[GRASS-SVN] r39611 - in grass/trunk: . include/Make
Thu Oct 22 16:12:19 EDT 2009
Author: martinl
Date: 2009-10-22 16:12:17 -0400 (Thu, 22 Oct 2009)
New Revision: 39611
Added:
   grass/trunk/include/Make/Doxyfile_arch_html.in
   grass/trunk/include/Make/Doxyfile_arch_latex.in
Removed:
   grass/trunk/configure
   grass/trunk/configure.in
doxygen: be more precise about version (taken from Platform)
enable search engine
Modified: grass/trunk/configure
--- grass/trunk/configure	2009-10-22 18:11:52 UTC (rev 39610)
+++ grass/trunk/configure	2009-10-22 20:12:17 UTC (rev 39611)
@@ -15592,7 +15592,7 @@
 ac_given_srcdir=$srcdir
 ac_given_INSTALL="$INSTALL"
-trap 'rm -fr `echo "include/Make/Platform.make include/version.h swig/perl/Makefile.PL swig/perl2/make.pl grass.pc include/config.h" | sed "s/:[^ ]*//g"` conftest*; exit 1' 1 2 15
+trap 'rm -fr `echo "include/Make/Platform.make include/Make/Doxyfile_arch_html include/Make/Doxyfile_arch_latex include/version.h swig/perl/Makefile.PL swig/perl2/make.pl grass.pc include/config.h" | sed "s/:[^ ]*//g"` conftest*; exit 1' 1 2 15
 EOF
 cat >> $CONFIG_STATUS <<EOF
@@ -15854,7 +15854,7 @@
-CONFIG_FILES=\${CONFIG_FILES-"include/Make/Platform.make include/version.h swig/perl/Makefile.PL swig/perl2/make.pl grass.pc"}
+CONFIG_FILES=\${CONFIG_FILES-"include/Make/Platform.make include/Make/Doxyfile_arch_html include/Make/Doxyfile_arch_latex include/version.h swig/perl/Makefile.PL swig/perl2/make.pl grass.pc"}
 EOF
 cat >> $CONFIG_STATUS <<\EOF
 for ac_file in .. $CONFIG_FILES; do if test "x$ac_file" != x..; then
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2009-10-22 18:11:52 UTC (rev 39610)
+++ grass/trunk/configure.in	2009-10-22 20:12:17 UTC (rev 39611)
@@ -1907,7 +1907,7 @@
 GRASS_HOME=${DSTDIR}
 AC_SUBST(GRASS_HOME)
-AC_OUTPUT(include/Make/Platform.make include/version.h swig/perl/Makefile.PL swig/perl2/make.pl grass.pc)
+AC_OUTPUT(include/Make/Platform.make include/Make/Doxyfile_arch_html include/Make/Doxyfile_arch_latex include/version.h swig/perl/Makefile.PL swig/perl2/make.pl grass.pc)
 LOC_MSG([Copying config.status to config.status.${ARCH}])
 cp -f config.status config.status.${ARCH}
Deleted: grass/trunk/include/Make/Doxyfile_arch_html
--- grass/trunk/include/Make/Doxyfile_arch_html	2009-10-22 18:11:52 UTC (rev 39610)
+++ grass/trunk/include/Make/Doxyfile_arch_html	2009-10-22 20:12:17 UTC (rev 39611)
@@ -1,1165 +0,0 @@
-# Doxyfile 1.3.9.1
-# This file describes the settings to be used by the documentation system
-# doxygen (www.doxygen.org) for a project
-# All text after a hash (#) is considered a comment and will be ignored
-# The format is:
-#       TAG = value [value, ...]
-# For lists items can also be appended using:
-#       TAG += value [value, ...]
-# Values that contain spaces should be placed between quotes (" ")
-# Project related configuration options
-# The PROJECT_NAME tag is a single word (or a sequence of words surrounded
-# by quotes) that should identify the project.
-PROJECT_NAME           = "GRASS Programmer's Manual"
-# The PROJECT_NUMBER tag can be used to enter a project or revision number.
-# This could be handy for archiving the generated documentation or
-# if some version control system is used.
-PROJECT_NUMBER         = 7
-# The OUTPUT_DIRECTORY tag is used to specify the (relative or absolute)
-# base path where the generated documentation will be put.
-# If a relative path is entered, it will be relative to the location
-# where doxygen was started. If left blank the current directory will be used.
-OUTPUT_DIRECTORY       = .
-# If the CREATE_SUBDIRS tag is set to YES, then doxygen will create
-# 4096 sub-directories (in 2 levels) under the output directory of each output
-# format and will distribute the generated files over these directories.
-# Enabling this option can be useful when feeding doxygen a huge amount of source
-# files, where putting all generated files in the same directory would otherwise
-# cause performance problems for the file system.
-CREATE_SUBDIRS         = NO
-# The OUTPUT_LANGUAGE tag is used to specify the language in which all
-# documentation generated by doxygen is written. Doxygen will use this
-# information to generate all constant output in the proper language.
-# The default language is English, other supported languages are:
-# Brazilian, Catalan, Chinese, Chinese-Traditional, Croatian, Czech, Danish,
-# Dutch, Finnish, French, German, Greek, Hungarian, Italian, Japanese,
-# Japanese-en (Japanese with English messages), Korean, Korean-en, Norwegian,
-# Polish, Portuguese, Romanian, Russian, Serbian, Slovak, Slovene, Spanish,
-# Swedish, and Ukrainian.
-OUTPUT_LANGUAGE        = English
-# This tag can be used to specify the encoding used in the generated output.
-# The encoding is not always determined by the language that is chosen,
-# but also whether or not the output is meant for Windows or non-Windows users.
-# In case there is a difference, setting the USE_WINDOWS_ENCODING tag to YES
-# forces the Windows encoding (this is the default for the Windows binary),
-# whereas setting the tag to NO uses a Unix-style encoding (the default for
-# all platforms other than Windows).
-USE_WINDOWS_ENCODING   = NO
-# If the BRIEF_MEMBER_DESC tag is set to YES (the default) Doxygen will
-# include brief member descriptions after the members that are listed in
-# the file and class documentation (similar to JavaDoc).
-# Set to NO to disable this.
-BRIEF_MEMBER_DESC      = YES
-# If the REPEAT_BRIEF tag is set to YES (the default) Doxygen will prepend
-# the brief description of a member or function before the detailed description.
-# Note: if both HIDE_UNDOC_MEMBERS and BRIEF_MEMBER_DESC are set to NO, the
-# brief descriptions will be completely suppressed.
-REPEAT_BRIEF           = YES
-# This tag implements a quasi-intelligent brief description abbreviator
-# that is used to form the text in various listings. Each string
-# in this list, if found as the leading text of the brief description, will be
-# stripped from the text and the result after processing the whole list, is used
-# as the annotated text. Otherwise, the brief description is used as-is. If left
-# blank, the following values are used ("$name" is automatically replaced with the
-# name of the entity): "The $name class" "The $name widget" "The $name file"
-# "is" "provides" "specifies" "contains" "represents" "a" "an" "the"
-ABBREVIATE_BRIEF       =
-# If the ALWAYS_DETAILED_SEC and REPEAT_BRIEF tags are both set to YES then
-# Doxygen will generate a detailed section even if there is only a brief
-# description.
-ALWAYS_DETAILED_SEC    = NO
-# If the INLINE_INHERITED_MEMB tag is set to YES, doxygen will show all inherited
-# members of a class in the documentation of that class as if those members were
-# ordinary class members. Constructors, destructors and assignment operators of
-# the base classes will not be shown.
-INLINE_INHERITED_MEMB  = NO
-# If the FULL_PATH_NAMES tag is set to YES then Doxygen will prepend the full
-# path before files name in the file list and in the header files. If set
-# to NO the shortest path that makes the file name unique will be used.
-FULL_PATH_NAMES        = NO
-# If the FULL_PATH_NAMES tag is set to YES then the STRIP_FROM_PATH tag
-# can be used to strip a user-defined part of the path. Stripping is
-# only done if one of the specified strings matches the left-hand part of
-# the path. The tag can be used to show relative paths in the file list.
-# If left blank the directory from which doxygen is run is used as the
-# path to strip.
-STRIP_FROM_PATH        =
-# The STRIP_FROM_INC_PATH tag can be used to strip a user-defined part of
-# the path mentioned in the documentation of a class, which tells
-# the reader which header file to include in order to use a class.
-# If left blank only the name of the header file containing the class
-# definition is used. Otherwise one should specify the include paths that
-# are normally passed to the compiler using the -I flag.
-STRIP_FROM_INC_PATH    =
-# If the SHORT_NAMES tag is set to YES, doxygen will generate much shorter
-# (but less readable) file names. This can be useful is your file systems
-# doesn't support long names like on DOS, Mac, or CD-ROM.
-SHORT_NAMES            = NO
-# If the JAVADOC_AUTOBRIEF tag is set to YES then Doxygen
-# will interpret the first line (until the first dot) of a JavaDoc-style
-# comment as the brief description. If set to NO, the JavaDoc
-# comments will behave just like the Qt-style comments (thus requiring an
-# explicit @brief command for a brief description.
-JAVADOC_AUTOBRIEF      = NO
-# The MULTILINE_CPP_IS_BRIEF tag can be set to YES to make Doxygen
-# treat a multi-line C++ special comment block (i.e. a block of //! or ///
-# comments) as a brief description. This used to be the default behaviour.
-# The new default is to treat a multi-line C++ comment block as a detailed
-# description. Set this tag to YES if you prefer the old behaviour instead.
-MULTILINE_CPP_IS_BRIEF = NO
-# If the DETAILS_AT_TOP tag is set to YES then Doxygen
-# will output the detailed description near the top, like JavaDoc.
-# If set to NO, the detailed description appears after the member
-# documentation.
-DETAILS_AT_TOP         = NO
-# If the INHERIT_DOCS tag is set to YES (the default) then an undocumented
-# member inherits the documentation from any documented member that it
-# re-implements.
-INHERIT_DOCS           = YES
-# If member grouping is used in the documentation and the DISTRIBUTE_GROUP_DOC
-# tag is set to YES, then doxygen will reuse the documentation of the first
-# member in the group (if any) for the other members of the group. By default
-# all members of a group must be documented explicitly.
-DISTRIBUTE_GROUP_DOC   = NO
-# The TAB_SIZE tag can be used to set the number of spaces in a tab.
-# Doxygen uses this value to replace tabs by spaces in code fragments.
-TAB_SIZE               = 8
-# This tag can be used to specify a number of aliases that acts
-# as commands in the documentation. An alias has the form "name=value".
-# For example adding "sideeffect=\par Side Effects:\n" will allow you to
-# put the command \sideeffect (or @sideeffect) in the documentation, which
-# will result in a user-defined paragraph with heading "Side Effects:".
-# You can put \n's in the value part of an alias to insert newlines.
-ALIASES                =
-# Set the OPTIMIZE_OUTPUT_FOR_C tag to YES if your project consists of C sources
-# only. Doxygen will then generate output that is more tailored for C.
-# For instance, some of the names that are used will be different. The list
-# of all members will be omitted, etc.
-OPTIMIZE_OUTPUT_FOR_C  = YES
-# Set the OPTIMIZE_OUTPUT_JAVA tag to YES if your project consists of Java sources
-# only. Doxygen will then generate output that is more tailored for Java.
-# For instance, namespaces will be presented as packages, qualified scopes
-# will look different, etc.
-OPTIMIZE_OUTPUT_JAVA   = NO
-# Set the SUBGROUPING tag to YES (the default) to allow class member groups of
-# the same type (for instance a group of public functions) to be put as a
-# subgroup of that type (e.g. under the Public Functions section). Set it to
-# NO to prevent subgrouping. Alternatively, this can be done per class using
-# the \nosubgrouping command.
-SUBGROUPING            = YES
-# Build related configuration options
-# If the EXTRACT_ALL tag is set to YES doxygen will assume all entities in
-# documentation are documented, even if no documentation was available.
-# Private class members and static file members will be hidden unless
-# the EXTRACT_PRIVATE and EXTRACT_STATIC tags are set to YES
-EXTRACT_ALL            = YES
-# If the EXTRACT_PRIVATE tag is set to YES all private members of a class
-# will be included in the documentation.
-EXTRACT_PRIVATE        = NO
-# If the EXTRACT_STATIC tag is set to YES all static members of a file
-EXTRACT_STATIC         = NO
-# If the EXTRACT_LOCAL_CLASSES tag is set to YES classes (and structs)
-# defined locally in source files will be included in the documentation.
-# If set to NO only classes defined in header files are included.
-EXTRACT_LOCAL_CLASSES  = YES
-# This flag is only useful for Objective-C code. When set to YES local
-# methods, which are defined in the implementation section but not in
-# the interface are included in the documentation.
-# If set to NO (the default) only methods in the interface are included.
-EXTRACT_LOCAL_METHODS  = NO
-# If the HIDE_UNDOC_MEMBERS tag is set to YES, Doxygen will hide all
-# undocumented members of documented classes, files or namespaces.
-# If set to NO (the default) these members will be included in the
-# various overviews, but no documentation section is generated.
-# This option has no effect if EXTRACT_ALL is enabled.
-HIDE_UNDOC_MEMBERS     = NO
-# If the HIDE_UNDOC_CLASSES tag is set to YES, Doxygen will hide all
-# undocumented classes that are normally visible in the class hierarchy.
-# If set to NO (the default) these classes will be included in the various
-# overviews. This option has no effect if EXTRACT_ALL is enabled.
-HIDE_UNDOC_CLASSES     = NO
-# If the HIDE_FRIEND_COMPOUNDS tag is set to YES, Doxygen will hide all
-# friend (class|struct|union) declarations.
-# If set to NO (the default) these declarations will be included in the
-# documentation.
-HIDE_FRIEND_COMPOUNDS  = NO
-# If the HIDE_IN_BODY_DOCS tag is set to YES, Doxygen will hide any
-# documentation blocks found inside the body of a function.
-# If set to NO (the default) these blocks will be appended to the
-# function's detailed documentation block.
-HIDE_IN_BODY_DOCS      = NO
-# The INTERNAL_DOCS tag determines if documentation
-# that is typed after a \internal command is included. If the tag is set
-# to NO (the default) then the documentation will be excluded.
-# Set it to YES to include the internal documentation.
-INTERNAL_DOCS          = NO
-# If the CASE_SENSE_NAMES tag is set to NO then Doxygen will only generate
-# file names in lower-case letters. If set to YES upper-case letters are also
-# allowed. This is useful if you have classes or files whose names only differ
-# in case and if your file system supports case sensitive file names. Windows
-# and Mac users are advised to set this option to NO.
-CASE_SENSE_NAMES       = YES
-# If the HIDE_SCOPE_NAMES tag is set to NO (the default) then Doxygen
-# will show members with their full class and namespace scopes in the
-# documentation. If set to YES the scope will be hidden.
-HIDE_SCOPE_NAMES       = NO
-# If the SHOW_INCLUDE_FILES tag is set to YES (the default) then Doxygen
-# will put a list of the files that are included by a file in the documentation
-# of that file.
-SHOW_INCLUDE_FILES     = YES
-# If the INLINE_INFO tag is set to YES (the default) then a tag [inline]
-# is inserted in the documentation for inline members.
-INLINE_INFO            = YES
-# If the SORT_MEMBER_DOCS tag is set to YES (the default) then doxygen
-# will sort the (detailed) documentation of file and class members
-# alphabetically by member name. If set to NO the members will appear in
-# declaration order.
-SORT_MEMBER_DOCS       = YES
-# If the SORT_BRIEF_DOCS tag is set to YES then doxygen will sort the
-# brief documentation of file, namespace and class members alphabetically
-# by member name. If set to NO (the default) the members will appear in
-SORT_BRIEF_DOCS        = NO
-# If the SORT_BY_SCOPE_NAME tag is set to YES, the class list will be
-# sorted by fully-qualified names, including namespaces. If set to
-# NO (the default), the class list will be sorted only by class name,
-# not including the namespace part.
-# Note: This option is not very useful if HIDE_SCOPE_NAMES is set to YES.
-# Note: This option applies only to the class list, not to the
-# alphabetical list.
-SORT_BY_SCOPE_NAME     = NO
-# The GENERATE_TODOLIST tag can be used to enable (YES) or
-# disable (NO) the todo list. This list is created by putting \todo
-# commands in the documentation.
-GENERATE_TODOLIST      = YES
-# The GENERATE_TESTLIST tag can be used to enable (YES) or
-# disable (NO) the test list. This list is created by putting \test
-GENERATE_TESTLIST      = YES
-# The GENERATE_BUGLIST tag can be used to enable (YES) or
-# disable (NO) the bug list. This list is created by putting \bug
-GENERATE_BUGLIST       = YES
-# The GENERATE_DEPRECATEDLIST tag can be used to enable (YES) or
-# disable (NO) the deprecated list. This list is created by putting
-# \deprecated commands in the documentation.
-GENERATE_DEPRECATEDLIST= YES
-# The ENABLED_SECTIONS tag can be used to enable conditional
-# documentation sections, marked by \if sectionname ... \endif.
-ENABLED_SECTIONS       =
-# The MAX_INITIALIZER_LINES tag determines the maximum number of lines
-# the initial value of a variable or define consists of for it to appear in
-# the documentation. If the initializer consists of more lines than specified
-# here it will be hidden. Use a value of 0 to hide initializers completely.
-# The appearance of the initializer of individual variables and defines in the
-# documentation can be controlled using \showinitializer or \hideinitializer
-# command in the documentation regardless of this setting.
-MAX_INITIALIZER_LINES  = 30
-# Set the SHOW_USED_FILES tag to NO to disable the list of files generated
-# at the bottom of the documentation of classes and structs. If set to YES the
-# list will mention the files that were used to generate the documentation.
-SHOW_USED_FILES        = YES
-# If the sources in your project are distributed over multiple directories
-# then setting the SHOW_DIRECTORIES tag to YES will show the directory hierarchy
-# in the documentation.
-SHOW_DIRECTORIES       = YES
-# configuration options related to warning and progress messages
-# The QUIET tag can be used to turn on/off the messages that are generated
-# by doxygen. Possible values are YES and NO. If left blank NO is used.
-QUIET                  = NO
-# The WARNINGS tag can be used to turn on/off the warning messages that are
-# generated by doxygen. Possible values are YES and NO. If left blank
-# NO is used.
-WARNINGS               = YES
-# If WARN_IF_UNDOCUMENTED is set to YES, then doxygen will generate warnings
-# for undocumented members. If EXTRACT_ALL is set to YES then this flag will
-# automatically be disabled.
-WARN_IF_UNDOCUMENTED   = YES
-# If WARN_IF_DOC_ERROR is set to YES, doxygen will generate warnings for
-# potential errors in the documentation, such as not documenting some
-# parameters in a documented function, or documenting parameters that
-# don't exist or using markup commands wrongly.
-WARN_IF_DOC_ERROR      = YES
-# The WARN_FORMAT tag determines the format of the warning messages that
-# doxygen can produce. The string should contain the $file, $line, and $text
-# tags, which will be replaced by the file and line number from which the
-# warning originated and the warning text.
-WARN_FORMAT            = "$file:$line: $text"
-# The WARN_LOGFILE tag can be used to specify a file to which warning
-# and error messages should be written. If left blank the output is written
-# to stderr.
-WARN_LOGFILE           =
-# configuration options related to the input files
-# The INPUT tag can be used to specify the files and/or directories that contain
-# documented source files. You may enter file names like "myfile.cpp" or
-# directories like "/usr/src/myproject". Separate the files or directories
-# with spaces.
-INPUT                  = .
-# If the value of the INPUT tag contains directories, you can use the
-# FILE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
-# and *.h) to filter out the source-files in the directories. If left
-# blank the following patterns are tested:
-# *.c *.cc *.cxx *.cpp *.c++ *.java *.ii *.ixx *.ipp *.i++ *.inl *.h *.hh *.hxx *.hpp
-# *.h++ *.idl *.odl *.cs *.php *.php3 *.inc *.m *.mm
-FILE_PATTERNS          = *.h \
-                         *.c \
-			 *.i \
-                         *.py \
-                         *.dox
-# The RECURSIVE tag can be used to turn specify whether or not subdirectories
-# should be searched for input files as well. Possible values are YES and NO.
-# If left blank NO is used.
-RECURSIVE              = YES
-# The EXCLUDE tag can be used to specify files and/or directories that should
-# excluded from the INPUT source files. This way you can easily exclude a
-# subdirectory from a directory tree whose root is specified with the INPUT tag.
-EXCLUDE                =
-# The EXCLUDE_SYMLINKS tag can be used select whether or not files or directories
-# that are symbolic links (a Unix filesystem feature) are excluded from the input.
-EXCLUDE_SYMLINKS       = NO
-# EXCLUDE_PATTERNS tag to specify one or more wildcard patterns to exclude
-# certain files from those directories.
-EXCLUDE_PATTERNS       =
-# The EXAMPLE_PATH tag can be used to specify one or more files or
-# directories that contain example code fragments that are included (see
-# the \include command).
-EXAMPLE_PATH           =
-# If the value of the EXAMPLE_PATH tag contains directories, you can use the
-# EXAMPLE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
-# blank all files are included.
-EXAMPLE_PATTERNS       =
-# If the EXAMPLE_RECURSIVE tag is set to YES then subdirectories will be
-# searched for input files to be used with the \include or \dontinclude
-# commands irrespective of the value of the RECURSIVE tag.
-# Possible values are YES and NO. If left blank NO is used.
-EXAMPLE_RECURSIVE      = NO
-# The IMAGE_PATH tag can be used to specify one or more files or
-# directories that contain image that are included in the documentation (see
-# the \image command).
-IMAGE_PATH             = .
