[GRASS-SVN] r39533 - in grass/trunk: include lib/gis lib/vector/Vlib
svn_grass at osgeo.org
Fri Oct 16 17:15:25 EDT 2009
Author: martinl
Date: 2009-10-16 17:15:24 -0400 (Fri, 16 Oct 2009)
New Revision: 39533
grass/trunk/include/vector.h
grass/trunk/lib/gis/find_file.c
grass/trunk/lib/vector/Vlib/close.c
grass/trunk/lib/vector/Vlib/field.c
grass/trunk/lib/vector/Vlib/open.c
* direct OGR read access: switch to level 2 when pseudo-topology is
built successfully
* Vect_get_field2() added
Modified: grass/trunk/include/vector.h
--- grass/trunk/include/vector.h 2009-10-16 18:56:18 UTC (rev 39532)
+++ grass/trunk/include/vector.h 2009-10-16 21:15:24 UTC (rev 39533)
@@ -111,6 +111,7 @@
struct field_info *Vect_get_dblink(const struct Map_info *, int);
struct field_info *Vect_get_field(const struct Map_info *, int);
struct field_info *Vect_get_field_by_name(const struct Map_info *, const char *);
+struct field_info *Vect_get_field2(const struct Map_info *, const char *);
void Vect_set_db_updated(struct Map_info *);
const char *Vect_get_column_names(const struct Map_info *, int);
const char *Vect_get_column_types(const struct Map_info *, int);
Modified: grass/trunk/lib/gis/find_file.c
--- grass/trunk/lib/gis/find_file.c 2009-10-16 18:56:18 UTC (rev 39532)
+++ grass/trunk/lib/gis/find_file.c 2009-10-16 21:15:24 UTC (rev 39533)
@@ -45,6 +45,12 @@
pmapset = mapset;
+ if (strcmp(element, "vector") == 0 &&
+ strcasecmp(pmapset, "ogr") == 0) {
+ /* don't check for virtual OGR mapset */
+ return G_store(pmapset);
* reject illegal names and mapsets
Modified: grass/trunk/lib/vector/Vlib/close.c
--- grass/trunk/lib/vector/Vlib/close.c 2009-10-16 18:56:18 UTC (rev 39532)
+++ grass/trunk/lib/vector/Vlib/close.c 2009-10-16 21:15:24 UTC (rev 39533)
@@ -105,7 +105,9 @@
else {
/* spatial index must also be closed when opened with topo but not modified */
- if (Map->plus.Spidx_built == 1 && Map->plus.built == GV_BUILD_ALL)
+ if (Map->format == GV_FORMAT_NATIVE &&
+ Map->plus.Spidx_built == 1 &&
+ Map->plus.built == GV_BUILD_ALL)
Vect_save_sidx(Map);
Modified: grass/trunk/lib/vector/Vlib/field.c
--- grass/trunk/lib/vector/Vlib/field.c 2009-10-16 18:56:18 UTC (rev 39532)
+++ grass/trunk/lib/vector/Vlib/field.c 2009-10-16 21:15:24 UTC (rev 39533)
@@ -447,6 +447,27 @@
+ \brief Get information about link to database (by layer name or layer number)
+ \param Map pointer to Map_info structure
+ \param field layer name or number
+ \return pointer to new field_info structure
+ \return NULL if not found
+struct field_info *Vect_get_field2(const struct Map_info *Map, const char *field)
+ struct field_info *fi = NULL;
+ G_debug(1, "Vect_get_field2(): field = %s", field);
+ fi = Vect_get_field_by_name(Map, field);
+ if (fi)
+ return fi;
+ return Vect_get_field(Map, atoi(field));
\brief Read dblinks to existing structure.
Variables are not substituted by values.
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c 2009-10-16 18:56:18 UTC (rev 39532)
+++ grass/trunk/lib/vector/Vlib/open.c 2009-10-16 21:15:24 UTC (rev 39533)
@@ -334,12 +334,8 @@
#endif
if (level_request == 2 && level < 2) {
- if (ogr_mapset) {
- G_warning(_("Topology level (2) is not supported when reading "
- "OGR layers directly. For topology level "
- "is required link to OGR layer via v.external command."));
- else {
+ if (!ogr_mapset) {
+ /* for direct OGR read access is built pseudo-topology on the fly */
sprintf(errmsg,
_("Unable to open vector map <%s> on level %d. "
"Try to rebuild vector topology by v.build."),
@@ -376,6 +372,7 @@
Map->fInfo.ogr.layer_name, Map->fInfo.ogr.dsn);
G_set_verbose(0);
Vect_build(Map);
+ level = 2;
G_set_verbose(verbose);
@@ -418,8 +415,7 @@
/* read db links */
Map->dblnk = Vect_new_dblinks_struct();
- if (!ogr_mapset)
- Vect_read_dblinks(Map);
+ Vect_read_dblinks(Map);
/* open history file */
sprintf(buf, "%s/%s", GV_DIRECTORY, Map->name);
