[GRASS-SVN] r39602 - grass/trunk/lib/segment
svn_grass at osgeo.org
Wed Oct 21 11:49:13 EDT 2009
Author: mmetz
Date: 2009-10-21 11:49:13 -0400 (Wed, 21 Oct 2009)
New Revision: 39602
Added:
grass/trunk/lib/segment/rbtree.c
grass/trunk/lib/segment/rbtree.h
grass/trunk/lib/segment/address.c
grass/trunk/lib/segment/flush.c
grass/trunk/lib/segment/format.c
grass/trunk/lib/segment/get.c
grass/trunk/lib/segment/get_row.c
grass/trunk/lib/segment/init.c
grass/trunk/lib/segment/pagein.c
grass/trunk/lib/segment/pageout.c
grass/trunk/lib/segment/put.c
grass/trunk/lib/segment/put_row.c
grass/trunk/lib/segment/release.c
grass/trunk/lib/segment/seek.c
grass/trunk/lib/segment/segmentlib.dox
grass/trunk/lib/segment/setup.c
faster segment library
Modified: grass/trunk/lib/segment/address.c
--- grass/trunk/lib/segment/address.c 2009-10-21 15:48:12 UTC (rev 39601)
+++ grass/trunk/lib/segment/address.c 2009-10-21 15:49:13 UTC (rev 39602)
@@ -9,12 +9,56 @@
* \author GRASS GIS Development Team
- * \date 2005-2006
+ * \date 2005-2009
#include <grass/segment.h>
+int segment_address_fast(const SEGMENT * SEG, int row, int col, int *n, int *index)
+ if (row) {
+ int seg_r = row >> SEG->srowbits;
+ int seg_c = col >> SEG->scolbits;
+ *n = seg_r * SEG->spr + seg_c;
+ *index = ((row - (seg_r << SEG->srowbits)) << SEG->scolbits) + col - (seg_c << SEG->scolbits);
+ /* for simple arrays */
+ else {
+ *n = col >> SEG->scolbits;
+ *index = col - ((*n) << SEG->scolbits);
+ if (SEG->slow_seek == 0)
+ *index = *index << SEG->lenbits;
+ else
+ *index *= SEG->len;
+ return 0;
+int segment_address_slow(const SEGMENT * SEG, int row, int col, int *n, int *index)
+ if (row) {
+ int seg_r = row / SEG->srows;
+ int seg_c = col / SEG->scols;
+ *index = (row - seg_r * SEG->srows) * SEG->scols + col - seg_c * SEG->scols;
+ else {
+ *n = col / SEG->scols;
+ *index = col - *n * SEG->scols;
+ return 0;
+static int (*segment_adrs[2]) () = {
+ segment_address_fast, segment_address_slow
* \fn int segment_address (SEGMENT *SEG, int row, int col, int *n, int *index)
@@ -30,8 +74,13 @@
int segment_address(const SEGMENT * SEG, int row, int col, int *n, int *index)
+ /* old code
*n = row / SEG->srows * SEG->spr + col / SEG->scols;
*index = (row % SEG->srows * SEG->scols + col % SEG->scols) * SEG->len;
- return 0;
+ /* this function is called at least once every time data are accessed in SEG
+ * avoid very slow modulus and divisions, modulus was the main time killer */
+ return (*segment_adrs[SEG->slow_adrs])(SEG, row, col, n, index);
Modified: grass/trunk/lib/segment/flush.c
--- grass/trunk/lib/segment/flush.c 2009-10-21 15:48:12 UTC (rev 39601)
+++ grass/trunk/lib/segment/flush.c 2009-10-21 15:49:13 UTC (rev 39602)
@@ -9,7 +9,7 @@
- * \date 2005-2006
+ * \date 2005-2009
Modified: grass/trunk/lib/segment/format.c
--- grass/trunk/lib/segment/format.c 2009-10-21 15:48:12 UTC (rev 39601)
+++ grass/trunk/lib/segment/format.c 2009-10-21 15:49:13 UTC (rev 39602)
@@ -9,7 +9,7 @@
- * \date 2005-2006
+ * \date 2005-2009
#include <grass/config.h>
Modified: grass/trunk/lib/segment/get.c
--- grass/trunk/lib/segment/get.c 2009-10-21 15:48:12 UTC (rev 39601)
+++ grass/trunk/lib/segment/get.c 2009-10-21 15:49:13 UTC (rev 39602)
@@ -9,7 +9,7 @@
- * \date 2005-2006
+ * \date 2005-2009
#include <string.h>
Modified: grass/trunk/lib/segment/get_row.c
--- grass/trunk/lib/segment/get_row.c 2009-10-21 15:48:12 UTC (rev 39601)
+++ grass/trunk/lib/segment/get_row.c 2009-10-21 15:49:13 UTC (rev 39602)
@@ -9,7 +9,7 @@
- * \date 2005-2006
+ * \date 2005-2009
#include <stdio.h>
Modified: grass/trunk/lib/segment/init.c
--- grass/trunk/lib/segment/init.c 2009-10-21 15:48:12 UTC (rev 39601)
+++ grass/trunk/lib/segment/init.c 2009-10-21 15:49:13 UTC (rev 39602)
@@ -6,9 +6,10 @@
* Bernhard Reiter <bernhard intevation.de>,
* Brad Douglas <rez touchofmadness.com>,
* Glynn Clements <glynn gclements.plus.com>,
- * Markus Neteler <neteler itc.it>
+ * Markus Neteler <neteler itc.it>,
+ * Markus Metz <markus.metz.giswork googlemail.com>
* PURPOSE: Segment initialization routines
- * COPYRIGHT: (C) 2000-2006 by the GRASS Development Team
+ * COPYRIGHT: (C) 2000-2009 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
Modified: grass/trunk/lib/segment/pagein.c
--- grass/trunk/lib/segment/pagein.c 2009-10-21 15:48:12 UTC (rev 39601)
