[GRASS-SVN] r39530 - in grass/trunk: general general/g.ppmtopng
raster/r.colors
svn_grass at osgeo.org
Fri Oct 16 12:31:42 EDT 2009
Author: glynn
Date: 2009-10-16 12:31:39 -0400 (Fri, 16 Oct 2009)
New Revision: 39530
Added:
grass/trunk/general/g.ppmtopng/
grass/trunk/general/g.ppmtopng/Makefile
grass/trunk/general/g.ppmtopng/g.ppmtopng.html
grass/trunk/general/g.ppmtopng/main.c
grass/trunk/general/Makefile
grass/trunk/raster/r.colors/Makefile
grass/trunk/raster/r.colors/thumbnails.py
Add, use g.ppmtopng utility
Error creating r.colors' thumbnails shouldn't be fatal
Modified: grass/trunk/general/Makefile
--- grass/trunk/general/Makefile 2009-10-16 15:19:24 UTC (rev 39529)
+++ grass/trunk/general/Makefile 2009-10-16 16:31:39 UTC (rev 39530)
@@ -20,6 +20,7 @@
g.mremove \
g.parser \
g.pnmcomp \
+ g.ppmtopng \
g.proj \
g.region \
g.remove \
Added: grass/trunk/general/g.ppmtopng/Makefile
--- grass/trunk/general/g.ppmtopng/Makefile (rev 0)
+++ grass/trunk/general/g.ppmtopng/Makefile 2009-10-16 16:31:39 UTC (rev 39530)
@@ -0,0 +1,15 @@
+MODULE_TOPDIR = ../..
+PGM = g.ppmtopng
+LIBES = $(GISLIB) $(PNGLIB)
+DEPENDENCIES = $(GISDEP)
+EXTRA_CFLAGS=$(ZLIBINCPATH) $(PNGINC)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+ifneq ($(USE_PNG),)
+default: cmd
+endif
Added: grass/trunk/general/g.ppmtopng/g.ppmtopng.html
--- grass/trunk/general/g.ppmtopng/g.ppmtopng.html (rev 0)
+++ grass/trunk/general/g.ppmtopng/g.ppmtopng.html 2009-10-16 16:31:39 UTC (rev 39530)
@@ -0,0 +1,8 @@
+<H2>DESCRIPTION</H2>
+<p>A utility to convert between PPM/PGM and PNG image formats.</p>
+<H2>AUTHOR</H2>
+Glynn Clements
+<p><i>Last changed: $Date: 2008-08-15 07:16:42 +0100 (Fri, 15 Aug 2008) $</i>
Added: grass/trunk/general/g.ppmtopng/main.c
--- grass/trunk/general/g.ppmtopng/main.c (rev 0)
+++ grass/trunk/general/g.ppmtopng/main.c 2009-10-16 16:31:39 UTC (rev 39530)
@@ -0,0 +1,142 @@
+ * MODULE: g.ppmtopng
+ * AUTHOR(S): Glynn Clements
+ * PURPOSE: g.ppmtopng isn't meant for end users. It's an internal tool for use by
+ * the script to generate thumbnails for the r.colors manual page.
+ * COPYRIGHT: (C) 2009 by Glynn Clements and the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <stdarg.h>
+#include <string.h>
+#include <png.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+static int width, height;
+static unsigned char *buf;
+static void read_ppm(const char *filename)
+ FILE *input;
+ int x, y;
+ int maxval;
+ unsigned char *p;
+ input = fopen(filename, "rb");
+ if (!input)
+ G_fatal_error(_("unable to open input file %s"), filename);
+ if (fscanf(input, "P6 %d %d %d", &width, &height, &maxval) != 3)
+ G_fatal_error(_("invalid input file %s"), filename);
+ fgetc(input);
+ buf = G_malloc(width * height * 3);
+ p = buf;
+ for (y = 0; y < height; y++) {
+ for (x = 0; x < width; x++) {
+ int r = fgetc(input);
+ int g = fgetc(input);
+ int b = fgetc(input);
+ *p++ = (unsigned char) (r * 255 / maxval);
+ *p++ = (unsigned char) (g * 255 / maxval);
+ *p++ = (unsigned char) (b * 255 / maxval);
+ fclose(input);
+static void write_png(const char *filename)
+ static jmp_buf jbuf;
+ static png_struct *png_ptr;
+ static png_info *info_ptr;
+ FILE *output;
+ int y;
+ unsigned char *p;
