[GRASS-SVN] r39574 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Oct 19 00:00:39 EDT 2009
Author: cmbarton
Date: 2009-10-19 00:00:38 -0400 (Mon, 19 Oct 2009)
New Revision: 39574
grass/trunk/gui/wxpython/gui_modules/location_wizard.py
Backport from develbranch_6 r39568. Interface enhancements to location wizard.
Modified: grass/trunk/gui/wxpython/gui_modules/location_wizard.py
--- grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2009-10-19 03:59:06 UTC (rev 39573)
+++ grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2009-10-19 04:00:38 UTC (rev 39574)
@@ -698,6 +698,12 @@
style = wx.RB_GROUP)
self.radio2 = wx.RadioButton(parent=self, id=wx.ID_ANY,
label=_("Ellipsoid only"))
+ # default button setting
+ if self.radio1.GetValue() == False and self.radio2.GetValue() == False:
+ self.radio1.SetValue(True)
+ self.SetNext(self.parent.datumpage)
+# self.parent.sumpage.SetPrev(self.parent.datumpage)
radioSBSizer.Add(item=self.radio1,
flag=wx.ALIGN_LEFT | wx.RIGHT, border=20)
@@ -798,6 +804,7 @@
self.Bind(wx.EVT_TEXT, self.OnParamEntry)
if paramgrp[1] == 'noask':
self.pentry[num].SetEditable(False)
+ self.pentry[num].SetBackgroundColour(wx.LIGHT_GREY)
self.prjparamsizer.Add(item=label, pos=(num, 1),
flag=wx.ALIGN_RIGHT | wx.RIGHT, border=5)
@@ -817,7 +824,6 @@
event.Skip()
def SetVal(self, event):
- global coordsys
if event.GetId() == self.radio1.GetId():
@@ -861,7 +867,7 @@
data.append([key, self.parent.datums[key][0], self.parent.datums[key][1]])
self.datumlist = ItemList(self,
data=data,
- columns=[_('Code'), _('Description'), _('Ellipsoid')])
+ columns=[_('Code'), _('Ellipsoid'), _('Description')])
self.datumlist.resizeLastColumn(10)
# layout
@@ -953,8 +959,8 @@
if len(self.datum) == 0 or self.datum not in self.parent.datums:
nextButton.Enable(False)
else:
- self.datumdesc = self.parent.datums[self.datum][0]
- self.ellipsoid = self.parent.datums[self.datum][1]
+ self.ellipsoid = self.parent.datums[self.datum][0]
+ self.datumdesc = self.parent.datums[self.datum][1]
self.datumparams = self.parent.datums[self.datum][2]
for p in self.datumparams:
if p in ['dx=0.0','dy=0.0','dz=0.0']: self.datumparams.remove(p)
@@ -966,7 +972,7 @@
def OnDSearch(self, event):
str = self.searchb.GetValue()
try:
- self.datum, self.datumdesc, self.ellipsoid = self.datumlist.Search(index=[0,1,2], pattern=str)
+ self.datum, self.ellipsoid, self.datumdesc = self.datumlist.Search(index=[0,1,2], pattern=str)
except:
self.datum = self.datumdesc = self.ellipsoid = ''
@@ -1270,12 +1276,6 @@
style=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL)
self.lcode= self.MakeLabel(_("EPSG code:"),
- self.lsearch = self.MakeLabel(_("Search in"),
- style=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL)
- self.csearch = wx.Choice(parent = self, id = wx.ID_ANY,
- choices = [_("codes"), _("description"), _("parameters")])
- self.csearch.SetStringSelection(_("description"))
# text input
epsgdir = utils.PathJoin(os.environ["GRASS_PROJSHARE"], 'epsg')
self.tfile = self.MakeTextCtrl(text=epsgdir, size=(200,-1))
@@ -1283,7 +1283,7 @@
