[GRASS-SVN] r39589 - grass/trunk/gui/wxpython/gui_modules
Mon Oct 19 19:27:31 EDT 2009
Author: martinl
Date: 2009-10-19 19:27:31 -0400 (Mon, 19 Oct 2009)
New Revision: 39589
   grass/trunk/gui/wxpython/gui_modules/dbm.py
   grass/trunk/gui/wxpython/gui_modules/gdialogs.py
wxGUI/dbm: fix extract selected features
	   (merge r39588 from devbr6)
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py	2009-10-19 23:24:44 UTC (rev 39588)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py	2009-10-19 23:27:31 UTC (rev 39589)
@@ -1931,7 +1931,7 @@
         event.Skip()
     def OnExtractSelected(self, event):
         Extract vector objects selected in attribute browse window
         to new vector map
@@ -1945,12 +1945,21 @@
             return
         else:
             # dialog to get file name
-            gdialogs.CreateNewVector(parent = self, title = _('Extract selected features'),
-                                     log = self.cmdLog,
-                                     cmd = (('v.extract',
-                                             { 'input' : self.vectorName,
-                                               'list' : utils.ListOfCatsToRange(cats) },
-                                             'output')))
+            name, add = gdialogs.CreateNewVector(parent = self, title = _('Extract selected features'),
+                                                 log = self.cmdLog,
+                                                 cmd = (('v.extract',
+                                                         { 'input' : self.vectorName,
+                                                           'list' : utils.ListOfCatsToRange(cats) },
+                                                         'output')),
+                                                 disableTable = True)
+            if name and add:
+                # add layer to map layer tree
+                self.parent.curr_page.maptree.AddLayer(ltype='vector',
+                                                       lname=name,
+                                                       lchecked=True,
+                                                       lopacity=1.0,
+                                                       lcmd=['d.vect', 'map=%s' % name])
     def OnDeleteSelected(self, event):
         Delete vector objects selected in attribute browse window
Modified: grass/trunk/gui/wxpython/gui_modules/gdialogs.py
--- grass/trunk/gui/wxpython/gui_modules/gdialogs.py	2009-10-19 23:24:44 UTC (rev 39588)
+++ grass/trunk/gui/wxpython/gui_modules/gdialogs.py	2009-10-19 23:27:31 UTC (rev 39589)
@@ -183,7 +183,7 @@
 class NewVectorDialog(ElementDialog):
     """!Dialog for creating new vector map"""
-    def __init__(self, parent, id, title, disableAdd=False,
+    def __init__(self, parent, id, title, disableAdd=False, disableTable=False,
                  style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
         ElementDialog.__init__(self, parent, title, label = _("Name for new vector map:"))
@@ -194,6 +194,8 @@
         self.table = wx.CheckBox(parent = self.panel, id = wx.ID_ANY,
                                  label = _("Create attribute table"))
         self.table.SetValue(True)
+        if disableTable:
+            self.table.Enable(False)
         self.addbox = wx.CheckBox(parent = self.panel,
                                   label = _('Add created map into layer tree'), style = wx.NO_BORDER)
@@ -233,7 +235,7 @@
         return self.GetElement().split('@', 1)[0]
 def CreateNewVector(parent, cmd, title=_('Create new vector map'),
-                    exceptMap=None, log=None, disableAdd=False):
+                    exceptMap=None, log=None, disableAdd=False, disableTable=False):
     """!Create new vector map layer
     @cmd cmd (prog, **kwargs)
@@ -242,7 +244,7 @@
     @return None of failure
     dlg = NewVectorDialog(parent, wx.ID_ANY, title,
-                          disableAdd)
+                          disableAdd, disableTable)
     if dlg.ShowModal() == wx.ID_OK:
         outmap = dlg.GetName()
         if outmap == exceptMap:
@@ -290,7 +292,7 @@
         # create attribute table
-        if dlg.table.IsChecked():
+        if dlg.table.IsEnabled() and dlg.table.IsChecked():
             key = UserSettings.Get(group='atm', key='keycolumn', subkey='value')
             sql = 'CREATE TABLE %s (%s INTEGER)' % (outmap, key)