-# The INPUT_FILTER tag can be used to specify a program that doxygen should
-# invoke to filter for each input file. Doxygen will invoke the filter program
-# by executing (via popen()) the command <filter> <input-file>, where <filter>
-# is the value of the INPUT_FILTER tag, and <input-file> is the name of an
-# input file. Doxygen will then use the output that the filter program writes
-# to standard output.  If FILTER_PATTERNS is specified, this tag will be
-# ignored.
-INPUT_FILTER           =
-# The FILTER_PATTERNS tag can be used to specify filters on a per file pattern
-# basis.  Doxygen will compare the file name with each pattern and apply the
-# filter if there is a match.  The filters are a list of the form:
-# pattern=filter (like *.cpp=my_cpp_filter). See INPUT_FILTER for further
-# info on how filters are used. If FILTER_PATTERNS is empty, INPUT_FILTER
-# is applied to all files.
-FILTER_PATTERNS        =
-# If the FILTER_SOURCE_FILES tag is set to YES, the input filter (if set using
-# INPUT_FILTER) will be used to filter the input files when producing source
-# files to browse (i.e. when SOURCE_BROWSER is set to YES).
-FILTER_SOURCE_FILES    = NO
-# configuration options related to source browsing
-# If the SOURCE_BROWSER tag is set to YES then a list of source files will
-# be generated. Documented entities will be cross-referenced with these sources.
-# Note: To get rid of all source code in the generated output, make sure also
-# VERBATIM_HEADERS is set to NO.
-SOURCE_BROWSER         = YES
-# Setting the INLINE_SOURCES tag to YES will include the body
-# of functions and classes directly in the documentation.
-INLINE_SOURCES         = NO
-# Setting the STRIP_CODE_COMMENTS tag to YES (the default) will instruct
-# doxygen to hide any special comment blocks from generated source code
-# fragments. Normal C and C++ comments will always remain visible.
-STRIP_CODE_COMMENTS    = YES
-# If the REFERENCED_BY_RELATION tag is set to YES (the default)
-# then for each documented function all documented
-# functions referencing it will be listed.
-REFERENCED_BY_RELATION = YES
-# If the REFERENCES_RELATION tag is set to YES (the default)
-# then for each documented function all documented entities
-# called/used by that function will be listed.
-REFERENCES_RELATION    = YES
-# If the VERBATIM_HEADERS tag is set to YES (the default) then Doxygen
-# will generate a verbatim copy of the header file for each class for
-# which an include is specified. Set to NO to disable this.
-VERBATIM_HEADERS       = YES
-# configuration options related to the alphabetical class index
-# If the ALPHABETICAL_INDEX tag is set to YES, an alphabetical index
-# of all compounds will be generated. Enable this if the project
-# contains a lot of classes, structs, unions or interfaces.
-ALPHABETICAL_INDEX     = NO
-# If the alphabetical index is enabled (see ALPHABETICAL_INDEX) then
-# the COLS_IN_ALPHA_INDEX tag can be used to specify the number of columns
-# in which this list will be split (can be a number in the range [1..20])
-COLS_IN_ALPHA_INDEX    = 5
-# In case all classes in a project start with a common prefix, all
-# classes will be put under the same header in the alphabetical index.
-# The IGNORE_PREFIX tag can be used to specify one or more prefixes that
-# should be ignored while generating the index headers.
-IGNORE_PREFIX          =
-# configuration options related to the HTML output
-# If the GENERATE_HTML tag is set to YES (the default) Doxygen will
-# generate HTML output.
-GENERATE_HTML          = YES
-# The HTML_OUTPUT tag is used to specify where the HTML docs will be put.
-# If a relative path is entered the value of OUTPUT_DIRECTORY will be
-# put in front of it. If left blank `html' will be used as the default path.
-HTML_OUTPUT            =
-# The HTML_FILE_EXTENSION tag can be used to specify the file extension for
-# each generated HTML page (for example: .htm,.php,.asp). If it is left blank
-# doxygen will generate files with .html extension.
-HTML_FILE_EXTENSION    =
-# The HTML_HEADER tag can be used to specify a personal HTML header for
-# each generated HTML page. If it is left blank doxygen will generate a
-# standard header.
-HTML_HEADER            =
-# The HTML_FOOTER tag can be used to specify a personal HTML footer for
-# standard footer.
-HTML_FOOTER            =
-# The HTML_STYLESHEET tag can be used to specify a user-defined cascading
-# style sheet that is used by each HTML page. It can be used to
-# fine-tune the look of the HTML output. If the tag is left blank doxygen
-# will generate a default style sheet. Note that doxygen will try to copy
-# the style sheet file to the HTML output directory, so don't put your own
-# stylesheet in the HTML output directory as well, or it will be erased!
-HTML_STYLESHEET        =
-# If the HTML_ALIGN_MEMBERS tag is set to YES, the members of classes,
-# files or namespaces will be aligned in HTML using tables. If set to
-# NO a bullet list will be used.
-HTML_ALIGN_MEMBERS     = YES
-# If the GENERATE_HTMLHELP tag is set to YES, additional index files
-# will be generated that can be used as input for tools like the
-# Microsoft HTML help workshop to generate a compressed HTML help file (.chm)
-# of the generated HTML documentation.
-GENERATE_HTMLHELP      = NO
-# If the GENERATE_HTMLHELP tag is set to YES, the CHM_FILE tag can
-# be used to specify the file name of the resulting .chm file. You
-# can add a path in front of the file if the result should not be
-# written to the html output directory.
-CHM_FILE               =
-# If the GENERATE_HTMLHELP tag is set to YES, the HHC_LOCATION tag can
-# be used to specify the location (absolute path including file name) of
-# the HTML help compiler (hhc.exe). If non-empty doxygen will try to run
-# the HTML help compiler on the generated index.hhp.
-HHC_LOCATION           =
-# If the GENERATE_HTMLHELP tag is set to YES, the GENERATE_CHI flag
-# controls if a separate .chi index file is generated (YES) or that
-# it should be included in the master .chm file (NO).
-GENERATE_CHI           = NO
-# If the GENERATE_HTMLHELP tag is set to YES, the BINARY_TOC flag
-# controls whether a binary table of contents is generated (YES) or a
-# normal table of contents (NO) in the .chm file.
-BINARY_TOC             = NO
-# The TOC_EXPAND flag can be set to YES to add extra items for group members
-# to the contents of the HTML help documentation and to the tree view.
-TOC_EXPAND             = NO
-# The DISABLE_INDEX tag can be used to turn on/off the condensed index at
-# top of each HTML page. The value NO (the default) enables the index and
-# the value YES disables it.
-DISABLE_INDEX          = NO
-# This tag can be used to set the number of enum values (range [1..20])
-# that doxygen will group on one line in the generated HTML documentation.
-ENUM_VALUES_PER_LINE   = 4
-# If the GENERATE_TREEVIEW tag is set to YES, a side panel will be
-# generated containing a tree-like index structure (just like the one that
-# is generated for HTML Help). For this to work a browser that supports
-# JavaScript, DHTML, CSS and frames is required (for instance Mozilla 1.0+,
-# Netscape 6.0+, Internet explorer 5.0+, or Konqueror). Windows users are
-# probably better off using the HTML help feature.
-GENERATE_TREEVIEW      = YES
-# If the treeview is enabled (see GENERATE_TREEVIEW) then this tag can be
-# used to set the initial width (in pixels) of the frame in which the tree
-# is shown.
-TREEVIEW_WIDTH         = 250
-# configuration options related to the LaTeX output
-# If the GENERATE_LATEX tag is set to YES (the default) Doxygen will
-# generate Latex output.
-GENERATE_LATEX         = YES
-# The LATEX_OUTPUT tag is used to specify where the LaTeX docs will be put.
-# put in front of it. If left blank `latex' will be used as the default path.
-LATEX_OUTPUT           = latex
-# The LATEX_CMD_NAME tag can be used to specify the LaTeX command name to be
-# invoked. If left blank `latex' will be used as the default command name.
-LATEX_CMD_NAME         = latex
-# The MAKEINDEX_CMD_NAME tag can be used to specify the command name to
-# generate index for LaTeX. If left blank `makeindex' will be used as the
-# default command name.
-MAKEINDEX_CMD_NAME     = makeindex
-# If the COMPACT_LATEX tag is set to YES Doxygen generates more compact
-# LaTeX documents. This may be useful for small projects and may help to
-# save some trees in general.
-COMPACT_LATEX          = NO
-# The PAPER_TYPE tag can be used to set the paper type that is used
-# by the printer. Possible values are: a4, a4wide, letter, legal and
-# executive. If left blank a4wide will be used.
-PAPER_TYPE             = a4
-# The EXTRA_PACKAGES tag can be to specify one or more names of LaTeX
-# packages that should be included in the LaTeX output.
-EXTRA_PACKAGES         =
-# The LATEX_HEADER tag can be used to specify a personal LaTeX header for
-# the generated latex document. The header should contain everything until
-# the first chapter. If it is left blank doxygen will generate a
-# standard header. Notice: only use this tag if you know what you are doing!
-LATEX_HEADER           =
-# If the PDF_HYPERLINKS tag is set to YES, the LaTeX that is generated
-# is prepared for conversion to pdf (using ps2pdf). The pdf file will
-# contain links (just like the HTML output) instead of page references
-# This makes the output suitable for online browsing using a pdf viewer.
-PDF_HYPERLINKS         = NO
-# If the USE_PDFLATEX tag is set to YES, pdflatex will be used instead of
-# plain latex in the generated Makefile. Set this option to YES to get a
-# higher quality PDF documentation.
-USE_PDFLATEX           = NO
-# If the LATEX_BATCHMODE tag is set to YES, doxygen will add the \\batchmode.
-# command to the generated LaTeX files. This will instruct LaTeX to keep
-# running if errors occur, instead of asking the user for help.
-# This option is also used when generating formulas in HTML.
-LATEX_BATCHMODE        = NO
-# If LATEX_HIDE_INDICES is set to YES then doxygen will not
-# include the index chapters (such as File Index, Compound Index, etc.)
-# in the output.
-LATEX_HIDE_INDICES     = NO
-# configuration options related to the RTF output
-# If the GENERATE_RTF tag is set to YES Doxygen will generate RTF output
-# The RTF output is optimized for Word 97 and may not look very pretty with
-# other RTF readers or editors.
-GENERATE_RTF           = NO
-# The RTF_OUTPUT tag is used to specify where the RTF docs will be put.
-# put in front of it. If left blank `rtf' will be used as the default path.
-RTF_OUTPUT             = rtf
-# If the COMPACT_RTF tag is set to YES Doxygen generates more compact
-# RTF documents. This may be useful for small projects and may help to
-COMPACT_RTF            = NO
-# If the RTF_HYPERLINKS tag is set to YES, the RTF that is generated
-# will contain hyperlink fields. The RTF file will
-# contain links (just like the HTML output) instead of page references.
-# This makes the output suitable for online browsing using WORD or other
-# programs which support those fields.
-# Note: wordpad (write) and others do not support links.
-RTF_HYPERLINKS         = NO
-# Load stylesheet definitions from file. Syntax is similar to doxygen's
-# config file, i.e. a series of assignments. You only have to provide
-# replacements, missing definitions are set to their default value.
-RTF_STYLESHEET_FILE    =
-# Set optional variables used in the generation of an rtf document.
-# Syntax is similar to doxygen's config file.
-RTF_EXTENSIONS_FILE    =
-# configuration options related to the man page output
-# If the GENERATE_MAN tag is set to YES (the default) Doxygen will
-# generate man pages
-GENERATE_MAN           = NO
-# The MAN_OUTPUT tag is used to specify where the man pages will be put.
-# put in front of it. If left blank `man' will be used as the default path.
-MAN_OUTPUT             = man
-# The MAN_EXTENSION tag determines the extension that is added to
-# the generated man pages (default is the subroutine's section .3)
-MAN_EXTENSION          = .3
-# If the MAN_LINKS tag is set to YES and Doxygen generates man output,
-# then it will generate one additional man file for each entity
-# documented in the real man page(s). These additional files
-# only source the real man page, but without them the man command
-# would be unable to find the correct page. The default is NO.
-MAN_LINKS              = NO
-# configuration options related to the XML output
-# If the GENERATE_XML tag is set to YES Doxygen will
-# generate an XML file that captures the structure of
-# the code including all documentation.
-GENERATE_XML           = NO
-# The XML_OUTPUT tag is used to specify where the XML pages will be put.
-# put in front of it. If left blank `xml' will be used as the default path.
-XML_OUTPUT             = xml
-# The XML_SCHEMA tag can be used to specify an XML schema,
-# which can be used by a validating XML parser to check the
-# syntax of the XML files.
-XML_SCHEMA             =
-# The XML_DTD tag can be used to specify an XML DTD,
-XML_DTD                =
-# If the XML_PROGRAMLISTING tag is set to YES Doxygen will
-# dump the program listings (including syntax highlighting
-# and cross-referencing information) to the XML output. Note that
-# enabling this will significantly increase the size of the XML output.
-XML_PROGRAMLISTING     = YES
-# configuration options for the AutoGen Definitions output
-# If the GENERATE_AUTOGEN_DEF tag is set to YES Doxygen will
-# generate an AutoGen Definitions (see autogen.sf.net) file
-# that captures the structure of the code including all
-# documentation. Note that this feature is still experimental
-# and incomplete at the moment.
-GENERATE_AUTOGEN_DEF   = NO
-# configuration options related to the Perl module output
-# If the GENERATE_PERLMOD tag is set to YES Doxygen will
-# generate a Perl module file that captures the structure of
-# the code including all documentation. Note that this
-# feature is still experimental and incomplete at the
-# moment.
-GENERATE_PERLMOD       = NO
-# If the PERLMOD_LATEX tag is set to YES Doxygen will generate
-# the necessary Makefile rules, Perl scripts and LaTeX code to be able
-# to generate PDF and DVI output from the Perl module output.
-PERLMOD_LATEX          = NO
-# If the PERLMOD_PRETTY tag is set to YES the Perl module output will be
-# nicely formatted so it can be parsed by a human reader.  This is useful
-# if you want to understand what is going on.  On the other hand, if this
-# tag is set to NO the size of the Perl module output will be much smaller
-# and Perl will parse it just the same.
-PERLMOD_PRETTY         = YES
-# The names of the make variables in the generated doxyrules.make file
-# are prefixed with the string contained in PERLMOD_MAKEVAR_PREFIX.
-# This is useful so different doxyrules.make files included by the same
-# Makefile don't overwrite each other's variables.
-PERLMOD_MAKEVAR_PREFIX =
-# Configuration options related to the preprocessor
-# If the ENABLE_PREPROCESSING tag is set to YES (the default) Doxygen will
-# evaluate all C-preprocessor directives found in the sources and include
-# files.
-ENABLE_PREPROCESSING   = YES
-# If the MACRO_EXPANSION tag is set to YES Doxygen will expand all macro
-# names in the source code. If set to NO (the default) only conditional
-# compilation will be performed. Macro expansion can be done in a controlled
-# way by setting EXPAND_ONLY_PREDEF to YES.
-MACRO_EXPANSION        = NO
-# If the EXPAND_ONLY_PREDEF and MACRO_EXPANSION tags are both set to YES
-# then the macro expansion is limited to the macros specified with the
-# PREDEFINED and EXPAND_AS_PREDEFINED tags.
-EXPAND_ONLY_PREDEF     = NO
-# If the SEARCH_INCLUDES tag is set to YES (the default) the includes files
-# in the INCLUDE_PATH (see below) will be search if a #include is found.
-SEARCH_INCLUDES        = YES
-# The INCLUDE_PATH tag can be used to specify one or more directories that
-# contain include files that are not input files but should be processed by
-# the preprocessor.
-INCLUDE_PATH           = ../include ../../include
-# You can use the INCLUDE_FILE_PATTERNS tag to specify one or more wildcard
-# patterns (like *.h and *.hpp) to filter out the header-files in the
-# directories. If left blank, the patterns specified with FILE_PATTERNS will
-# be used.
-INCLUDE_FILE_PATTERNS  =
-# The PREDEFINED tag can be used to specify one or more macro names that
-# are defined before the preprocessor is started (similar to the -D option of
-# gcc). The argument of the tag is a list of macros of the form: name
-# or name=definition (no spaces). If the definition and the = are
-# omitted =1 is assumed. To prevent a macro definition from being
-# undefined via #undef or recursively expanded use the := operator
-# instead of the = operator.
-PREDEFINED             = HAVE_OGR HAVE_TIFFIO_H HAVE_GEOS
-# If the MACRO_EXPANSION and EXPAND_ONLY_PREDEF tags are set to YES then
-# this tag can be used to specify a list of macro names that should be expanded.
-# The macro definition that is found in the sources will be used.
-# Use the PREDEFINED tag if you want to use a different macro definition.
-EXPAND_AS_DEFINED      =
-# If the SKIP_FUNCTION_MACROS tag is set to YES (the default) then
-# doxygen's preprocessor will remove all function-like macros that are alone
-# on a line, have an all uppercase name, and do not end with a semicolon. Such
-# function macros are typically used for boiler-plate code, and will confuse the
-# parser if not removed.
-SKIP_FUNCTION_MACROS   = YES
-# Configuration::additions related to external references
-# The TAGFILES option can be used to specify one or more tagfiles.
-# Optionally an initial location of the external documentation
-# can be added for each tagfile. The format of a tag file without
-# this location is as follows:
-#   TAGFILES = file1 file2 ...
-# Adding location for the tag files is done as follows:
-#   TAGFILES = file1=loc1 "file2 = loc2" ...
-# where "loc1" and "loc2" can be relative or absolute paths or
-# URLs. If a location is present for each tag, the installdox tool
-# does not have to be run to correct the links.
-# Note that each tag file must have a unique name
-# (where the name does NOT include the path)
-# If a tag file is not located in the directory in which doxygen
-# is run, you must also specify the path to the tagfile here.
-TAGFILES               =
-# When a file name is specified after GENERATE_TAGFILE, doxygen will create
-# a tag file that is based on the input files it reads.
-GENERATE_TAGFILE       =
-# If the ALLEXTERNALS tag is set to YES all external classes will be listed
-# in the class index. If set to NO only the inherited external classes
-# will be listed.
-ALLEXTERNALS           = NO
-# If the EXTERNAL_GROUPS tag is set to YES all external groups will be listed
-# in the modules index. If set to NO, only the current project's groups will
-# be listed.
-EXTERNAL_GROUPS        = YES
-# The PERL_PATH should be the absolute path and name of the perl script
-# interpreter (i.e. the result of `which perl').
-PERL_PATH              = /usr/bin/perl
-# Configuration options related to the dot tool
-# If the CLASS_DIAGRAMS tag is set to YES (the default) Doxygen will
-# generate a inheritance diagram (in HTML, RTF and LaTeX) for classes with base or
-# super classes. Setting the tag to NO turns the diagrams off. Note that this
-# option is superseded by the HAVE_DOT option below. This is only a fallback. It is
-# recommended to install and use dot, since it yields more powerful graphs.
-CLASS_DIAGRAMS         = YES
-# If set to YES, the inheritance and collaboration graphs will hide
-# inheritance and usage relations if the target is undocumented
-# or is not a class.
-HIDE_UNDOC_RELATIONS   = YES
-# If you set the HAVE_DOT tag to YES then doxygen will assume the dot tool is
-# available from the path. This tool is part of Graphviz, a graph visualization
-# toolkit from AT&T and Lucent Bell Labs. The other options in this section
-# have no effect if this option is set to NO (the default)
-HAVE_DOT               = YES
-# If the CLASS_GRAPH and HAVE_DOT tags are set to YES then doxygen
-# will generate a graph for each documented class showing the direct and
-# indirect inheritance relations. Setting this tag to YES will force the
-# the CLASS_DIAGRAMS tag to NO.
-CLASS_GRAPH            = YES
-# If the COLLABORATION_GRAPH and HAVE_DOT tags are set to YES then doxygen
-# indirect implementation dependencies (inheritance, containment, and
-# class references variables) of the class with other documented classes.
-COLLABORATION_GRAPH    = YES
-# If the UML_LOOK tag is set to YES doxygen will generate inheritance and
-# collaboration diagrams in a style similar to the OMG's Unified Modeling
-# Language.
-UML_LOOK               = NO
-# If set to YES, the inheritance and collaboration graphs will show the
-# relations between templates and their instances.
-TEMPLATE_RELATIONS     = NO
-# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDE_GRAPH, and HAVE_DOT
-# tags are set to YES then doxygen will generate a graph for each documented
-# file showing the direct and indirect include dependencies of the file with
-# other documented files.
-INCLUDE_GRAPH          = YES
-# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDED_BY_GRAPH, and
-# HAVE_DOT tags are set to YES then doxygen will generate a graph for each
-# documented header file showing the documented files that directly or
-# indirectly include this file.
-INCLUDED_BY_GRAPH      = YES
-# If the CALL_GRAPH and HAVE_DOT tags are set to YES then doxygen will
-# generate a call dependency graph for every global function or class method.
-# Note that enabling this option will significantly increase the time of a run.
-# So in most cases it will be better to enable call graphs for selected
-# functions only using the \callgraph command.
-CALL_GRAPH             = NO
-# If the GRAPHICAL_HIERARCHY and HAVE_DOT tags are set to YES then doxygen
-# will graphical hierarchy of all classes instead of a textual one.
-GRAPHICAL_HIERARCHY    = YES
-# The DOT_IMAGE_FORMAT tag can be used to set the image format of the images
-# generated by dot. Possible values are png, jpg, or gif
-# If left blank png will be used.
-DOT_IMAGE_FORMAT       = png
-# The tag DOT_PATH can be used to specify the path where the dot tool can be
-# found. If left blank, it is assumed the dot tool can be found on the path.
