[GRASS-SVN] r39513 - grass-addons/raster/r.stream.extract
Tue Oct 13 14:19:38 EDT 2009
Author: mmetz
Date: 2009-10-13 14:19:38 -0400 (Tue, 13 Oct 2009)
New Revision: 39513
Added:
   grass-addons/raster/r.stream.extract/del_streams.c
   grass-addons/raster/r.stream.extract/close.c
   grass-addons/raster/r.stream.extract/description.html
   grass-addons/raster/r.stream.extract/do_astar.c
   grass-addons/raster/r.stream.extract/local_proto.h
   grass-addons/raster/r.stream.extract/main.c
   grass-addons/raster/r.stream.extract/streams.c
   grass-addons/raster/r.stream.extract/thin.c
optimized A* Search, added option to delete short stream segments
Modified: grass-addons/raster/r.stream.extract/close.c
--- grass-addons/raster/r.stream.extract/close.c	2009-10-13 17:15:48 UTC (rev 39512)
+++ grass-addons/raster/r.stream.extract/close.c	2009-10-13 18:19:38 UTC (rev 39513)
@@ -56,6 +56,9 @@
 	thisindex = INDEX(r, c);
 	stream_id = stream[thisindex];
+	if (!stream_id)
+	    continue;
 	Vect_reset_line(Points);
 	Vect_reset_cats(Cats);
@@ -194,7 +197,7 @@
 	sprintf(buf, "insert into %s values ( %d, \'%s\', %d )",
 		Fi->table, i,
-		(stream_node[i].n_trib > 0 ? "start" : "intermediate"),
+		(stream_node[i].n_trib > 0 ? "intermediate" : "start"),
 		(stream_node[i].n_trib > 0));
 	db_set_string(&dbsql, buf);
Added: grass-addons/raster/r.stream.extract/del_streams.c
--- grass-addons/raster/r.stream.extract/del_streams.c	                        (rev 0)
+++ grass-addons/raster/r.stream.extract/del_streams.c	2009-10-13 18:19:38 UTC (rev 39513)
@@ -0,0 +1,225 @@
+#include <stdlib.h>
+#include <math.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include "local_proto.h"
+/* delete short stream segments according to threshold */
+int del_streams(int min_length)
+    int i;
+    int n_deleted = 0;
+    unsigned int thisindex, next_stream_pos = -1;
+    int curr_stream, stream_id, other_trib, tmp_trib;
+    int slength;
+    G_message(_("delete stream segments shorter than %d cells..."), min_length);
+    /* go through all nodes */
+    for (i = 1; i <= n_stream_nodes; i++) {
+	G_percent(i, n_stream_nodes, 2);
+	/* not a stream head */
+	if (stream_node[i].n_trib > 0)
+	    continue;
+	/* already deleted */
+	thisindex = INDEX(stream_node[i].r, stream_node[i].c);
+	if (stream[thisindex] == 0)
+	    continue;
+	/* get length counted as n cells */
+	if ((slength = seg_length(i, &next_stream_pos)) >= min_length)
+	    continue;
+	stream_id = i;
+	/* check n sibling tributaries */
+	if ((curr_stream = stream[next_stream_pos]) != stream_id) {
+	    /* only one sibling tributary */
+	    if (stream_node[curr_stream].n_trib == 2) {
+		if (stream_node[curr_stream].trib[0] != stream_id)
+		    other_trib = stream_node[curr_stream].trib[0];
+		else
+		    other_trib = stream_node[curr_stream].trib[1];
+		/* other trib is also stream head */
+		if (stream_node[other_trib].n_trib == 0) {
+		    /* use shorter one */
+		    if (seg_length(other_trib, NULL) < slength) {
+			tmp_trib = stream_id;
+			stream_id = other_trib;
+			other_trib = tmp_trib;
+		del_stream_seg(stream_id);
