[GRASS-SVN] r39527 - in grass/trunk: include lib/vector
lib/vector/Vlib
svn_grass at osgeo.org
Fri Oct 16 05:40:22 EDT 2009
Author: martinl
Date: 2009-10-16 05:40:21 -0400 (Fri, 16 Oct 2009)
New Revision: 39527
grass/trunk/include/vector.h
grass/trunk/lib/vector/Vlib/open.c
grass/trunk/lib/vector/vectorlib.dox
vlib: Vect_maptype() added
Modified: grass/trunk/include/vector.h
--- grass/trunk/include/vector.h 2009-10-15 14:48:39 UTC (rev 39526)
+++ grass/trunk/include/vector.h 2009-10-16 09:40:21 UTC (rev 39527)
@@ -433,6 +433,7 @@
/* Open/close/rewind map */
int Vect_coor_info(const struct Map_info *, struct Coor_info *);
const char *Vect_maptype_info(const struct Map_info *);
+int Vect_maptype(const struct Map_info *);
int Vect_open_topo(struct Map_info *, int);
int Vect_save_topo(struct Map_info *);
int Vect_open_sidx(struct Map_info *, int);
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c 2009-10-15 14:48:39 UTC (rev 39526)
+++ grass/trunk/lib/vector/Vlib/open.c 2009-10-16 09:40:21 UTC (rev 39527)
@@ -764,14 +764,29 @@
sprintf(maptype, "ogr");
break;
default:
- sprintf(maptype, "unknown %d (update Vect_maptype_info)",
+ sprintf(maptype, _("unknown %d (update Vect_maptype_info)"),
Map->format);
return G_store(maptype);
+ \brief Gets vector map format
+ Currently are implemeted:
+ - Native format (GV_FORMAT_NATIVE)
+ - OGR format (GV_FORMAT_OGR)
+ \param Map pointer to Map_info structure
+ \return maptype code
+int Vect_maptype(const struct Map_info *Map)
+ return Map->format;
* \brief Open topology file ('topo')
Modified: grass/trunk/lib/vector/vectorlib.dox
--- grass/trunk/lib/vector/vectorlib.dox 2009-10-15 14:48:39 UTC (rev 39526)
+++ grass/trunk/lib/vector/vectorlib.dox 2009-10-16 09:40:21 UTC (rev 39527)
@@ -2238,6 +2238,8 @@
- Vect_maptype_info()
+ - Vect_maptype()
- Vect_open_new()
- Vect__open_old()