-DOT_PATH               =
-# The DOTFILE_DIRS tag can be used to specify one or more directories that
-# contain dot files that are included in the documentation (see the
-# \dotfile command).
-DOTFILE_DIRS           =
-# The MAX_DOT_GRAPH_WIDTH tag can be used to set the maximum allowed width
-# (in pixels) of the graphs generated by dot. If a graph becomes larger than
-# this value, doxygen will try to truncate the graph, so that it fits within
-# the specified constraint. Beware that most browsers cannot cope with very
-# large images.
-MAX_DOT_GRAPH_WIDTH    = 2000
-# The MAX_DOT_GRAPH_HEIGHT tag can be used to set the maximum allows height
-# large images.
-MAX_DOT_GRAPH_HEIGHT   = 2000
-# The MAX_DOT_GRAPH_DEPTH tag can be used to set the maximum depth of the
-# graphs generated by dot. A depth value of 3 means that only nodes reachable
-# from the root by following a path via at most 3 edges will be shown. Nodes that
-# lay further from the root node will be omitted. Note that setting this option to
-# 1 or 2 may greatly reduce the computation time needed for large code bases. Also
-# note that a graph may be further truncated if the graph's image dimensions are
-# not sufficient to fit the graph (see MAX_DOT_GRAPH_WIDTH and MAX_DOT_GRAPH_HEIGHT).
-# If 0 is used for the depth value (the default), the graph is not depth-constrained.
-MAX_DOT_GRAPH_DEPTH    = 0
-# If the GENERATE_LEGEND tag is set to YES (the default) Doxygen will
-# generate a legend page explaining the meaning of the various boxes and
-# arrows in the dot generated graphs.
-GENERATE_LEGEND        = YES
-# If the DOT_CLEANUP tag is set to YES (the default) Doxygen will
-# remove the intermediate dot files that are used to generate
-# the various graphs.
-DOT_CLEANUP            = YES
-# Configuration::additions related to the search engine
-# The SEARCHENGINE tag specifies whether or not a search engine should be
-# used. If set to NO the values of all tags below this one will be ignored.
-SEARCHENGINE           = NO
Copied: grass/trunk/include/Make/Doxyfile_arch_html.in (from rev 39609, grass/trunk/include/Make/Doxyfile_arch_html)
--- grass/trunk/include/Make/Doxyfile_arch_html.in	                        (rev 0)
+++ grass/trunk/include/Make/Doxyfile_arch_html.in	2009-10-22 20:12:17 UTC (rev 39611)
@@ -0,0 +1,1165 @@
+# Doxyfile 1.3.9.1
+# This file describes the settings to be used by the documentation system
+# doxygen (www.doxygen.org) for a project
+# All text after a hash (#) is considered a comment and will be ignored
+# The format is:
+#       TAG = value [value, ...]
+# For lists items can also be appended using:
+#       TAG += value [value, ...]
+# Values that contain spaces should be placed between quotes (" ")
+# Project related configuration options
+# The PROJECT_NAME tag is a single word (or a sequence of words surrounded
+# by quotes) that should identify the project.
+PROJECT_NAME           = "GRASS Programmer's Manual"
+# The PROJECT_NUMBER tag can be used to enter a project or revision number.
+# This could be handy for archiving the generated documentation or
+# if some version control system is used.
+PROJECT_NUMBER         = @GRASS_VERSION_MAJOR at .@GRASS_VERSION_MINOR at .@GRASS_VERSION_RELEASE@ (@GRASS_VERSION_DATE@)
+# The OUTPUT_DIRECTORY tag is used to specify the (relative or absolute)
+# base path where the generated documentation will be put.
+# If a relative path is entered, it will be relative to the location
+# where doxygen was started. If left blank the current directory will be used.
+OUTPUT_DIRECTORY       = .
+# If the CREATE_SUBDIRS tag is set to YES, then doxygen will create
+# 4096 sub-directories (in 2 levels) under the output directory of each output
+# format and will distribute the generated files over these directories.
+# Enabling this option can be useful when feeding doxygen a huge amount of source
+# files, where putting all generated files in the same directory would otherwise
+# cause performance problems for the file system.
+CREATE_SUBDIRS         = NO
+# The OUTPUT_LANGUAGE tag is used to specify the language in which all
+# documentation generated by doxygen is written. Doxygen will use this
+# information to generate all constant output in the proper language.
+# The default language is English, other supported languages are:
+# Brazilian, Catalan, Chinese, Chinese-Traditional, Croatian, Czech, Danish,
+# Dutch, Finnish, French, German, Greek, Hungarian, Italian, Japanese,
+# Japanese-en (Japanese with English messages), Korean, Korean-en, Norwegian,
+# Polish, Portuguese, Romanian, Russian, Serbian, Slovak, Slovene, Spanish,
+# Swedish, and Ukrainian.
+OUTPUT_LANGUAGE        = English
+# This tag can be used to specify the encoding used in the generated output.
+# The encoding is not always determined by the language that is chosen,
+# but also whether or not the output is meant for Windows or non-Windows users.
+# In case there is a difference, setting the USE_WINDOWS_ENCODING tag to YES
+# forces the Windows encoding (this is the default for the Windows binary),
+# whereas setting the tag to NO uses a Unix-style encoding (the default for
+# all platforms other than Windows).
+USE_WINDOWS_ENCODING   = NO
+# If the BRIEF_MEMBER_DESC tag is set to YES (the default) Doxygen will
+# include brief member descriptions after the members that are listed in
+# the file and class documentation (similar to JavaDoc).
+# Set to NO to disable this.
+BRIEF_MEMBER_DESC      = YES
+# If the REPEAT_BRIEF tag is set to YES (the default) Doxygen will prepend
+# the brief description of a member or function before the detailed description.
+# Note: if both HIDE_UNDOC_MEMBERS and BRIEF_MEMBER_DESC are set to NO, the
+# brief descriptions will be completely suppressed.
+REPEAT_BRIEF           = YES
+# This tag implements a quasi-intelligent brief description abbreviator
+# that is used to form the text in various listings. Each string
+# in this list, if found as the leading text of the brief description, will be
+# stripped from the text and the result after processing the whole list, is used
+# as the annotated text. Otherwise, the brief description is used as-is. If left
+# blank, the following values are used ("$name" is automatically replaced with the
+# name of the entity): "The $name class" "The $name widget" "The $name file"
+# "is" "provides" "specifies" "contains" "represents" "a" "an" "the"
+ABBREVIATE_BRIEF       =
+# If the ALWAYS_DETAILED_SEC and REPEAT_BRIEF tags are both set to YES then
+# Doxygen will generate a detailed section even if there is only a brief
+# description.
+ALWAYS_DETAILED_SEC    = NO
+# If the INLINE_INHERITED_MEMB tag is set to YES, doxygen will show all inherited
+# members of a class in the documentation of that class as if those members were
+# ordinary class members. Constructors, destructors and assignment operators of
+# the base classes will not be shown.
+INLINE_INHERITED_MEMB  = NO
+# If the FULL_PATH_NAMES tag is set to YES then Doxygen will prepend the full
+# path before files name in the file list and in the header files. If set
+# to NO the shortest path that makes the file name unique will be used.
+FULL_PATH_NAMES        = NO
+# If the FULL_PATH_NAMES tag is set to YES then the STRIP_FROM_PATH tag
+# can be used to strip a user-defined part of the path. Stripping is
+# only done if one of the specified strings matches the left-hand part of
+# the path. The tag can be used to show relative paths in the file list.
+# If left blank the directory from which doxygen is run is used as the
+# path to strip.
+STRIP_FROM_PATH        =
+# The STRIP_FROM_INC_PATH tag can be used to strip a user-defined part of
+# the path mentioned in the documentation of a class, which tells
+# the reader which header file to include in order to use a class.
+# If left blank only the name of the header file containing the class
+# definition is used. Otherwise one should specify the include paths that
+# are normally passed to the compiler using the -I flag.
+STRIP_FROM_INC_PATH    =
+# If the SHORT_NAMES tag is set to YES, doxygen will generate much shorter
+# (but less readable) file names. This can be useful is your file systems
+# doesn't support long names like on DOS, Mac, or CD-ROM.
+SHORT_NAMES            = NO
+# If the JAVADOC_AUTOBRIEF tag is set to YES then Doxygen
+# will interpret the first line (until the first dot) of a JavaDoc-style
+# comment as the brief description. If set to NO, the JavaDoc
+# comments will behave just like the Qt-style comments (thus requiring an
+# explicit @brief command for a brief description.
+JAVADOC_AUTOBRIEF      = NO
+# The MULTILINE_CPP_IS_BRIEF tag can be set to YES to make Doxygen
+# treat a multi-line C++ special comment block (i.e. a block of //! or ///
+# comments) as a brief description. This used to be the default behaviour.
+# The new default is to treat a multi-line C++ comment block as a detailed
+# description. Set this tag to YES if you prefer the old behaviour instead.
+MULTILINE_CPP_IS_BRIEF = NO
+# If the DETAILS_AT_TOP tag is set to YES then Doxygen
+# will output the detailed description near the top, like JavaDoc.
+# If set to NO, the detailed description appears after the member
+# documentation.
+DETAILS_AT_TOP         = NO
+# If the INHERIT_DOCS tag is set to YES (the default) then an undocumented
+# member inherits the documentation from any documented member that it
+# re-implements.
+INHERIT_DOCS           = YES
+# If member grouping is used in the documentation and the DISTRIBUTE_GROUP_DOC
+# tag is set to YES, then doxygen will reuse the documentation of the first
+# member in the group (if any) for the other members of the group. By default
+# all members of a group must be documented explicitly.
+DISTRIBUTE_GROUP_DOC   = NO
+# The TAB_SIZE tag can be used to set the number of spaces in a tab.
+# Doxygen uses this value to replace tabs by spaces in code fragments.
+TAB_SIZE               = 8
+# This tag can be used to specify a number of aliases that acts
+# as commands in the documentation. An alias has the form "name=value".
+# For example adding "sideeffect=\par Side Effects:\n" will allow you to
+# put the command \sideeffect (or @sideeffect) in the documentation, which
+# will result in a user-defined paragraph with heading "Side Effects:".
+# You can put \n's in the value part of an alias to insert newlines.
+ALIASES                =
+# Set the OPTIMIZE_OUTPUT_FOR_C tag to YES if your project consists of C sources
+# only. Doxygen will then generate output that is more tailored for C.
+# For instance, some of the names that are used will be different. The list
+# of all members will be omitted, etc.
+OPTIMIZE_OUTPUT_FOR_C  = YES
+# Set the OPTIMIZE_OUTPUT_JAVA tag to YES if your project consists of Java sources
+# only. Doxygen will then generate output that is more tailored for Java.
+# For instance, namespaces will be presented as packages, qualified scopes
+# will look different, etc.
+OPTIMIZE_OUTPUT_JAVA   = NO
+# Set the SUBGROUPING tag to YES (the default) to allow class member groups of
+# the same type (for instance a group of public functions) to be put as a
+# subgroup of that type (e.g. under the Public Functions section). Set it to
+# NO to prevent subgrouping. Alternatively, this can be done per class using
+# the \nosubgrouping command.
+SUBGROUPING            = YES
+# Build related configuration options
+# If the EXTRACT_ALL tag is set to YES doxygen will assume all entities in
+# documentation are documented, even if no documentation was available.
+# Private class members and static file members will be hidden unless
+# the EXTRACT_PRIVATE and EXTRACT_STATIC tags are set to YES
+EXTRACT_ALL            = YES
+# If the EXTRACT_PRIVATE tag is set to YES all private members of a class
+# will be included in the documentation.
+EXTRACT_PRIVATE        = NO
+# If the EXTRACT_STATIC tag is set to YES all static members of a file
+EXTRACT_STATIC         = NO
+# If the EXTRACT_LOCAL_CLASSES tag is set to YES classes (and structs)
+# defined locally in source files will be included in the documentation.
+# If set to NO only classes defined in header files are included.
+EXTRACT_LOCAL_CLASSES  = YES
+# This flag is only useful for Objective-C code. When set to YES local
+# methods, which are defined in the implementation section but not in
+# the interface are included in the documentation.
+# If set to NO (the default) only methods in the interface are included.
+EXTRACT_LOCAL_METHODS  = NO
+# If the HIDE_UNDOC_MEMBERS tag is set to YES, Doxygen will hide all
+# undocumented members of documented classes, files or namespaces.
+# If set to NO (the default) these members will be included in the
+# various overviews, but no documentation section is generated.
+# This option has no effect if EXTRACT_ALL is enabled.
+HIDE_UNDOC_MEMBERS     = NO
+# If the HIDE_UNDOC_CLASSES tag is set to YES, Doxygen will hide all
+# undocumented classes that are normally visible in the class hierarchy.
+# If set to NO (the default) these classes will be included in the various
+# overviews. This option has no effect if EXTRACT_ALL is enabled.
+HIDE_UNDOC_CLASSES     = NO
+# If the HIDE_FRIEND_COMPOUNDS tag is set to YES, Doxygen will hide all
+# friend (class|struct|union) declarations.
+# If set to NO (the default) these declarations will be included in the
+# documentation.
+HIDE_FRIEND_COMPOUNDS  = NO
+# If the HIDE_IN_BODY_DOCS tag is set to YES, Doxygen will hide any
+# documentation blocks found inside the body of a function.
+# If set to NO (the default) these blocks will be appended to the
+# function's detailed documentation block.
+HIDE_IN_BODY_DOCS      = NO
+# The INTERNAL_DOCS tag determines if documentation
+# that is typed after a \internal command is included. If the tag is set
+# to NO (the default) then the documentation will be excluded.
+# Set it to YES to include the internal documentation.
+INTERNAL_DOCS          = NO
+# If the CASE_SENSE_NAMES tag is set to NO then Doxygen will only generate
+# file names in lower-case letters. If set to YES upper-case letters are also
+# allowed. This is useful if you have classes or files whose names only differ
+# in case and if your file system supports case sensitive file names. Windows
+# and Mac users are advised to set this option to NO.
+CASE_SENSE_NAMES       = YES
+# If the HIDE_SCOPE_NAMES tag is set to NO (the default) then Doxygen
+# will show members with their full class and namespace scopes in the
+# documentation. If set to YES the scope will be hidden.
+HIDE_SCOPE_NAMES       = NO
+# If the SHOW_INCLUDE_FILES tag is set to YES (the default) then Doxygen
+# will put a list of the files that are included by a file in the documentation
+# of that file.
+SHOW_INCLUDE_FILES     = YES
+# If the INLINE_INFO tag is set to YES (the default) then a tag [inline]
+# is inserted in the documentation for inline members.
+INLINE_INFO            = YES
+# If the SORT_MEMBER_DOCS tag is set to YES (the default) then doxygen
+# will sort the (detailed) documentation of file and class members
+# alphabetically by member name. If set to NO the members will appear in
+# declaration order.
+SORT_MEMBER_DOCS       = YES
+# If the SORT_BRIEF_DOCS tag is set to YES then doxygen will sort the
+# brief documentation of file, namespace and class members alphabetically
+# by member name. If set to NO (the default) the members will appear in
+SORT_BRIEF_DOCS        = NO
+# If the SORT_BY_SCOPE_NAME tag is set to YES, the class list will be
+# sorted by fully-qualified names, including namespaces. If set to
+# NO (the default), the class list will be sorted only by class name,
+# not including the namespace part.
+# Note: This option is not very useful if HIDE_SCOPE_NAMES is set to YES.
+# Note: This option applies only to the class list, not to the
+# alphabetical list.
+SORT_BY_SCOPE_NAME     = NO
+# The GENERATE_TODOLIST tag can be used to enable (YES) or
+# disable (NO) the todo list. This list is created by putting \todo
+# commands in the documentation.
+GENERATE_TODOLIST      = YES
+# The GENERATE_TESTLIST tag can be used to enable (YES) or
+# disable (NO) the test list. This list is created by putting \test
+GENERATE_TESTLIST      = YES
+# The GENERATE_BUGLIST tag can be used to enable (YES) or
+# disable (NO) the bug list. This list is created by putting \bug
+GENERATE_BUGLIST       = YES
+# The GENERATE_DEPRECATEDLIST tag can be used to enable (YES) or
+# disable (NO) the deprecated list. This list is created by putting
+# \deprecated commands in the documentation.
+GENERATE_DEPRECATEDLIST= YES
+# The ENABLED_SECTIONS tag can be used to enable conditional
+# documentation sections, marked by \if sectionname ... \endif.
+ENABLED_SECTIONS       =
+# The MAX_INITIALIZER_LINES tag determines the maximum number of lines
+# the initial value of a variable or define consists of for it to appear in
+# the documentation. If the initializer consists of more lines than specified
+# here it will be hidden. Use a value of 0 to hide initializers completely.
+# The appearance of the initializer of individual variables and defines in the
+# documentation can be controlled using \showinitializer or \hideinitializer
+# command in the documentation regardless of this setting.
+MAX_INITIALIZER_LINES  = 30
+# Set the SHOW_USED_FILES tag to NO to disable the list of files generated
+# at the bottom of the documentation of classes and structs. If set to YES the
+# list will mention the files that were used to generate the documentation.
+SHOW_USED_FILES        = YES
+# If the sources in your project are distributed over multiple directories
+# then setting the SHOW_DIRECTORIES tag to YES will show the directory hierarchy
+# in the documentation.
+SHOW_DIRECTORIES       = YES
+# configuration options related to warning and progress messages
+# The QUIET tag can be used to turn on/off the messages that are generated
+# by doxygen. Possible values are YES and NO. If left blank NO is used.
+QUIET                  = NO
+# The WARNINGS tag can be used to turn on/off the warning messages that are
+# generated by doxygen. Possible values are YES and NO. If left blank
+# NO is used.
+WARNINGS               = YES
+# If WARN_IF_UNDOCUMENTED is set to YES, then doxygen will generate warnings
+# for undocumented members. If EXTRACT_ALL is set to YES then this flag will
+# automatically be disabled.
+WARN_IF_UNDOCUMENTED   = YES
+# If WARN_IF_DOC_ERROR is set to YES, doxygen will generate warnings for
+# potential errors in the documentation, such as not documenting some
+# parameters in a documented function, or documenting parameters that
+# don't exist or using markup commands wrongly.
+WARN_IF_DOC_ERROR      = YES
+# The WARN_FORMAT tag determines the format of the warning messages that
+# doxygen can produce. The string should contain the $file, $line, and $text
+# tags, which will be replaced by the file and line number from which the
+# warning originated and the warning text.
+WARN_FORMAT            = "$file:$line: $text"
+# The WARN_LOGFILE tag can be used to specify a file to which warning
+# and error messages should be written. If left blank the output is written
+# to stderr.
+WARN_LOGFILE           =
+# configuration options related to the input files
+# The INPUT tag can be used to specify the files and/or directories that contain
+# documented source files. You may enter file names like "myfile.cpp" or
+# directories like "/usr/src/myproject". Separate the files or directories
+# with spaces.
+INPUT                  = .
+# If the value of the INPUT tag contains directories, you can use the
+# FILE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
+# and *.h) to filter out the source-files in the directories. If left
+# blank the following patterns are tested:
+# *.c *.cc *.cxx *.cpp *.c++ *.java *.ii *.ixx *.ipp *.i++ *.inl *.h *.hh *.hxx *.hpp
+# *.h++ *.idl *.odl *.cs *.php *.php3 *.inc *.m *.mm
+FILE_PATTERNS          = *.h \
+                         *.c \
+			 *.i \
+                         *.py \
+                         *.dox
+# The RECURSIVE tag can be used to turn specify whether or not subdirectories
+# should be searched for input files as well. Possible values are YES and NO.
+# If left blank NO is used.
+RECURSIVE              = YES
+# The EXCLUDE tag can be used to specify files and/or directories that should
+# excluded from the INPUT source files. This way you can easily exclude a
+# subdirectory from a directory tree whose root is specified with the INPUT tag.
+EXCLUDE                =
+# The EXCLUDE_SYMLINKS tag can be used select whether or not files or directories
+# that are symbolic links (a Unix filesystem feature) are excluded from the input.
+EXCLUDE_SYMLINKS       = NO
+# EXCLUDE_PATTERNS tag to specify one or more wildcard patterns to exclude
+# certain files from those directories.
+EXCLUDE_PATTERNS       =
+# The EXAMPLE_PATH tag can be used to specify one or more files or
+# directories that contain example code fragments that are included (see
+# the \include command).
+EXAMPLE_PATH           =
+# If the value of the EXAMPLE_PATH tag contains directories, you can use the
+# EXAMPLE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
+# blank all files are included.
+EXAMPLE_PATTERNS       =
+# If the EXAMPLE_RECURSIVE tag is set to YES then subdirectories will be
+# searched for input files to be used with the \include or \dontinclude
+# commands irrespective of the value of the RECURSIVE tag.
+# Possible values are YES and NO. If left blank NO is used.
+EXAMPLE_RECURSIVE      = NO
+# The IMAGE_PATH tag can be used to specify one or more files or
+# directories that contain image that are included in the documentation (see
+# the \image command).
+IMAGE_PATH             = .
+# The INPUT_FILTER tag can be used to specify a program that doxygen should
+# invoke to filter for each input file. Doxygen will invoke the filter program
+# by executing (via popen()) the command <filter> <input-file>, where <filter>
+# is the value of the INPUT_FILTER tag, and <input-file> is the name of an
+# input file. Doxygen will then use the output that the filter program writes
+# to standard output.  If FILTER_PATTERNS is specified, this tag will be
+# ignored.