+		n_deleted++;
+		/* update downstream IDs */
+		update_stream_id(curr_stream, other_trib);
+	    /* more than one other tributary */
+	    else {
+		n_deleted++;
+	/* stream head is also outlet */
+	else {
+	    n_deleted++;
+    G_debug(1, "%d stream segments deleted", n_deleted);
+    return n_deleted;
+/* get stream segment length */
+int seg_length(int stream_id, unsigned int *new_stream_pos)
+    int r, c, r_nbr, c_nbr;
+    int slength = 1;
+    struct ddir draindir, *founddir;
+    int curr_stream;
+    int asp_r[9] = { 0, -1, -1, -1, 0, 1, 1, 1, 0 };
+    int asp_c[9] = { 0, 1, 0, -1, -1, -1, 0, 1, 1 };
+    r = stream_node[stream_id].r;
+    c = stream_node[stream_id].c;
+    /* get next downstream point */
+    draindir.pos = INDEX(r, c);
+    if (new_stream_pos)
+	*new_stream_pos = draindir.pos;
+    while ((founddir = rbtree_find(draintree, &draindir)) != NULL) {
+	r_nbr = r + asp_r[(int)founddir->dir];
+	c_nbr = c + asp_c[(int)founddir->dir];
+	/* user-defined depression */
+	if (r_nbr == r && c_nbr == c)
+	    break;
+	/* outside region */
+	if (r_nbr < 0 || r_nbr >= nrows || c_nbr < 0 || c_nbr >= ncols)
+	    break;
+	/* next stream */
+	if ((curr_stream = stream[INDEX(r_nbr, c_nbr)]) != stream_id) {
+		*new_stream_pos = INDEX(r_nbr, c_nbr);
+	    break;
+	slength++;
+	r = r_nbr;
+	c = c_nbr;
+    return slength;
+/* delete stream segment */
+int del_stream_seg(int stream_id)
+    int i, r, c, r_nbr, c_nbr;
+    unsigned int this_index;
+    int curr_stream;
+    this_index = INDEX(r, c);
+    stream[this_index] = 0;
+    curr_stream = stream_id;
+    draindir.pos = this_index;
+	    break;
+	    break;
+	/* next stream */
+	    break;
+	r = r_nbr;
+	c = c_nbr;
+	rbtree_remove(draintree, &draindir);
+    /* update tributaries */
+    if (curr_stream != stream_id) {
+	for (i = 0; i < stream_node[curr_stream].n_trib; i++) {
+	    if (stream_node[curr_stream].trib[i] == stream_id) {
+		stream_node[curr_stream].trib[i] = stream_node[curr_stream].trib[stream_node[curr_stream].n_trib - 1];
+		stream_node[curr_stream].n_trib--;
+		break;
+    return 1;
+/* update downstream id */
+int update_stream_id(int stream_id, int new_stream_id)
+    int curr_stream;
+    stream[this_index] = new_stream_id;
+	    break;
+	    break;
+	/* next stream */
+	    break;
+	r = r_nbr;
+	c = c_nbr;
+		stream_node[curr_stream].trib[i] = new_stream_id;
+		break;
+    return curr_stream;
Modified: grass-addons/raster/r.stream.extract/description.html
--- grass-addons/raster/r.stream.extract/description.html	2009-10-13 17:15:48 UTC (rev 39512)
+++ grass-addons/raster/r.stream.extract/description.html	2009-10-13 18:19:38 UTC (rev 39513)
@@ -65,6 +65,11 @@
 Larger <em>mexp</em> values decrease the number of streams in flat areas
 and increase the number of streams in steep areas. If <em>weight</em> is
 given, the weight is applied first.
+<p>
+<dt><em>stream_length</em>
+<dd>Minimum stream length in number of cells for first-order (head/spring)
+stream segments. All first-order stream segments shorter than
+<em>stream_length</em> will be deleted.
