[GRASS-SVN] r39600 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Oct 21 02:42:35 EDT 2009
Author: cmbarton
Date: 2009-10-21 02:42:28 -0400 (Wed, 21 Oct 2009)
New Revision: 39600
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/location_wizard.py
Major update and fix of location wizard. This is equivalent to fixes and updates of develbranch_6 r39480, r39492, r39554, r39568, r39576, r39584, and r39591. Could not be backported because the code was out of sync between develbranch_6 and releasebranch.
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/location_wizard.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/location_wizard.py 2009-10-20 13:12:49 UTC (rev 39599)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/location_wizard.py 2009-10-21 06:42:28 UTC (rev 39600)
@@ -1,4 +1,4 @@
@package location_wizard.py
@brief Location wizard - creates a new GRASS Location. User can choose
@@ -11,7 +11,7 @@
- CoordinateSystemPage
- ProjectionsPage
- ItemList
- - ProjTypePage
+ - ProjParamsPage
- DatumPage
- EllipsePage
- GeoreferencedFilePage
@@ -20,7 +20,7 @@
- SummaryPage
- RegionDef
- LocationWizard
- - SelectDatumDialog
+ - SelectTransformDialog
COPYRIGHT: (C) 2007-2009 by the GRASS Development Team
This program is free software under the GNU General Public
@@ -42,6 +42,8 @@
import wx
import wx.lib.mixins.listctrl as listmix
import wx.wizard as wiz
+import wx.lib.scrolledpanel as scrolled
+import time
import gcmd
import globalvar
@@ -61,6 +63,7 @@
global west
global resolution
global wizerror
+global translist
coordsys = ''
north = ''
@@ -68,28 +71,29 @@
east = ''
west = ''
resolution = ''
+transformlist = []
class BaseClass(wx.Object):
- """Base class providing basic methods"""
+ """!Base class providing basic methods"""
def __init__(self):
pass
def MakeLabel(self, text="", style=wx.ALIGN_LEFT, parent=None):
- """Make aligned label"""
+ """!Make aligned label"""
if not parent:
parent = self
return wx.StaticText(parent=parent, id=wx.ID_ANY, label=text,
style=style)
def MakeTextCtrl(self, text='', size=(100,-1), style=0, parent=None):
- """Generic text control"""
+ """!Generic text control"""
if not parent:
parent = self
return wx.TextCtrl(parent=parent, id=wx.ID_ANY, value=text,
size=size, style=style)
def MakeButton(self, text, id=wx.ID_ANY, size=(-1,-1), parent=None):
- """Generic button"""
+ """!Generic button"""
if not parent:
parent = self
return wx.Button(parent=parent, id=id, label=text,
@@ -108,26 +112,24 @@
self.title = wx.StaticText(parent=self, id=wx.ID_ANY, label=title)
self.title.SetFont(wx.Font(13, wx.SWISS, wx.NORMAL, wx.BOLD))
- # main sizer
+ # main sizers
+ self.pagesizer = wx.BoxSizer(wx.VERTICAL)
self.sizer = wx.GridBagSizer(vgap=0, hgap=0)
def DoLayout(self):
- """Do page layout"""
+ """!Do page layout"""
- tmpsizer = wx.BoxSizer(wx.VERTICAL)
- tmpsizer.Add(item=self.title, proportion=0,
+ self.pagesizer.Add(item=self.title, proportion=0,
flag=wx.ALIGN_CENTRE | wx.ALL,
border=5)
- tmpsizer.Add(item=wx.StaticLine(self, -1), proportion=0,
+ self.pagesizer.Add(item=wx.StaticLine(self, -1), proportion=0,
flag=wx.EXPAND | wx.ALL,
border=0)
- tmpsizer.Add(item=self.sizer, proportion=1,
- flag=wx.EXPAND | wx.ALL,
- border=5)
+ self.pagesizer.Add(item=self.sizer)
self.SetAutoLayout(True)
- self.SetSizer(tmpsizer)
+ self.SetSizer(self.pagesizer)
# tmpsizer.Fit(self)
self.Layout()
@@ -193,7 +195,7 @@
# self.DoLayout()
def OnChangeName(self, event):
- """Name for new location was changed"""
+ """!Name for new location was changed"""
nextButton = wx.FindWindowById(wx.ID_FORWARD)
if len(event.GetString()) > 0:
if not nextButton.IsEnabled():
@@ -233,7 +235,7 @@
self.grassdatabase = self.tgisdbase.GetValue()
def OnEnterPage(self, event):
- """Wizard page changed"""
+ """!Wizard page changed"""
self.location = self.tlocation.GetValue()
@@ -251,22 +253,21 @@
# toggles
self.radio1 = wx.RadioButton(parent=self, id=wx.ID_ANY,
- label=_("Select coordinate system"),
+ label=_("Select coordinate system parameters from a list"),
style = wx.RB_GROUP)
self.radio2 = wx.RadioButton(parent=self, id=wx.ID_ANY,
- label=_("Select EPSG code of coordinate system"))
+ label=_("Select EPSG code of spatial reference system"))
self.radio3 = wx.RadioButton(parent=self, id=wx.ID_ANY,
- label=_("Use coordinate system of selected "
- "georeferenced file"))
+ label=_("Read projection and datum terms from a "
+ "georeferenced data file"))
self.radio4 = wx.RadioButton(parent=self, id=wx.ID_ANY,
"WKT or PRJ file"))
self.radio5 = wx.RadioButton(parent=self, id=wx.ID_ANY,
- label=_("Create custom PROJ.4 parameters "
- "string for coordinate system"))
+ label=_("Specify projection and datum terms using custom "
+ "PROJ.4 parameters"))
self.radio6 = wx.RadioButton(parent=self, id=wx.ID_ANY,
- label=_("Use arbitrary non-earth "
- "coordinate system (XY)"))
+ label=_("Create an arbitrary non-earth coordinate system (XY)"))
# layout
self.sizer.AddGrowableCol(1)
self.sizer.SetVGap(10)
@@ -297,8 +298,25 @@
global coordsys
- if event.GetDirection() and not coordsys:
+ if not coordsys:
coordsys = "proj"
+ self.radio1.SetValue(True)
+ else:
+ if coordsys == 'proj':
+ if coordsys == "epsg":
+ self.radio2.SetValue(True)
+ if coordsys == "file":
+ self.radio3.SetValue(True)
+ if coordsys == "wkt":
+ self.radio4.SetValue(True)
+ if coordsys == "custom":
+ self.radio5.SetValue(True)
+ if coordsys == "xy":
+ self.radio6.SetValue(True)
+ if event.GetDirection():
self.SetNext(self.parent.projpage)
self.parent.sumpage.SetPrev(self.parent.datumpage)
@@ -306,7 +324,7 @@
wx.FindWindowById(wx.ID_FORWARD).Enable()
def SetVal(self, event):
- """Choose method"""
+ """!Choose method"""
global coordsys
if event.GetId() == self.radio1.GetId():
coordsys = "proj"
@@ -343,6 +361,7 @@
self.parent = parent
self.proj = ''
self.projdesc = ''
+ self.p4proj = ''
# text input
self.tproj = self.MakeTextCtrl("", size=(200,-1))
@@ -352,8 +371,10 @@
style=wx.TE_PROCESS_ENTER)
# projection list
- self.projlist = ItemList(self, data=self.parent.projections.items(),
+ self.projlist = ItemList(self, data=self.parent.projdesc.items(),
columns=[_('Code'), _('Description')])
+ self.projlist.resizeLastColumn(30)
# layout
self.sizer.AddGrowableCol(3)
self.sizer.Add(item=self.MakeLabel(_("Projection code:")),
@@ -389,27 +410,33 @@
# self.Layout()
def OnPageChanging(self,event):
- if event.GetDirection() and self.proj not in self.parent.projections:
+ if event.GetDirection() and self.proj not in self.parent.projections.keys():
event.Veto()
- if self.proj == 'utm':
- self.parent.projtypepage.text_utm.SetEditable(True)
- self.parent.projtypepage.hemischoices = ['north','south']
- else:
- self.parent.projtypepage.text_utm.SetValue('')
- self.parent.projtypepage.text_utm.SetEditable(False)
- self.parent.projtypepage.hemischoices = []
def OnText(self, event):
- """Projection name changed"""
+ """!Projection name changed"""
self.proj = event.GetString().lower()
+ self.p4proj = ''
if len(self.proj) == 0 and nextButton.IsEnabled():
nextButton.Enable(False)
- if self.proj in self.parent.projections:
- self.projdesc = self.parent.projections[self.proj]
- if not nextButton.IsEnabled():
- nextButton.Enable()
+ if self.proj in self.parent.projections.keys():
+ if self.proj == 'stp':
+ wx.MessageBox('Currently State Plane projections must be selected using the '
+ 'text-based setup (g.setproj), or entered by EPSG code or '
+ 'custom PROJ.4 terms.',
+ 'Warning', wx.ICON_WARNING)
+ self.proj = ''
+ self.tproj.SetValue(self.proj)
+ nextButton.Enable(False)
+ return
+ elif self.proj.lower() == 'll':
+ self.p4proj = '+proj=longlat'
+ else:
+ self.p4proj = '+proj=' + self.proj.lower()
+ self.projdesc = self.parent.projections[self.proj][0]
+ nextButton.Enable()
if len(self.proj) == 0:
@@ -421,28 +448,29 @@
event.Skip()
def OnSearch(self, event):
- """Search projection by desc"""
+ """!Search projection by desc"""
str = event.GetString()
try:
- self.proj, self.projdesc = self.projlist.Search(index=1, pattern=event.GetString())
+ self.proj, self.projdesc = self.projlist.Search(index=[0,1], pattern=event.GetString())
except:
self.proj = self.projdesc = ''
event.Skip()
def OnItemSelected(self, event):
- """Projection selected"""
+ """!Projection selected"""
index = event.m_itemIndex
# set values
self.proj = self.projlist.GetItem(index, 0).GetText().lower()
- self.projdesc = self.projlist.GetItem(index, 0).GetText()
+ event.Skip()
class ItemList(wx.ListCtrl,
listmix.ListCtrlAutoWidthMixin,
listmix.ColumnSorterMixin):
- """Generic list (for projections, ellipsoids, etc.)"""