+INPUT_FILTER           =
+# The FILTER_PATTERNS tag can be used to specify filters on a per file pattern
+# basis.  Doxygen will compare the file name with each pattern and apply the
+# filter if there is a match.  The filters are a list of the form:
+# pattern=filter (like *.cpp=my_cpp_filter). See INPUT_FILTER for further
+# info on how filters are used. If FILTER_PATTERNS is empty, INPUT_FILTER
+# is applied to all files.
+FILTER_PATTERNS        =
+# If the FILTER_SOURCE_FILES tag is set to YES, the input filter (if set using
+# INPUT_FILTER) will be used to filter the input files when producing source
+# files to browse (i.e. when SOURCE_BROWSER is set to YES).
+FILTER_SOURCE_FILES    = NO
+# configuration options related to source browsing
+# If the SOURCE_BROWSER tag is set to YES then a list of source files will
+# be generated. Documented entities will be cross-referenced with these sources.
+# Note: To get rid of all source code in the generated output, make sure also
+# VERBATIM_HEADERS is set to NO.
+SOURCE_BROWSER         = YES
+# Setting the INLINE_SOURCES tag to YES will include the body
+# of functions and classes directly in the documentation.
+INLINE_SOURCES         = NO
+# Setting the STRIP_CODE_COMMENTS tag to YES (the default) will instruct
+# doxygen to hide any special comment blocks from generated source code
+# fragments. Normal C and C++ comments will always remain visible.
+STRIP_CODE_COMMENTS    = YES
+# If the REFERENCED_BY_RELATION tag is set to YES (the default)
+# then for each documented function all documented
+# functions referencing it will be listed.
+REFERENCED_BY_RELATION = YES
+# If the REFERENCES_RELATION tag is set to YES (the default)
+# then for each documented function all documented entities
+# called/used by that function will be listed.
+REFERENCES_RELATION    = YES
+# If the VERBATIM_HEADERS tag is set to YES (the default) then Doxygen
+# will generate a verbatim copy of the header file for each class for
+# which an include is specified. Set to NO to disable this.
+VERBATIM_HEADERS       = YES
+# configuration options related to the alphabetical class index
+# If the ALPHABETICAL_INDEX tag is set to YES, an alphabetical index
+# of all compounds will be generated. Enable this if the project
+# contains a lot of classes, structs, unions or interfaces.
+ALPHABETICAL_INDEX     = NO
+# If the alphabetical index is enabled (see ALPHABETICAL_INDEX) then
+# the COLS_IN_ALPHA_INDEX tag can be used to specify the number of columns
+# in which this list will be split (can be a number in the range [1..20])
+COLS_IN_ALPHA_INDEX    = 5
+# In case all classes in a project start with a common prefix, all
+# classes will be put under the same header in the alphabetical index.
+# The IGNORE_PREFIX tag can be used to specify one or more prefixes that
+# should be ignored while generating the index headers.
+IGNORE_PREFIX          =
+# configuration options related to the HTML output
+# If the GENERATE_HTML tag is set to YES (the default) Doxygen will
+# generate HTML output.
+GENERATE_HTML          = YES
+# The HTML_OUTPUT tag is used to specify where the HTML docs will be put.
+# If a relative path is entered the value of OUTPUT_DIRECTORY will be
+# put in front of it. If left blank `html' will be used as the default path.
+HTML_OUTPUT            =
+# The HTML_FILE_EXTENSION tag can be used to specify the file extension for
+# each generated HTML page (for example: .htm,.php,.asp). If it is left blank
+# doxygen will generate files with .html extension.
+HTML_FILE_EXTENSION    =
+# The HTML_HEADER tag can be used to specify a personal HTML header for
+# each generated HTML page. If it is left blank doxygen will generate a
+# standard header.
+HTML_HEADER            =
+# The HTML_FOOTER tag can be used to specify a personal HTML footer for
+# standard footer.
+HTML_FOOTER            =
+# The HTML_STYLESHEET tag can be used to specify a user-defined cascading
+# style sheet that is used by each HTML page. It can be used to
+# fine-tune the look of the HTML output. If the tag is left blank doxygen
+# will generate a default style sheet. Note that doxygen will try to copy
+# the style sheet file to the HTML output directory, so don't put your own
+# stylesheet in the HTML output directory as well, or it will be erased!
+HTML_STYLESHEET        =
+# If the HTML_ALIGN_MEMBERS tag is set to YES, the members of classes,
+# files or namespaces will be aligned in HTML using tables. If set to
+# NO a bullet list will be used.
+HTML_ALIGN_MEMBERS     = YES
+# If the GENERATE_HTMLHELP tag is set to YES, additional index files
+# will be generated that can be used as input for tools like the
+# Microsoft HTML help workshop to generate a compressed HTML help file (.chm)
+# of the generated HTML documentation.
+GENERATE_HTMLHELP      = NO
+# If the GENERATE_HTMLHELP tag is set to YES, the CHM_FILE tag can
+# be used to specify the file name of the resulting .chm file. You
+# can add a path in front of the file if the result should not be
+# written to the html output directory.
+CHM_FILE               =
+# If the GENERATE_HTMLHELP tag is set to YES, the HHC_LOCATION tag can
+# be used to specify the location (absolute path including file name) of
+# the HTML help compiler (hhc.exe). If non-empty doxygen will try to run
+# the HTML help compiler on the generated index.hhp.
+HHC_LOCATION           =
+# If the GENERATE_HTMLHELP tag is set to YES, the GENERATE_CHI flag
+# controls if a separate .chi index file is generated (YES) or that
+# it should be included in the master .chm file (NO).
+GENERATE_CHI           = NO
+# If the GENERATE_HTMLHELP tag is set to YES, the BINARY_TOC flag
+# controls whether a binary table of contents is generated (YES) or a
+# normal table of contents (NO) in the .chm file.
+BINARY_TOC             = NO
+# The TOC_EXPAND flag can be set to YES to add extra items for group members
+# to the contents of the HTML help documentation and to the tree view.
+TOC_EXPAND             = NO
+# The DISABLE_INDEX tag can be used to turn on/off the condensed index at
+# top of each HTML page. The value NO (the default) enables the index and
+# the value YES disables it.
+DISABLE_INDEX          = NO
+# This tag can be used to set the number of enum values (range [1..20])
+# that doxygen will group on one line in the generated HTML documentation.
+ENUM_VALUES_PER_LINE   = 4
+# If the GENERATE_TREEVIEW tag is set to YES, a side panel will be
+# generated containing a tree-like index structure (just like the one that
+# is generated for HTML Help). For this to work a browser that supports
+# JavaScript, DHTML, CSS and frames is required (for instance Mozilla 1.0+,
+# Netscape 6.0+, Internet explorer 5.0+, or Konqueror). Windows users are
+# probably better off using the HTML help feature.
+GENERATE_TREEVIEW      = YES
+# If the treeview is enabled (see GENERATE_TREEVIEW) then this tag can be
+# used to set the initial width (in pixels) of the frame in which the tree
+# is shown.
+TREEVIEW_WIDTH         = 250
+# configuration options related to the LaTeX output
+# If the GENERATE_LATEX tag is set to YES (the default) Doxygen will
+# generate Latex output.
+GENERATE_LATEX         = YES
+# The LATEX_OUTPUT tag is used to specify where the LaTeX docs will be put.
+# put in front of it. If left blank `latex' will be used as the default path.
+LATEX_OUTPUT           = latex
+# The LATEX_CMD_NAME tag can be used to specify the LaTeX command name to be
+# invoked. If left blank `latex' will be used as the default command name.
+LATEX_CMD_NAME         = latex
+# The MAKEINDEX_CMD_NAME tag can be used to specify the command name to
+# generate index for LaTeX. If left blank `makeindex' will be used as the
+# default command name.
+MAKEINDEX_CMD_NAME     = makeindex
+# If the COMPACT_LATEX tag is set to YES Doxygen generates more compact
+# LaTeX documents. This may be useful for small projects and may help to
+# save some trees in general.
+COMPACT_LATEX          = NO
+# The PAPER_TYPE tag can be used to set the paper type that is used
+# by the printer. Possible values are: a4, a4wide, letter, legal and
+# executive. If left blank a4wide will be used.
+PAPER_TYPE             = a4
+# The EXTRA_PACKAGES tag can be to specify one or more names of LaTeX
+# packages that should be included in the LaTeX output.
+EXTRA_PACKAGES         =
+# The LATEX_HEADER tag can be used to specify a personal LaTeX header for
+# the generated latex document. The header should contain everything until
+# the first chapter. If it is left blank doxygen will generate a
+# standard header. Notice: only use this tag if you know what you are doing!
+LATEX_HEADER           =
+# If the PDF_HYPERLINKS tag is set to YES, the LaTeX that is generated
+# is prepared for conversion to pdf (using ps2pdf). The pdf file will
+# contain links (just like the HTML output) instead of page references
+# This makes the output suitable for online browsing using a pdf viewer.
+PDF_HYPERLINKS         = NO
+# If the USE_PDFLATEX tag is set to YES, pdflatex will be used instead of
+# plain latex in the generated Makefile. Set this option to YES to get a
+# higher quality PDF documentation.
+USE_PDFLATEX           = NO
+# If the LATEX_BATCHMODE tag is set to YES, doxygen will add the \\batchmode.
+# command to the generated LaTeX files. This will instruct LaTeX to keep
+# running if errors occur, instead of asking the user for help.
+# This option is also used when generating formulas in HTML.
+LATEX_BATCHMODE        = NO
+# If LATEX_HIDE_INDICES is set to YES then doxygen will not
+# include the index chapters (such as File Index, Compound Index, etc.)
+# in the output.
+LATEX_HIDE_INDICES     = NO
+# configuration options related to the RTF output
+# If the GENERATE_RTF tag is set to YES Doxygen will generate RTF output
+# The RTF output is optimized for Word 97 and may not look very pretty with
+# other RTF readers or editors.
+GENERATE_RTF           = NO
+# The RTF_OUTPUT tag is used to specify where the RTF docs will be put.
+# put in front of it. If left blank `rtf' will be used as the default path.
+RTF_OUTPUT             = rtf
+# If the COMPACT_RTF tag is set to YES Doxygen generates more compact
+# RTF documents. This may be useful for small projects and may help to
+COMPACT_RTF            = NO
+# If the RTF_HYPERLINKS tag is set to YES, the RTF that is generated
+# will contain hyperlink fields. The RTF file will
+# contain links (just like the HTML output) instead of page references.
+# This makes the output suitable for online browsing using WORD or other
+# programs which support those fields.
+# Note: wordpad (write) and others do not support links.
+RTF_HYPERLINKS         = NO
+# Load stylesheet definitions from file. Syntax is similar to doxygen's
+# config file, i.e. a series of assignments. You only have to provide
+# replacements, missing definitions are set to their default value.
+RTF_STYLESHEET_FILE    =
+# Set optional variables used in the generation of an rtf document.
+# Syntax is similar to doxygen's config file.
+RTF_EXTENSIONS_FILE    =
+# configuration options related to the man page output
+# If the GENERATE_MAN tag is set to YES (the default) Doxygen will
+# generate man pages
+GENERATE_MAN           = NO
+# The MAN_OUTPUT tag is used to specify where the man pages will be put.
+# put in front of it. If left blank `man' will be used as the default path.
+MAN_OUTPUT             = man
+# The MAN_EXTENSION tag determines the extension that is added to
+# the generated man pages (default is the subroutine's section .3)
+MAN_EXTENSION          = .3
+# If the MAN_LINKS tag is set to YES and Doxygen generates man output,
+# then it will generate one additional man file for each entity
+# documented in the real man page(s). These additional files
+# only source the real man page, but without them the man command
+# would be unable to find the correct page. The default is NO.
+MAN_LINKS              = NO
+# configuration options related to the XML output
+# If the GENERATE_XML tag is set to YES Doxygen will
+# generate an XML file that captures the structure of
+# the code including all documentation.
+GENERATE_XML           = NO
+# The XML_OUTPUT tag is used to specify where the XML pages will be put.
+# put in front of it. If left blank `xml' will be used as the default path.
+XML_OUTPUT             = xml
+# The XML_SCHEMA tag can be used to specify an XML schema,
+# which can be used by a validating XML parser to check the
+# syntax of the XML files.
+XML_SCHEMA             =
+# The XML_DTD tag can be used to specify an XML DTD,
+XML_DTD                =
+# If the XML_PROGRAMLISTING tag is set to YES Doxygen will
+# dump the program listings (including syntax highlighting
+# and cross-referencing information) to the XML output. Note that
+# enabling this will significantly increase the size of the XML output.
+XML_PROGRAMLISTING     = YES
+# configuration options for the AutoGen Definitions output
+# If the GENERATE_AUTOGEN_DEF tag is set to YES Doxygen will
+# generate an AutoGen Definitions (see autogen.sf.net) file
+# that captures the structure of the code including all
+# documentation. Note that this feature is still experimental
+# and incomplete at the moment.
+GENERATE_AUTOGEN_DEF   = NO
+# configuration options related to the Perl module output
+# If the GENERATE_PERLMOD tag is set to YES Doxygen will
+# generate a Perl module file that captures the structure of
+# the code including all documentation. Note that this
+# feature is still experimental and incomplete at the
+# moment.
+GENERATE_PERLMOD       = NO
+# If the PERLMOD_LATEX tag is set to YES Doxygen will generate
+# the necessary Makefile rules, Perl scripts and LaTeX code to be able
+# to generate PDF and DVI output from the Perl module output.
+PERLMOD_LATEX          = NO
+# If the PERLMOD_PRETTY tag is set to YES the Perl module output will be
+# nicely formatted so it can be parsed by a human reader.  This is useful
+# if you want to understand what is going on.  On the other hand, if this
+# tag is set to NO the size of the Perl module output will be much smaller
+# and Perl will parse it just the same.
+PERLMOD_PRETTY         = YES
+# The names of the make variables in the generated doxyrules.make file
+# are prefixed with the string contained in PERLMOD_MAKEVAR_PREFIX.
+# This is useful so different doxyrules.make files included by the same
+# Makefile don't overwrite each other's variables.
+PERLMOD_MAKEVAR_PREFIX =
+# Configuration options related to the preprocessor
+# If the ENABLE_PREPROCESSING tag is set to YES (the default) Doxygen will
+# evaluate all C-preprocessor directives found in the sources and include
+# files.
+ENABLE_PREPROCESSING   = YES
+# If the MACRO_EXPANSION tag is set to YES Doxygen will expand all macro
+# names in the source code. If set to NO (the default) only conditional
+# compilation will be performed. Macro expansion can be done in a controlled
+# way by setting EXPAND_ONLY_PREDEF to YES.
+MACRO_EXPANSION        = NO
+# If the EXPAND_ONLY_PREDEF and MACRO_EXPANSION tags are both set to YES
+# then the macro expansion is limited to the macros specified with the
+# PREDEFINED and EXPAND_AS_PREDEFINED tags.
+EXPAND_ONLY_PREDEF     = NO
+# If the SEARCH_INCLUDES tag is set to YES (the default) the includes files
+# in the INCLUDE_PATH (see below) will be search if a #include is found.
+SEARCH_INCLUDES        = YES
+# The INCLUDE_PATH tag can be used to specify one or more directories that
+# contain include files that are not input files but should be processed by
+# the preprocessor.
+INCLUDE_PATH           = ../include ../../include
+# You can use the INCLUDE_FILE_PATTERNS tag to specify one or more wildcard
+# patterns (like *.h and *.hpp) to filter out the header-files in the
+# directories. If left blank, the patterns specified with FILE_PATTERNS will
+# be used.
+INCLUDE_FILE_PATTERNS  =
+# The PREDEFINED tag can be used to specify one or more macro names that
+# are defined before the preprocessor is started (similar to the -D option of
+# gcc). The argument of the tag is a list of macros of the form: name
+# or name=definition (no spaces). If the definition and the = are
+# omitted =1 is assumed. To prevent a macro definition from being
+# undefined via #undef or recursively expanded use the := operator
+# instead of the = operator.
+PREDEFINED             = HAVE_OGR HAVE_TIFFIO_H HAVE_GEOS
+# If the MACRO_EXPANSION and EXPAND_ONLY_PREDEF tags are set to YES then
+# this tag can be used to specify a list of macro names that should be expanded.
+# The macro definition that is found in the sources will be used.
+# Use the PREDEFINED tag if you want to use a different macro definition.
+EXPAND_AS_DEFINED      =
+# If the SKIP_FUNCTION_MACROS tag is set to YES (the default) then
+# doxygen's preprocessor will remove all function-like macros that are alone
+# on a line, have an all uppercase name, and do not end with a semicolon. Such
+# function macros are typically used for boiler-plate code, and will confuse the
+# parser if not removed.
+SKIP_FUNCTION_MACROS   = YES
+# Configuration::additions related to external references
+# The TAGFILES option can be used to specify one or more tagfiles.
+# Optionally an initial location of the external documentation
+# can be added for each tagfile. The format of a tag file without
+# this location is as follows:
+#   TAGFILES = file1 file2 ...
+# Adding location for the tag files is done as follows:
+#   TAGFILES = file1=loc1 "file2 = loc2" ...
+# where "loc1" and "loc2" can be relative or absolute paths or
+# URLs. If a location is present for each tag, the installdox tool
+# does not have to be run to correct the links.
+# Note that each tag file must have a unique name
+# (where the name does NOT include the path)
+# If a tag file is not located in the directory in which doxygen
+# is run, you must also specify the path to the tagfile here.
+TAGFILES               =
+# When a file name is specified after GENERATE_TAGFILE, doxygen will create
+# a tag file that is based on the input files it reads.
+GENERATE_TAGFILE       =
+# If the ALLEXTERNALS tag is set to YES all external classes will be listed
+# in the class index. If set to NO only the inherited external classes
+# will be listed.
+ALLEXTERNALS           = NO
+# If the EXTERNAL_GROUPS tag is set to YES all external groups will be listed
+# in the modules index. If set to NO, only the current project's groups will
+# be listed.
+EXTERNAL_GROUPS        = YES
+# The PERL_PATH should be the absolute path and name of the perl script
+# interpreter (i.e. the result of `which perl').
+PERL_PATH              = /usr/bin/perl
+# Configuration options related to the dot tool
+# If the CLASS_DIAGRAMS tag is set to YES (the default) Doxygen will
+# generate a inheritance diagram (in HTML, RTF and LaTeX) for classes with base or
+# super classes. Setting the tag to NO turns the diagrams off. Note that this
+# option is superseded by the HAVE_DOT option below. This is only a fallback. It is
+# recommended to install and use dot, since it yields more powerful graphs.
+CLASS_DIAGRAMS         = YES
+# If set to YES, the inheritance and collaboration graphs will hide
+# inheritance and usage relations if the target is undocumented
+# or is not a class.
+HIDE_UNDOC_RELATIONS   = YES
+# If you set the HAVE_DOT tag to YES then doxygen will assume the dot tool is
+# available from the path. This tool is part of Graphviz, a graph visualization
+# toolkit from AT&T and Lucent Bell Labs. The other options in this section
+# have no effect if this option is set to NO (the default)
+HAVE_DOT               = YES
+# If the CLASS_GRAPH and HAVE_DOT tags are set to YES then doxygen
+# will generate a graph for each documented class showing the direct and
+# indirect inheritance relations. Setting this tag to YES will force the
+# the CLASS_DIAGRAMS tag to NO.
+CLASS_GRAPH            = YES
+# If the COLLABORATION_GRAPH and HAVE_DOT tags are set to YES then doxygen
+# indirect implementation dependencies (inheritance, containment, and
+# class references variables) of the class with other documented classes.
+COLLABORATION_GRAPH    = YES
+# If the UML_LOOK tag is set to YES doxygen will generate inheritance and
+# collaboration diagrams in a style similar to the OMG's Unified Modeling
+# Language.
+UML_LOOK               = NO
+# If set to YES, the inheritance and collaboration graphs will show the
+# relations between templates and their instances.
+TEMPLATE_RELATIONS     = NO
+# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDE_GRAPH, and HAVE_DOT
+# tags are set to YES then doxygen will generate a graph for each documented
+# file showing the direct and indirect include dependencies of the file with
+# other documented files.
+INCLUDE_GRAPH          = YES
+# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDED_BY_GRAPH, and
+# HAVE_DOT tags are set to YES then doxygen will generate a graph for each
+# documented header file showing the documented files that directly or
+# indirectly include this file.
+INCLUDED_BY_GRAPH      = YES
+# If the CALL_GRAPH and HAVE_DOT tags are set to YES then doxygen will
+# generate a call dependency graph for every global function or class method.
+# Note that enabling this option will significantly increase the time of a run.
+# So in most cases it will be better to enable call graphs for selected
+# functions only using the \callgraph command.
+CALL_GRAPH             = NO
+# If the GRAPHICAL_HIERARCHY and HAVE_DOT tags are set to YES then doxygen
+# will graphical hierarchy of all classes instead of a textual one.
+GRAPHICAL_HIERARCHY    = YES
+# The DOT_IMAGE_FORMAT tag can be used to set the image format of the images
+# generated by dot. Possible values are png, jpg, or gif
+# If left blank png will be used.
+DOT_IMAGE_FORMAT       = png
+# The tag DOT_PATH can be used to specify the path where the dot tool can be
+# found. If left blank, it is assumed the dot tool can be found on the path.
+DOT_PATH               =
+# The DOTFILE_DIRS tag can be used to specify one or more directories that
+# contain dot files that are included in the documentation (see the
+# \dotfile command).
+DOTFILE_DIRS           =
+# The MAX_DOT_GRAPH_WIDTH tag can be used to set the maximum allowed width
+# (in pixels) of the graphs generated by dot. If a graph becomes larger than
+# this value, doxygen will try to truncate the graph, so that it fits within
+# the specified constraint. Beware that most browsers cannot cope with very
+# large images.