+++ grass/trunk/lib/segment/pagein.c 2009-10-21 15:49:13 UTC (rev 39602)
@@ -9,7 +9,7 @@
- * \date 2005-2006
+ * \date 2005-2009
#include <stdio.h>
@@ -17,11 +17,9 @@
#include <string.h>
#include <errno.h>
+#include "rbtree.h"
-static int segment_select(SEGMENT *, int);
* \fn int segment_pagein (SEGMENT *SEG, int n)
@@ -38,37 +36,60 @@
int segment_pagein(SEGMENT * SEG, int n)
- int age;
int cur;
- int i;
int read_result;
+ SEGID *seg_found, seg_search;
/* is n the current segment? */
if (n == SEG->scb[SEG->cur].n)
return SEG->cur;
/* search the in memory segments */
- for (i = 0; i < SEG->nseg; i++)
- if (n == SEG->scb[i].n)
- return segment_select(SEG, i);
+ seg_search.i = 0;
+ seg_search.n = n;
+ seg_found = rbtree_find(SEG->loaded, &seg_search);
+ if (seg_found) {
+ cur = seg_found->i;
+ if (SEG->scb[cur].age != SEG->youngest) {
+ /* splice out */
+ SEG->scb[cur].age->younger->older = SEG->scb[cur].age->older;
+ SEG->scb[cur].age->older->younger = SEG->scb[cur].age->younger;
+ /* splice in */
+ SEG->scb[cur].age->younger = SEG->youngest->younger;
+ SEG->scb[cur].age->older = SEG->youngest;
+ SEG->scb[cur].age->older->younger = SEG->scb[cur].age;
+ SEG->scb[cur].age->younger->older = SEG->scb[cur].age;
+ /* make it youngest */
+ SEG->youngest = SEG->scb[cur].age;
+ return SEG->cur = cur;
/* find a slot to use to hold segment */
- age = 0;
- cur = 0;
- if (SEG->scb[i].n < 0) { /* free slot */
- cur = i;
- break;
- else if (age < SEG->scb[i].age) { /* find oldest segment */
- cur = i;
- age = SEG->scb[i].age;
+ if (SEG->nfreeslots) { /* any free slots left ? */
+ cur = SEG->freeslot[--SEG->nfreeslots];
+ else { /* find oldest segment */
+ SEG->oldest = SEG->oldest->younger;
+ cur = SEG->oldest->cur;
+ SEG->oldest->cur = -1;
+ SEG->scb[cur].age = NULL;
/* if slot is used, write it out, if dirty */
- if (SEG->scb[cur].n >= 0 && SEG->scb[cur].dirty)
+ if (SEG->scb[cur].n >= 0 && SEG->scb[cur].dirty) {
if (segment_pageout(SEG, cur) < 0)
return -1;
+ if (SEG->scb[cur].n >= 0) {
+ seg_search.n = SEG->scb[cur].n;
+ if (rbtree_remove(SEG->loaded, &seg_search) == 0)
+ G_fatal_error("could not remove segment");
+ seg_search.n = n;
/* read in the segment */
SEG->scb[cur].n = n;
@@ -92,17 +113,18 @@
return -1;
- return segment_select(SEG, cur);
+ if (cur < 0 || n < 0)
+ G_fatal_error("segment not loaded");
+ /* remember loaded segment */
+ seg_search.i = cur;
+ if (rbtree_insert(SEG->loaded, &seg_search) == 0)
+ G_fatal_error("could not insert segment");
-static int segment_select(SEGMENT * SEG, int n)
- int i;
- SEG->scb[n].age = 0;
- SEG->scb[i].age++;
- return SEG->cur = n;
+ /* make it youngest segment */
+ SEG->youngest = SEG->youngest->younger;
+ SEG->scb[cur].age = SEG->youngest;
+ SEG->youngest->cur = cur;
Modified: grass/trunk/lib/segment/pageout.c
--- grass/trunk/lib/segment/pageout.c 2009-10-21 15:48:12 UTC (rev 39601)
+++ grass/trunk/lib/segment/pageout.c 2009-10-21 15:49:13 UTC (rev 39602)
@@ -9,7 +9,7 @@
- * \date 2005-2006
+ * \date 2005-2009
#include <stdio.h>
Modified: grass/trunk/lib/segment/put.c
--- grass/trunk/lib/segment/put.c 2009-10-21 15:48:12 UTC (rev 39601)
+++ grass/trunk/lib/segment/put.c 2009-10-21 15:49:13 UTC (rev 39602)
@@ -9,7 +9,7 @@
- * \date 2005-2006
+ * \date 2005-2009
#include <string.h>
@@ -46,8 +46,10 @@
int index, n, i;
segment_address(SEG, row, col, &n, &index);
- if ((i = segment_pagein(SEG, n)) < 0)
- return -1;
+ if ((i = segment_pagein(SEG, n)) < 0) {
+ G_warning("segment lib: put: pagein failed");
+ return -1;
SEG->scb[i].dirty = 1;
Modified: grass/trunk/lib/segment/put_row.c
--- grass/trunk/lib/segment/put_row.c 2009-10-21 15:48:12 UTC (rev 39601)
+++ grass/trunk/lib/segment/put_row.c 2009-10-21 15:49:13 UTC (rev 39602)
@@ -9,7 +9,7 @@
- * \date 2005-2006
+ * \date 2005-2009
#include <stdio.h>
Added: grass/trunk/lib/segment/rbtree.c
--- grass/trunk/lib/segment/rbtree.c (rev 0)
+++ grass/trunk/lib/segment/rbtree.c 2009-10-21 15:49:13 UTC (rev 39602)
@@ -0,0 +1,536 @@
+ * \file rbtree.c
+ * \brief binary search tree
+ * Generic balanced binary search tree (Red Black Tree) implementation
+ * (C) 2009 by the GRASS Development Team
+ * This program is free software under the GNU General Public License
+ * (>=v2). Read the file COPYING that comes with GRASS for details.