 <p>
 <dt><em>stream_rast</em>
@@ -148,4 +153,4 @@
 <h2>AUTHOR</h2>
 Markus Metz
-<p><i>Last changed: $Date: 2008-05-16 21:09:06 +0200 (Fri, 16 May 2008) $</i>
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/raster/r.stream.extract/description.html
___________________________________________________________________
Added: svn:keywords
   + Date
Modified: grass-addons/raster/r.stream.extract/do_astar.c
--- grass-addons/raster/r.stream.extract/do_astar.c	2009-10-13 17:15:48 UTC (rev 39512)
+++ grass-addons/raster/r.stream.extract/do_astar.c	2009-10-13 18:19:38 UTC (rev 39513)
@@ -50,10 +50,10 @@
 	astar_pts[first_cum] = astp;
 	first_cum--;
-	r = astp.r;
-	c = astp.c;
+	thisindex = astp.idx;
+	r = thisindex / ncols;
+	c = thisindex - r * ncols;
-	thisindex = INDEX(r, c);
 	ele_val = ele[thisindex];
 	for (ct_dir = 0; ct_dir < sides; ct_dir++) {
@@ -103,7 +103,7 @@
 int sift_up(unsigned int start, CELL elec)
-    unsigned int child, child_added, parent, nindex;
+    unsigned int child, child_added, parent;
     CELL elep;
     struct ast_point childp;
@@ -114,10 +114,8 @@
     while (child > 1) {
 	parent = get_parent(child);
-	nindex = INDEX(astar_pts[parent].r, astar_pts[parent].c);
+	elep = ele[astar_pts[parent].idx];
-	elep = ele[nindex];
 	/* child < parent */
 	if (heap_cmp(elec, child_added, elep, astar_added[parent]) == 1) {
 	    /* push parent point down */
@@ -156,8 +154,7 @@
 	G_fatal_error(_("heapsize too large"));
     astar_added[heap_size] = nxt_avail_pt;
-    astar_pts[heap_size].r = r;
-    astar_pts[heap_size].c = c;
+    astar_pts[heap_size].idx = INDEX(r, c);
     astar_pts[heap_size].asp = asp;
     nxt_avail_pt++;
@@ -188,13 +185,13 @@
     parent = 1;
     while ((child = get_child(parent)) <= heap_size) {
-	elec = ele[INDEX(astar_pts[child].r, astar_pts[child].c)];
+	elec = ele[astar_pts[child].idx];
 	if (child < heap_size) {
 	    childr = child + 1;
-	    i = child + 3;	/* change the number, GET_CHILD() and GET_PARENT() to play with different d-ary heaps */
+	    i = child + 3;
 	    while (childr <= heap_size && childr < i) {
-		eler = ele[INDEX(astar_pts[childr].r, astar_pts[childr].c)];
+		eler = ele[astar_pts[childr].idx];
 		if (heap_cmp
 		    (eler, astar_added[childr], elec,
@@ -217,7 +214,7 @@
 	astar_added[parent] = astar_added[heap_size];
 	astar_pts[parent] = astar_pts[heap_size];
-	elec = ele[INDEX(astar_pts[parent].r, astar_pts[parent].c)];
+	elec = ele[astar_pts[parent].idx];
 	/* sift up last swapped point, only necessary if hole moved to heap end */
 	sift_up(parent, elec);
Modified: grass-addons/raster/r.stream.extract/local_proto.h
--- grass-addons/raster/r.stream.extract/local_proto.h	2009-10-13 17:15:48 UTC (rev 39512)
+++ grass-addons/raster/r.stream.extract/local_proto.h	2009-10-13 18:19:38 UTC (rev 39513)
@@ -16,7 +16,7 @@
 struct ast_point
-    int r, c;
+    int idx;
     char asp;
@@ -62,12 +62,18 @@
 int do_astar(void);
 unsigned int heap_add(int, int, CELL, char);
+/* streams.c */
+int do_accum(double);
+int extract_streams(double, double, int, int);
 /* thin.c */
 int thin_streams(void);
-/* streams.c */
-int do_accum(double);
-int extract_streams(double, double, int);
+/* del_streams.c */
+int del_streams(int);
+int seg_length(int, unsigned int *);
+int del_stream_seg(int);
+int update_stream_id(int, int);
 /* close.c */
 int close_maps(char *, char *, char *);
Modified: grass-addons/raster/r.stream.extract/main.c
--- grass-addons/raster/r.stream.extract/main.c	2009-10-13 17:15:48 UTC (rev 39512)
+++ grass-addons/raster/r.stream.extract/main.c	2009-10-13 18:19:38 UTC (rev 39513)
@@ -30,6 +30,7 @@
 	struct Option *ele, *acc, *weight;
 	struct Option *threshold, *d8cut;
 	struct Option *mont_exp;