# buttons
self.bbrowse = self.MakeButton(_("Browse"))
- self.bbcodes = self.MakeButton(_("Reload EPSG Codes"))
+# self.bbcodes = self.MakeButton(_("Reload EPSG Codes"))
# search box
self.searchb = wx.SearchCtrl(self, size=(200,-1),
@@ -1306,7 +1306,6 @@
wx.ALIGN_CENTER_VERTICAL |
wx.ALL, border=5, pos=(1, 4))
self.sizer.Add(item=self.lcode,
@@ -1315,23 +1314,14 @@
wx.ALL, border=5, pos=(2, 3))
- self.sizer.Add(item=self.lsearch,
- flag=wx.ALIGN_LEFT |
- wx.ALIGN_CENTER_VERTICAL |
- wx.ALL, border=5, pos=(3, 1))
- self.sizer.Add(item=self.csearch,
- wx.ALL, border=5, pos=(3, 2))
self.sizer.Add(item=self.searchb,
wx.ALL, border=5, pos=(3, 3))
- self.sizer.Add(item=self.bbcodes,
- wx.ALL, border=5, pos=(3, 4))
+# self.sizer.Add(item=self.bbcodes,
+# flag=wx.ALIGN_LEFT |
+# wx.ALIGN_CENTER_VERTICAL |
+# wx.ALL, border=5, pos=(3, 4))
self.sizer.AddGrowableRow(4)
self.sizer.Add(item=self.epsglist,
@@ -1340,7 +1330,7 @@
# events
self.bbrowse.Bind(wx.EVT_BUTTON, self.OnBrowse)
- self.bbcodes.Bind(wx.EVT_BUTTON, self.OnBrowseCodes)
+# self.bbcodes.Bind(wx.EVT_BUTTON, self.OnBrowseCodes)
self.tcode.Bind(wx.EVT_TEXT, self.OnText)
self.tcode.Bind(wx.EVT_TEXT_ENTER, self.OnText)
self.epsglist.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemSelected)
@@ -1415,18 +1405,24 @@
def OnSearch(self, event):
value = self.searchb.GetValue()
- if self.epsglist.GetItemCount() == 0:
- event.Skip()
- return
- try:
- self.epsgcode = self.epsglist.Search(index=[self.csearch.GetSelection()],
- pattern=value)[0]
- except IndexError: # -> no item found
+ if value == '':
self.epsgcode = None
+ self.epsgdesc = self.epsgparams = ''
self.tcode.SetValue('')
self.searchb.SetValue('')
+ self.OnBrowseCodes(None)
+ else:
+ try:
+ self.epsgcode, self.epsgdesc, self.epsgparams = \
+ self.epsglist.Search(index=[0,1,2], pattern=value)
+ except IndexError: # -> no item found
+ self.epsgcode = None
+ self.tcode.SetValue('')
+ self.searchb.SetValue('')
event.Skip()
def OnBrowse(self, event):
@@ -1887,7 +1883,7 @@
datumdesc = datumdesc.strip('"')
paramlist = params.split()
ellipsoid = paramlist.pop(0)
- self.datums[datum] = (datumdesc.replace('_', ' '), ellipsoid, paramlist)
+ self.datums[datum] = (ellipsoid, datumdesc.replace('_', ' '), paramlist)
f.close()
# read ellipsiod definitions
@@ -2693,9 +2689,11 @@
bodyBox = wx.StaticBox(parent=panel, id=wx.ID_ANY,
label=" %s " % _("Select from list of datum transformations"))
- bodySizer = wx.StaticBoxSizer(bodyBox)
+ bodySizer = wx.StaticBoxSizer(bodyBox)
+ # add no transform option
+ transforms = '---\n\n0\nDo not apply any datum transformations\n\n' + transforms
transformlist = transforms.split('---')
tlistlen = len(transformlist)
@@ -2751,9 +2749,12 @@
def ClickTrans(self, event):
"""!Get the number of the datum transform to use in g.proj"""
self.transnum = event.GetSelection()
+ self.transnum = self.transnum - 1
def GetTransform(self):
+ """!Get the number of the datum transform to use in g.proj"""
self.transnum = self.translist.GetSelection()
return self.transnum
if __name__ == "__main__":