+ * \author Original author Julienne Walker 2003, 2008
+ * GRASS implementation Markus Metz, 2009
+/* balanced binary search tree implementation
+ * this one is a Red Black Tree, the bare version, no parent pointers, no threads
+ * The core code comes from Julienne Walker's tutorials on binary search trees
+ * original license: public domain
+ * http://eternallyconfuzzled.com/tuts/datastructures/jsw_tut_rbtree.aspx
+ * some ideas come from libavl (GPL >= 2)
+ * I could have used some off-the-shelf solution, but that's boring
+ * Red Black Trees are used to maintain a data structure with
+ * search, insertion and deletion in O(log N) time
+#include <assert.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+/* internal functions */
+void rbtree_destroy2(struct RB_NODE *);
+struct RB_NODE *rbtree_single(struct RB_NODE *, int);
+struct RB_NODE *rbtree_double(struct RB_NODE *, int);
+void *rbtree_first(struct RB_TRAV *);
+void *rbtree_next(struct RB_TRAV *);
+struct RB_NODE *rbtree_make_node(size_t, void *);
+int is_red(struct RB_NODE *);
+/* create new tree and initialize
+ * returns pointer to new tree, NULL for memory allocation error
+struct RB_TREE *rbtree_create(rb_compare_fn *compare, size_t rb_datasize)
+ struct RB_TREE *tree = G_malloc(sizeof(*tree));
+ if (tree == NULL) {
+ G_warning("RB tree: Out of memory!");
+ return NULL;
+ assert(compare);
+ tree->datasize = rb_datasize;
+ tree->rb_compare = compare;
+ tree->count = 0;
+ tree->root = NULL;
+ return tree;
+/* add an item to a tree
+ * non-recursive top-down insertion
+ * the algorithm does not allow duplicates and also does not warn about a duplicate
+ * returns 1 on success, 0 on failure
+int rbtree_insert(struct RB_TREE *tree, void *data)
+ assert(tree && data);
+ if (tree->root == NULL) {
+ /* create a new root node for tree */
+ tree->root = rbtree_make_node(tree->datasize, data);
+ return 0;
+ else {
+ struct RB_NODE head = {0}; /* False tree root */
+ struct RB_NODE *g, *t; /* Grandparent & parent */
+ struct RB_NODE *p, *q; /* Iterator & parent */
+ int dir = 0, last = 0;
+ /* Set up helpers */
+ t = &head;
+ g = p = NULL;
+ q = t->link[1] = tree->root;
+ /* Search down the tree */
+ for ( ; ; ) {
+ if (q == NULL) {
+ /* Insert new node at the bottom */
+ p->link[dir] = q = rbtree_make_node(tree->datasize, data);
+ if (q == NULL)
+ return 0;
+ else if (is_red(q->link[0]) && is_red(q->link[1])) {
+ /* Color flip */
+ q->red = 1;
+ q->link[0]->red = 0;
+ q->link[1]->red = 0;
+ /* Fix red violation */
+ if (is_red(q) && is_red(p)) {
+ int dir2 = t->link[1] == g;
+ if (q == p->link[last])
+ t->link[dir2] = rbtree_single(g, !last);
+ else
+ t->link[dir2] = rbtree_double(g, !last);
+ last = dir;
+ dir = tree->rb_compare(q->data, data);
+ /* Stop if found. This check also disallows duplicates in the tree */
+ if (dir == 0)
+ break;
+ dir = dir < 0;
+ /* Move the helpers down */
+ if (g != NULL)
+ t = g;
+ g = p, p = q;
+ q = q->link[dir];
+ /* Update root */
+ tree->root = head.link[1];
+ /* Make root black */
+ tree->root->red = 0;
+ tree->count++;
+ return 1;
+/* remove an item from a tree that matches given data
+ * non-recursive top-down removal
+ * returns 1 on successful removal
+ * returns 0 if data item was not found
+int rbtree_remove(struct RB_TREE *tree, const void *data)
+ struct RB_NODE *q, *p, *g; /* Helpers */
+ struct RB_NODE *f = NULL; /* Found item */
+ int dir = 1, removed = 0;
+ return 0; /* empty tree, nothing to remove */
+ q = &head;
+ g = p = NULL;
+ q->link[1] = tree->root;
+ /* Search and push a red down */
+ while (q->link[dir] != NULL) {
+ int last = dir;
+ /* Update helpers */
+ g = p, p = q;
+ q = q->link[dir];
+ /* Save found node */
+ if (dir == 0)
+ f = q;
+ dir = dir < 0;
+ /* Push the red node down */
+ if (!is_red(q) && !is_red(q->link[dir])) {
+ if (is_red(q->link[!dir]))
+ p = p->link[last] = rbtree_single(q, dir);
+ else if (!is_red(q->link[!dir])) {
+ struct RB_NODE *s = p->link[!last];
+ if (s != NULL) {
+ if (!is_red(s->link[!last]) &&
+ !is_red(s->link[last])) {
+ /* Color flip */
