[GRASS-SVN] r39547 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sat Oct 17 12:31:03 EDT 2009
Author: martinl
Date: 2009-10-17 12:31:02 -0400 (Sat, 17 Oct 2009)
New Revision: 39547
grass/trunk/lib/vector/Vlib/build.c
grass/trunk/lib/vector/Vlib/close.c
grass/trunk/lib/vector/Vlib/field.c
grass/trunk/lib/vector/Vlib/open.c
grass/trunk/lib/vector/Vlib/read.c
grass/trunk/lib/vector/Vlib/rewind.c
support GV_FORMAT_OGR_DIRECT
Modified: grass/trunk/lib/vector/Vlib/build.c
--- grass/trunk/lib/vector/Vlib/build.c 2009-10-17 15:30:32 UTC (rev 39546)
+++ grass/trunk/lib/vector/Vlib/build.c 2009-10-17 16:31:02 UTC (rev 39547)
@@ -37,8 +37,10 @@
Vect_build_nat
#ifdef HAVE_OGR
, Vect_build_ogr
+ , Vect_build_ogr
#else
, format
+ , format
#endif
Modified: grass/trunk/lib/vector/Vlib/close.c
--- grass/trunk/lib/vector/Vlib/close.c 2009-10-17 15:30:32 UTC (rev 39546)
+++ grass/trunk/lib/vector/Vlib/close.c 2009-10-17 16:31:02 UTC (rev 39547)
@@ -43,9 +43,13 @@
#ifdef HAVE_OGR
clo_dummy, V1_close_ogr}
+ clo_dummy, V1_close_ogr}
#else
clo_dummy, format}
+ clo_dummy, format}
#endif
Modified: grass/trunk/lib/vector/Vlib/field.c
--- grass/trunk/lib/vector/Vlib/field.c 2009-10-17 15:30:32 UTC (rev 39546)
+++ grass/trunk/lib/vector/Vlib/field.c 2009-10-17 16:31:02 UTC (rev 39547)
@@ -503,7 +503,7 @@
Vect_reset_dblinks(dbl);
G_debug(3, "Searching for FID column in OGR DB");
- if (Map->format == GV_FORMAT_OGR) {
+ if (Map->format & (GV_FORMAT_OGR | GV_FORMAT_OGR_DIRECT)) {
#ifndef HAVE_GDAL
G_fatal_error(_("The support for OGR vector maps wasn't"
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c 2009-10-17 15:30:32 UTC (rev 39546)
+++ grass/trunk/lib/vector/Vlib/open.c 2009-10-17 16:31:02 UTC (rev 39547)
@@ -53,9 +53,13 @@
#ifdef HAVE_OGR
open_old_dummy, V1_open_old_ogr}
+ open_old_dummy, V1_open_old_ogr}
#else
open_old_dummy, format}
+ open_old_dummy, format}
#endif
Modified: grass/trunk/lib/vector/Vlib/read.c
--- grass/trunk/lib/vector/Vlib/read.c 2009-10-17 15:30:32 UTC (rev 39546)
+++ grass/trunk/lib/vector/Vlib/read.c 2009-10-17 16:31:02 UTC (rev 39547)
@@ -38,9 +38,13 @@
#ifdef HAVE_OGR
read_next_dummy, V1_read_next_line_ogr, V2_read_next_line_ogr}
+ read_next_dummy, V1_read_next_line_ogr, V2_read_next_line_ogr}
#else
read_next_dummy, format, format}
+ read_next_dummy, format, format}
#endif
Modified: grass/trunk/lib/vector/Vlib/rewind.c
--- grass/trunk/lib/vector/Vlib/rewind.c 2009-10-17 15:30:32 UTC (rev 39546)
+++ grass/trunk/lib/vector/Vlib/rewind.c 2009-10-17 16:31:02 UTC (rev 39547)
@@ -41,9 +41,13 @@
#ifdef HAVE_OGR
rew_dummy, V1_rewind_ogr, V2_rewind_ogr}
+ rew_dummy, V1_rewind_ogr, V2_rewind_ogr}
#else
rew_dummy, format, format}
+ rew_dummy, format, format}
#endif