+ png_ptr = png_create_write_struct(PNG_LIBPNG_VER_STRING, &jbuf, NULL, NULL);
+ if (!png_ptr)
+ G_fatal_error(_("unable to allocate PNG structure"));
+ info_ptr = png_create_info_struct(png_ptr);
+ if (!info_ptr)
+ if (setjmp(png_jmpbuf(png_ptr)))
+ G_fatal_error(_("error writing PNG file"));
+ output = fopen(filename, "wb");
+ if (!output)
+ G_fatal_error(_("unable to open output file %s"), filename);
+ png_init_io(png_ptr, output);
+ png_set_IHDR(png_ptr, info_ptr,
+ width, height,
+ 8, PNG_COLOR_TYPE_RGB,
+ PNG_INTERLACE_NONE,
+ PNG_COMPRESSION_TYPE_DEFAULT,
+ PNG_FILTER_TYPE_DEFAULT);
+ png_set_invert_alpha(png_ptr);
+ png_write_info(png_ptr, info_ptr);
+ for (y = 0, p = buf; y < height; y++, p += 3 * width)
+ png_write_row(png_ptr, p);
+ png_write_end(png_ptr, info_ptr);
+ png_destroy_write_struct(&png_ptr, &info_ptr);
+ fclose(output);
+int main(int argc, char *argv[])
+ struct GModule *module;
+ struct
+ struct Option *in, *out;
+ } opt;
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ G_add_keyword(_("general"));
+ module->description = "Converts between PPM/PGM and PNG image formats";
+ opt.in = G_define_option();
+ opt.in->key = "input";
+ opt.in->type = TYPE_STRING;
+ opt.in->required = YES;
+ opt.in->multiple = YES;
+ opt.in->description = _("Name of input file");
+ opt.in->gisprompt = "old_file,file,input";
+ opt.out = G_define_option();
+ opt.out->key = "output";
+ opt.out->type = TYPE_STRING;
+ opt.out->required = YES;
+ opt.out->description = _("Name of output file");
+ opt.out->gisprompt = "new_file,file,output";
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ read_ppm(opt.in->answer);
+ write_png(opt.out->answer);
+ return 0;
Modified: grass/trunk/raster/r.colors/Makefile
--- grass/trunk/raster/r.colors/Makefile 2009-10-16 15:19:24 UTC (rev 39529)
+++ grass/trunk/raster/r.colors/Makefile 2009-10-16 16:31:39 UTC (rev 39530)
@@ -17,7 +17,7 @@
$(MAKE) thumbnails
thumbnails: $(BIN)/r.mapcalc$(EXE)
- $(call run_grass, ./thumbnails.py)
+ -$(call run_grass, ./thumbnails.py)
$(BIN)/r.mapcalc$(EXE):
$(MAKE) -C ../r.mapcalc
Modified: grass/trunk/raster/r.colors/thumbnails.py
--- grass/trunk/raster/r.colors/thumbnails.py 2009-10-16 15:19:24 UTC (rev 39529)
+++ grass/trunk/raster/r.colors/thumbnails.py 2009-10-16 16:31:39 UTC (rev 39530)
@@ -63,21 +63,23 @@
return dstd
def ppmtopng(dst, src):
- fh = open(dst, 'wb')
- grass.call(["pnmtopng", tmp_img], stdout = fh)
- fh.close()
-def convert_and_rotate(src, dst):
- if grass.find_program("convert"):
- grass.call(["convert", "-rotate", "90", src, dst])
+ if grass.find_program("g.ppmtopng"):
+ grass.run_command('g.ppmtopng', input = src, output = dst)
elif grass.find_program("pnmtopng"):
- srcd = read_ppm(src)
- dstd = rotate_ppm(srcd)
- write_ppm(tmp_img, dstd)
- ppmtopng(dst, tmp_img)
+ fh = open(dst, 'wb')
+ grass.call(["pnmtopng", src], stdout = fh)
+ fh.close()
+ elif grass.find_program("convert"):
+ grass.call(["convert", src, dst])
else:
- grass.fatal(_("Cannot find either convert or pnmtopng"))
+ grass.fatal(_("Cannot find g.ppmtopng, pnmtopng or convert"))
+def convert_and_rotate(src, dst):
+ srcd = read_ppm(src)
+ dstd = rotate_ppm(srcd)
+ write_ppm(tmp_img, dstd)
+ ppmtopng(dst, tmp_img)
def main():
global tmp_img, tmp_grad_abs, tmp_grad_rel