+ p->red = 0;
+ s->red = 1;
+ q->red = 1;
+ else {
+ int dir2 = g->link[1] == p;
+ if (is_red(s->link[last]))
+ g->link[dir2] = rbtree_double(p, last);
+ else if (is_red(s->link[!last]))
+ g->link[dir2] = rbtree_single(p, last);
+ /* Ensure correct coloring */
+ q->red = g->link[dir2]->red = 1;
+ g->link[dir2]->link[0]->red = 0;
+ g->link[dir2]->link[1]->red = 0;
+ /* Replace and remove if found */
+ if (f != NULL) {
+ G_free(f->data);
+ f->data = q->data;
+ p->link[p->link[1] == q] = q->link[q->link[0] == NULL];
+ G_free(q);
+ tree->count--;
+ removed = 1;
+ else
+ G_debug(2, "RB tree: data not found in search tree");
+ /* Update root and make it black */
+ if ( tree->root != NULL)
+ return removed;
+/* find data item in tree
+ * returns pointer to data item if found else NULL
+void *rbtree_find(struct RB_TREE *tree, const void *data)
+ struct RB_NODE *curr_node = tree->root;
+ int cmp = 0;
+ while (curr_node != NULL) {
+ cmp = tree->rb_compare(curr_node->data, data);
+ if (cmp == 0)
+ return curr_node->data; /* found */
+ else {
+ curr_node = curr_node->link[cmp < 0];
+ return NULL;
+/* initialize tree traversal
+ * (re-)sets trav structure
+ * returns 0
+int rbtree_init_trav(struct RB_TRAV *trav, struct RB_TREE *tree)
+ assert(trav && tree);
+ trav->tree = tree;
+ trav->curr_node = tree->root;
+ trav->first = 1;
+ trav->top = 0;
+ return 0;
+/* traverse the tree in ascending order
+ * useful to get all items in the tree non-recursively
+ * struct RB_TRAV *trav needs to be initialized first
+ * returns pointer to data, NULL when finished
+void *rbtree_traverse(struct RB_TRAV *trav)
+ assert(trav);
+ if (trav->curr_node == NULL) {
+ if (trav->first)
+ G_debug(1, "RB tree: empty tree");
+ else
+ G_debug(1, "RB tree: finished traversing");
+ return NULL;
+ if (!trav->first)
+ return rbtree_next(trav);
+ else {
+ trav->first = 0;
+ return rbtree_first(trav);
+/* find start point to traverse the tree in ascending order
+ * useful to get a selection of items in the tree
+ * magnitudes faster than traversing the whole tree
+ * may return first item that's smaller or first item that's larger
+void *rbtree_traverse_start(struct RB_TRAV *trav, const void *data)
+ int dir = 0;
+ assert(trav && data);
+ if (trav->first)
+ G_warning("RB tree: empty tree");
+ else
+ G_warning("RB tree: finished traversing");
+ return NULL;
+ if (!trav->first)
+ /* else first time, get start node */
+ trav->first = 0;
+ trav->top = 0;
+ while (trav->curr_node != NULL) {
+ dir = trav->tree->rb_compare(trav->curr_node->data, data);
+ /* exact match, great! */
+ if (dir == 0)
+ return trav->curr_node->data;
+ else {
+ dir = dir < 0;
+ /* end of branch, also reached if
+ * smallest item is larger than search template or
+ * largest item is smaller than search template */
+ if (trav->curr_node->link[dir] == NULL)
+ trav->up[trav->top++] = trav->curr_node;
+ trav->curr_node = trav->curr_node->link[dir];
+ return NULL; /* should not happen */
+/* two functions needed to fully traverse the tree: initialize and continue
+ * this one here uses a stack
+ * parent pointers or threads would also be possible
+ * but these would need to be added to RB_NODE
+ * -> more memory needed for standard operations
+/* start traversing the tree
+ * returns pointer to smallest data item
+void *rbtree_first(struct RB_TRAV *trav)
+ /* get smallest item */
+ while (trav->curr_node->link[0] != NULL) {
+ trav->curr_node = trav->curr_node->link[0];
+ return trav->curr_node->data; /* return smallest item */
+/* continue traversing the tree in ascending order
+ * returns pointer to data item, NULL when finished
+void *rbtree_next(struct RB_TRAV *trav)
+ if (trav->curr_node->link[1] != NULL) {
+ /* something on the right side: larger item */
+ trav->curr_node = trav->curr_node->link[1];
+ /* go down, find smallest item in this branch */
+ else {
+ /* at smallest item in this branch, go back up */
+ struct RB_NODE *last;
+ do {
+ if (trav->top == 0) {
+ trav->curr_node = NULL;
+ break;
+ last = trav->curr_node;
+ trav->curr_node = trav->up[--trav->top];
