[GRASS-SVN] r39592 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Oct 20 00:52:50 EDT 2009
Author: cmbarton
Date: 2009-10-20 00:52:50 -0400 (Tue, 20 Oct 2009)
New Revision: 39592
grass/trunk/gui/wxpython/gui_modules/location_wizard.py
Backport from develbranch_6 r39591 . Make zone entry a spinctrl and change boolean reply to Yes/No
Modified: grass/trunk/gui/wxpython/gui_modules/location_wizard.py
--- grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2009-10-20 04:49:50 UTC (rev 39591)
+++ grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2009-10-20 04:52:50 UTC (rev 39592)
@@ -719,14 +719,30 @@
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
def OnParamEntry(self, event):
- self.pval[event.GetId() - 2000] = event.GetString()
+ num = 0
+ # deal with weird spin control text event behavior, sending dup. event with negative number
+ if event.GetId() >= 2000:
+ num = event.GetId() - 2000
+ else:
+ pass
+ val = event.GetString()
+ if self.ptype[num] == 'zone':
+ if val.isdigit():
+ if int(val) < 0: self.pentry[num].SetValue(0)
+ if int(val) > 60: self.pentry[num].SetValue(60)
+ else:
+ self.pentry[num].SetValue(0)
+ self.pval[num] = val
+ event.Skip()
def OnPageChange(self,event=None):
if event.GetDirection():
self.p4projparams = ''
for num in range(self.pcount + 1):
if self.ptype[num] == 'bool':
- if self.pval[num] == 'N':
+ if self.pval[num] == 'No':
continue
else:
self.p4projparams += (' +' + self.proj4param[num])
@@ -781,25 +797,27 @@
self.pdesc[num] = self.parent.paramdesc[paramgrp[0]][2]
# default values
- if self.ptype[num] == 'bool': self.pval[num] = 'N'
- elif self.ptype[num] == 'zone': self.pval[num] = '30'
+ if self.ptype[num] == 'bool': self.pval[num] = 'No'
+ elif self.ptype[num] == 'zone':
+ self.pval[num] = '30'
+ self.pdesc[num] += ' (0-60)'
else: self.pval[num] = paramgrp[2]
label = wx.StaticText(self.panel, id=1000+num, label=self.pdesc[num],
style=wx.ALIGN_RIGHT | wx.ST_NO_AUTORESIZE)
self.pentry[num] = wx.Choice(self.panel, id=2000+num, size=(100,-1),
- choices = ['N','Y'])
+ choices = ['No','Yes'])
self.pentry[num].SetStringSelection(self.pval[num])
self.Bind(wx.EVT_CHOICE, self.OnParamEntry)
- zone = []
- for i in range(1, 61):
- zone.append(str(i))
- self.pentry[num] = wx.Choice(self.panel, id=2000+num, size=(100,-1),
- choices = zone)
- self.pentry[num].SetStringSelection(self.pval[num])
- self.Bind(wx.EVT_CHOICE, self.OnParamEntry)
+ self.pentry[num] = wx.SpinCtrl(self.panel, id=2000+num,
+ value='30',
+ size=(100,-1),
+ style=wx.SP_ARROW_KEYS | wx.SP_WRAP,
+ min=0, max=60, initial=30)
+ self.pentry[num].SetValue(int(self.pval[num]))
+ self.Bind(wx.EVT_TEXT, self.OnParamEntry)
else:
self.pentry[num] = wx.TextCtrl(self.panel, id=2000+num, value=self.pval[num],
size=(100,-1))
@@ -809,9 +827,13 @@
self.pentry[num].SetBackgroundColour(wx.LIGHT_GREY)
self.prjparamsizer.Add(item=label, pos=(num, 1),
- flag=wx.ALIGN_RIGHT | wx.RIGHT, border=5)
+ flag=wx.ALIGN_RIGHT |
+ wx.ALIGN_CENTER_VERTICAL |
+ wx.RIGHT, border=5)
self.prjparamsizer.Add(item=self.pentry[num], pos=(num, 2),
- flag=wx.ALIGN_LEFT | wx.LEFT, border=5)
+ flag=wx.ALIGN_LEFT |
+ wx.LEFT, border=5)
num += 1
self.panel.SetSize(self.panel.GetBestSize())