+ """!Generic list (for projections, ellipsoids, etc.)"""
def __init__(self, parent, columns, data=None):
wx.ListCtrl.__init__(self, parent=parent, id=wx.ID_ANY,
@@ -466,6 +494,9 @@
if self.sourceData:
self.Populate()
+ #FIXME: auto sizing doesn't work for some reason
+ for i in range(self.GetColumnCount()):
+ self.SetColumnWidth(i, wx.LIST_AUTOSIZE)
else:
self.SetColumnWidth(i, wx.LIST_AUTOSIZE_USEHEADER)
@@ -502,7 +533,7 @@
self.Bind(wx.EVT_LIST_COL_CLICK, self.OnColumnClick)
def Populate(self, data=None, update=False):
- """Populate list"""
+ """!Populate list"""
self.itemDataMap = {}
self.itemIndexMap = []
@@ -516,26 +547,15 @@
self.DeleteAllItems()
row = 0
for value in data:
- # index = self.InsertStringItem(sys.maxint, str(value[0]))
self.itemDataMap[row] = [value[0]]
for i in range(1, len(value)):
- # try:
- # self.SetStringItem(index, i, str(value[i]))
- # except:
- # self.SetStringItem(index, i, unicode(str(value[i]), 'latin1'))
- self.itemDataMap[row].append(value[i])
- # self.SetItemData(index, row)
+ self.itemDataMap[row].append(value[i])
self.itemIndexMap.append(row)
row += 1
self.SetItemCount(row)
# set column width
- # for i in range(self.GetColumnCount()):
- # self.SetColumnWidth(i, wx.LIST_AUTOSIZE)
- # if self.GetColumnWidth(i) < 80:
- # self.SetColumnWidth(i, 80)
self.SetColumnWidth(0, 80)
self.SetColumnWidth(1, 300)
@@ -547,7 +567,7 @@
caption=_("Error"), style=wx.OK | wx.ICON_ERROR)
def OnColumnClick(self, event):
- """Sort by column"""
+ """!Sort by column"""
self._col = event.GetColumn()
# remove duplicated arrow symbol from column header
@@ -562,17 +582,17 @@
event.Skip()
def GetSortImages(self):
- """Used by the ColumnSorterMixin, see wx/lib/mixins/listctrl.py"""
+ """!Used by the ColumnSorterMixin, see wx/lib/mixins/listctrl.py"""
return (self.sm_dn, self.sm_up)
def OnGetItemText(self, item, col):
- """Get item text"""
+ """!Get item text"""
index = self.itemIndexMap[item]
s = str(self.itemDataMap[index][col])
return s
def OnGetItemAttr(self, item):
- """Get item attributes"""
+ """!Get item attributes"""
if ( index % 2) == 0:
return self.attr2
@@ -580,7 +600,7 @@
return self.attr1
def SortItems(self, sorter=cmp):
- """Sort items"""
+ """!Sort items"""
items = list(self.itemDataMap.keys())
items.sort(self.Sorter)
self.itemIndexMap = items
@@ -611,11 +631,11 @@
return -cmpVal
def GetListCtrl(self):
- """Used by listmix.ColumnSorterMixin"""
+ """!Used by listmix.ColumnSorterMixin"""
return self
def Search (self, index, pattern):
- """Search projection by description
+ """!Search projection by description
Return first found item or None
@@ -626,112 +646,208 @@
data = []
pattern = pattern.lower()
for i in range(len(self.sourceData)):
- try:
- value = str(self.sourceData[i][index]).lower()
- if pattern in value:
- data.append(self.sourceData[i])
- except UnicodeDecodeError:
- # osgeo4w problem (should be fixed)
- pass
+ for idx in index:
+ try:
+ value = str(self.sourceData[i][idx]).lower()
+ if pattern in value:
+ data.append(self.sourceData[i])
+ break
+ except UnicodeDecodeError:
+ # osgeo4w problem (should be fixed)
+ pass
+ self.Populate(data)
if len(data) > 0:
- self.Populate(data)
return data[0]
else:
- self.Populate(self.sourceData)
+# self.Populate(self.sourceData)
return []
-class ProjTypePage(TitledPage):
+class ProjParamsPage(TitledPage):
Wizard page for selecting method of setting coordinate system parameters
(select coordinate system option)
def __init__(self, wizard, parent):
- TitledPage.__init__(self, wizard, _("Choose method of specifying georeferencing parameters"))
+ TitledPage.__init__(self, wizard, _("Choose projection parameters"))
global coordsys
self.utmzone = ''
self.utmhemisphere = ''
self.hemischoices = ["north","south"]
+ self.panel = ''
+ self.prjparamsizer = ''
+ self.pentry = {}
+ self.pdesc = {}
+ self.ptype = {}
+ self.pval = {}
+ self.proj4param = {}
+ self.pcount = 0
+ self.paramlist = []
+ self.p4projparams = ''
+ self.projdesc = ''
+ radioSBox = wx.StaticBox(parent=self, id=wx.ID_ANY,
+ label=" %s " % _("Select datum or ellipsoid (next page)"))
+ radioSBSizer = wx.StaticBoxSizer(radioSBox)
+ self.sizer.Add(radioSBSizer, pos=(0,1), span=(1,2),
+ flag=wx.EXPAND | wx.ALIGN_TOP | wx.TOP, border=10)
- self.radio1 = wx.RadioButton(parent=self, id=wx.ID_ANY, label=_("Select datum with associated ellipsoid"),
- style = wx.RB_GROUP)
+ self.radio1 = wx.RadioButton(parent=self, id=wx.ID_ANY,
+ label=_("Datum with associated ellipsoid"),
+ style = wx.RB_GROUP)
- label=_("Select ellipsoid"))
- self.title_utm = self.MakeLabel(_("Set zone for UTM projection:"))
- self.text_utm = self.MakeTextCtrl(size=(100,-1))
- self.label_utm = self.MakeLabel(_("Zone:"))
- self.hemisphere = wx.Choice(parent=self, id=wx.ID_ANY, size=(100, -1),
- choices=self.hemischoices)
- self.label_hemisphere = self.MakeLabel(_("Hemisphere for zone:"))
+ label=_("Ellipsoid only"))
+ # default button setting
+ if self.radio1.GetValue() == False and self.radio2.GetValue() == False:
+ self.SetNext(self.parent.datumpage)
+# self.parent.sumpage.SetPrev(self.parent.datumpage)
- # layout
- self.sizer.AddGrowableCol(2)
- self.sizer.Add(item=self.radio1,
- flag=wx.ALIGN_LEFT, pos=(1, 1), span=(1, 2))
- self.sizer.Add(item=self.radio2,
- flag=wx.ALIGN_LEFT, pos=(2, 1), span=(1, 2))
- self.sizer.Add(item=self.title_utm,
- flag=wx.ALIGN_LEFT | wx.ALL,
- border=5, pos=(4, 1), span=(1, 2))
- self.sizer.Add(item=self.label_utm,
- flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL,
- border=5, pos=(5, 1), span=(1, 1))
- self.sizer.Add(item=self.text_utm,
- flag=wx.ALIGN_LEFT | wx.ALL, border=5,
- pos=(5, 2), span=(1, 1))
- self.sizer.Add(item=self.label_hemisphere,
- border=5, pos=(6, 1), span=(1, 1))
- self.sizer.Add(item=self.hemisphere,
- flag=wx.ALIGN_LEFT|wx.ALL,
- border=5, pos=(6, 2), span=(1, 1))
+ radioSBSizer.Add(item=self.radio1,
+ flag=wx.ALIGN_LEFT | wx.RIGHT, border=20)
+ radioSBSizer.Add(item=self.radio2,
+ flag=wx.ALIGN_LEFT)
- self.title_utm.Hide()
- self.text_utm.Hide()
- self.label_utm.Hide()
- self.hemisphere.Hide()
- self.label_hemisphere.Hide()
# bindings
self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id=self.radio1.GetId())
self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id=self.radio2.GetId())
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnPageChange)
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
+ def OnParamEntry(self, event):
+ num = 0
+ # deal with weird spin control text event behavior, sending dup. event with negative number
+ if event.GetId() >= 2000:
+ num = event.GetId() - 2000
+ else:
+ pass
+ val = event.GetString()
+ if self.ptype[num] == 'zone':
+ if val.isdigit():