+ } while (last == trav->curr_node->link[1]);
+ if (trav->curr_node != NULL) {
+ else
+ return NULL; /* finished traversing */
+/* destroy the tree */
+void rbtree_destroy(struct RB_TREE *tree) {
+ rbtree_destroy2(tree->root);
+ G_free(tree);
+void rbtree_destroy2(struct RB_NODE *root)
+ if (root != NULL) {
+ rbtree_destroy2(root->link[0]);
+ rbtree_destroy2(root->link[1]);
+ G_free(root->data);
+ G_free(root);
+/* used for debugging: check for errors in tree structure */
+int rbtree_debug(struct RB_TREE *tree, struct RB_NODE *root)
+ int lh, rh;
+ if (root == NULL)
+ return 1;
+ else {
+ struct RB_NODE *ln = root->link[0];
+ struct RB_NODE *rn = root->link[1];
+ int lcmp = 0, rcmp = 0;
+ /* Consecutive red links */
+ if (is_red(root)) {
+ if (is_red(ln) || is_red(rn)) {
+ G_warning("Red Black Tree debugging: Red violation");
+ return 0;
+ lh = rbtree_debug(tree, ln);
+ rh = rbtree_debug(tree, rn);
+ if (ln) {
+ lcmp = tree->rb_compare(ln->data, root->data);
+ if (rn) {
+ rcmp = tree->rb_compare(rn->data, root->data);
+ /* Invalid binary search tree:
+ * left node >= parent or right node <= parent */
+ if ((ln != NULL && lcmp > -1)
+ || (rn != NULL && rcmp < 1)) {
+ G_warning("Red Black Tree debugging: Binary tree violation" );
+ return 0;
+ /* Black height mismatch */
+ if (lh != 0 && rh != 0 && lh != rh) {
+ G_warning("Red Black Tree debugging: Black violation");
+ return 0;
+ /* Only count black links */
+ if (lh != 0 && rh != 0)
+ return is_red(root) ? lh : lh + 1;
+ else
+ return 0;
+ * internal functions for Red Black Tree maintenance *
+/* add a new node to the tree */
+struct RB_NODE *rbtree_make_node(size_t datasize, void *data)
+ struct RB_NODE *new_node = G_malloc(sizeof(*new_node));
+ if (new_node == NULL)
+ G_fatal_error("RB Search Tree: Out of memory!");
+ new_node->data = G_malloc(datasize);
+ if (new_node->data == NULL)
+ memcpy(new_node->data, data, datasize);
+ new_node->red = 1; /* 1 is red, 0 is black */
+ new_node->link[0] = NULL;
+ new_node->link[1] = NULL;
+ return new_node;
+/* check for red violation */
+int is_red(struct RB_NODE *root)
+ if (root)
+ return root->red == 1;
+ return 0;
+/* single rotation */
+struct RB_NODE *rbtree_single(struct RB_NODE *root, int dir)
+ struct RB_NODE *newroot = root->link[!dir];
+ root->link[!dir] = newroot->link[dir];
+ newroot->link[dir] = root;
+ root->red = 1;
+ newroot->red = 0;
+ return newroot;
+/* double rotation */
+struct RB_NODE *rbtree_double(struct RB_NODE *root, int dir)
+ root->link[!dir] = rbtree_single(root->link[!dir], !dir);
+ return rbtree_single(root, dir);
Added: grass/trunk/lib/segment/rbtree.h
--- grass/trunk/lib/segment/rbtree.h (rev 0)
+++ grass/trunk/lib/segment/rbtree.h 2009-10-21 15:49:13 UTC (rev 39602)
@@ -0,0 +1,112 @@
+ * USAGE *
+ * NOTE: duplicates are not supported
+ * custom compare function
+ * extern int my_compare_fn(const void *, const void *);
+ * int my_compare_fn(const void *a, const void *b) {
+ * if ((mydatastruct *) a < (mydatastruct *) b)
+ * return -1;
+ * else if ((mydatastruct *) a > (mydatastruct *) b)
+ * return 1;
+ * else if ((mydatastruct *) a == (mydatastruct *) b)
+ * return 0;
+ * create and initialize tree:
+ * struct RB_TREE *mytree = rbtree_create(my_compare_fn, item_size);
+ * insert items to tree:
+ * struct mydatastruct data = <some data>;
+ * if (rbtree_insert(mytree, &data) == 0)
+ * G_warning("could not insert data");
+ * find item in tree:
+ * if (rbtree_find(mytree, &data) == 0)
+ * G_message("data not found");
+ * delete item from tree:
+ * if (rbtree_remove(mytree, &data) == 0)
+ * G_warning("could not find data in tree");
+ * traverse tree (get all items in tree in ascending order):
+ * struct RB_TRAV trav;
+ * rbtree_init_trav(&trav, tree);
+ * while ((data = rbtree_traverse(&trav)) != NULL) {
+ * if (my_compare_fn(data, threshold_data) == 0) break;
+ * <do something with data>;
+ * get a selection of items: all data > data1 and < data2
+ * start in tree where data is last smaller or first larger compared to data1
+ * data = rbtree_traverse_start(&trav, &data1);