+	struct Option *min_stream_length;
     } input;
     struct
@@ -40,6 +41,7 @@
     struct GModule *module;
     int ele_fd, acc_fd, weight_fd;
     double threshold, d8cut, mont_exp;
+    int min_stream_length = 0;
     char *mapset;
     G_gisinit(argv[0]);
@@ -95,6 +97,16 @@
     input.mont_exp->description =
 	_("Montgomery: accumulation is multiplied with pow(slope,mexp) and then compared with threshold.");
+    input.min_stream_length = G_define_option();
+    input.min_stream_length->key = "stream_length";
+    input.min_stream_length->type = TYPE_INTEGER;
+    input.min_stream_length->required = NO;
+    input.min_stream_length->answer = "0";
+    input.min_stream_length->label =
+	_("Delete stream segments shorter than stream_length cells.");
+    input.min_stream_length->description =
+	_("Applies only to first-order stream segments (springs/stream heads).");
     output.stream_rast = G_define_standard_option(G_OPT_R_OUTPUT);
     output.stream_rast->key = "stream_rast";
     output.stream_rast->description =
@@ -121,7 +133,6 @@
     /*    check options    */
     /* input maps exist ? */
@@ -168,6 +179,16 @@
     else
 	mont_exp = 0;
+    /* Minimum stream segment length */
+    if (input.min_stream_length->answer) {
+	min_stream_length = atoi(input.min_stream_length->answer);
+	if (min_stream_length < 0)
+	    G_fatal_error(_("Minimum stream length must be positive or zero but is %d"),
+			  min_stream_length);
+    else
+	min_stream_length = 0;
     /* Check for some output map */
     if ((output.stream_rast->answer == NULL)
 	&& (output.stream_vect->answer == NULL)) {
@@ -176,7 +197,6 @@
     /*    preparation    */
     /* open input maps */
@@ -213,6 +233,7 @@
     /* allocate memory */
     ele = (CELL *) G_malloc(nrows * ncols * sizeof(CELL));
+    /* TODO: allocate acc and stream memory only after A* Search */
     acc = (DCELL *) G_malloc(nrows * ncols * sizeof(DCELL));
     stream = (CELL *) G_malloc(nrows * ncols * sizeof(CELL));
     if (input.weight->answer)
@@ -226,7 +247,6 @@
     /*    processing    */
     /* sort elevation and get initial stream direction */
@@ -237,16 +257,15 @@
     if (acc_fd < 0) {
 	if (do_accum(d8cut) < 0)
 	    G_fatal_error(_("could not calculate flow accumulation"));
-	if (extract_streams
-	    (threshold, mont_exp, (input.weight->answer != NULL)) < 0)
-	    G_fatal_error(_("could not extract streams"));
     else {
+	/* load accumulation */
+    if (extract_streams
+	(threshold, mont_exp, (input.weight->answer != NULL), min_stream_length) < 0)
+	G_fatal_error(_("could not extract streams"));
     G_free(ele);
     G_free(acc);
@@ -256,6 +275,12 @@
     if (thin_streams() < 0)
+    /* delete short streams */
+    if (min_stream_length) {
+	if (del_streams(min_stream_length) < 0)
     /* write output maps */
     if (close_maps(output.stream_rast->answer, output.stream_vect->answer,
 		   output.dir_rast->answer) < 0)
Modified: grass-addons/raster/r.stream.extract/streams.c
--- grass-addons/raster/r.stream.extract/streams.c	2009-10-13 17:15:48 UTC (rev 39512)
+++ grass-addons/raster/r.stream.extract/streams.c	2009-10-13 18:19:38 UTC (rev 39513)
@@ -38,8 +38,8 @@
     return result;
-int continue_stream(CELL is_swale, int r, int c, int r_max, int c_max,
-		    unsigned int thisindex, int *stream_no)
+int continue_stream(CELL stream_id, int r, int c, int r_max, int c_max,
+		    unsigned int thisindex, int *stream_no, int min_length)
     char aspect;
     int curr_stream;
@@ -68,134 +68,142 @@
     if (curr_stream <= 0) {
 	/* no confluence, just continue */
 	G_debug(2, "no confluence, just continue stream");
-	stream[INDEX(r_max, c_max)] = is_swale;
+	stream[INDEX(r_max, c_max)] = stream_id;
+	return 0;
