[GRASS-SVN] r39499 -
grass/branches/releasebranch_6_4/vector/lidar/v.lidar.growing
svn_grass at osgeo.org
Tue Oct 13 03:11:33 EDT 2009
Author: neteler
Date: 2009-10-13 03:11:27 -0400 (Tue, 13 Oct 2009)
New Revision: 39499
grass/branches/releasebranch_6_4/vector/lidar/v.lidar.growing/main.c
work around G__name_is_fully_qualified() bug
Modified: grass/branches/releasebranch_6_4/vector/lidar/v.lidar.growing/main.c
--- grass/branches/releasebranch_6_4/vector/lidar/v.lidar.growing/main.c 2009-10-13 07:11:26 UTC (rev 39498)
+++ grass/branches/releasebranch_6_4/vector/lidar/v.lidar.growing/main.c 2009-10-13 07:11:27 UTC (rev 39499)
@@ -68,6 +68,8 @@
dbString sql;
dbTable *table;
dbCursor cursor;
+ const char *p;
+ int found;
/* Options' declaration */ ;
@@ -118,8 +120,19 @@
/* Open input vector */
Vect_check_input_output_name(in_opt->answer, out_opt->answer,
GV_FATAL_EXIT);
- if(G__name_is_fully_qualified(in_opt->answer, xname, xmapset) < 0 ) /* strip off mapset from input for SQL*/
- G_fatal_error(_("Vector map <%s> not found"), xname);
+ sprintf(xname, "%s", in_opt->answer);
+ found = 0;
+ for (p = in_opt->answer; *p; p++)
+ if (*p == '@') {
+ found = 1;
+ break;
+ if (found) {
+ if (G__name_is_fully_qualified(in_opt->answer, xname, xmapset) < 0) /* strip off mapset from input for SQL */
+ G_fatal_error(_("Vector map <%s> not found"), xname);
if ((mapset = G_find_vector2(in_opt->answer, "")) == NULL) {
G_fatal_error(_("Vector map <%s> not found"), in_opt->answer);
@@ -171,13 +184,12 @@
db_init_string(&sql);
db_zero_string(&sql);
- sprintf(buf, "SELECT Interp,ID FROM %s_edge_Interpolation",
- xname);
- G_debug(1,"buf: %s", buf);
+ sprintf(buf, "SELECT Interp,ID FROM %s_edge_Interpolation", xname);
+ G_debug(1, "buf: %s", buf);
db_append_string(&sql, buf);
if (db_open_select_cursor(driver, &sql, &cursor, DB_SEQUENTIAL) != DB_OK)
- G_fatal_error(_("Unable to create table <%s_edge_Interpolation>"), xname);
+ G_fatal_error(_("Unable to open table <%s_edge_Interpolation>"), xname);
count_obj = 1;
