[GRASS-SVN] r39613 - in grass/trunk: lib/vector/Vlib
vector/v.db.select vector/v.extract
svn_grass at osgeo.org
Thu Oct 22 16:14:47 EDT 2009
Author: martinl
Date: 2009-10-22 16:14:46 -0400 (Thu, 22 Oct 2009)
New Revision: 39613
grass/trunk/lib/vector/Vlib/open.c
grass/trunk/lib/vector/Vlib/read.c
grass/trunk/vector/v.db.select/main.c
grass/trunk/vector/v.extract/main.c
v.extract: initial step for direct OGR read access
vlib: fix read_line
message cosmetics
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c 2009-10-22 20:13:14 UTC (rev 39612)
+++ grass/trunk/lib/vector/Vlib/open.c 2009-10-22 20:14:46 UTC (rev 39613)
@@ -379,6 +379,9 @@
level = 2;
G_set_verbose(verbose);
+ if (level < level_request)
+ G_fatal_error(_("Unable to open vector map <%s> on level %d"),
+ Map->fInfo.ogr.layer_name, level_request);
else {
Modified: grass/trunk/lib/vector/Vlib/read.c
--- grass/trunk/lib/vector/Vlib/read.c 2009-10-22 20:13:14 UTC (rev 39612)
+++ grass/trunk/lib/vector/Vlib/read.c 2009-10-22 20:14:46 UTC (rev 39613)
@@ -52,8 +52,10 @@
V2_read_line_nat
#ifdef HAVE_OGR
, V2_read_line_ogr
+ , V2_read_line_ogr
#else
, format
+ , format
#endif
Modified: grass/trunk/vector/v.db.select/main.c
--- grass/trunk/vector/v.db.select/main.c 2009-10-22 20:13:14 UTC (rev 39612)
+++ grass/trunk/vector/v.db.select/main.c 2009-10-22 20:14:46 UTC (rev 39613)
@@ -228,6 +228,7 @@
if (r_flag->answer) {
/* get minimal region extent */
+ /* TODO: support layer name */
Vect_cidx_find_all(&Map, atoi(field_opt->answer), -1, cat, list_lines);
for (i = 0; i < list_lines->n_values; i++) {
line = list_lines->value[i];
Modified: grass/trunk/vector/v.extract/main.c
--- grass/trunk/vector/v.extract/main.c 2009-10-22 20:13:14 UTC (rev 39612)
+++ grass/trunk/vector/v.extract/main.c 2009-10-22 20:14:46 UTC (rev 39613)
@@ -11,7 +11,7 @@
* boundaries for 1 or several areas of a list of
* user provided categories.
- * COPYRIGHT: (C) 2002-2007 by the GRASS Development Team
+ * COPYRIGHT: (C) 2002-2009 by the GRASS Development Team
* This program is free software under the
* GNU General Public License (>=v2).
@@ -66,7 +66,7 @@
int main(int argc, char **argv)
- int i, new_cat, type, ncats, *cats, field, c;
+ int i, new_cat, type, ncats, *cats, c;
int **ocats, *nocats, nfields, *fields;
int dissolve = 0, x, y, type_only;
char buffr[1024], text[80];
@@ -79,7 +79,6 @@
struct field_info *Fi;
FILE *in;
dbDriver *driver;
- dbHandle handle;
struct line_cats *Cats;
struct Cat_index *ci;
int ucat_count, *ucat_array = NULL, prnd, seed, nrandom, nfeatures;
@@ -195,18 +194,14 @@
if (d_flag->answer)
dissolve = 1;
- field = atoi(fieldopt->answer);
- if (field == 0)
- G_fatal_error(_("Layer 0 not supported"));
if (!newopt->answer)
new_cat = 0;
else
new_cat = atoi(newopt->answer);
/* Do initial read of input file */
- Vect_set_open_level(2);
- Vect_open_old(&In, input, "");
+ Vect_set_open_level(2); /* topology required */
+ Vect_open_old2(&In, input, "", fieldopt->answer);
type = Vect_option_to_types(typopt);
if (type & GV_AREA) {
@@ -266,29 +261,21 @@
else if (whereopt->answer != NULL) {
- if (field < 1) {
- G_fatal_error(_("'layer' must be > 0 for 'where'."));
- Fi = Vect_get_field(&In, field);
+ Fi = Vect_get_field2(&In, fieldopt->answer);
if (!Fi) {
- G_fatal_error(_("Database connection not defined for layer %d"),
- field);
+ G_fatal_error(_("Database connection not defined for layer <%s>"),
+ fieldopt->answer);
G_debug(1, "Loading categories from table <%s>", Fi->table);
- driver = db_start_driver(Fi->driver);
+ driver = db_start_driver_open_database(Fi->driver, Fi->database);
if (driver == NULL)
- G_fatal_error(_("Unable to start driver <%s>"), Fi->driver);
- db_init_handle(&handle);
- db_set_handle(&handle, Fi->database, NULL);
- if (db_open_database(driver, &handle) != DB_OK)
G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
Fi->database, Fi->driver);
- ncats =db_select_int(driver, Fi->table, Fi->key, whereopt->answer,
- &cats);
+ ncats = db_select_int(driver, Fi->table, Fi->key, whereopt->answer,
+ &cats);
if (ncats == -1)
G_fatal_error(_("Unable select records from table <%s>"), Fi->table);
G_message(_("%d categories loaded from table <%s>"), ncats,
@@ -305,7 +292,7 @@
else if (nrandopt->answer != NULL) { /* Generate random category list */
/* We operate on layer's CAT's and thus valid layer is required */
- if (Vect_cidx_get_field_index(&In, field) < 0)
+ if (Vect_cidx_get_field_index(&In, atoi(fieldopt->answer)) < 0)
G_fatal_error(_("This map has no categories attached. "
"Use v.category to attach categories to this vector map."));
@@ -314,7 +301,7 @@
if (nrandom < 1)
G_fatal_error(_("Please specify random number larger than 0"));
- nfeatures = Vect_cidx_get_type_count(&In, field, type);
+ nfeatures = Vect_cidx_get_type_count(&In, atoi(fieldopt->answer), type);
if (nrandom >= nfeatures)
G_fatal_error(_("Random category count must be smaller than feature count. "
"There are only %d features of type(s): %s"),
@@ -322,7 +309,7 @@
/* Let's create an array of uniq CAT values
According to Vlib/build.c, cidx should be allready sorted by dig_cidx_sort() */
- ci = &(In.plus.cidx[Vect_cidx_get_field_index(&In, field)]);
+ ci = &(In.plus.cidx[Vect_cidx_get_field_index(&In, atoi(fieldopt->answer))]);
ucat_count = 0;
for (c = 0; c < ci->n_cats; c++) {
/* Bitwise AND compares ci feature type with user's requested types */
@@ -378,7 +365,7 @@
G_message(_("Extracting features..."));
xtract_line(cat_count, cat_array, &In, &Out, new_cat, type, dissolve,
- field, type_only, r_flag->answer ? 1 : 0);
+ fieldopt->answer, type_only, r_flag->answer ? 1 : 0);
Vect_build(&Out);
@@ -451,7 +438,7 @@
continue;
if (nocats[i] == 0)
continue;
- if (fields[i] == field && new_cat != -1)
+ if (fields[i] == atoi(fieldopt->answer) && new_cat != -1)
continue;
G_verbose_message(_("Layer %d"), fields[i]);