+ * if (data > data2) break;
+ * destroy tree:
+ * rbtree_destroy(mytree);
+ * debug the whole tree with
+ * rbtree_debug(mytree, mytree->root);
+#include <stddef.h>
+/* maximum RB Tree height */
+#define RBTREE_MAX_HEIGHT 64 /* should be more than enough */
+/* routine to compare data items
+ * return -1 if rb_a < rb_b
+ * return 0 if rb_a == rb_b
+ * return 1 if rb_a > rb_b
+typedef int rb_compare_fn(const void *rb_a, const void *rb_b);
+struct RB_NODE
+ unsigned char red; /* 0 = black, 1 = red */
+ void *data; /* any kind of data */
+ struct RB_NODE *link[2]; /* link to children: link[0] for smaller, link[1] for larger */
+struct RB_TREE
+ struct RB_NODE *root; /* root node */
+ size_t datasize; /* item size */
+ size_t count; /* number of items in tree. */
+ rb_compare_fn *rb_compare; /* function to compare data */
+struct RB_TRAV
+ struct RB_TREE *tree; /* tree being traversed */
+ struct RB_NODE *curr_node; /* current node */
+ struct RB_NODE *up[RBTREE_MAX_HEIGHT]; /* stack of parent nodes */
+ int top; /* index for stack */
+ int first; /* little helper flag */
+/* tree functions */
+struct RB_TREE *rbtree_create(rb_compare_fn *, size_t);
+void rbtree_destroy(struct RB_TREE *);
+int rbtree_insert(struct RB_TREE *, void *);
+int rbtree_remove(struct RB_TREE *, const void *);
+void *rbtree_find(struct RB_TREE *, const void *);
+/* tree traversal functions */
+int rbtree_init_trav(struct RB_TRAV *, struct RB_TREE *);
+void* rbtree_traverse(struct RB_TRAV *);
+void *rbtree_traverse_start(struct RB_TRAV *, const void *);
+/* debug tree from given node downwards */
+int rbtree_debug(struct RB_TREE *, struct RB_NODE *);
Modified: grass/trunk/lib/segment/release.c
--- grass/trunk/lib/segment/release.c 2009-10-21 15:48:12 UTC (rev 39601)
+++ grass/trunk/lib/segment/release.c 2009-10-21 15:49:13 UTC (rev 39602)
@@ -9,7 +9,7 @@
- * \date 2005-2006
+ * \date 2005-2009
#include <stdlib.h>
Modified: grass/trunk/lib/segment/seek.c
--- grass/trunk/lib/segment/seek.c 2009-10-21 15:48:12 UTC (rev 39601)
+++ grass/trunk/lib/segment/seek.c 2009-10-21 15:49:13 UTC (rev 39602)
@@ -9,15 +9,15 @@
- * \date 2005-2006
+ * \date 2005-2009
+#include <grass/config.h>
#include <stdio.h>
#include <sys/types.h>
#include <unistd.h>
#include <string.h>
#include <errno.h>
-#include <grass/config.h>
@@ -34,11 +34,23 @@
* \return -1 if unable to seek
-int segment_seek(const SEGMENT * SEG, int n, int index)
+int segment_seek_fast(const SEGMENT * SEG, int n, int index)
+ off_t offset = (((off_t) n) << SEG->sizebits) + index + SEG->offset;
+ if (lseek(SEG->fd, offset, SEEK_SET) == (off_t) - 1) {
+ G_warning("segment_seek: %s", strerror(errno));
+ return -1;
+ return 0;
+int segment_seek_slow(const SEGMENT * SEG, int n, int index)
off_t offset;
- offset = (off_t) n *SEG->size + index + SEG->offset;
+ offset = (off_t) n * SEG->size + index + SEG->offset;
@@ -47,3 +59,12 @@
return 0;
+static int (*segment_seek_mode[2]) () = {
+ segment_seek_fast, segment_seek_slow
+int segment_seek(const SEGMENT * SEG, int n, int index)
+ return (*segment_seek_mode[SEG->slow_seek]) (SEG, n, index);
Modified: grass/trunk/lib/segment/segmentlib.dox
--- grass/trunk/lib/segment/segmentlib.dox 2009-10-21 15:48:12 UTC (rev 39601)
+++ grass/trunk/lib/segment/segmentlib.dox 2009-10-21 15:49:13 UTC (rev 39602)
@@ -37,7 +37,7 @@
code and requires no significant amount of memory to hold the data. But the
i/o involved will certainly degrade performance. Method (3) is a mixture of
(1) and (2) . Memory requirements are fixed and data is read from the data
-file only when not already in memory. Howev er the programming is more
+file only when not already in memory. However the programming is more
complex.
<P>
@@ -87,11 +87,13 @@
<P>
-int segment_format (int fd, int nrows, int ncols, int srows, int scols,
- int len) format a segment fileThe segmentation routines require a disk file
- to be used for paging segments in and out of memory. This routine formats the
- file open for write on file descriptor <B>fd</B> for use as a segment file.