-    else {
-	G_debug(2, "confluence");
-	/* new confluence */
-	if (stream_node[curr_stream].r != r_max ||
-	    stream_node[curr_stream].c != c_max) {
-	    G_debug(2, "new confluence");
-	    /* set new stream id */
-	    curr_stream = stream[INDEX(r_max, c_max)] = ++(*stream_no);
-	    /* add stream node */
-	    if (*stream_no >= n_alloc_nodes - 1) {
-		n_alloc_nodes += stream_node_step;
-		stream_node =
-		    (struct snode *)G_realloc(stream_node,
-					      n_alloc_nodes *
-					      sizeof(struct snode));
-	    stream_node[*stream_no].r = r_max;
-	    stream_node[*stream_no].c = c_max;
-	    stream_node[*stream_no].id = *stream_no;
-	    stream_node[*stream_no].n_trib = 0;
-	    stream_node[*stream_no].n_trib_total = 0;
-	    stream_node[*stream_no].n_alloc = 0;
-	    stream_node[*stream_no].trib = NULL;
-	    stream_node[*stream_no].acc = NULL;
-	    n_stream_nodes++;
-	    /* debug */
-	    if (n_stream_nodes != *stream_no)
-		G_warning(_("stream_no %d and n_stream_nodes %d out of sync"),
-			  *stream_no, n_stream_nodes);
+    G_debug(2, "confluence");
+    /* delete short stream segments */
+    /* if (min_length && stream_node[stream_id].n_trib == 0) {
+	if (seg_length(stream_id, NULL) < min_length) {
+	    return 0;
+    /* new confluence */
+    if (stream_node[curr_stream].r != r_max ||
+	stream_node[curr_stream].c != c_max) {
+	G_debug(2, "new confluence");
+	/* set new stream id */
+	curr_stream = stream[INDEX(r_max, c_max)] = ++(*stream_no);
+	/* add stream node */
+	if (*stream_no >= n_alloc_nodes - 1) {
+	    n_alloc_nodes += stream_node_step;
+	    stream_node =
+		(struct snode *)G_realloc(stream_node,
+					  n_alloc_nodes *
+					  sizeof(struct snode));
+	stream_node[*stream_no].r = r_max;
+	stream_node[*stream_no].c = c_max;
+	stream_node[*stream_no].id = *stream_no;
+	stream_node[*stream_no].n_trib = 0;
+	stream_node[*stream_no].n_trib_total = 0;
+	stream_node[*stream_no].n_alloc = 0;
+	stream_node[*stream_no].trib = NULL;
+	stream_node[*stream_no].acc = NULL;
+	n_stream_nodes++;
-	    /* add all tributaries */
-	    G_debug(2, "add all tributaries");
-	    for (ct_dir = 0; ct_dir < sides; ct_dir++) {
-		/* get r_nbr, c_nbr for neighbours */
-		r_nbr = r_max + nextdr[ct_dir];
-		c_nbr = c_max + nextdc[ct_dir];
-		/* check that neighbour is within region */
-		if (r_nbr >= 0 && r_nbr < nrows && c_nbr >= 0 &&
-		    c_nbr < ncols) {
-		    draindir.pos = INDEX(r_nbr, c_nbr);
-		    if ((founddir =
-			 rbtree_find(draintree, &draindir)) != NULL) {
-			if (r_nbr + asp_r[(int)founddir->dir] == r_max &&
-			    c_nbr + asp_c[(int)founddir->dir] == c_max) {
+	/* debug */
+	if (n_stream_nodes != *stream_no)
+	    G_warning(_("stream_no %d and n_stream_nodes %d out of sync"),
+		      *stream_no, n_stream_nodes);
-			    /* add tributary to stream node */
-			    if (stream_node[curr_stream].n_trib >=
-				stream_node[curr_stream].n_alloc) {
-				size_t new_size;
+	/* add all tributaries */
+	G_debug(2, "add all tributaries");
+	for (ct_dir = 0; ct_dir < sides; ct_dir++) {
+	    /* get r_nbr, c_nbr for neighbours */
+	    r_nbr = r_max + nextdr[ct_dir];
+	    c_nbr = c_max + nextdc[ct_dir];
+	    /* check that neighbour is within region */
+	    if (r_nbr >= 0 && r_nbr < nrows && c_nbr >= 0 &&
+		c_nbr < ncols) {
+		draindir.pos = INDEX(r_nbr, c_nbr);
+		if ((founddir =
+		     rbtree_find(draintree, &draindir)) != NULL) {
+		    if (r_nbr + asp_r[(int)founddir->dir] == r_max &&
+			c_nbr + asp_c[(int)founddir->dir] == c_max) {
-				stream_node[curr_stream].n_alloc += 2;
-				new_size =
-				    stream_node[curr_stream].n_alloc *
-				    sizeof(int);
-				stream_node[curr_stream].trib =
-				    (int *)G_realloc(stream_node[curr_stream].