+MAX_DOT_GRAPH_WIDTH    = 2000
+# The MAX_DOT_GRAPH_HEIGHT tag can be used to set the maximum allows height
+# large images.
+MAX_DOT_GRAPH_HEIGHT   = 2000
+# The MAX_DOT_GRAPH_DEPTH tag can be used to set the maximum depth of the
+# graphs generated by dot. A depth value of 3 means that only nodes reachable
+# from the root by following a path via at most 3 edges will be shown. Nodes that
+# lay further from the root node will be omitted. Note that setting this option to
+# 1 or 2 may greatly reduce the computation time needed for large code bases. Also
+# note that a graph may be further truncated if the graph's image dimensions are
+# not sufficient to fit the graph (see MAX_DOT_GRAPH_WIDTH and MAX_DOT_GRAPH_HEIGHT).
+# If 0 is used for the depth value (the default), the graph is not depth-constrained.
+MAX_DOT_GRAPH_DEPTH    = 0
+# If the GENERATE_LEGEND tag is set to YES (the default) Doxygen will
+# generate a legend page explaining the meaning of the various boxes and
+# arrows in the dot generated graphs.
+GENERATE_LEGEND        = YES
+# If the DOT_CLEANUP tag is set to YES (the default) Doxygen will
+# remove the intermediate dot files that are used to generate
+# the various graphs.
+DOT_CLEANUP            = YES
+# Configuration::additions related to the search engine
+# The SEARCHENGINE tag specifies whether or not a search engine should be
+# used. If set to NO the values of all tags below this one will be ignored.
+SEARCHENGINE           = YES
Deleted: grass/trunk/include/Make/Doxyfile_arch_latex
--- grass/trunk/include/Make/Doxyfile_arch_latex	2009-10-22 18:11:52 UTC (rev 39610)
+++ grass/trunk/include/Make/Doxyfile_arch_latex	2009-10-22 20:12:17 UTC (rev 39611)
@@ -1,1165 +0,0 @@
-# Doxyfile 1.3.9.1
-# This file describes the settings to be used by the documentation system
-# doxygen (www.doxygen.org) for a project
-# All text after a hash (#) is considered a comment and will be ignored
-# The format is:
-#       TAG = value [value, ...]
-# For lists items can also be appended using:
-#       TAG += value [value, ...]
-# Values that contain spaces should be placed between quotes (" ")
-# Project related configuration options
-# The PROJECT_NAME tag is a single word (or a sequence of words surrounded
-# by quotes) that should identify the project.
-PROJECT_NAME           = GRASS
-# The PROJECT_NUMBER tag can be used to enter a project or revision number.
-# This could be handy for archiving the generated documentation or
-# if some version control system is used.
-PROJECT_NUMBER         = 7
-# The OUTPUT_DIRECTORY tag is used to specify the (relative or absolute)
-# base path where the generated documentation will be put.
-# If a relative path is entered, it will be relative to the location
-# where doxygen was started. If left blank the current directory will be used.
-OUTPUT_DIRECTORY       = .
-# If the CREATE_SUBDIRS tag is set to YES, then doxygen will create
-# 4096 sub-directories (in 2 levels) under the output directory of each output
-# format and will distribute the generated files over these directories.
-# Enabling this option can be useful when feeding doxygen a huge amount of source
-# files, where putting all generated files in the same directory would otherwise
-# cause performance problems for the file system.
-CREATE_SUBDIRS         = NO
-# The OUTPUT_LANGUAGE tag is used to specify the language in which all
-# documentation generated by doxygen is written. Doxygen will use this
-# information to generate all constant output in the proper language.
-# The default language is English, other supported languages are:
-# Brazilian, Catalan, Chinese, Chinese-Traditional, Croatian, Czech, Danish,
-# Dutch, Finnish, French, German, Greek, Hungarian, Italian, Japanese,
-# Japanese-en (Japanese with English messages), Korean, Korean-en, Norwegian,
-# Polish, Portuguese, Romanian, Russian, Serbian, Slovak, Slovene, Spanish,
-# Swedish, and Ukrainian.
-OUTPUT_LANGUAGE        = English
-# This tag can be used to specify the encoding used in the generated output.
-# The encoding is not always determined by the language that is chosen,
-# but also whether or not the output is meant for Windows or non-Windows users.
-# In case there is a difference, setting the USE_WINDOWS_ENCODING tag to YES
-# forces the Windows encoding (this is the default for the Windows binary),
-# whereas setting the tag to NO uses a Unix-style encoding (the default for
-# all platforms other than Windows).
-USE_WINDOWS_ENCODING   = NO
-# If the BRIEF_MEMBER_DESC tag is set to YES (the default) Doxygen will
-# include brief member descriptions after the members that are listed in
-# the file and class documentation (similar to JavaDoc).
-# Set to NO to disable this.
-BRIEF_MEMBER_DESC      = YES
-# If the REPEAT_BRIEF tag is set to YES (the default) Doxygen will prepend
-# the brief description of a member or function before the detailed description.
-# Note: if both HIDE_UNDOC_MEMBERS and BRIEF_MEMBER_DESC are set to NO, the
-# brief descriptions will be completely suppressed.
-REPEAT_BRIEF           = YES
-# This tag implements a quasi-intelligent brief description abbreviator
-# that is used to form the text in various listings. Each string
-# in this list, if found as the leading text of the brief description, will be
-# stripped from the text and the result after processing the whole list, is used
-# as the annotated text. Otherwise, the brief description is used as-is. If left
-# blank, the following values are used ("$name" is automatically replaced with the
-# name of the entity): "The $name class" "The $name widget" "The $name file"
-# "is" "provides" "specifies" "contains" "represents" "a" "an" "the"
-ABBREVIATE_BRIEF       =
-# If the ALWAYS_DETAILED_SEC and REPEAT_BRIEF tags are both set to YES then
-# Doxygen will generate a detailed section even if there is only a brief
-# description.
-ALWAYS_DETAILED_SEC    = NO
-# If the INLINE_INHERITED_MEMB tag is set to YES, doxygen will show all inherited
-# members of a class in the documentation of that class as if those members were
-# ordinary class members. Constructors, destructors and assignment operators of
-# the base classes will not be shown.
-INLINE_INHERITED_MEMB  = NO
-# If the FULL_PATH_NAMES tag is set to YES then Doxygen will prepend the full
-# path before files name in the file list and in the header files. If set
-# to NO the shortest path that makes the file name unique will be used.
-FULL_PATH_NAMES        = NO
-# If the FULL_PATH_NAMES tag is set to YES then the STRIP_FROM_PATH tag
-# can be used to strip a user-defined part of the path. Stripping is
-# only done if one of the specified strings matches the left-hand part of
-# the path. The tag can be used to show relative paths in the file list.
-# If left blank the directory from which doxygen is run is used as the
-# path to strip.
-STRIP_FROM_PATH        =
-# The STRIP_FROM_INC_PATH tag can be used to strip a user-defined part of
-# the path mentioned in the documentation of a class, which tells
-# the reader which header file to include in order to use a class.
-# If left blank only the name of the header file containing the class
-# definition is used. Otherwise one should specify the include paths that
-# are normally passed to the compiler using the -I flag.
-STRIP_FROM_INC_PATH    =
-# If the SHORT_NAMES tag is set to YES, doxygen will generate much shorter
-# (but less readable) file names. This can be useful is your file systems
-# doesn't support long names like on DOS, Mac, or CD-ROM.
-SHORT_NAMES            = NO
-# If the JAVADOC_AUTOBRIEF tag is set to YES then Doxygen
-# will interpret the first line (until the first dot) of a JavaDoc-style
-# comment as the brief description. If set to NO, the JavaDoc
-# comments will behave just like the Qt-style comments (thus requiring an
-# explicit @brief command for a brief description.
-JAVADOC_AUTOBRIEF      = NO
-# The MULTILINE_CPP_IS_BRIEF tag can be set to YES to make Doxygen
-# treat a multi-line C++ special comment block (i.e. a block of //! or ///
-# comments) as a brief description. This used to be the default behaviour.
-# The new default is to treat a multi-line C++ comment block as a detailed
-# description. Set this tag to YES if you prefer the old behaviour instead.
-MULTILINE_CPP_IS_BRIEF = NO
-# If the DETAILS_AT_TOP tag is set to YES then Doxygen
-# will output the detailed description near the top, like JavaDoc.
-# If set to NO, the detailed description appears after the member
-# documentation.
-DETAILS_AT_TOP         = NO
-# If the INHERIT_DOCS tag is set to YES (the default) then an undocumented
-# member inherits the documentation from any documented member that it
-# re-implements.
-INHERIT_DOCS           = YES
-# If member grouping is used in the documentation and the DISTRIBUTE_GROUP_DOC
-# tag is set to YES, then doxygen will reuse the documentation of the first
-# member in the group (if any) for the other members of the group. By default
-# all members of a group must be documented explicitly.
-DISTRIBUTE_GROUP_DOC   = NO
-# The TAB_SIZE tag can be used to set the number of spaces in a tab.
-# Doxygen uses this value to replace tabs by spaces in code fragments.
-TAB_SIZE               = 8
-# This tag can be used to specify a number of aliases that acts
-# as commands in the documentation. An alias has the form "name=value".
-# For example adding "sideeffect=\par Side Effects:\n" will allow you to
-# put the command \sideeffect (or @sideeffect) in the documentation, which
-# will result in a user-defined paragraph with heading "Side Effects:".
-# You can put \n's in the value part of an alias to insert newlines.
-ALIASES                =
-# Set the OPTIMIZE_OUTPUT_FOR_C tag to YES if your project consists of C sources
-# only. Doxygen will then generate output that is more tailored for C.
-# For instance, some of the names that are used will be different. The list
-# of all members will be omitted, etc.
-OPTIMIZE_OUTPUT_FOR_C  = YES
-# Set the OPTIMIZE_OUTPUT_JAVA tag to YES if your project consists of Java sources
-# only. Doxygen will then generate output that is more tailored for Java.
-# For instance, namespaces will be presented as packages, qualified scopes
-# will look different, etc.
-OPTIMIZE_OUTPUT_JAVA   = NO
-# Set the SUBGROUPING tag to YES (the default) to allow class member groups of
-# the same type (for instance a group of public functions) to be put as a
-# subgroup of that type (e.g. under the Public Functions section). Set it to
-# NO to prevent subgrouping. Alternatively, this can be done per class using
-# the \nosubgrouping command.
-SUBGROUPING            = YES
-# Build related configuration options
-# If the EXTRACT_ALL tag is set to YES doxygen will assume all entities in
-# documentation are documented, even if no documentation was available.
-# Private class members and static file members will be hidden unless
-# the EXTRACT_PRIVATE and EXTRACT_STATIC tags are set to YES
-EXTRACT_ALL            = YES
-# If the EXTRACT_PRIVATE tag is set to YES all private members of a class
-# will be included in the documentation.
-EXTRACT_PRIVATE        = NO
-# If the EXTRACT_STATIC tag is set to YES all static members of a file
-EXTRACT_STATIC         = NO
-# If the EXTRACT_LOCAL_CLASSES tag is set to YES classes (and structs)
-# defined locally in source files will be included in the documentation.
-# If set to NO only classes defined in header files are included.
-EXTRACT_LOCAL_CLASSES  = YES
-# This flag is only useful for Objective-C code. When set to YES local
-# methods, which are defined in the implementation section but not in
-# the interface are included in the documentation.
-# If set to NO (the default) only methods in the interface are included.
-EXTRACT_LOCAL_METHODS  = NO
-# If the HIDE_UNDOC_MEMBERS tag is set to YES, Doxygen will hide all
-# undocumented members of documented classes, files or namespaces.
-# If set to NO (the default) these members will be included in the
-# various overviews, but no documentation section is generated.
-# This option has no effect if EXTRACT_ALL is enabled.
-HIDE_UNDOC_MEMBERS     = NO
-# If the HIDE_UNDOC_CLASSES tag is set to YES, Doxygen will hide all
-# undocumented classes that are normally visible in the class hierarchy.
-# If set to NO (the default) these classes will be included in the various
-# overviews. This option has no effect if EXTRACT_ALL is enabled.
-HIDE_UNDOC_CLASSES     = NO
-# If the HIDE_FRIEND_COMPOUNDS tag is set to YES, Doxygen will hide all
-# friend (class|struct|union) declarations.
-# If set to NO (the default) these declarations will be included in the
-# documentation.
-HIDE_FRIEND_COMPOUNDS  = NO
-# If the HIDE_IN_BODY_DOCS tag is set to YES, Doxygen will hide any
-# documentation blocks found inside the body of a function.
-# If set to NO (the default) these blocks will be appended to the
-# function's detailed documentation block.
-HIDE_IN_BODY_DOCS      = NO
-# The INTERNAL_DOCS tag determines if documentation
-# that is typed after a \internal command is included. If the tag is set
-# to NO (the default) then the documentation will be excluded.
-# Set it to YES to include the internal documentation.
-INTERNAL_DOCS          = NO
-# If the CASE_SENSE_NAMES tag is set to NO then Doxygen will only generate
-# file names in lower-case letters. If set to YES upper-case letters are also
-# allowed. This is useful if you have classes or files whose names only differ
-# in case and if your file system supports case sensitive file names. Windows
-# and Mac users are advised to set this option to NO.
-CASE_SENSE_NAMES       = YES
-# If the HIDE_SCOPE_NAMES tag is set to NO (the default) then Doxygen
-# will show members with their full class and namespace scopes in the
-# documentation. If set to YES the scope will be hidden.
-HIDE_SCOPE_NAMES       = NO
-# If the SHOW_INCLUDE_FILES tag is set to YES (the default) then Doxygen
-# will put a list of the files that are included by a file in the documentation
-# of that file.
-SHOW_INCLUDE_FILES     = YES
-# If the INLINE_INFO tag is set to YES (the default) then a tag [inline]
-# is inserted in the documentation for inline members.
-INLINE_INFO            = YES
-# If the SORT_MEMBER_DOCS tag is set to YES (the default) then doxygen
-# will sort the (detailed) documentation of file and class members
-# alphabetically by member name. If set to NO the members will appear in
-# declaration order.
-SORT_MEMBER_DOCS       = YES
-# If the SORT_BRIEF_DOCS tag is set to YES then doxygen will sort the
-# brief documentation of file, namespace and class members alphabetically
-# by member name. If set to NO (the default) the members will appear in
-SORT_BRIEF_DOCS        = NO
-# If the SORT_BY_SCOPE_NAME tag is set to YES, the class list will be
-# sorted by fully-qualified names, including namespaces. If set to
-# NO (the default), the class list will be sorted only by class name,
-# not including the namespace part.
-# Note: This option is not very useful if HIDE_SCOPE_NAMES is set to YES.
-# Note: This option applies only to the class list, not to the
-# alphabetical list.
-SORT_BY_SCOPE_NAME     = NO
-# The GENERATE_TODOLIST tag can be used to enable (YES) or
-# disable (NO) the todo list. This list is created by putting \todo
-# commands in the documentation.
-GENERATE_TODOLIST      = YES
-# The GENERATE_TESTLIST tag can be used to enable (YES) or
-# disable (NO) the test list. This list is created by putting \test
-GENERATE_TESTLIST      = YES
-# The GENERATE_BUGLIST tag can be used to enable (YES) or
-# disable (NO) the bug list. This list is created by putting \bug
-GENERATE_BUGLIST       = YES
-# The GENERATE_DEPRECATEDLIST tag can be used to enable (YES) or
-# disable (NO) the deprecated list. This list is created by putting
-# \deprecated commands in the documentation.
-GENERATE_DEPRECATEDLIST= YES
-# The ENABLED_SECTIONS tag can be used to enable conditional
-# documentation sections, marked by \if sectionname ... \endif.
-ENABLED_SECTIONS       =
-# The MAX_INITIALIZER_LINES tag determines the maximum number of lines
-# the initial value of a variable or define consists of for it to appear in
-# the documentation. If the initializer consists of more lines than specified
-# here it will be hidden. Use a value of 0 to hide initializers completely.
-# The appearance of the initializer of individual variables and defines in the
-# documentation can be controlled using \showinitializer or \hideinitializer
-# command in the documentation regardless of this setting.
-MAX_INITIALIZER_LINES  = 30
-# Set the SHOW_USED_FILES tag to NO to disable the list of files generated
-# at the bottom of the documentation of classes and structs. If set to YES the
-# list will mention the files that were used to generate the documentation.
-SHOW_USED_FILES        = YES
-# If the sources in your project are distributed over multiple directories
-# then setting the SHOW_DIRECTORIES tag to YES will show the directory hierarchy
-# in the documentation.
-SHOW_DIRECTORIES       = YES
-# configuration options related to warning and progress messages
-# The QUIET tag can be used to turn on/off the messages that are generated
-# by doxygen. Possible values are YES and NO. If left blank NO is used.
-QUIET                  = NO
-# The WARNINGS tag can be used to turn on/off the warning messages that are
-# generated by doxygen. Possible values are YES and NO. If left blank
-# NO is used.
-WARNINGS               = YES
-# If WARN_IF_UNDOCUMENTED is set to YES, then doxygen will generate warnings
-# for undocumented members. If EXTRACT_ALL is set to YES then this flag will
-# automatically be disabled.
-WARN_IF_UNDOCUMENTED   = YES
-# If WARN_IF_DOC_ERROR is set to YES, doxygen will generate warnings for
-# potential errors in the documentation, such as not documenting some
-# parameters in a documented function, or documenting parameters that
-# don't exist or using markup commands wrongly.
-WARN_IF_DOC_ERROR      = YES
-# The WARN_FORMAT tag determines the format of the warning messages that
-# doxygen can produce. The string should contain the $file, $line, and $text
-# tags, which will be replaced by the file and line number from which the
-# warning originated and the warning text.
-WARN_FORMAT            = "$file:$line: $text"
-# The WARN_LOGFILE tag can be used to specify a file to which warning
-# and error messages should be written. If left blank the output is written
-# to stderr.
-WARN_LOGFILE           =
-# configuration options related to the input files
-# The INPUT tag can be used to specify the files and/or directories that contain
-# documented source files. You may enter file names like "myfile.cpp" or
-# directories like "/usr/src/myproject". Separate the files or directories
-# with spaces.
-INPUT                  = .
-# If the value of the INPUT tag contains directories, you can use the
-# FILE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
-# and *.h) to filter out the source-files in the directories. If left
-# blank the following patterns are tested:
-# *.c *.cc *.cxx *.cpp *.c++ *.java *.ii *.ixx *.ipp *.i++ *.inl *.h *.hh *.hxx *.hpp
-# *.h++ *.idl *.odl *.cs *.php *.php3 *.inc *.m *.mm
-FILE_PATTERNS          = *.h \
-                         *.c \
-                         *.i \
-                         *.py \
-                         *.dox
-# The RECURSIVE tag can be used to turn specify whether or not subdirectories
-# should be searched for input files as well. Possible values are YES and NO.
-# If left blank NO is used.
-RECURSIVE              = YES
-# The EXCLUDE tag can be used to specify files and/or directories that should
-# excluded from the INPUT source files. This way you can easily exclude a
-# subdirectory from a directory tree whose root is specified with the INPUT tag.
-EXCLUDE                =
-# The EXCLUDE_SYMLINKS tag can be used select whether or not files or directories
-# that are symbolic links (a Unix filesystem feature) are excluded from the input.
-EXCLUDE_SYMLINKS       = NO
-# EXCLUDE_PATTERNS tag to specify one or more wildcard patterns to exclude
-# certain files from those directories.
-EXCLUDE_PATTERNS       =
-# The EXAMPLE_PATH tag can be used to specify one or more files or
-# directories that contain example code fragments that are included (see
-# the \include command).
-EXAMPLE_PATH           =
-# If the value of the EXAMPLE_PATH tag contains directories, you can use the
-# EXAMPLE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
-# blank all files are included.
-EXAMPLE_PATTERNS       =
-# If the EXAMPLE_RECURSIVE tag is set to YES then subdirectories will be
-# searched for input files to be used with the \include or \dontinclude
-# commands irrespective of the value of the RECURSIVE tag.
-# Possible values are YES and NO. If left blank NO is used.
-EXAMPLE_RECURSIVE      = NO
-# The IMAGE_PATH tag can be used to specify one or more files or
-# directories that contain image that are included in the documentation (see
-# the \image command).
-IMAGE_PATH             =
-# The INPUT_FILTER tag can be used to specify a program that doxygen should
-# invoke to filter for each input file. Doxygen will invoke the filter program
-# by executing (via popen()) the command <filter> <input-file>, where <filter>
-# is the value of the INPUT_FILTER tag, and <input-file> is the name of an
-# input file. Doxygen will then use the output that the filter program writes
-# to standard output.  If FILTER_PATTERNS is specified, this tag will be
-# ignored.
-INPUT_FILTER           =
-# The FILTER_PATTERNS tag can be used to specify filters on a per file pattern
-# basis.  Doxygen will compare the file name with each pattern and apply the
-# filter if there is a match.  The filters are a list of the form:
-# pattern=filter (like *.cpp=my_cpp_filter). See INPUT_FILTER for further
-# info on how filters are used. If FILTER_PATTERNS is empty, INPUT_FILTER
-# is applied to all files.
-FILTER_PATTERNS        =
-# If the FILTER_SOURCE_FILES tag is set to YES, the input filter (if set using
-# INPUT_FILTER) will be used to filter the input files when producing source
-# files to browse (i.e. when SOURCE_BROWSER is set to YES).
-FILTER_SOURCE_FILES    = NO
-# configuration options related to source browsing
-# If the SOURCE_BROWSER tag is set to YES then a list of source files will
-# be generated. Documented entities will be cross-referenced with these sources.
-# Note: To get rid of all source code in the generated output, make sure also
-# VERBATIM_HEADERS is set to NO.