+ if int(val) < 0: self.pentry[num].SetValue(0)
+ if int(val) > 60: self.pentry[num].SetValue(60)
+ else:
+ self.pentry[num].SetValue(0)
+ self.pval[num] = val
+ event.Skip()
- # do page layout
- # self.DoLayout()
def OnPageChange(self,event=None):
- if event.GetDirection() and self.parent.projpage.proj == 'utm' and self.utmzone == '':
- wx.MessageBox('You must set a zone for a UTM projection')
- event.Veto()
+ for num in range(self.pcount + 1):
+ if self.ptype[num] == 'bool':
+ if self.pval[num] == 'No':
+ continue
+ else:
+ self.p4projparams += (' +' + self.proj4param[num])
+ else:
+ if self.pval[num] == '':
+ wx.MessageBox('You must enter a value for %s' % self.pdesc[num],
+ 'Something is missing!', wx.ICON_ERROR)
+ event.Veto()
+ else:
+ self.p4projparams += (' +' + self.proj4param[num] + '=' + self.pval[num])
def OnEnterPage(self,event):
- if self.parent.projpage.proj == 'utm':
- self.title_utm.Show()
- self.text_utm.Show()
- self.label_utm.Show()
- self.hemisphere.Show()
- self.label_hemisphere.Show()
+ self.projdesc = self.parent.projections[self.parent.projpage.proj][0]
+ try:
+ # page already formatted
+ if self.pagesizer.GetItem(self.panel) != '':
+ pass
+ except:
+ # entering page for the first time
+ paramSBox = wx.StaticBox(parent=self, id=wx.ID_ANY,
+ label=_(" Enter parameters for %s projection ") % self.projdesc)
+ paramSBSizer = wx.StaticBoxSizer(paramSBox)
+ self.panel = scrolled.ScrolledPanel(self, wx.ID_ANY)
+ self.prjparamsizer = wx.GridBagSizer(vgap=0, hgap=0)
+ self.panel.SetupScrolling()
+# this ought to work but it doesn't
+# self.sizer.Add(paramSBSizer, pos=(2,1), span=(3,2),
+# flag=wx.EXPAND )
+ self.pagesizer.Add(paramSBSizer, proportion=1,
+ flag=wx.EXPAND | wx.ALIGN_TOP | wx.ALL, border=10)
+ paramSBSizer.Add(self.panel, proportion=1,
+ flag=wx.ALIGN_CENTER|wx.EXPAND)
+ paramSBSizer.Fit(self.panel)
+ self.panel.SetSizer(self.prjparamsizer)
+ self.pcount = 0
+ self.prjparamsizer.Clear(True)
+ num = 0
- self.Bind(wx.EVT_CHOICE, self.OnHemisphere, self.hemisphere)
- self.Bind(wx.EVT_TEXT, self.GetUTM, self.text_utm)
+ for paramgrp in self.parent.projections[self.parent.projpage.proj][1]:
+ # get parameters
+ self.pcount = num
+ self.ptype[num] = self.parent.paramdesc[paramgrp[0]][0]
+ self.proj4param[num] = self.parent.paramdesc[paramgrp[0]][1]
+ self.pdesc[num] = self.parent.paramdesc[paramgrp[0]][2]
+ # default values
+ if self.ptype[num] == 'bool': self.pval[num] = 'No'
+ elif self.ptype[num] == 'zone':
+ self.pval[num] = '30'
+ self.pdesc[num] += ' (0-60)'
+ else: self.pval[num] = paramgrp[2]
+ label = wx.StaticText(self.panel, id=1000+num, label=self.pdesc[num],
+ style=wx.ALIGN_RIGHT | wx.ST_NO_AUTORESIZE)
+ self.pentry[num] = wx.Choice(self.panel, id=2000+num, size=(100,-1),
+ choices = ['No','Yes'])
+ self.pentry[num].SetStringSelection(self.pval[num])
+ self.Bind(wx.EVT_CHOICE, self.OnParamEntry)
+ self.pentry[num] = wx.SpinCtrl(self.panel, id=2000+num,
+ value='30',
+ size=(100,-1),
+ style=wx.SP_ARROW_KEYS | wx.SP_WRAP,
+ min=0, max=60, initial=30)
+ self.pentry[num].SetValue(int(self.pval[num]))
+ self.Bind(wx.EVT_TEXT, self.OnParamEntry)
+ else:
+ self.pentry[num] = wx.TextCtrl(self.panel, id=2000+num, value=self.pval[num],
+ size=(100,-1))
+ if paramgrp[1] == 'noask':
+ self.pentry[num].SetEditable(False)
+ self.pentry[num].SetBackgroundColour(wx.LIGHT_GREY)
+ self.prjparamsizer.Add(item=label, pos=(num, 1),
+ flag=wx.ALIGN_RIGHT |
+ wx.ALIGN_CENTER_VERTICAL |
+ wx.RIGHT, border=5)
+ self.prjparamsizer.Add(item=self.pentry[num], pos=(num, 2),
+ wx.LEFT, border=5)
+ num += 1
+ self.panel.SetSize(self.panel.GetBestSize())
+ self.panel.Layout()
+ self.Layout()
+ self.Update()
if not wx.FindWindowById(wx.ID_FORWARD).IsEnabled():
event.Skip()
- global coordsys
@@ -758,17 +874,12 @@
self.datum = ''
self.datumdesc = ''
- self.ellipsoid = ''
+ self.ellipse = ''
self.datumparams = ''
- self.transform = ''
- self.transregion = ''
- self.transparams = ''
- self.hastransform = False
self.proj4params = ''
# text input
self.tdatum = self.MakeTextCtrl("", size=(200,-1))
- self.ttrans = self.MakeTextCtrl("", size=(200,-1))
# search box
self.searchb = wx.SearchCtrl(self, size=(200,-1),
@@ -780,16 +891,8 @@
data.append([key, self.parent.datums[key][0], self.parent.datums[key][1]])
self.datumlist = ItemList(self,
data=data,
- columns=[_('Code'), _('Description'), _('Ellipsoid')])
- # create list control for datum transformation parameters list
- data = []
- for key in self.parent.transforms.keys():
- data.append([key, self.parent.transforms[key][0], self.parent.transforms[key][1]])
- self.transformlist = ItemList(self,
- data=None,
- columns=[_('Code'), _('Datum'), _('Description')])
- self.transformlist.sourceData = data
+ columns=[_('Code'), _('Ellipsoid'), _('Description')])
+ self.datumlist.resizeLastColumn(10)
# layout
self.sizer.AddGrowableCol(4)
@@ -817,28 +920,11 @@
wx.ALIGN_LEFT |
wx.ALL, border=5, pos=(3, 1), span=(1, 4))
- self.sizer.Add(item=self.MakeLabel(_("Transformation parameters:")),
- flag=wx.ALIGN_RIGHT |
- wx.ALIGN_CENTER_VERTICAL |
- wx.ALL, border=5, pos=(5, 1))
- self.sizer.Add(item=self.ttrans,
- wx.ALL, border=5, pos=(5, 2))
- self.sizer.Add(item=self.transformlist,
- flag=wx.EXPAND |
- wx.ALIGN_LEFT |
- wx.ALL, border=5, pos=(6, 1), span=(1, 4))
# events
self.datumlist.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnDatumSelected)
- self.transformlist.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnTransformSelected)
self.searchb.Bind(wx.EVT_TEXT_ENTER, self.OnDSearch)
self.tdatum.Bind(wx.EVT_TEXT, self.OnDText)
self.tdatum.Bind(wx.EVT_TEXT_ENTER, self.OnDText)
- self.ttrans.Bind(wx.EVT_TEXT, self.OnTText)
- self.ttrans.Bind(wx.EVT_TEXT_ENTER, self.OnTText)
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnPageChanging)
@@ -847,100 +933,94 @@
def OnPageChanging(self, event):
- if event.GetDirection() and self.datum not in self.parent.datums:
- event.Veto()
- if self.hastransform == True and self.transform == '':
- event.Veto()
- self.GetNext().SetPrev(self)
- self.parent.ellipsepage.ellipseparams = self.parent.ellipsoids[self.ellipsoid][1]
+ proj = self.parent.projpage.p4proj
+ if self.datum not in self.parent.datums:
+ event.Veto()
+ else:
+ # check for datum tranforms
+ ret = gcmd.RunCommand('g.proj',
+ read = True,
+ proj4 = '%s +datum=%s' % (proj, self.datum),
+ datumtrans = '-1')
+ if ret != '':
+ dtrans = ''
+ # open a dialog to select datum transform number
+ dlg = SelectTransformDialog(self.parent.parent, transforms=ret)
+ if dlg.ShowModal() == wx.ID_OK:
+ dtrans = dlg.GetTransform()
+ if dtrans == '':
+ dlg.Destroy()
+ event.Veto()
+ return 'Datum transform is required.'