-						     trib, new_size);
-				new_size =
-				    sizeof(double);
-				stream_node[curr_stream].acc =
-				    (double *)
-				    G_realloc(stream_node[curr_stream].acc,
-					      new_size);
+			/* add tributary to stream node */
+			if (stream_node[curr_stream].n_trib >=
+			    stream_node[curr_stream].n_alloc) {
+			    size_t new_size;
-				trib[stream_node[curr_stream].n_trib] =
-				stream[draindir.pos];
-				acc[stream_node[curr_stream].n_trib++] =
-				acc[draindir.pos];
+			    stream_node[curr_stream].n_alloc += 2;
+			    new_size =
+				stream_node[curr_stream].n_alloc *
+				sizeof(int);
+			    stream_node[curr_stream].trib =
+				(int *)G_realloc(stream_node[curr_stream].
+						 trib, new_size);
+			    new_size =
+				sizeof(double);
+			    stream_node[curr_stream].acc =
+				(double *)
+				G_realloc(stream_node[curr_stream].acc,
+					  new_size);
+			    trib[stream_node[curr_stream].n_trib] =
+			    stream[draindir.pos];
+			    acc[stream_node[curr_stream].n_trib++] =
+			    acc[draindir.pos];
-	    /* update stream IDs downstream */
-	    G_debug(2, "update stream IDs downstream");
-	    r_nbr = r_max;
-	    c_nbr = c_max;
+	/* update stream IDs downstream */
+	G_debug(2, "update stream IDs downstream");
+	r_nbr = r_max;
+	c_nbr = c_max;
+	    if (asp_r[(int)founddir->dir] == 0 &&
+		asp_c[(int)founddir->dir] == 0)
+		G_fatal_error("no valid stream direction");
+	    r_nbr = r_nbr + asp_r[(int)founddir->dir];
+	    c_nbr = c_nbr + asp_c[(int)founddir->dir];
-	    while ((founddir = rbtree_find(draintree, &draindir)) != NULL) {
-		if (asp_r[(int)founddir->dir] == 0 &&
-		    asp_c[(int)founddir->dir] == 0)
-		    G_fatal_error("no valid stream direction");
-		r_nbr = r_nbr + asp_r[(int)founddir->dir];
-		c_nbr = c_nbr + asp_c[(int)founddir->dir];
-		if (stream[INDEX(r_nbr, c_nbr)] <= 0)
-		    G_fatal_error("stream id not set");
-		else
-		    stream[INDEX(r_nbr, c_nbr)] = curr_stream;
+	    if (stream[INDEX(r_nbr, c_nbr)] <= 0)
+		G_fatal_error("stream id not set");
+	    else
+		stream[INDEX(r_nbr, c_nbr)] = curr_stream;
-	else {
-	    /* stream node already existing here */
-	    G_debug(2, "existing confluence");
-	    /* add new tributary to stream node */
-		size_t new_size;
+    else {
+	/* stream node already existing here */
+	G_debug(2, "existing confluence");
+	/* add new tributary to stream node */
+	    size_t new_size;
-		new_size = stream_node[curr_stream].n_alloc * sizeof(int);
-		    (int *)G_realloc(stream_node[curr_stream].trib, new_size);
-		new_size = stream_node[curr_stream].n_alloc * sizeof(double);
-		    (double *)G_realloc(stream_node[curr_stream].acc,
-					new_size);
-	    stream_node[curr_stream].trib[stream_node[curr_stream].n_trib++] =
-		stream[thisindex];
+	    new_size = stream_node[curr_stream].n_alloc * sizeof(int);
+		(int *)G_realloc(stream_node[curr_stream].trib, new_size);
