[GRASS-SVN] r39538 - grass/trunk/vector/v.db.connect
svn_grass at osgeo.org
Sat Oct 17 06:22:24 EDT 2009
Author: martinl
Date: 2009-10-17 06:22:23 -0400 (Sat, 17 Oct 2009)
New Revision: 39538
grass/trunk/vector/v.db.connect/main.c
v.db.connect: initial support for OGR (-p/-g)
Modified: grass/trunk/vector/v.db.connect/main.c
--- grass/trunk/vector/v.db.connect/main.c 2009-10-17 10:10:36 UTC (rev 39537)
+++ grass/trunk/vector/v.db.connect/main.c 2009-10-17 10:22:23 UTC (rev 39538)
@@ -7,7 +7,7 @@
* PURPOSE: sets/prints DB connection for a given vector map
- * COPYRIGHT: (C) 2002-2008 by the GRASS Development Team
+ * COPYRIGHT: (C) 2002-2009 by the GRASS Development Team
* This program is free software under the
* GNU General Public License (>=v2).
@@ -138,8 +138,10 @@
if (print->answer && shell_print->answer)
G_fatal_error(_("Please choose only one print style"));
- if (print->answer || shell_print->answer || columns->answer)
- Vect_open_old(&Map, inopt->answer, "");
+ if (print->answer || shell_print->answer || columns->answer) {
+ Vect_set_open_level(1); /* no topology needed */
+ Vect_open_old2(&Map, inopt->answer, "", field_opt->answer);
else {
if (Vect_open_update_head(&Map, inopt->answer, G_mapset()) < 1)
G_fatal_error(_("Unable to modify vector map stored in other mapset"));
@@ -196,8 +198,8 @@
else { /* columns */
if ((fi = Vect_get_field(&Map, field)) == NULL)
- G_fatal_error(_("Database connection not defined for layer %d"),
- field);
+ G_fatal_error(_("Database connection not defined for layer <%s>"),
+ field_opt->answer);
driver = db_start_driver(fi->driver);
if (driver == NULL)
G_fatal_error(_("Unable to start driver <%s>"),