+ else:
+ dlg.Destroy()
+ event.Veto()
+ self.parent.datumtrans = dtrans
+ self.GetNext().SetPrev(self)
+ self.parent.ellipsepage.ellipse = self.ellipse
+ self.parent.ellipsepage.ellipseparams = self.parent.ellipsoids[self.ellipse][1]
- if len(self.datum) == 0 or \
- (self.hastransform == True and self.transform == ''):
- # disable 'next' button by default
- wx.FindWindowById(wx.ID_FORWARD).Enable(False)
- else:
- wx.FindWindowById(wx.ID_FORWARD).Enable(True)
+ self.parent.datumtrans = 0
+ if len(self.datum) == 0:
+ # disable 'next' button by default when entering from previous page
+ wx.FindWindowById(wx.ID_FORWARD).Enable(False)
+ else:
+ wx.FindWindowById(wx.ID_FORWARD).Enable(True)
event.Skip()
def OnDText(self, event):
- self.datum = event.GetString().lower()
- tlist = self.transformlist.Search(index=1, pattern=self.datum)
- if len(tlist) > 0:
- self.hastransform = True
- else:
+ self.datum = event.GetString()
- if len(self.datum) == 0 and nextButton.IsEnabled():
+ if len(self.datum) == 0 or self.datum not in self.parent.datums:
- elif self.datum in self.parent.datums:
- self.datumdesc = self.parent.datums[self.datum][0]
- self.ellipsoid = self.parent.datums[self.datum][1]
+ else:
+ self.ellipse = self.parent.datums[self.datum][0]
+ self.datumdesc = self.parent.datums[self.datum][1]
self.datumparams = self.parent.datums[self.datum][2]
- if self.hastransform == False or \
- (self.hastransform == True and self.transform != ''):
- nextButton.Enable(True)
- else:
- if nextButton.IsEnabled():
- nextButton.Enable(False)
+ try:
+ self.datumparams.remove('dx=0.0')
+ except:
+ pass
+ try:
+ self.datumparams.remove('dy=0.0')
+ except:
+ pass
+ try:
+ self.datumparams.remove('dz=0.0')
+ except:
+ pass
+ nextButton.Enable(True)
+ self.Update()
event.Skip()
- def OnTText(self, event):
- if self.hastransform == False:
- event.Skip()
- return
- self.transform = event.GetString()
- nextButton = wx.FindWindowById(wx.ID_FORWARD)
- if len(self.transform) == 0 and nextButton.IsEnabled():
- elif self.transform in self.parent.transforms:
- self.transdatum = self.parent.transforms[self.transform][0]
- self.transregion = self.parent.transforms[self.transform][1]
- self.transparams = self.parent.transforms[self.transform][2]
def OnDSearch(self, event):
str = self.searchb.GetValue()
try:
- self.datum, self.datumdesc, self.ellipsoid = self.datumlist.Search(index=1, pattern=str)
- self.transformlist.Search(index=1, pattern=self.datum)
+ self.datum, self.ellipsoid, self.datumdesc = self.datumlist.Search(index=[0,1,2], pattern=str)
except:
self.datum = self.datumdesc = self.ellipsoid = ''
- if str == '' or self.datum == '':
- self.transformlist.DeleteAllItems()
- self.transformlist.Refresh()
event.Skip()
- def OnTransformSelected(self,event):
- index = event.m_itemIndex
- item = event.GetItem()
- self.transform = self.transformlist.GetItem(index, 0).GetText()
- self.ttrans.SetValue(str(self.transform))
- def OnDatumSelected(self,event):
+ def OnDatumSelected(self, event):
self.datum = self.datumlist.GetItem(index, 0).GetText()
- self.datumparams = self.parent.datums[self.datum][2]
self.tdatum.SetValue(self.datum)
event.Skip()
class EllipsePage(TitledPage):
@@ -973,6 +1053,7 @@
self.ellipselist = ItemList(self, data=data,
+ self.ellipselist.resizeLastColumn(30)
# layout
@@ -1007,9 +1088,6 @@
- # do page layout
- # self.DoLayout()
if len(self.ellipse) == 0:
@@ -1026,14 +1104,13 @@
self.parent.datumpage.datumparams = ''
- self.parent.datumpage.transparams = ''
