[GRASS-SVN] r39604 - grass/trunk/raster/r.watershed/seg
svn_grass at osgeo.org
Wed Oct 21 11:53:30 EDT 2009
Author: mmetz
Date: 2009-10-21 11:53:30 -0400 (Wed, 21 Oct 2009)
New Revision: 39604
Added:
grass/trunk/raster/r.watershed/seg/do_stream.c
more accurate stream extraction
Added: grass/trunk/raster/r.watershed/seg/do_stream.c
--- grass/trunk/raster/r.watershed/seg/do_stream.c (rev 0)
+++ grass/trunk/raster/r.watershed/seg/do_stream.c 2009-10-21 15:53:30 UTC (rev 39604)
@@ -0,0 +1,216 @@
+#include "Gwater.h"
+#include <unistd.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+int do_stream(void)
+ int r, c, dr, dc;
+ char is_swale;
+ DCELL value, *wat_nbr;
+ WAT_ALT wa;
+ POINT point;
+ int killer, threshold, count;
+ /* Breadth First Search */
+ int stream_cells, swale_cells;
+ int r_nbr, c_nbr, r_max, c_max, ct_dir, np_side;
+ CELL ele, *ele_nbr, asp_val, asp_val_down;
+ double max_acc;
+ int edge;
+ char *flag_nbr, this_flag_value, flag_value;
+ int workedon;
+ SHORT asp_r[9] = { 0, -1, -1, -1, 0, 1, 1, 1, 0 };
+ SHORT asp_c[9] = { 0, 1, 0, -1, -1, -1, 0, 1, 1 };
+ G_message(_("SECTION 4: Extracting Streams."));
+ flag_nbr = (char *)G_malloc(sides * sizeof(char));
+ wat_nbr = (DCELL *)G_malloc(sides * sizeof(DCELL));
+ ele_nbr = (CELL *)G_malloc(sides * sizeof(CELL));
+ workedon = 0;
+ count = 0;
+ if (bas_thres <= 0)
+ threshold = 60;
+ else
+ threshold = bas_thres;
+ for (killer = 0; killer < do_points; killer++) {
+ G_percent(count++, do_points, 1);
+ seg_get(&astar_pts, (char *)&point, 0, killer);
+ r = point.r;
+ c = point.c;
+ cseg_get(&asp, &asp_val, r, c);
+ if (asp_val) {
+ dr = r + asp_r[ABS(asp_val)];
+ dc = c + asp_c[ABS(asp_val)];
+ else
+ dr = dc = -1;
+ if (dr >= 0 && dr < nrows && dc >= 0 && dc < ncols) {
+ bseg_get(&bitflags, &this_flag_value, r, c);
+ /* do not continue streams along edges, this causes artifacts */
+ if (FLAG_GET(this_flag_value, EDGEFLAG)) {
+ is_swale = FLAG_GET(this_flag_value, SWALEFLAG);
+ if (is_swale && asp_val > 0) {
+ /* find first neighbour that is NULL or outside region */
+ for (ct_dir = 0; ct_dir < sides; ct_dir++) {
+ r_nbr = r + nextdr[ct_dir];
+ c_nbr = c + nextdc[ct_dir];
+ /* check if neighbour is within region */
+ if (r_nbr >= 0 && r_nbr < nrows && c_nbr >= 0 &&
+ c_nbr < ncols) {
+ bseg_get(&bitflags, &flag_value, r_nbr, c_nbr);
+ if (FLAG_GET(flag_value, NULLFLAG)) {
+ asp_val = -1 * drain[r - r_nbr + 1][c - c_nbr + 1];
+ break;
+ else {
+ break;
+ cseg_put(&asp, &asp_val, r, c);
+ continue;
+ seg_get(&watalt, (char *)&wa, r, c);
+ value = wa.wat;
+ if (point.guessed && value > 0)
+ value = -value;
+ r_max = dr;
+ c_max = dc;
+ np_side = -1;
+ stream_cells = 0;
+ swale_cells = 0;
+ max_acc = -1;
+ ele = wa.ele;
+ edge = 0;
+ /* visit all neighbours */
+ /* get r, c (r_nbr, c_nbr) for neighbours */
+ wat_nbr[ct_dir] = 0;
+ ele_nbr[ct_dir] = 0;
+ FLAG_SET(flag_nbr[ct_dir], WORKEDFLAG);
+ if (dr == r_nbr && dc == c_nbr)
+ np_side = ct_dir;
+ c_nbr < ncols) {
+ /* check for swale or stream cells */
+ bseg_get(&bitflags, &flag_nbr[ct_dir], r_nbr, c_nbr);
+ is_swale = FLAG_GET(flag_nbr[ct_dir], SWALEFLAG);
+ if (is_swale)
+ swale_cells++;
+ seg_get(&watalt, (char *)&wa, r_nbr, c_nbr);
+ wat_nbr[ct_dir] = wa.wat;
+ if (fabs(wat_nbr[ct_dir]) >= threshold)
+ stream_cells++;
+ if (!FLAG_GET(flag_nbr[ct_dir], WORKEDFLAG)) {
+ ele_nbr[ct_dir] = wa.ele;
+ edge = FLAG_GET(flag_nbr[ct_dir], NULLFLAG);
+ if (!edge && ele_nbr[ct_dir] <= ele) {
+ /* set main drainage direction */
+ if (fabs(wat_nbr[ct_dir]) >= max_acc) {
+ max_acc = fabs(wat_nbr[ct_dir]);
+ r_max = r_nbr;
+ c_max = c_nbr;
+ else if (ct_dir == np_side && !edge) {
+ /* check for consistency with main drainage direction */
+ workedon++;
+ else
+ edge = 1;
+ if (edge)
+ break;
+ if (edge) {
+ continue;
+ /* adjust main drainage direction to A* path if possible */
+ if (fabs(wat_nbr[np_side]) >= max_acc) {
+ r_max = dr;
+ c_max = dc;
+ /* update asp */
+ if (dr != r_max || dc != c_max) {
+ if (asp_val > 0) {
+ asp_val = drain[r - r_max + 1][c - c_max + 1];
+ /* start new stream */
+ value = fabs(value) + 0.5;
+ if (!is_swale && (int)value >= threshold && stream_cells < 4 &&
+ swale_cells < 1) {
+ FLAG_SET(this_flag_value, SWALEFLAG);
+ is_swale = 1;
+ /* update asp for depression */
+ if (is_swale && pit_flag) {
+ cseg_get(&asp, &asp_val_down, dr, dc);
+ if (asp_val > 0 && asp_val_down == 0) {
+ asp_val = -asp_val;
+ /* continue stream */
+ if (is_swale) {
+ bseg_get(&bitflags, &flag_value, r_max, c_max);
+ FLAG_SET(flag_value, SWALEFLAG);
+ bseg_put(&bitflags, &flag_value, r_max, c_max);
+ else {
+ if (er_flag && !is_swale && !FLAG_GET(this_flag_value, RUSLEBLOCKFLAG))
+ slope_length(r, c, r_max, c_max);
+ FLAG_SET(this_flag_value, WORKEDFLAG);
+ bseg_put(&bitflags, &this_flag_value, r, c);
+ G_percent(count, do_points, 1); /* finish it */
+ if (workedon)
+ G_warning(_("MFD: A * path already processed when extracting streams: %d of %d cells"),
+ workedon, do_points);
+ seg_close(&astar_pts);
+ G_free(wat_nbr);
+ G_free(ele_nbr);
+ G_free(flag_nbr);
+ return 0;