- A segment file must be formatted before it can be processed by other segment
+<I>int segment_format (int fd, int nrows, int ncols, int srows, int scols,
+ int len)</I>, format a segment file
+<P>
+ The segmentation routines require a disk file to be used for paging
+ segments in and out of memory. This routine formats the file open for
+ write on file descriptor <B>fd</B> for use as a segment file. A segment
+ file must be formatted before it can be processed by other segment
routines. The configuration parameters <B>nrows, ncols, srows, scols</B>,
and <B>len</B> are written to the beginning of the segment file which is
then filled with zeros.
@@ -112,8 +114,10 @@
segment file formatted by <I>segment_format.</I>
<P>
-int segment_init (SEGMENT *seg, int fd, int nsegs) initialize segment
- structureInitializes the <B>seg</B> structure. The file on <B>fd</B> is
+<I>int segment_init (SEGMENT *seg, int fd, int nsegs)</I>, initialize segment
+ structure
+<P>
+ Initializes the <B>seg</B> structure. The file on <B>fd</B> is
a segment file created by <I>segment_format</I> and must be open for
reading and writing. The segment file configuration parameters <I>nrows,
ncols, srows, scols</I>, and <I>len</I>, as written to the file by
@@ -132,8 +136,10 @@
Then data can be written from another file to the segment file row by row:
<P>
-int segment_put_row (SEGMENT *seg, char *buf, int row) write row to
- segment fileTransfers nonsegmented matrix data, row by row, into a segment
+<I>int segment_put_row (SEGMENT *seg, char *buf, int row)</I>, write row to
+ segment file
+<P>
+ Transfers nonsegmented matrix data, row by row, into a segment
file. <B>Seg</B> is the segment structure that was configured from a call
to <I>segment_init.</I> <B>Buf</B> should contain <I>ncols*len</I>
bytes of data to be transferred to the segment file. <B>Row</B> specifies
@@ -146,8 +152,10 @@
Then data can be read or written to the segment file randomly:
<P>
-int segment_get (SEGMENT *seg, char *value, int row, int col) get value
- from segment fileProvides random read access to the segmented data. It gets
+<I>int segment_get (SEGMENT *seg, char *value, int row, int col)</I>, get value
+ from segment file
+<P>
+ Provides random read access to the segmented data. It gets
<I>len</I> bytes of data into <B>value</B> from the segment file
<B>seg</B> for the corresponding <B>row</B> and <B>col</B> in the
original data matrix.
@@ -156,8 +164,10 @@
Return codes are: 1 if ok; else -1 could not seek or read segment file.
<P>
-int segment_put (SEGMENT *seg, char *value, int row, int col) put
- value to segment fileProvides random write access to the segmented data. It
+<I>int segment_put (SEGMENT *seg, char *value, int row, int col)</I>, put
+ value to segment file
+<P>
+ Provides random write access to the segmented data. It
copies <I>len</I> bytes of data from <B>value</B> into the segment
structure <B>seg</B> for the corresponding <B>row</B> and <B>col</B> in
the original data matrix.
@@ -169,26 +179,27 @@
<P>
Return codes are: 1 if ok; else -1 could not seek or write segment file.
<P>
After random reading and writing is finished, the pending updates must be
flushed to disk:
<P>
-int segment_flush (SEGMENT *seg) flush pending updates to diskForces
- all pending updates generated by <I>segment_put()</I> to be written to the
- segment file <B>seg.</B> Must be called after the final segment_put() to
- force all pending updates to disk. Must also be called before the first call
- to <I>segment_get_row.</I>
+<I>int segment_flush (SEGMENT *seg)</I>, flush pending updates to disk
+<P>
+ Forces all pending updates generated by <I>segment_put()</I> to be
+ written to the segment file <B>seg.</B> Must be called after the final
+ segment_put() to force all pending updates to disk. Must also be called
+ before the first call to <I>segment_get_row.</I>
<P>
Now the data in segment file can be read row by row and transferred to a normal
sequential data file:
<P>
-int segment_get_row (SEGMENT *seg, char *buf, int row) read row from
- segment fileTransfers data from a segment file, row by row, into memory
+<I>int segment_get_row (SEGMENT *seg, char *buf, int row)</I>, read row from
+ segment file
+<P>
+ Transfers data from a segment file, row by row, into memory
(which can then be written to a regular matrix file) . <B>Seg</B> is the
segment structure that was configured from a call to <I>segment_init.</I>
<B>Buf</B> will be filled with <I>ncols*len</I> bytes of data
@@ -201,10 +212,11 @@
Finally, memory allocated in the SEGMENT structure is freed:
<P>
-int segment_release (SEGMENT *seg) free allocated memoryReleases the
- allocated memory associated with the segment file <B>seg.</B> Does not close
- the file. Does not flush the data which may be pending from previous
- <I>segment_put()</I> calls.
+<I>int segment_release (SEGMENT *seg)</I>, free allocated memory
+<P>
+ Releases the allocated memory associated with the segment file
+ <B>seg.</B> Does not close the file. Does not flush the data which may
+ be pending from previous <I>segment_put()</I> calls.
<P>
@@ -328,10 +340,24 @@
<P>
+\section Segment_Library_Performance Segment Library Performance
+Performance of the <I>Segment Library</I> routines can be improved by
+about 10% if <B>srows, scols</B> are each powers of 2; in this case a
+faster alternative is used to access the segment file. An additional
+improvement can be achieved if <B>len</B> is also a power of 2. For
+highly random and scattered access to a large dataset, smaller segments,
+i.e. values for <B>srows, scols</B> of 32, 64, or 128 seem to provide
+better performance than e.g. srows = nrows / 4 + 1.