# self.GetNext().SetPrev(self) (???)
- """Ellipspoid code changed"""
+ """!Ellipspoid code changed"""
self.ellipse = event.GetString()
- if len(self.ellipse) == 0 and nextButton.IsEnabled():
+ if len(self.ellipse) == 0 or self.ellipse not in self.parent.ellipsoids:
self.ellipsedesc = ''
self.ellipseparams = ''
@@ -1041,23 +1118,17 @@
elif self.ellipse in self.parent.ellipsoids:
self.ellipsedesc = self.parent.ellipsoids[self.ellipse][0]
self.ellipseparams = self.parent.ellipsoids[self.ellipse][1]
- """Search ellipsoid by desc"""
- str = event.GetString()
+ """!Search ellipsoid by desc"""
try:
self.ellipse, self.ellipsedesc = \
- self.ellipselist.Search(index=1, pattern=event.GetString())
+ self.ellipselist.Search(index=[0,1], pattern=event.GetString())
- self.proj4params = self.parent.ellipsoids[self.ellipse][2]
except:
- self.ellipse = self.ellipsedesc = ''
- self.ellipseparams = self.proj4params = ''
+ self.ellipse = self.ellipsedesc = self.ellipseparams = ''
- self.tellipse.SetValue(self.ellipse)
event.Skip()
def OnItemSelected(self,event):
@@ -1065,10 +1136,9 @@
self.ellipse = self.ellipselist.GetItem(index, 0).GetText()
- self.ellipsedesc = self.parent.ellipsoids[self.ellipse][0]
- self.ellipseparams = self.parent.ellipsoids[self.ellipse][1]
+ event.Skip()
class GeoreferencedFilePage(TitledPage):
@@ -1134,7 +1204,7 @@
event.Skip()
def OnBrowse(self, event):
- """Choose file"""
+ """!Choose file"""
dlg = wx.FileDialog(self,
_("Select georeferenced file"),
os.getcwd(), "", "*.*", wx.OPEN)
@@ -1180,9 +1250,6 @@
- # do page layout
- # self.DoLayout()
if len(self.wktfile) == 0:
@@ -1212,7 +1279,7 @@
event.Skip()
- """Choose file"""
_("Select WKT file"),
@@ -1245,12 +1312,6 @@
style=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL)
self.lcode= self.MakeLabel(_("EPSG code:"),
- self.lsearch = self.MakeLabel(_("Search in"),
- style=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL)
- self.csearch = wx.Choice(parent = self, id = wx.ID_ANY,
- choices = [_("codes"), _("description"), _("parameters")])
- self.csearch.SetStringSelection(_("description"))
# text input
epsgdir = utils.PathJoin(os.environ["GRASS_PROJSHARE"], 'epsg')
self.tfile = self.MakeTextCtrl(text=epsgdir, size=(200,-1))
@@ -1258,8 +1319,7 @@
# buttons
self.bbrowse = self.MakeButton(_("Browse"))
- self.bbcodes = self.MakeButton(_("Reload EPSG Codes"))
- self.bbsearch = self.MakeButton(_("Search"))
+# self.bbcodes = self.MakeButton(_("Reload EPSG Codes"))
# search box
@@ -1282,7 +1342,6 @@
wx.ALL, border=5, pos=(1, 4))
self.sizer.Add(item=self.lcode,
@@ -1291,29 +1350,15 @@
wx.ALL, border=5, pos=(2, 3))
- self.sizer.Add(item=self.lsearch,
- wx.ALL, border=5, pos=(3, 1))
- self.sizer.Add(item=self.csearch,
- wx.ALL, border=5, pos=(3, 2))
self.sizer.Add(item=self.searchb,
wx.ALL, border=5, pos=(3, 3))
- self.sizer.Add(item=self.bbcodes,
- wx.ALL, border=5, pos=(2, 4))
- self.sizer.Add(item=self.bbsearch,
- wx.ALL, border=5, pos=(3, 4))
+# self.sizer.Add(item=self.bbcodes,
+# flag=wx.ALIGN_LEFT |
+# wx.ALIGN_CENTER_VERTICAL |
+# wx.ALL, border=5, pos=(3, 4))
self.sizer.AddGrowableRow(4)
self.sizer.Add(item=self.epsglist,
flag=wx.ALIGN_LEFT | wx.EXPAND, pos=(4, 1),
@@ -1321,8 +1366,7 @@
# events
self.bbrowse.Bind(wx.EVT_BUTTON, self.OnBrowse)
- self.bbcodes.Bind(wx.EVT_BUTTON, self.OnBrowseCodes)
- self.bbsearch.Bind(wx.EVT_BUTTON, self.OnSearch)
+# self.bbcodes.Bind(wx.EVT_BUTTON, self.OnBrowseCodes)
self.tcode.Bind(wx.EVT_TEXT, self.OnText)
self.tcode.Bind(wx.EVT_TEXT_ENTER, self.OnText)
self.epsglist.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemSelected)
@@ -1330,15 +1374,14 @@
- # do page layout
- # self.DoLayout()
- if not self.epsgcode:
- else:
+ if not self.epsgcode:
+ else:
# load default epsg database file
self.OnBrowseCodes(None)
@@ -1346,9 +1389,34 @@
event.Skip()
- if event.GetDirection() and not self.epsgcode:
- event.Veto()
+ event.Veto()
+ return
+ else:
+ # check for datum transforms
+ read = True,
+ epsg = '%s' % self.epsgcode,
+ if ret != '':
+ dtrans = ''
+ if dtrans == '':
+ dlg.Destroy()
+ event.Veto()
+ else:
+ dlg.Destroy()
+ event.Veto()
self.epsgcode = event.GetString()
@@ -1372,22 +1440,28 @@
value = self.searchb.GetValue()
- if self.epsglist.GetItemCount() == 0:
- event.Skip()
- return
- try:
- self.epsgcode = self.epsglist.Search(index=self.csearch.GetSelection(),
- pattern=value)[0]
- except IndexError: # -> no item found
+ if value == '':
self.epsgcode = None
+ self.epsgdesc = self.epsgparams = ''
self.tcode.SetValue('')
self.searchb.SetValue('')
+ self.OnBrowseCodes(None)
+ else:
+ try:
+ self.epsgcode, self.epsgdesc, self.epsgparams = \
+ self.epsglist.Search(index=[0,1,2], pattern=value)
+ except IndexError: # -> no item found
+ self.epsgcode = None
+ self.tcode.SetValue('')
+ self.searchb.SetValue('')
event.Skip()
- """Define path for EPSG code file"""
+ """!Define path for EPSG code file"""
path = os.path.dirname(self.tfile.GetValue())
if not path:
path = os.getcwd()
@@ -1405,7 +1479,7 @@
event.Skip()
- """EPSG code selected from the list"""
+ """!EPSG code selected from the list"""
@@ -1416,8 +1490,7 @@
event.Skip()
def OnBrowseCodes(self, event, search=None):
- """Browse EPSG codes"""
-# try:
+ """!Browse EPSG codes"""
if True:
data = []
self.epsgCodeDict = {}
@@ -1442,13 +1515,20 @@
i += 1
f.close()
- self.epsglist.Populate(data, update=True)
-# except StandardError, e:
-# wx.MessageBox(parent=self,
-# message=_("Unable to read EPGS codes: %s") % e,
-# caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
-# self.epsglist.Populate([], update=True)
+ if type(self.epsgCodeDict) == type(''):
+ wx.MessageBox(parent=self,
+ message=_("Unable to read EPGS codes: %s") % self.epsgCodeDict,
+ caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ self.epsglist.Populate([], update=True)
+ return
+ data = []
+ for code, val in self.epsgCodeDict.iteritems():
+ if code is not None:
+ data.append((code, val[0], val[1]))
+ self.epsglist.Populate(data, update=True)
class CustomPage(TitledPage):
Wizard page for entering custom PROJ.4 string
@@ -1481,9 +1561,6 @@
- # do page layout
- # self.DoLayout()
if len(self.customstring) == 0:
@@ -1496,10 +1573,34 @@
if event.GetDirection() and not self.customstring:
event.Veto()
+ else:
+ read = True,
+ proj4 = '%s' % self.customstring,
+ if ret != '':
+ dtrans = ''
+ dlg = SelectTransformDialog(self.parent.parent, transforms=out)
+ if dtrans == '':
+ dlg.Destroy()
+ event.Veto()
+ else:
+ dlg.Destroy()
+ event.Veto()
def GetProjstring(self, event):
- """Change proj string"""
+ """!Change proj string"""
# TODO: check PROJ.4 syntax
self.customstring = event.GetString()
@@ -1536,7 +1637,7 @@
self.__DoLayout()
def __DoLayout(self):
self.sizer.Add(item=self.MakeLabel(_("GRASS Database:")),
@@ -1565,13 +1666,6 @@
self.sizer.Add(item=(10,20),
flag=wx.ALIGN_CENTER_HORIZONTAL | wx.ALL,
border=5, pos=(5, 0), span=(1, 2))
- # self.sizer.AddGrowableRow(6)
- #self.sizer.Add(item=self.MakeLabel(_("You can set the default extents "
- # "and resolution after creating new location%s"
- # "or you can set them during a working session.") % os.linesep,
- # style=wx.ALIGN_CENTER),
- # flag=wx.ALIGN_CENTRE | wx.ALL, border=5, pos=(6, 0),
- # span=(1, 2))
@@ -1580,7 +1674,10 @@
database = self.parent.startpage.grassdatabase
location = self.parent.startpage.location
+ proj4string = self.parent.CreateProj4String()
+ epsgcode = self.parent.epsgpage.epsgcode
+ dtrans = self.parent.datumtrans
global coordsys
if coordsys not in ['proj', 'epsg']:
self.lproj4stringLabel.Hide()
@@ -1591,28 +1688,36 @@
self.lproj4string.Show()
self.lproj4stringLabel.SetLabel(_("PROJ.4 definition:"))
- self.lproj4string.SetLabel(self.parent.CreateProj4String())
+ p = gcmd.Command(['g.proj', '-j',
+ 'proj4=%s' % proj4string,
+ 'datumtrans=%s' % dtrans,
+ 'location=%s' % location])
+ elif coordsys == 'epsg':
+ 'epsg=%s' % epsgcode,
+ if p.returncode == 0:
+ projlabel = ''
+ msg = p.ReadStdOutput()
+ for line in msg:
+ projlabel = projlabel + '%s ' % line
+ self.lproj4string.SetLabel(projlabel)
else:
- self.lproj4string.SetLabel(self.parent.epsgpage.epsgCodeDict[self.parent.epsgpage.epsgcode][1])
+ err = p.ReadErrOutput()
+ wx.MessageBox(err, 'Error', wx.ICON_ERROR)
self.lproj4string.Wrap(400)
- projection = self.parent.projpage.proj
projdesc = self.parent.projpage.projdesc
- utmzone = self.parent.projtypepage.utmzone
- utmhemisphere = self.parent.projtypepage.utmhemisphere
- ellipse = self.parent.ellipsepage.ellipse
ellipsedesc = self.parent.ellipsepage.ellipsedesc
- datum = self.parent.datumpage.datum
datumdesc = self.parent.datumpage.datumdesc
- ellipsoid = self.parent.datumpage.ellipsoid
- datumparams = self.parent.datumpage.datumparams
- transform = self.parent.datumpage.transform
- transregion = self.parent.datumpage.transregion
- transparams = self.parent.datumpage.transparams
self.ldatabase.SetLabel(str(database))
self.llocation.SetLabel(str(location))
label = ''
label = 'EPSG code %s (%s)' % (self.parent.epsgpage.epsgcode, self.parent.epsgpage.epsgdesc)
self.lprojection.SetLabel(label)
@@ -1623,7 +1728,7 @@
label = 'matches file %s' % self.parent.wktpage.wktfile
elif coordsys == 'proj':
- label = ('%s, %s%s' % (projdesc, datumdesc, ellipsedesc))
+ label = ('%s, %s %s' % (projdesc, datumdesc, ellipsedesc))
elif coordsys == 'xy':
label = ('XY coordinate system (not projected).')
