[GRASS-SVN] r39493 - grass/trunk/scripts/db.dropcolumn
svn_grass at osgeo.org
Mon Oct 12 14:46:28 EDT 2009
Author: martinl
Date: 2009-10-12 14:46:27 -0400 (Mon, 12 Oct 2009)
New Revision: 39493
grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py
db_describes requires 'table' paramater
Modified: grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py
--- grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py 2009-10-12 04:49:16 UTC (rev 39492)
+++ grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py 2009-10-12 18:46:27 UTC (rev 39493)
@@ -69,7 +69,7 @@
if column == "cat":
grass.warning(_("Deleting <%s> column which may be needed to keep table connected to a vector map") % column)
- cols = [f[0] for f in grass.db_describe()['cols']]
+ cols = [f[0] for f in grass.db_describe(table)['cols']]
if column not in cols:
grass.fatal(_("Column <%s> not found in table") % column)