\section Loading_the_Segment_Library Loading the Segment Library
<P>
-The library is loaded by specifying $(SEGMENTLIB) in the Makefile.
+The library is loaded by specifying
+\verbatim
+$(SEGMENTLIB)
+\endverbatim
+in the Makefile.
<P>
See \ref Compiling_and_Installing_GRASS_Modules for a complete
Modified: grass/trunk/lib/segment/setup.c
--- grass/trunk/lib/segment/setup.c 2009-10-21 15:48:12 UTC (rev 39601)
+++ grass/trunk/lib/segment/setup.c 2009-10-21 15:49:13 UTC (rev 39602)
@@ -9,15 +9,18 @@
- * \date 2005-2006
+ * \date 2005-2009
#include <stdlib.h>
#include <stdio.h>
+#include <math.h>
* \fn int segment_setup (SEGMENT *SEG)
@@ -41,7 +44,7 @@
if (SEG->nrows <= 0 || SEG->ncols <= 0
|| SEG->srows <= 0 || SEG->scols <= 0
|| SEG->len <= 0 || SEG->nseg <= 0) {
- G_warning("segment_setup: illegal segment file parameters\n");
+ G_warning("segment_setup: illegal segment file parameters");
return -1;
@@ -53,23 +56,93 @@
if (SEG->spill)
SEG->spr++;
+ /* fast address */
+ SEG->slow_adrs = 1;
+ if (SEG->scols - pow(2, (log(SEG->scols) / log(2))) == 0) {
+ if (SEG->srows - pow(2, (log(SEG->srows) / log(2))) == 0) {
+ SEG->scolbits = log(SEG->scols) / log(2);
+ SEG->srowbits = log(SEG->srows) / log(2);
+ SEG->segbits = SEG->srowbits + SEG->scolbits;
+ SEG->slow_adrs = 0;
+ G_debug(1, "segment lib: fast address activated");
+ /* fast seek */
+ SEG->slow_seek = 1;
+ if (SEG->slow_adrs == 0) {
+ if (SEG->len - pow(2, (log(SEG->len) / log(2))) == 0) {
+ SEG->lenbits = log(SEG->len) / log(2);
+ SEG->sizebits = SEG->segbits + SEG->lenbits;
+ SEG->slow_seek = 0;
+ G_debug(1, "segment lib: fast seek activated");
+ /* adjust number of open segments if larger than number of total segments */
+ if (SEG->nseg > SEG->spr * ((SEG->nrows + SEG->srows - 1) / SEG->srows)) {
+ G_warning("segment: reducing number of open segments from %d to %d",
+ SEG->nseg, SEG->spr * ((SEG->nrows + SEG->srows - 1) / SEG->srows));
+ SEG->nseg = SEG->spr * ((SEG->nrows + SEG->srows - 1) / SEG->srows);
if ((SEG->scb =
(struct SEGMENT_SCB *)G_malloc(SEG->nseg *
sizeof(struct SEGMENT_SCB))) == NULL)
return -2;
- SEG->size = SEG->srows * SEG->scols * SEG->len;
+ if ((SEG->freeslot = (int *)G_malloc(SEG->nseg * sizeof(int))) == NULL)
+ return -2;
+ if ((SEG->agequeue = (struct aq *)G_malloc((SEG->nseg + 1) * sizeof(struct aq))) == NULL)
+ return -2;
+ SEG->srowscols = SEG->srows * SEG->scols;
+ SEG->size = SEG->srowscols * SEG->len;
for (i = 0; i < SEG->nseg; i++) {
if ((SEG->scb[i].buf = G_malloc(SEG->size)) == NULL)
return -2;
SEG->scb[i].n = -1; /* mark free */
SEG->scb[i].dirty = 0;
- SEG->scb[i].age = 0;
+ SEG->scb[i].age = NULL;
+ SEG->freeslot[i] = i;
+ SEG->agequeue[i].cur = -1;
+ if (i > 0) {
+ SEG->agequeue[i].younger = &(SEG->agequeue[i - 1]);
+ SEG->agequeue[i].older = &(SEG->agequeue[i + 1]);
+ else if (i == 0) {
+ SEG->agequeue[i].younger = &(SEG->agequeue[SEG->nseg]);
+ SEG->agequeue[SEG->nseg].cur = -1;
+ SEG->agequeue[SEG->nseg].younger = &(SEG->agequeue[SEG->nseg - 1]);
+ SEG->agequeue[SEG->nseg].older = &(SEG->agequeue[0]);
+ SEG->youngest = SEG->oldest = &(SEG->agequeue[SEG->nseg]);
+ SEG->nfreeslots = SEG->nseg;
SEG->cur = 0;
SEG->open = 1;
+ SEG->loaded = rbtree_create(segment_compare, sizeof(SEGID));
return 1;
+int segment_compare(const void *sega, const void *segb)
+ SEGID *a, *b;
+ a = (SEGID *)sega;
+ b = (SEGID *)segb;
+ if (a->n > b->n)
+ return 1;
+ else if (a->n < b->n)
+ return -1;
+ return 0;