@@ -1667,6 +1772,12 @@
# get georeferencing information from tables in $GISBASE/etc
self.__readData()
+ # datum transform number and list of datum transforms
+ self.datumtrans = 0
+ self.proj4string = ''
# define wizard pages
@@ -1677,7 +1788,7 @@
self.csystemspage = CoordinateSystemPage(self.wizard, self)
self.projpage = ProjectionsPage(self.wizard, self)
self.datumpage = DatumPage(self.wizard, self)
- self.projtypepage = ProjTypePage(self.wizard,self)
+ self.paramspage = ProjParamsPage(self.wizard,self)
self.epsgpage = EPSGPage(self.wizard, self)
self.filepage = GeoreferencedFilePage(self.wizard, self)
self.wktpage = WKTPage(self.wizard, self)
@@ -1695,15 +1806,15 @@
self.csystemspage.SetNext(self.sumpage)
self.projpage.SetPrev(self.csystemspage)
- self.projpage.SetNext(self.projtypepage)
+ self.projpage.SetNext(self.paramspage)
- self.projtypepage.SetPrev(self.projpage)
- self.projtypepage.SetNext(self.datumpage)
+ self.paramspage.SetPrev(self.projpage)
+ self.paramspage.SetNext(self.datumpage)
- self.datumpage.SetPrev(self.projtypepage)
+ self.datumpage.SetPrev(self.paramspage)
self.datumpage.SetNext(self.sumpage)
- self.ellipsepage.SetPrev(self.projtypepage)
+ self.ellipsepage.SetPrev(self.paramspage)
self.ellipsepage.SetNext(self.sumpage)
self.epsgpage.SetPrev(self.csystemspage)
@@ -1727,7 +1838,7 @@
self.csystemspage.DoLayout()
self.projpage.DoLayout()
self.datumpage.DoLayout()
- self.projtypepage.DoLayout()
+ self.paramspage.DoLayout()
self.epsgpage.DoLayout()
self.filepage.DoLayout()
self.wktpage.DoLayout()
@@ -1747,8 +1858,8 @@
# run wizard...
if self.wizard.RunWizard(self.startpage):
- success = self.OnWizFinished()
- if success == True:
+ msg = self.OnWizFinished()
+ if len(msg) < 1:
self.wizard.Destroy()
self.location = self.startpage.location
@@ -1766,34 +1877,45 @@
defineRegion.Show()
else:
dlg.Destroy()
- elif success == False:
+ else: # -> error
wx.MessageBox(parent=self.parent,
message="%s" % _("Unable to create new location. "
- "Location <%s> not created.") % self.startpage.location,
+ "Location <%(loc)s> not created.\n\n"
+ "Details: %(err)s") % \
+ { 'loc' : self.startpage.location,
+ 'err' : msg },
caption=_("Location wizard"),
- else: # None
- pass
else:
win = wx.MessageBox(parent=self.parent,
message=_("Location wizard canceled. "
"Location not created."),
caption=_("Location wizard"))
+ def __readData(self):
+ """!Get georeferencing information from tables in $GISBASE/etc"""
- def __readData(self):
- """Get georeferencing information from tables in $GISBASE/etc"""
- # read projection definitions
- f = open(os.path.join(globalvar.ETCDIR, "projections"), "r")
+ # read projection and parameters
+ f = open(os.path.join(globalvar.ETCDIR, "proj-parms.table"), "r")
self.projections = {}
+ self.projdesc = {}
for line in f.readlines():
- line = line.expandtabs(1)
line = line.strip()
- if line == '' or line[0] == "#":
+ try:
+ proj, projdesc, params = line.split(':')
+ paramslist = params.split(';')
+ plist = []
+ for p in paramslist:
+ if p == '': continue
+ p1, pdefault = p.split(',')
+ pterm, pask = p1.split('=')
+ p = [pterm.strip(), pask.strip(), pdefault.strip()]
+ plist.append(p)
+ self.projections[proj.lower().strip()] = (projdesc.strip(), plist)
+ self.projdesc[proj.lower().strip()] = projdesc.strip()
+ except:
continue
- proj, projdesc = line.split(":", 1)
- self.projections[proj.strip()] = projdesc.strip()
f.close()
# read datum definitions
@@ -1811,37 +1933,9 @@
datumdesc = datumdesc.strip('"')
paramlist = params.split()
ellipsoid = paramlist.pop(0)
- self.datums[datum] = (datumdesc.replace('_', ' '), ellipsoid, paramlist)
+ self.datums[datum] = (ellipsoid, datumdesc.replace('_', ' '), paramlist)
f.close()
- # read datum transforms parameters
- f = open(os.path.join(globalvar.ETCDIR, "datumtransform.table"), "r")
- self.transforms = {}
- j = 1
- for line in f.readlines():
- if j < 10:
- transcode = 'T0' + str(j)
- else:
- transcode = 'T' + str(j)
- line = line.strip()
- continue
- datum, rest = line.split(" ", 1)
- rest = rest.strip('" ')
- params, rest = rest.split('"', 1)
- params = params.strip()
- try:
- region, info = rest.split('"', 1)
- info = info.strip('" ')
- info = region + ': ' + info
- except:
- info = rest
- self.transforms[transcode] = (datum, info, params)
- j += 1
- f.close()
# read ellipsiod definitions
f = open(os.path.join(globalvar.ETCDIR, "ellipse.table"), "r")
self.ellipsoids = {}
@@ -1857,12 +1951,24 @@
paramslist = params.split()
self.ellipsoids[ellipse] = (desc, paramslist)
f.close()
+ # read projection parameter description and parsing table
+ f = open(os.path.join(globalvar.ETCDIR, "proj-desc.table"), "r")
+ self.paramdesc = {}
+ for line in f.readlines():
+ line = line.strip()
+ try:
+ pparam, datatype, proj4term, desc = line.split(':')
+ self.paramdesc[pparam] = (datatype, proj4term, desc)
+ except:
+ continue
+ f.close()
def OnWizFinished(self):
database = self.startpage.grassdatabase
global coordsys
- success = False
+ msg = '' # error message (empty on success)
