[GRASS-SVN] r39580 - grass/trunk/vector/v.out.ogr
svn_grass at osgeo.org
Mon Oct 19 04:55:33 EDT 2009
Author: martinl
Date: 2009-10-19 04:55:31 -0400 (Mon, 19 Oct 2009)
New Revision: 39580
grass/trunk/vector/v.out.ogr/main.c
v.out.ogr: --o adds OVERWRITE=YES to lcos
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c 2009-10-19 08:44:44 UTC (rev 39579)
+++ grass/trunk/vector/v.out.ogr/main.c 2009-10-19 08:55:31 UTC (rev 39580)
@@ -287,9 +287,16 @@
options.dsn->answer);
/* check if OGR layer exists */
- if (!G_check_overwrite(argc, argv) && OGR_DS_GetLayerByName(Ogr_ds, options.layer->answer)) {
- G_fatal_error(_("OGR layer <%s> already exists in '%s'"),
- options.layer->answer, options.dsn->answer);
+ if (OGR_DS_GetLayerByName(Ogr_ds, options.layer->answer)) {
+ if (!G_check_overwrite(argc, argv)) {
+ G_fatal_error(_("OGR layer <%s> already exists in '%s'"),
+ options.layer->answer, options.dsn->answer);
+ else {
+ G_warning(_("OGR layer <%s> already exists and will be overwritten"),
+ options.layer->answer);
+ papszLCO = CSLSetNameValue(papszLCO, "OVERWRITE", "YES");
/* check if the map is 3d */