+	    new_size = stream_node[curr_stream].n_alloc * sizeof(double);
+		(double *)G_realloc(stream_node[curr_stream].acc,
+				    new_size);
-	/* end new confluence */
-	G_debug(2, "%d tribs", stream_node[curr_stream].n_trib);
-	if (stream_node[curr_stream].n_trib == 1)
-	    G_warning("stream node %d only 1 trib: %d", curr_stream,
-		      stream_node[curr_stream].trib[0]);
+	stream_node[curr_stream].trib[stream_node[curr_stream].n_trib++] =
+	    stream[thisindex];
+    G_debug(2, "%d tribs", stream_node[curr_stream].n_trib);
+    if (stream_node[curr_stream].n_trib == 1)
+	G_warning("stream node %d only 1 trib: %d", curr_stream,
+		  stream_node[curr_stream].trib[0]);
     return 1;
@@ -252,12 +260,11 @@
     for (killer = 1; killer <= n_points; killer++) {
 	G_percent(killer, n_points, 1);
-	r = astar_pts[killer].r;
-	c = astar_pts[killer].c;
+	thisindex = astar_pts[killer].idx;
 	aspect = astar_pts[killer].asp;
 	/* do not distribute flow along edges */
 	if (aspect < 0) {
 	    G_debug(3, "edge");
@@ -422,7 +429,7 @@
  * extracts streams for threshold, accumulation is provided
-int extract_streams(double threshold, double mont_exp, int use_weight)
+int extract_streams(double threshold, double mont_exp, int use_weight, int min_length)
     int r, c, dr, dc;
     CELL is_swale, ele_val, ele_nbr;
@@ -495,12 +502,11 @@
 	if (aspect < 0) {
 	    G_debug(3, "edge");
@@ -536,11 +542,10 @@
 	value = acc[thisindex];
 	/*  find main drainage direction  */
 	max_acc = -1;
 	max_side = np_side = -1;
 	mfd_cells = 0;
@@ -609,7 +614,7 @@
 	is_swale = stream[thisindex];
-	/* do not distribute flow along edges, this causes artifacts */
+	/* do not continue streams along edges, these are artifacts */
 	if (edge) {
 	    G_debug(3, "edge");
 	    if (is_swale) {
@@ -656,7 +661,6 @@
 	/*  start new stream  */
 	/* weight map has precedence over Montgomery */
@@ -670,7 +674,6 @@
 		G_warning
 		    ("Can't use Montgomery's method, no stream direction found");
 	    else {
 		ele_nbr = ele[INDEX(r_max, c_max)];
 		slope = (double)(ele_val - ele_nbr) / ele_scale;
@@ -679,7 +682,6 @@
 		    slope /= diag;
 		value *= pow(fabs(slope), mont_exp);
@@ -713,7 +715,6 @@
 	/*  continue stream  */
 	/* can't continue stream, add outlet point */
@@ -732,7 +733,7 @@
 	else if (is_swale > 0) {
 	    continue_stream(is_swale, r, c, r_max, c_max, thisindex,
-			    &stream_no);
+			    &stream_no, min_length);
 	FLAG_SET(worked, r, c);
@@ -742,7 +743,6 @@
 		  workedon, n_points);
     flag_destroy(worked);
     G_free(dist_to_nbr);
     G_debug(1, "%d outlets", n_outlets);
Modified: grass-addons/raster/r.stream.extract/thin.c
--- grass-addons/raster/r.stream.extract/thin.c	2009-10-13 17:15:48 UTC (rev 39512)
+++ grass-addons/raster/r.stream.extract/thin.c	2009-10-13 18:19:38 UTC (rev 39513)
@@ -100,6 +100,9 @@
+	if (stream_id == 0)
+	    continue;
 	/* add root node to stack */
 	G_debug(2, "add root node");
 	top = 0;