# location already exists?
if os.path.isdir(os.path.join(database,location)):
@@ -1902,31 +2008,29 @@
self.altdb = True
- success = self.XYCreate()
- elif coordsys == "latlong":
- rows = int(round((float(north) - float(south)) / float(resolution)))
- cols = int(round((float(east) - float(west)) / float(resolution)))
- cells = int(rows * cols)
- success = self.LatlongCreate()
+ msg = self.XYCreate()
elif coordsys == "proj":
proj4string = self.CreateProj4String()
- success = self.Proj4Create(proj4string)
+ msg = self.Proj4Create(proj4string)
elif coordsys == 'custom':
- success = self.CustomCreate()
+ msg = self.CustomCreate()
elif coordsys == "epsg":
- success = self.EPSGCreate()
+ msg = self.EPSGCreate()
elif coordsys == "file":
- success = self.FileCreate()
+ msg = self.FileCreate()
elif coordsys == "wkt":
- success = self.WKTCreate()
+ msg = self.WKTCreate()
- return success
+ return msg
def XYCreate(self):
- """Create an XY location"""
+ """!Create an XY location
+ @return error message (empty string on success)
# create location directory and PERMANENT mapset
try:
os.mkdir(os.path.join(database, location))
@@ -1956,247 +2060,168 @@
for param in regioninfo:
defwind.write(param + '%s' % os.linesep)
defwind.close()
shutil.copy(os.path.join(database, location, "PERMANENT", "DEFAULT_WIND"),
os.path.join(database, location, "PERMANENT", "WIND"))
# create MYNAME file
myname = open(os.path.join(database, location, "PERMANENT",
"MYNAME"), 'w')
myname.write('%s' % os.linesep)
myname.close()
- return True
except OSError, e:
- dlg = wx.MessageDialog(parent=self.wizard,
- message="%s: %s" % (_("Unable to create new location"), e),
- caption=_("Error"),
- style=wx.OK | wx.ICON_ERROR)
- dlg.ShowModal()
- dlg.Destroy()
- return False
+ return e
+ return ''
def CreateProj4String(self):
- """Constract PROJ.4 string"""
+ """!Constract PROJ.4 string"""
- proj = self.projpage.proj
+ proj = self.projpage.p4proj
projdesc = self.projpage.projdesc
- utmzone = self.projtypepage.utmzone
- utmhemisphere = self.projtypepage.utmhemisphere
+ proj4params = self.paramspage.p4projparams
datum = self.datumpage.datum
if self.datumpage.datumdesc:
- datumdesc = self.datumpage.datumdesc +' - ' + self.datumpage.ellipsoid
+ datumdesc = self.datumpage.datumdesc +' - ' + self.datumpage.ellipse
else:
datumdesc = ''
- datumparams = self.datumpage.datumparams
- transparams = self.datumpage.transparams
+ datumparams = self.datumpage.datumparams
ellipse = self.ellipsepage.ellipse
ellipsedesc = self.ellipsepage.ellipsedesc
ellipseparams = self.ellipsepage.ellipseparams
# creating PROJ.4 string
- if proj == 'll':
- proj4string = '+proj=longlat'
- elif proj == 'utm':
- proj4string = '+proj=%s +zone=%s' % (proj, utmzone)
- if utmhemisphere == 'south':
- proj4string += ' +south'
- else:
- proj4string = '+proj=%s ' % (proj)
- proj4params = ''
+ proj4string = '%s %s' % (proj, proj4params)
# set ellipsoid parameters
+ if ellipse != '': proj4string = '%s +ellps=%s' % (proj4string, ellipse)
for item in ellipseparams:
if item[:4] == 'f=1/':
- item = '+rf='+item[4:]
+ item = ' +rf='+item[4:]
else:
- item = '+'+item
- proj4params = '%s %s' % (proj4params, item)
+ item = ' +'+item
+ proj4string = '%s %s' % (proj4string, item)
# set datum and transform parameters if relevant
+ if datum != '': proj4string = '%s +datum=%s' % (proj4string, datum)
if datumparams:
for item in datumparams:
- proj4params = '%s +%s' % (proj4params,item)
- if transparams:
- proj4params = '%s +no_defs +%s' % (proj4params,transparams)
- else:
- proj4params = '%s +no_defs' % proj4params
- else:
+ proj4string = '%s +%s' % (proj4string,item)
- return '%s %s' % (proj4string, proj4params)
+ proj4string = '%s +no_defs' % proj4string
+ return proj4string
def Proj4Create(self, proj4string):
+ """!Create a new location for selected projection
- Create a new location for selected projection
- # creating location from PROJ.4 string passed to g.proj
- cmdlist = ['g.proj', '-c',
- 'proj4=%s' % proj4string,
- 'location=%s' % self.startpage.location]
- p = gcmd.Command(cmdlist, stderr=None)
+ p = gcmd.Command(['g.proj', '-c',
+ 'location=%s' % self.startpage.location,
+ 'datumtrans=%s' % self.datumtrans])
- return True
+ return ''
- return False
+ return err
def CustomCreate(self):
- """Create a new location based on given proj4 string"""
+ """!Create a new location based on given proj4 string
proj4string = self.custompage.customstring
- 'location=%s' % location]
- return True
+ return ''
- return False
+ return err
def EPSGCreate(self):
+ """!Create a new location from an EPSG code.
- Create a new location from an EPSG code.
epsgcode = self.epsgpage.epsgcode
epsgdesc = self.epsgpage.epsgdesc
- cmdlist = []
# should not happend
if epsgcode == '':
- wx.MessageBox(parent=self,
- message="%s: %s" % (_("Unable to create new location"), _("EPSG code missing.")),
- caption=_("Error"), style=wx.OK | wx.ICON_ERROR)
- return False
+ return _('EPSG code missing.')
- 'epsg=%s' % epsgcode,
- 'datumtrans=-1']
- p = gcmd.Command(cmdlist)
- dtoptions = {}
- try:
- line = p.ReadStdOutput()
- i = 0
- while i < len(line):
- if line[i] == '---':
- for j in range(3):
- dtoptions[line[i+1]] = (line[i+2],
- line[i+3],
- line[i+4])
- i += 5
- except:
- pass
- if dtoptions != {}:
- dtrans = ''
- # open a dialog to select datum transform number
- dlg = SelectDatumDialog(self.parent, datums=dtoptions)
- if dlg.ShowModal() == wx.ID_OK:
- dtrans = dlg.GetDatum()
- if dtrans == '':
- wx.MessageBox(parent=self.parent,
- message=_('Datum transform is required.'),
- style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
- dlg.Destroy()
- return False
- dlg.Destroy()
- else:
- dlg.Destroy()
- return False
- 'location=%s' % location,
- 'datumtrans=%s' % dtrans]
- else:
- cmdlist = ['g.proj','-c',
- 'datumtrans=1']
- return True
+ return ''
+ return err
+ def FileCreate(self):
+ """!Create a new location from a georeferenced file
- return False
- def FileCreate(self):
- Create a new location from a georeferenced file
georeffile = self.filepage.georeffile
- cmdlist = []
# this should not happen
if not georeffile or not os.path.isfile(georeffile):
- dlg = wx.MessageBox(parent=self.wizard,
- message="%s: %s ('%s')" % \
- (_("Unable to create new location"),
- _("file not found"),
- georeffile),
- caption=("Error"), style=wx.OK | wx.ICON_ERROR)
- return False
+ return _("File not found.")