-SOURCE_BROWSER         = YES
-# Setting the INLINE_SOURCES tag to YES will include the body
-# of functions and classes directly in the documentation.
-INLINE_SOURCES         = NO
-# Setting the STRIP_CODE_COMMENTS tag to YES (the default) will instruct
-# doxygen to hide any special comment blocks from generated source code
-# fragments. Normal C and C++ comments will always remain visible.
-STRIP_CODE_COMMENTS    = YES
-# If the REFERENCED_BY_RELATION tag is set to YES (the default)
-# then for each documented function all documented
-# functions referencing it will be listed.
-REFERENCED_BY_RELATION = YES
-# If the REFERENCES_RELATION tag is set to YES (the default)
-# then for each documented function all documented entities
-# called/used by that function will be listed.
-REFERENCES_RELATION    = YES
-# If the VERBATIM_HEADERS tag is set to YES (the default) then Doxygen
-# will generate a verbatim copy of the header file for each class for
-# which an include is specified. Set to NO to disable this.
-VERBATIM_HEADERS       = YES
-# configuration options related to the alphabetical class index
-# If the ALPHABETICAL_INDEX tag is set to YES, an alphabetical index
-# of all compounds will be generated. Enable this if the project
-# contains a lot of classes, structs, unions or interfaces.
-ALPHABETICAL_INDEX     = NO
-# If the alphabetical index is enabled (see ALPHABETICAL_INDEX) then
-# the COLS_IN_ALPHA_INDEX tag can be used to specify the number of columns
-# in which this list will be split (can be a number in the range [1..20])
-COLS_IN_ALPHA_INDEX    = 5
-# In case all classes in a project start with a common prefix, all
-# classes will be put under the same header in the alphabetical index.
-# The IGNORE_PREFIX tag can be used to specify one or more prefixes that
-# should be ignored while generating the index headers.
-IGNORE_PREFIX          =
-# configuration options related to the HTML output
-# If the GENERATE_HTML tag is set to YES (the default) Doxygen will
-# generate HTML output.
-GENERATE_HTML          = YES
-# The HTML_OUTPUT tag is used to specify where the HTML docs will be put.
-# If a relative path is entered the value of OUTPUT_DIRECTORY will be
-# put in front of it. If left blank `html' will be used as the default path.
-HTML_OUTPUT            =
-# The HTML_FILE_EXTENSION tag can be used to specify the file extension for
-# each generated HTML page (for example: .htm,.php,.asp). If it is left blank
-# doxygen will generate files with .html extension.
-HTML_FILE_EXTENSION    =
-# The HTML_HEADER tag can be used to specify a personal HTML header for
-# each generated HTML page. If it is left blank doxygen will generate a
-# standard header.
-HTML_HEADER            =
-# The HTML_FOOTER tag can be used to specify a personal HTML footer for
-# standard footer.
-HTML_FOOTER            =
-# The HTML_STYLESHEET tag can be used to specify a user-defined cascading
-# style sheet that is used by each HTML page. It can be used to
-# fine-tune the look of the HTML output. If the tag is left blank doxygen
-# will generate a default style sheet. Note that doxygen will try to copy
-# the style sheet file to the HTML output directory, so don't put your own
-# stylesheet in the HTML output directory as well, or it will be erased!
-HTML_STYLESHEET        =
-# If the HTML_ALIGN_MEMBERS tag is set to YES, the members of classes,
-# files or namespaces will be aligned in HTML using tables. If set to
-# NO a bullet list will be used.
-HTML_ALIGN_MEMBERS     = YES
-# If the GENERATE_HTMLHELP tag is set to YES, additional index files
-# will be generated that can be used as input for tools like the
-# Microsoft HTML help workshop to generate a compressed HTML help file (.chm)
-# of the generated HTML documentation.
-GENERATE_HTMLHELP      = NO
-# If the GENERATE_HTMLHELP tag is set to YES, the CHM_FILE tag can
-# be used to specify the file name of the resulting .chm file. You
-# can add a path in front of the file if the result should not be
-# written to the html output directory.
-CHM_FILE               =
-# If the GENERATE_HTMLHELP tag is set to YES, the HHC_LOCATION tag can
-# be used to specify the location (absolute path including file name) of
-# the HTML help compiler (hhc.exe). If non-empty doxygen will try to run
-# the HTML help compiler on the generated index.hhp.
-HHC_LOCATION           =
-# If the GENERATE_HTMLHELP tag is set to YES, the GENERATE_CHI flag
-# controls if a separate .chi index file is generated (YES) or that
-# it should be included in the master .chm file (NO).
-GENERATE_CHI           = NO
-# If the GENERATE_HTMLHELP tag is set to YES, the BINARY_TOC flag
-# controls whether a binary table of contents is generated (YES) or a
-# normal table of contents (NO) in the .chm file.
-BINARY_TOC             = NO
-# The TOC_EXPAND flag can be set to YES to add extra items for group members
-# to the contents of the HTML help documentation and to the tree view.
-TOC_EXPAND             = NO
-# The DISABLE_INDEX tag can be used to turn on/off the condensed index at
-# top of each HTML page. The value NO (the default) enables the index and
-# the value YES disables it.
-DISABLE_INDEX          = NO
-# This tag can be used to set the number of enum values (range [1..20])
-# that doxygen will group on one line in the generated HTML documentation.
-ENUM_VALUES_PER_LINE   = 4
-# If the GENERATE_TREEVIEW tag is set to YES, a side panel will be
-# generated containing a tree-like index structure (just like the one that
-# is generated for HTML Help). For this to work a browser that supports
-# JavaScript, DHTML, CSS and frames is required (for instance Mozilla 1.0+,
-# Netscape 6.0+, Internet explorer 5.0+, or Konqueror). Windows users are
-# probably better off using the HTML help feature.
-GENERATE_TREEVIEW      = NO
-# If the treeview is enabled (see GENERATE_TREEVIEW) then this tag can be
-# used to set the initial width (in pixels) of the frame in which the tree
-# is shown.
-TREEVIEW_WIDTH         = 250
-# configuration options related to the LaTeX output
-# If the GENERATE_LATEX tag is set to YES (the default) Doxygen will
-# generate Latex output.
-GENERATE_LATEX         = YES
-# The LATEX_OUTPUT tag is used to specify where the LaTeX docs will be put.
-# put in front of it. If left blank `latex' will be used as the default path.
-LATEX_OUTPUT           =
-# The LATEX_CMD_NAME tag can be used to specify the LaTeX command name to be
-# invoked. If left blank `latex' will be used as the default command name.
-LATEX_CMD_NAME         = latex
-# The MAKEINDEX_CMD_NAME tag can be used to specify the command name to
-# generate index for LaTeX. If left blank `makeindex' will be used as the
-# default command name.
-MAKEINDEX_CMD_NAME     = makeindex
-# If the COMPACT_LATEX tag is set to YES Doxygen generates more compact
-# LaTeX documents. This may be useful for small projects and may help to
-# save some trees in general.
-COMPACT_LATEX          = YES
-# The PAPER_TYPE tag can be used to set the paper type that is used
-# by the printer. Possible values are: a4, a4wide, letter, legal and
-# executive. If left blank a4wide will be used.
-PAPER_TYPE             = a4
-# The EXTRA_PACKAGES tag can be to specify one or more names of LaTeX
-# packages that should be included in the LaTeX output.
-EXTRA_PACKAGES         =
-# The LATEX_HEADER tag can be used to specify a personal LaTeX header for
-# the generated latex document. The header should contain everything until
-# the first chapter. If it is left blank doxygen will generate a
-# standard header. Notice: only use this tag if you know what you are doing!
-LATEX_HEADER           =
-# If the PDF_HYPERLINKS tag is set to YES, the LaTeX that is generated
-# is prepared for conversion to pdf (using ps2pdf). The pdf file will
-# contain links (just like the HTML output) instead of page references
-# This makes the output suitable for online browsing using a pdf viewer.
-PDF_HYPERLINKS         = YES
-# If the USE_PDFLATEX tag is set to YES, pdflatex will be used instead of
-# plain latex in the generated Makefile. Set this option to YES to get a
-# higher quality PDF documentation.
-USE_PDFLATEX           = YES
-# If the LATEX_BATCHMODE tag is set to YES, doxygen will add the \\batchmode.
-# command to the generated LaTeX files. This will instruct LaTeX to keep
-# running if errors occur, instead of asking the user for help.
-# This option is also used when generating formulas in HTML.
-LATEX_BATCHMODE        = YES
-# If LATEX_HIDE_INDICES is set to YES then doxygen will not
-# include the index chapters (such as File Index, Compound Index, etc.)
-# in the output.
-LATEX_HIDE_INDICES     = NO
-# configuration options related to the RTF output
-# If the GENERATE_RTF tag is set to YES Doxygen will generate RTF output
-# The RTF output is optimized for Word 97 and may not look very pretty with
-# other RTF readers or editors.
-GENERATE_RTF           = NO
-# The RTF_OUTPUT tag is used to specify where the RTF docs will be put.
-# put in front of it. If left blank `rtf' will be used as the default path.
-RTF_OUTPUT             = rtf
-# If the COMPACT_RTF tag is set to YES Doxygen generates more compact
-# RTF documents. This may be useful for small projects and may help to
-COMPACT_RTF            = NO
-# If the RTF_HYPERLINKS tag is set to YES, the RTF that is generated
-# will contain hyperlink fields. The RTF file will
-# contain links (just like the HTML output) instead of page references.
-# This makes the output suitable for online browsing using WORD or other
-# programs which support those fields.
-# Note: wordpad (write) and others do not support links.
-RTF_HYPERLINKS         = NO
-# Load stylesheet definitions from file. Syntax is similar to doxygen's
-# config file, i.e. a series of assignments. You only have to provide
-# replacements, missing definitions are set to their default value.
-RTF_STYLESHEET_FILE    =
-# Set optional variables used in the generation of an rtf document.
-# Syntax is similar to doxygen's config file.
-RTF_EXTENSIONS_FILE    =
-# configuration options related to the man page output
-# If the GENERATE_MAN tag is set to YES (the default) Doxygen will
-# generate man pages
-GENERATE_MAN           = NO
-# The MAN_OUTPUT tag is used to specify where the man pages will be put.
-# put in front of it. If left blank `man' will be used as the default path.
-MAN_OUTPUT             = man
-# The MAN_EXTENSION tag determines the extension that is added to
-# the generated man pages (default is the subroutine's section .3)
-MAN_EXTENSION          = .3
-# If the MAN_LINKS tag is set to YES and Doxygen generates man output,
-# then it will generate one additional man file for each entity
-# documented in the real man page(s). These additional files
-# only source the real man page, but without them the man command
-# would be unable to find the correct page. The default is NO.
-MAN_LINKS              = NO
-# configuration options related to the XML output
-# If the GENERATE_XML tag is set to YES Doxygen will
-# generate an XML file that captures the structure of
-# the code including all documentation.
-GENERATE_XML           = NO
-# The XML_OUTPUT tag is used to specify where the XML pages will be put.
-# put in front of it. If left blank `xml' will be used as the default path.
-XML_OUTPUT             = xml
-# The XML_SCHEMA tag can be used to specify an XML schema,
-# which can be used by a validating XML parser to check the
-# syntax of the XML files.
-XML_SCHEMA             =
-# The XML_DTD tag can be used to specify an XML DTD,
-XML_DTD                =
-# If the XML_PROGRAMLISTING tag is set to YES Doxygen will
-# dump the program listings (including syntax highlighting
-# and cross-referencing information) to the XML output. Note that
-# enabling this will significantly increase the size of the XML output.
-XML_PROGRAMLISTING     = YES
-# configuration options for the AutoGen Definitions output
-# If the GENERATE_AUTOGEN_DEF tag is set to YES Doxygen will
-# generate an AutoGen Definitions (see autogen.sf.net) file
-# that captures the structure of the code including all
-# documentation. Note that this feature is still experimental
-# and incomplete at the moment.
-GENERATE_AUTOGEN_DEF   = NO
-# configuration options related to the Perl module output
-# If the GENERATE_PERLMOD tag is set to YES Doxygen will
-# generate a Perl module file that captures the structure of
-# the code including all documentation. Note that this
-# feature is still experimental and incomplete at the
-# moment.
-GENERATE_PERLMOD       = NO
-# If the PERLMOD_LATEX tag is set to YES Doxygen will generate
-# the necessary Makefile rules, Perl scripts and LaTeX code to be able
-# to generate PDF and DVI output from the Perl module output.
-PERLMOD_LATEX          = NO
-# If the PERLMOD_PRETTY tag is set to YES the Perl module output will be
-# nicely formatted so it can be parsed by a human reader.  This is useful
-# if you want to understand what is going on.  On the other hand, if this
-# tag is set to NO the size of the Perl module output will be much smaller
-# and Perl will parse it just the same.
-PERLMOD_PRETTY         = YES
-# The names of the make variables in the generated doxyrules.make file
-# are prefixed with the string contained in PERLMOD_MAKEVAR_PREFIX.
-# This is useful so different doxyrules.make files included by the same
-# Makefile don't overwrite each other's variables.
-PERLMOD_MAKEVAR_PREFIX =
-# Configuration options related to the preprocessor
-# If the ENABLE_PREPROCESSING tag is set to YES (the default) Doxygen will
-# evaluate all C-preprocessor directives found in the sources and include
-# files.
-ENABLE_PREPROCESSING   = YES
-# If the MACRO_EXPANSION tag is set to YES Doxygen will expand all macro
-# names in the source code. If set to NO (the default) only conditional
-# compilation will be performed. Macro expansion can be done in a controlled
-# way by setting EXPAND_ONLY_PREDEF to YES.
-MACRO_EXPANSION        = NO
-# If the EXPAND_ONLY_PREDEF and MACRO_EXPANSION tags are both set to YES
-# then the macro expansion is limited to the macros specified with the
-# PREDEFINED and EXPAND_AS_PREDEFINED tags.
-EXPAND_ONLY_PREDEF     = NO
-# If the SEARCH_INCLUDES tag is set to YES (the default) the includes files
-# in the INCLUDE_PATH (see below) will be search if a #include is found.
-SEARCH_INCLUDES        = YES
-# The INCLUDE_PATH tag can be used to specify one or more directories that
-# contain include files that are not input files but should be processed by
-# the preprocessor.
-INCLUDE_PATH           = ../include ../../include
-# You can use the INCLUDE_FILE_PATTERNS tag to specify one or more wildcard
-# patterns (like *.h and *.hpp) to filter out the header-files in the
-# directories. If left blank, the patterns specified with FILE_PATTERNS will
-# be used.
-INCLUDE_FILE_PATTERNS  =
-# The PREDEFINED tag can be used to specify one or more macro names that
-# are defined before the preprocessor is started (similar to the -D option of
-# gcc). The argument of the tag is a list of macros of the form: name
-# or name=definition (no spaces). If the definition and the = are
-# omitted =1 is assumed. To prevent a macro definition from being
-# undefined via #undef or recursively expanded use the := operator
-# instead of the = operator.
-PREDEFINED             = HAVE_OGR HAVE_TIFFIO_H HAVE_GEOS
-# If the MACRO_EXPANSION and EXPAND_ONLY_PREDEF tags are set to YES then
-# this tag can be used to specify a list of macro names that should be expanded.
-# The macro definition that is found in the sources will be used.
-# Use the PREDEFINED tag if you want to use a different macro definition.
-EXPAND_AS_DEFINED      =
-# If the SKIP_FUNCTION_MACROS tag is set to YES (the default) then
-# doxygen's preprocessor will remove all function-like macros that are alone
-# on a line, have an all uppercase name, and do not end with a semicolon. Such
-# function macros are typically used for boiler-plate code, and will confuse the
-# parser if not removed.
-SKIP_FUNCTION_MACROS   = YES
-# Configuration::additions related to external references
-# The TAGFILES option can be used to specify one or more tagfiles.
-# Optionally an initial location of the external documentation
-# can be added for each tagfile. The format of a tag file without
-# this location is as follows:
-#   TAGFILES = file1 file2 ...
-# Adding location for the tag files is done as follows:
-#   TAGFILES = file1=loc1 "file2 = loc2" ...
-# where "loc1" and "loc2" can be relative or absolute paths or
-# URLs. If a location is present for each tag, the installdox tool
-# does not have to be run to correct the links.
-# Note that each tag file must have a unique name
-# (where the name does NOT include the path)
-# If a tag file is not located in the directory in which doxygen
-# is run, you must also specify the path to the tagfile here.
-TAGFILES               =
-# When a file name is specified after GENERATE_TAGFILE, doxygen will create
-# a tag file that is based on the input files it reads.
-GENERATE_TAGFILE       =
-# If the ALLEXTERNALS tag is set to YES all external classes will be listed
-# in the class index. If set to NO only the inherited external classes
-# will be listed.
-ALLEXTERNALS           = NO
-# If the EXTERNAL_GROUPS tag is set to YES all external groups will be listed
-# in the modules index. If set to NO, only the current project's groups will
-# be listed.
-EXTERNAL_GROUPS        = YES
-# The PERL_PATH should be the absolute path and name of the perl script
-# interpreter (i.e. the result of `which perl').
-PERL_PATH              = /usr/bin/perl
-# Configuration options related to the dot tool
-# If the CLASS_DIAGRAMS tag is set to YES (the default) Doxygen will
-# generate a inheritance diagram (in HTML, RTF and LaTeX) for classes with base or
-# super classes. Setting the tag to NO turns the diagrams off. Note that this
-# option is superseded by the HAVE_DOT option below. This is only a fallback. It is
-# recommended to install and use dot, since it yields more powerful graphs.
-CLASS_DIAGRAMS         = YES
-# If set to YES, the inheritance and collaboration graphs will hide
-# inheritance and usage relations if the target is undocumented
-# or is not a class.
-HIDE_UNDOC_RELATIONS   = YES
-# If you set the HAVE_DOT tag to YES then doxygen will assume the dot tool is
-# available from the path. This tool is part of Graphviz, a graph visualization
-# toolkit from AT&T and Lucent Bell Labs. The other options in this section
-# have no effect if this option is set to NO (the default)
-HAVE_DOT               = YES
-# If the CLASS_GRAPH and HAVE_DOT tags are set to YES then doxygen
-# will generate a graph for each documented class showing the direct and
-# indirect inheritance relations. Setting this tag to YES will force the
-# the CLASS_DIAGRAMS tag to NO.
-CLASS_GRAPH            = YES
-# If the COLLABORATION_GRAPH and HAVE_DOT tags are set to YES then doxygen
-# indirect implementation dependencies (inheritance, containment, and
-# class references variables) of the class with other documented classes.
-COLLABORATION_GRAPH    = YES
-# If the UML_LOOK tag is set to YES doxygen will generate inheritance and
-# collaboration diagrams in a style similar to the OMG's Unified Modeling
-# Language.
-UML_LOOK               = NO
-# If set to YES, the inheritance and collaboration graphs will show the
-# relations between templates and their instances.
-TEMPLATE_RELATIONS     = NO
-# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDE_GRAPH, and HAVE_DOT
-# tags are set to YES then doxygen will generate a graph for each documented
-# file showing the direct and indirect include dependencies of the file with
-# other documented files.
-INCLUDE_GRAPH          = YES
-# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDED_BY_GRAPH, and
-# HAVE_DOT tags are set to YES then doxygen will generate a graph for each
-# documented header file showing the documented files that directly or
-# indirectly include this file.
-INCLUDED_BY_GRAPH      = YES
-# If the CALL_GRAPH and HAVE_DOT tags are set to YES then doxygen will
-# generate a call dependency graph for every global function or class method.
-# Note that enabling this option will significantly increase the time of a run.
-# So in most cases it will be better to enable call graphs for selected
-# functions only using the \callgraph command.
-CALL_GRAPH             = NO
-# If the GRAPHICAL_HIERARCHY and HAVE_DOT tags are set to YES then doxygen
-# will graphical hierarchy of all classes instead of a textual one.
-GRAPHICAL_HIERARCHY    = YES
-# The DOT_IMAGE_FORMAT tag can be used to set the image format of the images
-# generated by dot. Possible values are png, jpg, or gif
-# If left blank png will be used.
-DOT_IMAGE_FORMAT       = png
-# The tag DOT_PATH can be used to specify the path where the dot tool can be
-# found. If left blank, it is assumed the dot tool can be found on the path.
-DOT_PATH               =
-# The DOTFILE_DIRS tag can be used to specify one or more directories that
-# contain dot files that are included in the documentation (see the
-# \dotfile command).
-DOTFILE_DIRS           =
-# The MAX_DOT_GRAPH_WIDTH tag can be used to set the maximum allowed width
-# (in pixels) of the graphs generated by dot. If a graph becomes larger than
-# this value, doxygen will try to truncate the graph, so that it fits within
-# the specified constraint. Beware that most browsers cannot cope with very
-# large images.
-MAX_DOT_GRAPH_WIDTH    = 2000
-# The MAX_DOT_GRAPH_HEIGHT tag can be used to set the maximum allows height
-# large images.
-MAX_DOT_GRAPH_HEIGHT   = 2000
-# The MAX_DOT_GRAPH_DEPTH tag can be used to set the maximum depth of the
-# graphs generated by dot. A depth value of 3 means that only nodes reachable
-# from the root by following a path via at most 3 edges will be shown. Nodes that
-# lay further from the root node will be omitted. Note that setting this option to
-# 1 or 2 may greatly reduce the computation time needed for large code bases. Also
-# note that a graph may be further truncated if the graph's image dimensions are
-# not sufficient to fit the graph (see MAX_DOT_GRAPH_WIDTH and MAX_DOT_GRAPH_HEIGHT).
-# If 0 is used for the depth value (the default), the graph is not depth-constrained.
