debug(1, "Update OGR data source");
- Ogr_ds = OGR_Dr_Open(Ogr_driver, dsn_opt->answer, TRUE);
+ Ogr_ds = OGR_Dr_Open(Ogr_driver, options.dsn->answer, TRUE);
} else {
G_debug(1, "Create OGR data source");
- Ogr_ds = OGR_Dr_CreateDataSource(Ogr_driver, dsn_opt->answer, papszDSCO);
+ Ogr_ds = OGR_Dr_CreateDataSource(Ogr_driver, options.dsn->answer, papszDSCO);
CSLDestroy(papszDSCO);
if (Ogr_ds == NULL)
G_fatal_error(_("Unable to open OGR data source '%s'"),
- dsn_opt->answer);
+ options.dsn->answer);
/* parse layer creation options */
i = 0;
- while (lco->answers[i]) {
- tokens = G_tokenize(lco->answers[i], "=");
+ while (options.lco->answers[i]) {
+ tokens = G_tokenize(options.lco->answers[i], "=");
papszLCO = CSLSetNameValue(papszLCO, tokens[0], tokens[1]);
@@ -376,7 +288,7 @@
/* check if the map is 3d */
if (Vect_is_3d(&In)) {
/* specific check for shp */
- if (strcmp(frmt_opt->answer, "ESRI_Shapefile") == 0) {
+ if (strcmp(options.format->answer, "ESRI_Shapefile") == 0) {
const char *shpt;
shpt = CSLFetchNameValue(papszLCO, "SHPT");
@@ -384,20 +296,20 @@
G_warning(_("Vector map <%s> is 3D. "
"Use format specific layer creation options (parameter 'lco') "
"to export in 3D rather than 2D (default)"),
- in_opt->answer);
+ options.input->answer);
else {
- in_opt->answer);
G_debug(1, "Create OGR layer");
Ogr_layer =
- OGR_DS_CreateLayer(Ogr_ds, layer_opt->answer, Ogr_projection, wkbtype,
+ OGR_DS_CreateLayer(Ogr_ds, options.layer->answer, Ogr_projection, wkbtype,
papszLCO);
CSLDestroy(papszLCO);
if (Ogr_layer == NULL)
@@ -414,9 +326,9 @@
G_warning(_("No attribute table found -> using only category numbers as attributes"));
/* if we have no more than a 'cat' column, then that has to
be exported in any case */
- if (nocat_flag->answer) {
+ if (flags.nocat->answer) {
G_warning(_("Exporting 'cat' anyway, as it is the only attribute table field"));
- nocat_flag->answer=0;
+ flags.nocat->answer=0;
Ogr_field = OGR_Fld_Create("cat", OFTInteger);
OGR_L_CreateField(Ogr_layer, Ogr_field, 0);
@@ -478,7 +390,7 @@
OGR_Fld_Create(db_get_column_name(Column), ogr_ftype);
OGR_Fld_Destroy(Ogr_field);
- if (!nocat_flag->answer) {
+ if (!flags.nocat->answer) {
Ogr_field =
@@ -635,7 +547,7 @@
/* Geometry */
- if (type == GV_LINE && poly_flag->answer) {
+ if (type == GV_LINE && flags.poly->answer) {
OGRGeometryH ring;
ring = OGR_G_CreateGeometry(wkbLinearRing);
@@ -685,7 +597,7 @@
continue;
- mk_att(cat, Fi, Driver, ncol, doatt, nocat_flag->answer, Ogr_feature);
+ mk_att(cat, Fi, Driver, ncol, doatt, flags.nocat->answer, Ogr_feature, &noatt, &fout);
OGR_L_CreateFeature(Ogr_layer, Ogr_feature);
OGR_G_DestroyGeometry(Ogr_geometry);
@@ -759,7 +671,7 @@
continue;
@@ -819,7 +731,7 @@
continue;
@@ -875,7 +787,7 @@
continue;
@@ -926,149 +838,3 @@
exit(EXIT_SUCCESS);
-int mk_att(int cat, struct field_info *Fi, dbDriver *Driver, int ncol,
- int doatt, int nocat, OGRFeatureH Ogr_feature)
- int j, ogrfieldnum;
- char buf[2000];
- int colsqltype, colctype, more;
- dbTable *Table;
- dbString dbstring;
- dbColumn *Column;
- dbCursor cursor;
- dbValue *Value;
- G_debug(2, "mk_att() cat = %d, doatt = %d", cat, doatt);