# creating location
- 'georef=%s' % georeffile,
+ 'georef=%s' % georeffile,
+ 'location=%s' % self.startpage.location])
- return True
+ return ''
- return False
+ return err
def WKTCreate(self):
+ """!Create a new location from a WKT file
- Create a new location from a WKT file
wktfile = self.wktpage.wktfile
- cmdlist = []
if not wktfile or not os.path.isfile(wktfile):
- wktfile),
- return False
- 'wkt=%s' % wktfile,
+ # creating location
+ 'wkt=%s' % wktfile,
+ out = p.ReadStdOutput()
+ msg = p.ReadErrOutput()
- return True
+ return ''
- return False
+ return msg
class RegionDef(BaseClass, wx.Frame):
@@ -2265,23 +2290,19 @@
# in selected location in order to set default region (WIND)
envval = {}
- cmdlist = ['g.gisenv']
- if p.returncode == 0:
- output = p.ReadStdOutput()
- for line in output:
- if '=' in line:
- key, val = line.split('=')
+ ret = gcmd.RunCommand('g.gisenv',
+ read = True)
+ if ret:
+ for line in ret.splitlines():
+ key, val = line.split('=')
envval[key] = val
self.currlocation = envval['LOCATION_NAME'].strip("';")
self.currmapset = envval['MAPSET'].strip("';")
if self.currlocation != self.location or self.currmapset != 'PERMANENT':
- gcmd.Command(["g.gisenv",
- "set=LOCATION_NAME=%s" % self.location])
- "set=MAPSET=PERMANENT"])
+ gcmd.RunCommand('g.gisenv',
+ set = 'LOCATION_NAME=%s' % self.location)
+ set = 'MAPSET=PERMANENT')
else:
dlg = wx.MessageBox(parent=self,
message=_('Invalid location selected.'),
@@ -2292,14 +2313,12 @@
# get current region settings
region = {}
- cmdlist = ['g.region', '-gp3']
- if '=' in line:
+ ret = gcmd.RunCommand('g.region',
+ read = True,
+ flags = 'gp3')
+ if ret:
region[key] = float(val)
else:
@@ -2383,7 +2402,7 @@
self.minWindowSize = self.GetMinSize()
def MakeSettings3DPaneContent(self, pane):
- """Create 3D region settings pane"""
+ """!Create 3D region settings pane"""
border = wx.BoxSizer(wx.VERTICAL)
gridSizer = wx.GridBagSizer(vgap=0, hgap=0)
@@ -2460,7 +2479,7 @@
border.Fit(pane)
def OnSettings3DPaneChanged(self, event):
- """Collapse 3D settings box"""
+ """!Collapse 3D settings box"""
if self.settings3D.IsExpanded():
self.settings3D.SetLabel(self.infoCollapseLabelCol)
@@ -2476,7 +2495,7 @@
self.SendSizeEvent()
def __DoLayout(self, panel):
- """Window layout"""
+ """!Window layout"""
frameSizer = wx.BoxSizer(wx.VERTICAL)
settings3DSizer = wx.BoxSizer(wx.VERTICAL)
@@ -2580,7 +2599,7 @@
self.Layout()
def OnValue(self, event):
- """Set given value"""
+ """!Set given value"""
try:
if event.GetId() == self.tnorth.GetId():
self.north = float(event.GetString())
@@ -2629,7 +2648,7 @@
event.Skip()
def __UpdateInfo(self):
- """Update number of rows/cols/cells"""
+ """!Update number of rows/cols/cells"""
self.rows = int((self.north - self.south) / self.nsres)
self.cols = int((self.east - self.west) / self.ewres)
self.cells = self.rows * self.cols
@@ -2646,71 +2665,113 @@
self.lcells3.SetLabel(_("3D Cells: %d" % self.cells3))
def OnSetButton(self, event=None):
- """Set default region"""
- cmdlist = ['g.region', '-sgpa',
- 'n=%f' % self.north,
- 's=%f' % self.south,
- 'e=%f' % self.east,
- 'w=%f' % self.west,
- 'nsres=%f' % self.nsres,
- 'ewres=%f' % self.ewres,
- 't=%f' % self.top,
- 'b=%f' % self.bottom,
- 'tbres=%f' % self.tbres]
+ """!Set default region"""
+ flags = 'sgpa',
+ n = self.north,
+ s = self.south,
+ e = self.east,
+ w = self.west,
+ nsres = self.nsres,
+ ewres = self.ewres,
+ t = self.top,
+ b = self.bottom,
+ tbres = self.tbres)
+ if ret == 0:
self.Destroy()
def OnCancel(self, event):
self.Destroy()
+class TransList(wx.VListBox):
+ """!Creates a multiline listbox for selecting datum transforms"""
+ def OnDrawItem(self, dc, rect, n):
+ if self.GetSelection() == n:
+ c = wx.SystemSettings.GetColour(wx.SYS_COLOUR_HIGHLIGHTTEXT)
+ else:
+ c = self.GetForegroundColour()
+ dc.SetFont(self.GetFont())
+ dc.SetTextForeground(c)
+ dc.DrawLabel(self._getItemText(n), rect,
+ wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL)
-class SelectDatumDialog(wx.Dialog):
- """Dialog for selecting datum transformations"""
- def __init__(self, parent, datums, title=_("Select datum transformation"),
- pos=wx.DefaultPosition, size=wx.DefaultSize, style=wx.DEFAULT_DIALOG_STYLE):
+ def OnMeasureItem(self, n):
+ height = 0
+ if self._getItemText(n) == None: return
+ for line in self._getItemText(n).splitlines():
+ w, h = self.GetTextExtent(line)
+ height += h
+ return height + 5
- self.datums = datums
+ def _getItemText(self, item):
+ global transformlist
+ transitem = transformlist[item]
+ if transitem.strip() !='':
+ return transitem
+class SelectTransformDialog(wx.Dialog):
+ """!Dialog for selecting datum transformations"""
+ def __init__(self, parent, transforms, title=_("Select datum transformation"),
+ pos=wx.DefaultPosition, size=wx.DefaultSize,
+ style=wx.DEFAULT_DIALOG_STYLE|wx.RESIZE_BORDER):
wx.Dialog.__init__(self, parent, wx.ID_ANY, title, pos, size, style)
- panel = wx.Panel(self, wx.ID_ANY)
+ self.CentreOnParent()
+ # default transform number
+ self.transnum = 0
+ panel = scrolled.ScrolledPanel(self, wx.ID_ANY)
+ # set panel sizer
+ panel.SetSizer(sizer)
+ panel.SetupScrolling()
# dialog body
bodyBox = wx.StaticBox(parent=panel, id=wx.ID_ANY,
- label=" %s " % _("List of datum transformations"))
- bodySizer = wx.StaticBoxSizer(bodyBox, wx.HORIZONTAL)
- gridSizer = wx.GridBagSizer(vgap=5, hgap=5)
+ label=" %s " % _("Select from list of datum transformations"))
+ bodySizer = wx.StaticBoxSizer(bodyBox)
- gridSizer.Add(item=wx.StaticText(parent=panel, label=_("Datums (select to see description):")),
- flag=wx.ALIGN_CENTER_VERTICAL, pos=(0, 0))
+ # add no transform option
+ transforms = '---\n\n0\nDo not apply any datum transformations\n\n' + transforms
+ transformlist = transforms.split('---')
+ tlistlen = len(transformlist)
+ # calculate size for transform list
+ height = 0
+ width = 0
+ for line in transforms.splitlines():
+ height += h
+ width = max(width, w)
+ height = height + 5
+ if height > 400: height = 400
+ width = width + 5
+ if width > 400: width = 400
- items = self.datums.keys()
- utils.ListSortLower(items)
- self.cdatums = wx.ComboBox(parent=panel, id=wx.ID_ANY,
- style=wx.CB_SIMPLE | wx.CB_READONLY,
- choices=items,
- size=(60,-1))
- self.cdatums.SetSelection(0)
- self.cdatums.Bind(wx.EVT_COMBOBOX, self.OnChangeDatum)
- gridSizer.Add(item=self.cdatums, pos=(0, 1))
+ # VListBox for displaying and selecting transformations
+ self.translist = TransList(panel, id=-1, size=(width, height), style=wx.SUNKEN_BORDER)
+ self.translist.SetItemCount(tlistlen)
+ self.translist.SetSelection(2)
+ self.translist.SetFocus()
+ self.Bind(wx.EVT_LISTBOX, self.ClickTrans, self.translist)
- self.textWidth = self.GetSize()[0]
+ bodySizer.Add(item=self.translist, proportion=1, flag=wx.ALIGN_CENTER|wx.ALL|wx.EXPAND)
- self.datumDesc = wx.StaticText(parent=panel, size=(self.textWidth,-1),
- label='\n'.join(self.datums[self.cdatums.GetStringSelection()]))
- self.datumDesc.Wrap(self.textWidth)
- gridSizer.Add(item=self.datumDesc, flag=wx.EXPAND,
- pos=(1, 0), span=(1, 2))
- bodySizer.Add(item=gridSizer, proportion=1,
- flag=wx.ALL | wx.ALIGN_CENTER | wx.EXPAND, border=5)
# buttons
@@ -2728,27 +2789,24 @@
flag=wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
sizer.Add(item=btnsizer, proportion=0,
- flag=wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
+ flag= wx.ALL | wx.ALIGN_RIGHT, border=5)
- # set panel sizer
- panel.SetSizer(sizer)
sizer.Fit(panel)
self.SetSize(self.GetBestSize())
+ self.Layout()
+ def ClickTrans(self, event):
+ """!Get the number of the datum transform to use in g.proj"""
+ self.transnum = event.GetSelection()
+ self.transnum = self.transnum - 1
+ def GetTransform(self):
+ self.transnum = self.translist.GetSelection()
+ return self.transnum
- def OnChangeDatum(self, event):
- """Datum changed, update description text"""
- self.datumDesc.SetLabel('\n'.join(self.datums[event.GetString()]))
-# self.textWidth = self.GetSize()[0]
-# self.datumDesc.Wrap(self.textWidth)
- event.Skip()
- def GetDatum(self):
- """Get selected datum"""
- return self.cdatums.GetStringSelection()
if __name__ == "__main__":
app = wx.PySimpleApp()
# gWizard = LocationWizard(None, "")
