[GRASS-SVN] r39567 - grass/trunk/lib/db/dbmi_base
svn_grass at osgeo.org
Sun Oct 18 14:29:19 EDT 2009
Author: martinl
Date: 2009-10-18 14:29:16 -0400 (Sun, 18 Oct 2009)
New Revision: 39567
grass/trunk/lib/db/dbmi_base/dbmscap.c
dbmscap.c: initial doxygen strings
Modified: grass/trunk/lib/db/dbmi_base/dbmscap.c
--- grass/trunk/lib/db/dbmi_base/dbmscap.c 2009-10-18 18:03:58 UTC (rev 39566)
+++ grass/trunk/lib/db/dbmi_base/dbmscap.c 2009-10-18 18:29:16 UTC (rev 39567)
@@ -1,3 +1,17 @@
+ \file db/dbmi_base/dbmscap.c
+ \brief DBMI Library (base) - DBmscap management
+ (C) 1999-2009 by the GRASS Development Team
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+ \author Joel Jones (CERL/UIUC), Radim Blazek
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
@@ -17,7 +31,7 @@
static void add_entry();
-static char *dbmscap_filename(err_flag)
+static char *dbmscap_filename(int err_flag)
char *file;
int i;
@@ -37,33 +51,32 @@
- \fn
- \brief
- \return
- \param
+ \brief Get dbmscap file name
+ \return pointer to string with file name
const char *db_dbmscap_filename(void)
return dbmscap_filename(1);
- \fn
- \brief
- \return
- \param
+ \brief Check dbms
+ \return 1 if true
+ \return 0 if false
int db_has_dbms(void)
return (dbmscap_filename(0) != NULL);
- \fn
- \brief
- \return
- \param
+ \brief Copy dbmscap entry
+ \param dst destination
+ \param src source
void db_copy_dbmscap_entry(dbDbmscap * dst, dbDbmscap * src)
strcpy(dst->driverName, src->driverName);
@@ -72,18 +85,17 @@
- \fn
- \brief
- \return
- \param
-/* dbmscap file was used in grass5.0 but it is not used in
- * grass5.7 until we find it necessary. All code for dbmscap
- * file is commented here.
- * Instead of in dbmscap file db_read_dbmscap() searches
- * for available dbmi drivers in $(GISBASE)/driver/db/ */
+ \brief Read dbmscap
+ dbmscap file was used in grass5.0 but it is not used in
+ grass5.7 until we find it necessary. All code for dbmscap
+ file is commented here.
+ Instead of in dbmscap file db_read_dbmscap() searches
+ for available dbmi drivers in $(GISBASE)/driver/db/
+ \return pointer to dbDbmscap
dbDbmscap *db_read_dbmscap(void)
@@ -221,11 +233,10 @@
- \fn
- \brief
- \return
- \param
+ \brief Free dbmscap
+ \param list pointer to dbDbmscap
void db_free_dbmscap(dbDbmscap * list)
dbDbmscap *next, *cur;
