[GRASS-SVN] r39535 - grass-addons/raster/r.out.kml
svn_grass at osgeo.org
Fri Oct 16 23:32:12 EDT 2009
Author: hamish
Date: 2009-10-16 23:32:12 -0400 (Fri, 16 Oct 2009)
New Revision: 39535
grass-addons/raster/r.out.kml/r.out.kml
conv angle comment
Modified: grass-addons/raster/r.out.kml/r.out.kml
--- grass-addons/raster/r.out.kml/r.out.kml 2009-10-17 03:26:15 UTC (rev 39534)
+++ grass-addons/raster/r.out.kml/r.out.kml 2009-10-17 03:32:12 UTC (rev 39535)
@@ -106,12 +106,13 @@
if [ "$IS_LL_WGS84" = "false" ] ; then
# check convergence angle is less than (arbitrary) 1px per 1280x1024 (~= 0.09 degrees)
- eval `g.region -gn`
- CONV_ANGLE_3INT=`echo $converge_angle | sed -e 's/\.//' | cut -b 1-3`
- if [ "$CONV_ANGLE_3INT" -gt 009 ] ; then
+ # also test conv angle at 4 corners? (world wide scale image might be ok at 0,0 center, but horrible elsewhere)
+ eval `g.region -gn`
+ CONV_ANGLE_3INT=`echo $converge_angle | sed -e 's/\.//' | cut -b 1-3`
+ if [ "$CONV_ANGLE_3INT" -gt 009 ] ; then
g.message -e "Convergence angle too great for undistorted output, reproject first. ($converge_angle degrees)"
exit 1
- fi
+ fi
fi