- db_init_string(&dbstring);
- /* Attributes */
- /* Reset */
- if (!doatt) {
- ogrfieldnum = OGR_F_GetFieldIndex(Ogr_feature, "cat");
- OGR_F_UnsetField(Ogr_feature, ogrfieldnum);
- /* doatt reset moved into have cat loop as the table needs to be
- open to know the OGR field ID. Hopefully this has no ill consequences */
- /* Read & set attributes */
- if (cat >= 0) { /* Line with category */
- if (doatt) {
- sprintf(buf, "SELECT * FROM %s WHERE %s = %d", Fi->table, Fi->key,
- cat);
- G_debug(2, "SQL: %s", buf);
- db_set_string(&dbstring, buf);
- if (db_open_select_cursor
- (Driver, &dbstring, &cursor, DB_SEQUENTIAL) != DB_OK) {
- G_fatal_error(_("Cannot select attributes for cat = %d"),
- cat);
- else {
- if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK)
- G_fatal_error(_("Unable to fetch data from table"));
- if (!more) {
- /* G_warning ("No database record for cat = %d", cat); */
- /* Set at least key column to category */
- if (!nocat) {
- ogrfieldnum = OGR_F_GetFieldIndex(Ogr_feature, Fi->key);
- OGR_F_SetFieldInteger(Ogr_feature, ogrfieldnum, cat);
- noatt++;
- } else {
- G_fatal_error (_("No database record for cat = %d and export of 'cat' disabled"),
- cat);
- else {
- Table = db_get_cursor_table(&cursor);
- for (j = 0; j < ncol; j++) {
- Column = db_get_table_column(Table, j);
- Value = db_get_column_value(Column);
- db_convert_column_value_to_string(Column, &dbstring); /* for debug only */
- G_debug(2, "col %d : val = %s", j,
- db_get_string(&dbstring));
- colsqltype = db_get_column_sqltype(Column);
- colctype = db_sqltype_to_Ctype(colsqltype);
- G_debug(2, " colctype = %d", colctype);
- db_get_column_name(Column));
- /* Reset */
- /* prevent writing NULL values */
- if (!db_test_value_isnull(Value)) {
- switch (colctype) {
- case DB_C_TYPE_INT:
- db_get_value_int(Value));
- break;
- case DB_C_TYPE_DOUBLE:
- OGR_F_SetFieldDouble(Ogr_feature, ogrfieldnum,
- db_get_value_double(Value));
- break;
- case DB_C_TYPE_STRING:
- OGR_F_SetFieldString(Ogr_feature, ogrfieldnum,
- db_get_value_string(Value));
- break;
- case DB_C_TYPE_DATETIME:
- &dbstring);
- break;
- db_close_cursor (&cursor);
- else { /* Use cat only */
- else {
- /* G_warning ("Line without cat of layer %d", field); */
- nocat++;
- fout++;
- db_free_string(&dbstring);
- return 1;
-/* to print available drivers in help text */
-char *OGR_list_write_drivers(void)
- int drn, i;
- OGRSFDriverH Ogr_driver;
- char buf[2000];
- /* Open OGR DSN */
- OGRRegisterAll();
- G_debug(2, "driver count = %d", OGRGetDriverCount());
- drn = -1;
- for (i = 0; i < OGRGetDriverCount(); i++) {
- /* only fetch read/write drivers */
- if (OGR_Dr_TestCapability(OGRGetDriver(i), ODrCCreateDataSource)) {
- Ogr_driver = OGRGetDriver(i);
- G_debug(2, "driver %d/%d : %s", i, OGRGetDriverCount(),
- OGR_Dr_GetName(Ogr_driver));
- /* chg white space to underscore in OGR driver names */
- sprintf(buf, "%s", OGR_Dr_GetName(Ogr_driver));
- G_strchg(buf, ' ', '_');
- strcat(OGRdrivers, buf);
- if (i < OGRGetDriverCount() - 1)
- strcat(OGRdrivers, ",");
- G_debug(2, "all drivers: %s", OGRdrivers);
- return OGRdrivers;