-MAX_DOT_GRAPH_DEPTH    = 0
-# If the GENERATE_LEGEND tag is set to YES (the default) Doxygen will
-# generate a legend page explaining the meaning of the various boxes and
-# arrows in the dot generated graphs.
-GENERATE_LEGEND        = YES
-# If the DOT_CLEANUP tag is set to YES (the default) Doxygen will
-# remove the intermediate dot files that are used to generate
-# the various graphs.
-DOT_CLEANUP            = YES
-# Configuration::additions related to the search engine
-# The SEARCHENGINE tag specifies whether or not a search engine should be
-# used. If set to NO the values of all tags below this one will be ignored.
-SEARCHENGINE           = NO
Copied: grass/trunk/include/Make/Doxyfile_arch_latex.in (from rev 39609, grass/trunk/include/Make/Doxyfile_arch_latex)
--- grass/trunk/include/Make/Doxyfile_arch_latex.in	                        (rev 0)
+++ grass/trunk/include/Make/Doxyfile_arch_latex.in	2009-10-22 20:12:17 UTC (rev 39611)
@@ -0,0 +1,1165 @@
+# Doxyfile 1.3.9.1
+# This file describes the settings to be used by the documentation system
+# doxygen (www.doxygen.org) for a project
+# All text after a hash (#) is considered a comment and will be ignored
+# The format is:
+#       TAG = value [value, ...]
+# For lists items can also be appended using:
+#       TAG += value [value, ...]
+# Values that contain spaces should be placed between quotes (" ")
+# Project related configuration options
+# The PROJECT_NAME tag is a single word (or a sequence of words surrounded
+# by quotes) that should identify the project.
+PROJECT_NAME           = GRASS
+# The PROJECT_NUMBER tag can be used to enter a project or revision number.
+# This could be handy for archiving the generated documentation or
+# if some version control system is used.
+PROJECT_NUMBER         = @GRASS_VERSION_MAJOR at .@GRASS_VERSION_MINOR at .@GRASS_VERSION_RELEASE@ (@GRASS_VERSION_DATE@)
+# The OUTPUT_DIRECTORY tag is used to specify the (relative or absolute)
+# base path where the generated documentation will be put.
+# If a relative path is entered, it will be relative to the location
+# where doxygen was started. If left blank the current directory will be used.
+OUTPUT_DIRECTORY       = .
+# If the CREATE_SUBDIRS tag is set to YES, then doxygen will create
+# 4096 sub-directories (in 2 levels) under the output directory of each output
+# format and will distribute the generated files over these directories.
+# Enabling this option can be useful when feeding doxygen a huge amount of source
+# files, where putting all generated files in the same directory would otherwise
+# cause performance problems for the file system.
+CREATE_SUBDIRS         = NO
+# The OUTPUT_LANGUAGE tag is used to specify the language in which all
+# documentation generated by doxygen is written. Doxygen will use this
+# information to generate all constant output in the proper language.
+# The default language is English, other supported languages are:
+# Brazilian, Catalan, Chinese, Chinese-Traditional, Croatian, Czech, Danish,
+# Dutch, Finnish, French, German, Greek, Hungarian, Italian, Japanese,
+# Japanese-en (Japanese with English messages), Korean, Korean-en, Norwegian,
+# Polish, Portuguese, Romanian, Russian, Serbian, Slovak, Slovene, Spanish,
+# Swedish, and Ukrainian.
+OUTPUT_LANGUAGE        = English
+# This tag can be used to specify the encoding used in the generated output.
+# The encoding is not always determined by the language that is chosen,
+# but also whether or not the output is meant for Windows or non-Windows users.
+# In case there is a difference, setting the USE_WINDOWS_ENCODING tag to YES
+# forces the Windows encoding (this is the default for the Windows binary),
+# whereas setting the tag to NO uses a Unix-style encoding (the default for
+# all platforms other than Windows).
+USE_WINDOWS_ENCODING   = NO
+# If the BRIEF_MEMBER_DESC tag is set to YES (the default) Doxygen will
+# include brief member descriptions after the members that are listed in
+# the file and class documentation (similar to JavaDoc).
+# Set to NO to disable this.
+BRIEF_MEMBER_DESC      = YES
+# If the REPEAT_BRIEF tag is set to YES (the default) Doxygen will prepend
+# the brief description of a member or function before the detailed description.
+# Note: if both HIDE_UNDOC_MEMBERS and BRIEF_MEMBER_DESC are set to NO, the
+# brief descriptions will be completely suppressed.
+REPEAT_BRIEF           = YES
+# This tag implements a quasi-intelligent brief description abbreviator
+# that is used to form the text in various listings. Each string
+# in this list, if found as the leading text of the brief description, will be
+# stripped from the text and the result after processing the whole list, is used
+# as the annotated text. Otherwise, the brief description is used as-is. If left
+# blank, the following values are used ("$name" is automatically replaced with the
+# name of the entity): "The $name class" "The $name widget" "The $name file"
+# "is" "provides" "specifies" "contains" "represents" "a" "an" "the"
+ABBREVIATE_BRIEF       =
+# If the ALWAYS_DETAILED_SEC and REPEAT_BRIEF tags are both set to YES then
+# Doxygen will generate a detailed section even if there is only a brief
+# description.
+ALWAYS_DETAILED_SEC    = NO
+# If the INLINE_INHERITED_MEMB tag is set to YES, doxygen will show all inherited
+# members of a class in the documentation of that class as if those members were
+# ordinary class members. Constructors, destructors and assignment operators of
+# the base classes will not be shown.
+INLINE_INHERITED_MEMB  = NO
+# If the FULL_PATH_NAMES tag is set to YES then Doxygen will prepend the full
+# path before files name in the file list and in the header files. If set
+# to NO the shortest path that makes the file name unique will be used.
+FULL_PATH_NAMES        = NO
+# If the FULL_PATH_NAMES tag is set to YES then the STRIP_FROM_PATH tag
+# can be used to strip a user-defined part of the path. Stripping is
+# only done if one of the specified strings matches the left-hand part of
+# the path. The tag can be used to show relative paths in the file list.
+# If left blank the directory from which doxygen is run is used as the
+# path to strip.
+STRIP_FROM_PATH        =
+# The STRIP_FROM_INC_PATH tag can be used to strip a user-defined part of
+# the path mentioned in the documentation of a class, which tells
+# the reader which header file to include in order to use a class.
+# If left blank only the name of the header file containing the class
+# definition is used. Otherwise one should specify the include paths that
+# are normally passed to the compiler using the -I flag.
+STRIP_FROM_INC_PATH    =
+# If the SHORT_NAMES tag is set to YES, doxygen will generate much shorter
+# (but less readable) file names. This can be useful is your file systems
+# doesn't support long names like on DOS, Mac, or CD-ROM.
+SHORT_NAMES            = NO
+# If the JAVADOC_AUTOBRIEF tag is set to YES then Doxygen
+# will interpret the first line (until the first dot) of a JavaDoc-style
+# comment as the brief description. If set to NO, the JavaDoc
+# comments will behave just like the Qt-style comments (thus requiring an
+# explicit @brief command for a brief description.
+JAVADOC_AUTOBRIEF      = NO
+# The MULTILINE_CPP_IS_BRIEF tag can be set to YES to make Doxygen
+# treat a multi-line C++ special comment block (i.e. a block of //! or ///
+# comments) as a brief description. This used to be the default behaviour.
+# The new default is to treat a multi-line C++ comment block as a detailed
+# description. Set this tag to YES if you prefer the old behaviour instead.
+MULTILINE_CPP_IS_BRIEF = NO
+# If the DETAILS_AT_TOP tag is set to YES then Doxygen
+# will output the detailed description near the top, like JavaDoc.
+# If set to NO, the detailed description appears after the member
+# documentation.
+DETAILS_AT_TOP         = NO
+# If the INHERIT_DOCS tag is set to YES (the default) then an undocumented
+# member inherits the documentation from any documented member that it
+# re-implements.
+INHERIT_DOCS           = YES
+# If member grouping is used in the documentation and the DISTRIBUTE_GROUP_DOC
+# tag is set to YES, then doxygen will reuse the documentation of the first
+# member in the group (if any) for the other members of the group. By default
+# all members of a group must be documented explicitly.
+DISTRIBUTE_GROUP_DOC   = NO
+# The TAB_SIZE tag can be used to set the number of spaces in a tab.
+# Doxygen uses this value to replace tabs by spaces in code fragments.
+TAB_SIZE               = 8
+# This tag can be used to specify a number of aliases that acts
+# as commands in the documentation. An alias has the form "name=value".
+# For example adding "sideeffect=\par Side Effects:\n" will allow you to
+# put the command \sideeffect (or @sideeffect) in the documentation, which
+# will result in a user-defined paragraph with heading "Side Effects:".
+# You can put \n's in the value part of an alias to insert newlines.
+ALIASES                =
+# Set the OPTIMIZE_OUTPUT_FOR_C tag to YES if your project consists of C sources
+# only. Doxygen will then generate output that is more tailored for C.
+# For instance, some of the names that are used will be different. The list
+# of all members will be omitted, etc.
+OPTIMIZE_OUTPUT_FOR_C  = YES
+# Set the OPTIMIZE_OUTPUT_JAVA tag to YES if your project consists of Java sources
+# only. Doxygen will then generate output that is more tailored for Java.
+# For instance, namespaces will be presented as packages, qualified scopes
+# will look different, etc.
+OPTIMIZE_OUTPUT_JAVA   = NO
+# Set the SUBGROUPING tag to YES (the default) to allow class member groups of
+# the same type (for instance a group of public functions) to be put as a
+# subgroup of that type (e.g. under the Public Functions section). Set it to
+# NO to prevent subgrouping. Alternatively, this can be done per class using
+# the \nosubgrouping command.
+SUBGROUPING            = YES
+# Build related configuration options
+# If the EXTRACT_ALL tag is set to YES doxygen will assume all entities in
+# documentation are documented, even if no documentation was available.
+# Private class members and static file members will be hidden unless
+# the EXTRACT_PRIVATE and EXTRACT_STATIC tags are set to YES
+EXTRACT_ALL            = YES
+# If the EXTRACT_PRIVATE tag is set to YES all private members of a class
+# will be included in the documentation.
+EXTRACT_PRIVATE        = NO
+# If the EXTRACT_STATIC tag is set to YES all static members of a file
+EXTRACT_STATIC         = NO
+# If the EXTRACT_LOCAL_CLASSES tag is set to YES classes (and structs)
+# defined locally in source files will be included in the documentation.
+# If set to NO only classes defined in header files are included.
+EXTRACT_LOCAL_CLASSES  = YES
+# This flag is only useful for Objective-C code. When set to YES local
+# methods, which are defined in the implementation section but not in
+# the interface are included in the documentation.
+# If set to NO (the default) only methods in the interface are included.
+EXTRACT_LOCAL_METHODS  = NO
+# If the HIDE_UNDOC_MEMBERS tag is set to YES, Doxygen will hide all
+# undocumented members of documented classes, files or namespaces.
+# If set to NO (the default) these members will be included in the
+# various overviews, but no documentation section is generated.
+# This option has no effect if EXTRACT_ALL is enabled.
+HIDE_UNDOC_MEMBERS     = NO
+# If the HIDE_UNDOC_CLASSES tag is set to YES, Doxygen will hide all
+# undocumented classes that are normally visible in the class hierarchy.
+# If set to NO (the default) these classes will be included in the various
+# overviews. This option has no effect if EXTRACT_ALL is enabled.
+HIDE_UNDOC_CLASSES     = NO
+# If the HIDE_FRIEND_COMPOUNDS tag is set to YES, Doxygen will hide all
+# friend (class|struct|union) declarations.
+# If set to NO (the default) these declarations will be included in the
+# documentation.
+HIDE_FRIEND_COMPOUNDS  = NO
+# If the HIDE_IN_BODY_DOCS tag is set to YES, Doxygen will hide any
+# documentation blocks found inside the body of a function.
+# If set to NO (the default) these blocks will be appended to the
+# function's detailed documentation block.
+HIDE_IN_BODY_DOCS      = NO
+# The INTERNAL_DOCS tag determines if documentation
+# that is typed after a \internal command is included. If the tag is set
+# to NO (the default) then the documentation will be excluded.
+# Set it to YES to include the internal documentation.
+INTERNAL_DOCS          = NO
+# If the CASE_SENSE_NAMES tag is set to NO then Doxygen will only generate
+# file names in lower-case letters. If set to YES upper-case letters are also
+# allowed. This is useful if you have classes or files whose names only differ
+# in case and if your file system supports case sensitive file names. Windows
+# and Mac users are advised to set this option to NO.
+CASE_SENSE_NAMES       = YES
+# If the HIDE_SCOPE_NAMES tag is set to NO (the default) then Doxygen
+# will show members with their full class and namespace scopes in the
+# documentation. If set to YES the scope will be hidden.
+HIDE_SCOPE_NAMES       = NO
+# If the SHOW_INCLUDE_FILES tag is set to YES (the default) then Doxygen
+# will put a list of the files that are included by a file in the documentation
+# of that file.
+SHOW_INCLUDE_FILES     = YES
+# If the INLINE_INFO tag is set to YES (the default) then a tag [inline]
+# is inserted in the documentation for inline members.
+INLINE_INFO            = YES
+# If the SORT_MEMBER_DOCS tag is set to YES (the default) then doxygen
+# will sort the (detailed) documentation of file and class members
+# alphabetically by member name. If set to NO the members will appear in
+# declaration order.
+SORT_MEMBER_DOCS       = YES
+# If the SORT_BRIEF_DOCS tag is set to YES then doxygen will sort the
+# brief documentation of file, namespace and class members alphabetically
+# by member name. If set to NO (the default) the members will appear in
+SORT_BRIEF_DOCS        = NO
+# If the SORT_BY_SCOPE_NAME tag is set to YES, the class list will be
+# sorted by fully-qualified names, including namespaces. If set to
+# NO (the default), the class list will be sorted only by class name,
+# not including the namespace part.
+# Note: This option is not very useful if HIDE_SCOPE_NAMES is set to YES.
+# Note: This option applies only to the class list, not to the
+# alphabetical list.
+SORT_BY_SCOPE_NAME     = NO
+# The GENERATE_TODOLIST tag can be used to enable (YES) or
+# disable (NO) the todo list. This list is created by putting \todo
+# commands in the documentation.
+GENERATE_TODOLIST      = YES
+# The GENERATE_TESTLIST tag can be used to enable (YES) or
+# disable (NO) the test list. This list is created by putting \test
+GENERATE_TESTLIST      = YES
+# The GENERATE_BUGLIST tag can be used to enable (YES) or
+# disable (NO) the bug list. This list is created by putting \bug
+GENERATE_BUGLIST       = YES
+# The GENERATE_DEPRECATEDLIST tag can be used to enable (YES) or
+# disable (NO) the deprecated list. This list is created by putting
+# \deprecated commands in the documentation.
+GENERATE_DEPRECATEDLIST= YES
+# The ENABLED_SECTIONS tag can be used to enable conditional
+# documentation sections, marked by \if sectionname ... \endif.
+ENABLED_SECTIONS       =
+# The MAX_INITIALIZER_LINES tag determines the maximum number of lines
+# the initial value of a variable or define consists of for it to appear in
+# the documentation. If the initializer consists of more lines than specified
+# here it will be hidden. Use a value of 0 to hide initializers completely.
+# The appearance of the initializer of individual variables and defines in the
+# documentation can be controlled using \showinitializer or \hideinitializer
+# command in the documentation regardless of this setting.
+MAX_INITIALIZER_LINES  = 30
+# Set the SHOW_USED_FILES tag to NO to disable the list of files generated
+# at the bottom of the documentation of classes and structs. If set to YES the
+# list will mention the files that were used to generate the documentation.
+SHOW_USED_FILES        = YES
+# If the sources in your project are distributed over multiple directories
+# then setting the SHOW_DIRECTORIES tag to YES will show the directory hierarchy
+# in the documentation.
+SHOW_DIRECTORIES       = YES
+# configuration options related to warning and progress messages
+# The QUIET tag can be used to turn on/off the messages that are generated
+# by doxygen. Possible values are YES and NO. If left blank NO is used.
+QUIET                  = NO
+# The WARNINGS tag can be used to turn on/off the warning messages that are
+# generated by doxygen. Possible values are YES and NO. If left blank
+# NO is used.
+WARNINGS               = YES
+# If WARN_IF_UNDOCUMENTED is set to YES, then doxygen will generate warnings
+# for undocumented members. If EXTRACT_ALL is set to YES then this flag will
+# automatically be disabled.
+WARN_IF_UNDOCUMENTED   = YES
+# If WARN_IF_DOC_ERROR is set to YES, doxygen will generate warnings for
+# potential errors in the documentation, such as not documenting some
+# parameters in a documented function, or documenting parameters that
+# don't exist or using markup commands wrongly.
+WARN_IF_DOC_ERROR      = YES
+# The WARN_FORMAT tag determines the format of the warning messages that
+# doxygen can produce. The string should contain the $file, $line, and $text
+# tags, which will be replaced by the file and line number from which the
+# warning originated and the warning text.
+WARN_FORMAT            = "$file:$line: $text"
+# The WARN_LOGFILE tag can be used to specify a file to which warning
+# and error messages should be written. If left blank the output is written
+# to stderr.
+WARN_LOGFILE           =
+# configuration options related to the input files
+# The INPUT tag can be used to specify the files and/or directories that contain
+# documented source files. You may enter file names like "myfile.cpp" or
+# directories like "/usr/src/myproject". Separate the files or directories
+# with spaces.
+INPUT                  = .
+# If the value of the INPUT tag contains directories, you can use the
+# FILE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
+# and *.h) to filter out the source-files in the directories. If left
+# blank the following patterns are tested:
+# *.c *.cc *.cxx *.cpp *.c++ *.java *.ii *.ixx *.ipp *.i++ *.inl *.h *.hh *.hxx *.hpp
+# *.h++ *.idl *.odl *.cs *.php *.php3 *.inc *.m *.mm
+FILE_PATTERNS          = *.h \
+                         *.c \
+                         *.i \
+                         *.py \
+                         *.dox
+# The RECURSIVE tag can be used to turn specify whether or not subdirectories
+# should be searched for input files as well. Possible values are YES and NO.
+# If left blank NO is used.
+RECURSIVE              = YES
+# The EXCLUDE tag can be used to specify files and/or directories that should
+# excluded from the INPUT source files. This way you can easily exclude a
+# subdirectory from a directory tree whose root is specified with the INPUT tag.
+EXCLUDE                =
+# The EXCLUDE_SYMLINKS tag can be used select whether or not files or directories
+# that are symbolic links (a Unix filesystem feature) are excluded from the input.
+EXCLUDE_SYMLINKS       = NO
+# EXCLUDE_PATTERNS tag to specify one or more wildcard patterns to exclude
+# certain files from those directories.
+EXCLUDE_PATTERNS       =
+# The EXAMPLE_PATH tag can be used to specify one or more files or
+# directories that contain example code fragments that are included (see
+# the \include command).
+EXAMPLE_PATH           =
+# If the value of the EXAMPLE_PATH tag contains directories, you can use the
+# EXAMPLE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
+# blank all files are included.
+EXAMPLE_PATTERNS       =
+# If the EXAMPLE_RECURSIVE tag is set to YES then subdirectories will be
+# searched for input files to be used with the \include or \dontinclude
+# commands irrespective of the value of the RECURSIVE tag.
+# Possible values are YES and NO. If left blank NO is used.
+EXAMPLE_RECURSIVE      = NO
+# The IMAGE_PATH tag can be used to specify one or more files or
+# directories that contain image that are included in the documentation (see
+# the \image command).
+IMAGE_PATH             =
+# The INPUT_FILTER tag can be used to specify a program that doxygen should
+# invoke to filter for each input file. Doxygen will invoke the filter program
+# by executing (via popen()) the command <filter> <input-file>, where <filter>
+# is the value of the INPUT_FILTER tag, and <input-file> is the name of an
+# input file. Doxygen will then use the output that the filter program writes
+# to standard output.  If FILTER_PATTERNS is specified, this tag will be
+# ignored.
+INPUT_FILTER           =
+# The FILTER_PATTERNS tag can be used to specify filters on a per file pattern
+# basis.  Doxygen will compare the file name with each pattern and apply the
+# filter if there is a match.  The filters are a list of the form:
+# pattern=filter (like *.cpp=my_cpp_filter). See INPUT_FILTER for further
+# info on how filters are used. If FILTER_PATTERNS is empty, INPUT_FILTER
+# is applied to all files.
+FILTER_PATTERNS        =
+# If the FILTER_SOURCE_FILES tag is set to YES, the input filter (if set using
+# INPUT_FILTER) will be used to filter the input files when producing source
+# files to browse (i.e. when SOURCE_BROWSER is set to YES).
+FILTER_SOURCE_FILES    = NO
+# configuration options related to source browsing
+# If the SOURCE_BROWSER tag is set to YES then a list of source files will
+# be generated. Documented entities will be cross-referenced with these sources.
+# Note: To get rid of all source code in the generated output, make sure also
+# VERBATIM_HEADERS is set to NO.
+SOURCE_BROWSER         = YES
+# Setting the INLINE_SOURCES tag to YES will include the body
+# of functions and classes directly in the documentation.
+INLINE_SOURCES         = NO
+# Setting the STRIP_CODE_COMMENTS tag to YES (the default) will instruct
+# doxygen to hide any special comment blocks from generated source code
+# fragments. Normal C and C++ comments will always remain visible.
+STRIP_CODE_COMMENTS    = YES
+# If the REFERENCED_BY_RELATION tag is set to YES (the default)
+# then for each documented function all documented
+# functions referencing it will be listed.
+REFERENCED_BY_RELATION = YES
+# If the REFERENCES_RELATION tag is set to YES (the default)
+# then for each documented function all documented entities
+# called/used by that function will be listed.
+REFERENCES_RELATION    = YES
+# If the VERBATIM_HEADERS tag is set to YES (the default) then Doxygen
+# will generate a verbatim copy of the header file for each class for
+# which an include is specified. Set to NO to disable this.
+VERBATIM_HEADERS       = YES
+# configuration options related to the alphabetical class index
+# If the ALPHABETICAL_INDEX tag is set to YES, an alphabetical index
+# of all compounds will be generated. Enable this if the project
+# contains a lot of classes, structs, unions or interfaces.
+ALPHABETICAL_INDEX     = NO
+# If the alphabetical index is enabled (see ALPHABETICAL_INDEX) then
+# the COLS_IN_ALPHA_INDEX tag can be used to specify the number of columns
+# in which this list will be split (can be a number in the range [1..20])
+COLS_IN_ALPHA_INDEX    = 5
+# In case all classes in a project start with a common prefix, all
+# classes will be put under the same header in the alphabetical index.
+# The IGNORE_PREFIX tag can be used to specify one or more prefixes that
+# should be ignored while generating the index headers.
+IGNORE_PREFIX          =
+# configuration options related to the HTML output
+# If the GENERATE_HTML tag is set to YES (the default) Doxygen will
+# generate HTML output.
+GENERATE_HTML          = YES
+# The HTML_OUTPUT tag is used to specify where the HTML docs will be put.
+# If a relative path is entered the value of OUTPUT_DIRECTORY will be
+# put in front of it. If left blank `html' will be used as the default path.
+HTML_OUTPUT            =
+# The HTML_FILE_EXTENSION tag can be used to specify the file extension for
+# each generated HTML page (for example: .htm,.php,.asp). If it is left blank
+# doxygen will generate files with .html extension.
+HTML_FILE_EXTENSION    =
+# The HTML_HEADER tag can be used to specify a personal HTML header for
+# each generated HTML page. If it is left blank doxygen will generate a
+# standard header.
+HTML_HEADER            =
+# The HTML_FOOTER tag can be used to specify a personal HTML footer for
+# standard footer.
+HTML_FOOTER            =
+# The HTML_STYLESHEET tag can be used to specify a user-defined cascading
+# style sheet that is used by each HTML page. It can be used to
+# fine-tune the look of the HTML output. If the tag is left blank doxygen
+# will generate a default style sheet. Note that doxygen will try to copy
+# the style sheet file to the HTML output directory, so don't put your own
+# stylesheet in the HTML output directory as well, or it will be erased!
+HTML_STYLESHEET        =
+# If the HTML_ALIGN_MEMBERS tag is set to YES, the members of classes,
+# files or namespaces will be aligned in HTML using tables. If set to
+# NO a bullet list will be used.
+HTML_ALIGN_MEMBERS     = YES
+# If the GENERATE_HTMLHELP tag is set to YES, additional index files
+# will be generated that can be used as input for tools like the
+# Microsoft HTML help workshop to generate a compressed HTML help file (.chm)
+# of the generated HTML documentation.
+GENERATE_HTMLHELP      = NO
+# If the GENERATE_HTMLHELP tag is set to YES, the CHM_FILE tag can
+# be used to specify the file name of the resulting .chm file. You
+# can add a path in front of the file if the result should not be
+# written to the html output directory.
+CHM_FILE               =
+# If the GENERATE_HTMLHELP tag is set to YES, the HHC_LOCATION tag can
+# be used to specify the location (absolute path including file name) of
+# the HTML help compiler (hhc.exe). If non-empty doxygen will try to run
+# the HTML help compiler on the generated index.hhp.
+HHC_LOCATION           =
+# If the GENERATE_HTMLHELP tag is set to YES, the GENERATE_CHI flag
+# controls if a separate .chi index file is generated (YES) or that
+# it should be included in the master .chm file (NO).
+GENERATE_CHI           = NO
+# If the GENERATE_HTMLHELP tag is set to YES, the BINARY_TOC flag
+# controls whether a binary table of contents is generated (YES) or a
+# normal table of contents (NO) in the .chm file.
+BINARY_TOC             = NO
+# The TOC_EXPAND flag can be set to YES to add extra items for group members
+# to the contents of the HTML help documentation and to the tree view.
+TOC_EXPAND             = NO
+# The DISABLE_INDEX tag can be used to turn on/off the condensed index at
+# top of each HTML page. The value NO (the default) enables the index and
+# the value YES disables it.
+DISABLE_INDEX          = NO
+# This tag can be used to set the number of enum values (range [1..20])
+# that doxygen will group on one line in the generated HTML documentation.
+ENUM_VALUES_PER_LINE   = 4
+# If the GENERATE_TREEVIEW tag is set to YES, a side panel will be
+# generated containing a tree-like index structure (just like the one that
+# is generated for HTML Help). For this to work a browser that supports
+# JavaScript, DHTML, CSS and frames is required (for instance Mozilla 1.0+,
+# Netscape 6.0+, Internet explorer 5.0+, or Konqueror). Windows users are
+# probably better off using the HTML help feature.
+GENERATE_TREEVIEW      = NO
+# If the treeview is enabled (see GENERATE_TREEVIEW) then this tag can be
+# used to set the initial width (in pixels) of the frame in which the tree
+# is shown.
+TREEVIEW_WIDTH         = 250
+# configuration options related to the LaTeX output
+# If the GENERATE_LATEX tag is set to YES (the default) Doxygen will
+# generate Latex output.
+GENERATE_LATEX         = YES
+# The LATEX_OUTPUT tag is used to specify where the LaTeX docs will be put.
+# put in front of it. If left blank `latex' will be used as the default path.
+LATEX_OUTPUT           =
+# The LATEX_CMD_NAME tag can be used to specify the LaTeX command name to be
+# invoked. If left blank `latex' will be used as the default command name.
+LATEX_CMD_NAME         = latex
+# The MAKEINDEX_CMD_NAME tag can be used to specify the command name to
+# generate index for LaTeX. If left blank `makeindex' will be used as the
+# default command name.
+MAKEINDEX_CMD_NAME     = makeindex
+# If the COMPACT_LATEX tag is set to YES Doxygen generates more compact
+# LaTeX documents. This may be useful for small projects and may help to
+# save some trees in general.
+COMPACT_LATEX          = YES
+# The PAPER_TYPE tag can be used to set the paper type that is used
+# by the printer. Possible values are: a4, a4wide, letter, legal and
+# executive. If left blank a4wide will be used.
+PAPER_TYPE             = a4
+# The EXTRA_PACKAGES tag can be to specify one or more names of LaTeX
+# packages that should be included in the LaTeX output.
+EXTRA_PACKAGES         =
+# The LATEX_HEADER tag can be used to specify a personal LaTeX header for
+# the generated latex document. The header should contain everything until
+# the first chapter. If it is left blank doxygen will generate a
+# standard header. Notice: only use this tag if you know what you are doing!
+LATEX_HEADER           =
+# If the PDF_HYPERLINKS tag is set to YES, the LaTeX that is generated
+# is prepared for conversion to pdf (using ps2pdf). The pdf file will
+# contain links (just like the HTML output) instead of page references
+# This makes the output suitable for online browsing using a pdf viewer.
+PDF_HYPERLINKS         = YES
+# If the USE_PDFLATEX tag is set to YES, pdflatex will be used instead of
+# plain latex in the generated Makefile. Set this option to YES to get a
+# higher quality PDF documentation.
+USE_PDFLATEX           = YES
+# If the LATEX_BATCHMODE tag is set to YES, doxygen will add the \\batchmode.
+# command to the generated LaTeX files. This will instruct LaTeX to keep
+# running if errors occur, instead of asking the user for help.
+# This option is also used when generating formulas in HTML.
+LATEX_BATCHMODE        = YES
+# If LATEX_HIDE_INDICES is set to YES then doxygen will not
+# include the index chapters (such as File Index, Compound Index, etc.)
+# in the output.
+LATEX_HIDE_INDICES     = NO
+# configuration options related to the RTF output
+# If the GENERATE_RTF tag is set to YES Doxygen will generate RTF output
+# The RTF output is optimized for Word 97 and may not look very pretty with
+# other RTF readers or editors.
+GENERATE_RTF           = NO
+# The RTF_OUTPUT tag is used to specify where the RTF docs will be put.
+# put in front of it. If left blank `rtf' will be used as the default path.
+RTF_OUTPUT             = rtf
+# If the COMPACT_RTF tag is set to YES Doxygen generates more compact
+# RTF documents. This may be useful for small projects and may help to
+COMPACT_RTF            = NO
+# If the RTF_HYPERLINKS tag is set to YES, the RTF that is generated
+# will contain hyperlink fields. The RTF file will
+# contain links (just like the HTML output) instead of page references.
+# This makes the output suitable for online browsing using WORD or other
+# programs which support those fields.
+# Note: wordpad (write) and others do not support links.
+RTF_HYPERLINKS         = NO
+# Load stylesheet definitions from file. Syntax is similar to doxygen's
+# config file, i.e. a series of assignments. You only have to provide
+# replacements, missing definitions are set to their default value.
+RTF_STYLESHEET_FILE    =
+# Set optional variables used in the generation of an rtf document.
+# Syntax is similar to doxygen's config file.
+RTF_EXTENSIONS_FILE    =
+# configuration options related to the man page output
+# If the GENERATE_MAN tag is set to YES (the default) Doxygen will
+# generate man pages
+GENERATE_MAN           = NO
+# The MAN_OUTPUT tag is used to specify where the man pages will be put.
+# put in front of it. If left blank `man' will be used as the default path.
+MAN_OUTPUT             = man
+# The MAN_EXTENSION tag determines the extension that is added to
+# the generated man pages (default is the subroutine's section .3)
+MAN_EXTENSION          = .3
+# If the MAN_LINKS tag is set to YES and Doxygen generates man output,
+# then it will generate one additional man file for each entity
+# documented in the real man page(s). These additional files
+# only source the real man page, but without them the man command
+# would be unable to find the correct page. The default is NO.
+MAN_LINKS              = NO
+# configuration options related to the XML output
+# If the GENERATE_XML tag is set to YES Doxygen will
+# generate an XML file that captures the structure of
+# the code including all documentation.
+GENERATE_XML           = NO
+# The XML_OUTPUT tag is used to specify where the XML pages will be put.
+# put in front of it. If left blank `xml' will be used as the default path.
+XML_OUTPUT             = xml
+# The XML_SCHEMA tag can be used to specify an XML schema,
+# which can be used by a validating XML parser to check the
+# syntax of the XML files.
+XML_SCHEMA             =
+# The XML_DTD tag can be used to specify an XML DTD,
+XML_DTD                =
+# If the XML_PROGRAMLISTING tag is set to YES Doxygen will
+# dump the program listings (including syntax highlighting
+# and cross-referencing information) to the XML output. Note that
+# enabling this will significantly increase the size of the XML output.
+XML_PROGRAMLISTING     = YES
+# configuration options for the AutoGen Definitions output
+# If the GENERATE_AUTOGEN_DEF tag is set to YES Doxygen will
+# generate an AutoGen Definitions (see autogen.sf.net) file
+# that captures the structure of the code including all
+# documentation. Note that this feature is still experimental
+# and incomplete at the moment.
+GENERATE_AUTOGEN_DEF   = NO
+# configuration options related to the Perl module output
+# If the GENERATE_PERLMOD tag is set to YES Doxygen will
+# generate a Perl module file that captures the structure of
+# the code including all documentation. Note that this
+# feature is still experimental and incomplete at the
+# moment.
+GENERATE_PERLMOD       = NO
+# If the PERLMOD_LATEX tag is set to YES Doxygen will generate
+# the necessary Makefile rules, Perl scripts and LaTeX code to be able
+# to generate PDF and DVI output from the Perl module output.
+PERLMOD_LATEX          = NO
+# If the PERLMOD_PRETTY tag is set to YES the Perl module output will be
+# nicely formatted so it can be parsed by a human reader.  This is useful
+# if you want to understand what is going on.  On the other hand, if this
+# tag is set to NO the size of the Perl module output will be much smaller
+# and Perl will parse it just the same.
+PERLMOD_PRETTY         = YES
+# The names of the make variables in the generated doxyrules.make file
+# are prefixed with the string contained in PERLMOD_MAKEVAR_PREFIX.
+# This is useful so different doxyrules.make files included by the same
+# Makefile don't overwrite each other's variables.
+PERLMOD_MAKEVAR_PREFIX =
+# Configuration options related to the preprocessor
+# If the ENABLE_PREPROCESSING tag is set to YES (the default) Doxygen will
+# evaluate all C-preprocessor directives found in the sources and include
+# files.
+ENABLE_PREPROCESSING   = YES
+# If the MACRO_EXPANSION tag is set to YES Doxygen will expand all macro
+# names in the source code. If set to NO (the default) only conditional
+# compilation will be performed. Macro expansion can be done in a controlled
+# way by setting EXPAND_ONLY_PREDEF to YES.
+MACRO_EXPANSION        = NO
+# If the EXPAND_ONLY_PREDEF and MACRO_EXPANSION tags are both set to YES
+# then the macro expansion is limited to the macros specified with the
+# PREDEFINED and EXPAND_AS_PREDEFINED tags.
+EXPAND_ONLY_PREDEF     = NO
+# If the SEARCH_INCLUDES tag is set to YES (the default) the includes files
+# in the INCLUDE_PATH (see below) will be search if a #include is found.
+SEARCH_INCLUDES        = YES
+# The INCLUDE_PATH tag can be used to specify one or more directories that
+# contain include files that are not input files but should be processed by
+# the preprocessor.
+INCLUDE_PATH           = ../include ../../include
+# You can use the INCLUDE_FILE_PATTERNS tag to specify one or more wildcard
+# patterns (like *.h and *.hpp) to filter out the header-files in the
+# directories. If left blank, the patterns specified with FILE_PATTERNS will
+# be used.
+INCLUDE_FILE_PATTERNS  =
+# The PREDEFINED tag can be used to specify one or more macro names that
+# are defined before the preprocessor is started (similar to the -D option of
+# gcc). The argument of the tag is a list of macros of the form: name
+# or name=definition (no spaces). If the definition and the = are
+# omitted =1 is assumed. To prevent a macro definition from being
+# undefined via #undef or recursively expanded use the := operator
+# instead of the = operator.
+PREDEFINED             = HAVE_OGR HAVE_TIFFIO_H HAVE_GEOS
+# If the MACRO_EXPANSION and EXPAND_ONLY_PREDEF tags are set to YES then
+# this tag can be used to specify a list of macro names that should be expanded.
+# The macro definition that is found in the sources will be used.
+# Use the PREDEFINED tag if you want to use a different macro definition.
+EXPAND_AS_DEFINED      =
+# If the SKIP_FUNCTION_MACROS tag is set to YES (the default) then
+# doxygen's preprocessor will remove all function-like macros that are alone
+# on a line, have an all uppercase name, and do not end with a semicolon. Such
+# function macros are typically used for boiler-plate code, and will confuse the
+# parser if not removed.
+SKIP_FUNCTION_MACROS   = YES
+# Configuration::additions related to external references
+# The TAGFILES option can be used to specify one or more tagfiles.
+# Optionally an initial location of the external documentation
+# can be added for each tagfile. The format of a tag file without
+# this location is as follows:
+#   TAGFILES = file1 file2 ...
+# Adding location for the tag files is done as follows:
+#   TAGFILES = file1=loc1 "file2 = loc2" ...
+# where "loc1" and "loc2" can be relative or absolute paths or
+# URLs. If a location is present for each tag, the installdox tool
+# does not have to be run to correct the links.
+# Note that each tag file must have a unique name
+# (where the name does NOT include the path)
+# If a tag file is not located in the directory in which doxygen
+# is run, you must also specify the path to the tagfile here.
+TAGFILES               =
+# When a file name is specified after GENERATE_TAGFILE, doxygen will create
+# a tag file that is based on the input files it reads.
+GENERATE_TAGFILE       =
+# If the ALLEXTERNALS tag is set to YES all external classes will be listed
+# in the class index. If set to NO only the inherited external classes
+# will be listed.
+ALLEXTERNALS           = NO
+# If the EXTERNAL_GROUPS tag is set to YES all external groups will be listed
+# in the modules index. If set to NO, only the current project's groups will
+# be listed.
+EXTERNAL_GROUPS        = YES
+# The PERL_PATH should be the absolute path and name of the perl script
+# interpreter (i.e. the result of `which perl').
+PERL_PATH              = /usr/bin/perl
+# Configuration options related to the dot tool
+# If the CLASS_DIAGRAMS tag is set to YES (the default) Doxygen will
+# generate a inheritance diagram (in HTML, RTF and LaTeX) for classes with base or
+# super classes. Setting the tag to NO turns the diagrams off. Note that this
+# option is superseded by the HAVE_DOT option below. This is only a fallback. It is
+# recommended to install and use dot, since it yields more powerful graphs.
+CLASS_DIAGRAMS         = YES
+# If set to YES, the inheritance and collaboration graphs will hide
+# inheritance and usage relations if the target is undocumented
+# or is not a class.
+HIDE_UNDOC_RELATIONS   = YES
+# If you set the HAVE_DOT tag to YES then doxygen will assume the dot tool is
+# available from the path. This tool is part of Graphviz, a graph visualization
+# toolkit from AT&T and Lucent Bell Labs. The other options in this section
+# have no effect if this option is set to NO (the default)
+HAVE_DOT               = YES
+# If the CLASS_GRAPH and HAVE_DOT tags are set to YES then doxygen
+# will generate a graph for each documented class showing the direct and
+# indirect inheritance relations. Setting this tag to YES will force the
+# the CLASS_DIAGRAMS tag to NO.
+CLASS_GRAPH            = YES
+# If the COLLABORATION_GRAPH and HAVE_DOT tags are set to YES then doxygen
+# indirect implementation dependencies (inheritance, containment, and
+# class references variables) of the class with other documented classes.
+COLLABORATION_GRAPH    = YES
+# If the UML_LOOK tag is set to YES doxygen will generate inheritance and
+# collaboration diagrams in a style similar to the OMG's Unified Modeling
+# Language.
+UML_LOOK               = NO
+# If set to YES, the inheritance and collaboration graphs will show the
+# relations between templates and their instances.
+TEMPLATE_RELATIONS     = NO
+# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDE_GRAPH, and HAVE_DOT
+# tags are set to YES then doxygen will generate a graph for each documented
+# file showing the direct and indirect include dependencies of the file with
+# other documented files.
+INCLUDE_GRAPH          = YES
+# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDED_BY_GRAPH, and
+# HAVE_DOT tags are set to YES then doxygen will generate a graph for each
+# documented header file showing the documented files that directly or
+# indirectly include this file.
+INCLUDED_BY_GRAPH      = YES
+# If the CALL_GRAPH and HAVE_DOT tags are set to YES then doxygen will
+# generate a call dependency graph for every global function or class method.
+# Note that enabling this option will significantly increase the time of a run.
+# So in most cases it will be better to enable call graphs for selected
+# functions only using the \callgraph command.
+CALL_GRAPH             = NO
+# If the GRAPHICAL_HIERARCHY and HAVE_DOT tags are set to YES then doxygen
+# will graphical hierarchy of all classes instead of a textual one.
+GRAPHICAL_HIERARCHY    = YES
+# The DOT_IMAGE_FORMAT tag can be used to set the image format of the images
+# generated by dot. Possible values are png, jpg, or gif
+# If left blank png will be used.
+DOT_IMAGE_FORMAT       = png
+# The tag DOT_PATH can be used to specify the path where the dot tool can be
+# found. If left blank, it is assumed the dot tool can be found on the path.
+DOT_PATH               =
+# The DOTFILE_DIRS tag can be used to specify one or more directories that
+# contain dot files that are included in the documentation (see the
+# \dotfile command).
+DOTFILE_DIRS           =
+# The MAX_DOT_GRAPH_WIDTH tag can be used to set the maximum allowed width
+# (in pixels) of the graphs generated by dot. If a graph becomes larger than
+# this value, doxygen will try to truncate the graph, so that it fits within
+# the specified constraint. Beware that most browsers cannot cope with very
+# large images.
+MAX_DOT_GRAPH_WIDTH    = 2000
+# The MAX_DOT_GRAPH_HEIGHT tag can be used to set the maximum allows height
+# large images.
+MAX_DOT_GRAPH_HEIGHT   = 2000
+# The MAX_DOT_GRAPH_DEPTH tag can be used to set the maximum depth of the
+# graphs generated by dot. A depth value of 3 means that only nodes reachable
+# from the root by following a path via at most 3 edges will be shown. Nodes that
+# lay further from the root node will be omitted. Note that setting this option to
+# 1 or 2 may greatly reduce the computation time needed for large code bases. Also
+# note that a graph may be further truncated if the graph's image dimensions are
+# not sufficient to fit the graph (see MAX_DOT_GRAPH_WIDTH and MAX_DOT_GRAPH_HEIGHT).
+# If 0 is used for the depth value (the default), the graph is not depth-constrained.
+MAX_DOT_GRAPH_DEPTH    = 0
+# If the GENERATE_LEGEND tag is set to YES (the default) Doxygen will
+# generate a legend page explaining the meaning of the various boxes and
+# arrows in the dot generated graphs.
+GENERATE_LEGEND        = YES
+# If the DOT_CLEANUP tag is set to YES (the default) Doxygen will
+# remove the intermediate dot files that are used to generate
+# the various graphs.
+DOT_CLEANUP            = YES
+# Configuration::additions related to the search engine
+# The SEARCHENGINE tag specifies whether or not a search engine should be
+# used. If set to NO the values of all tags below this one will be ignored.
+SEARCHENGINE           = NO
