[GRASS-SVN] r39616 - grass/trunk/db/drivers/ogr
svn_grass at osgeo.org
Fri Oct 23 06:17:53 EDT 2009
Author: martinl
Date: 2009-10-23 06:17:52 -0400 (Fri, 23 Oct 2009)
New Revision: 39616
grass/trunk/db/drivers/ogr/cursor.c
grass/trunk/db/drivers/ogr/db.c
grass/trunk/db/drivers/ogr/describe.c
grass/trunk/db/drivers/ogr/driver.c
grass/trunk/db/drivers/ogr/error.c
grass/trunk/db/drivers/ogr/fetch.c
grass/trunk/db/drivers/ogr/globals.h
grass/trunk/db/drivers/ogr/listtab.c
grass/trunk/db/drivers/ogr/main.c
grass/trunk/db/drivers/ogr/proto.h
grass/trunk/db/drivers/ogr/select.c
db ogr driver: initial doxygen strings added
Modified: grass/trunk/db/drivers/ogr/cursor.c
--- grass/trunk/db/drivers/ogr/cursor.c 2009-10-22 21:12:05 UTC (rev 39615)
+++ grass/trunk/db/drivers/ogr/cursor.c 2009-10-23 10:17:52 UTC (rev 39616)
@@ -4,10 +4,11 @@
* MODULE: OGR driver
* AUTHOR(S): Radim Blazek
+* Some updates by Martin Landa <landa.martin gmail.com>
* PURPOSE: DB driver for OGR sources
-* COPYRIGHT: (C) 2004 by the GRASS Development Team
+* COPYRIGHT: (C) 2004-2009 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -15,34 +16,50 @@
#include <stdio.h>
#include <grass/gis.h>
#include <grass/dbmi.h>
+#include <grass/glocale.h>
#include "ogr_api.h"
#include "globals.h"
#include "proto.h"
+ \brief Close cursor
+ \param dbc pointer to dbCursor to be closed
+ \return DB_OK on success
+ \return DB_FAILED on failure
int db__driver_close_cursor(dbCursor * dbc)
cursor *c;
G_debug(3, "db_driver_close_cursor()");
init_error();
/* get my cursor via the dbc token */
c = (cursor *) db_find_token(db_get_cursor_token(dbc));
if (c == NULL)
return DB_FAILED;
/* free_cursor(cursor) */
free_cursor(c);
G_debug(3, "Cursor closed");
return DB_OK;
+ \brief Allocate cursor
+ \return pointer to cursor structure
+ \return NULL on error
cursor *alloc_cursor()
cursor *c;
@@ -50,14 +67,14 @@
/* allocate the cursor */
c = (cursor *) db_malloc(sizeof(cursor));
if (c == NULL) {
- append_error("Cannot allocate cursor.");
+ append_error(_("Unable to allocate cursor"));
return NULL;
/* tokenize it */
c->token = db_new_token(c);
if (c->token < 0) {
- append_error("Cannot ad new token.");
+ append_error(_("Unable to add new token"));
return NULL;
@@ -66,6 +83,11 @@
return c;
+ \brief Free cursor structure (destroy OGR feature and release OGR layer)
+ \param c pointer to cursor
void free_cursor(cursor * c)
if (c->hFeature)
Modified: grass/trunk/db/drivers/ogr/db.c
--- grass/trunk/db/drivers/ogr/db.c 2009-10-22 21:12:05 UTC (rev 39615)
+++ grass/trunk/db/drivers/ogr/db.c 2009-10-23 10:17:52 UTC (rev 39616)
@@ -4,24 +4,37 @@
* for details.
#include <stdlib.h>
#include <string.h>
#include "proto.h"
+ \brief Open database (OGR datasource)
+ \param handle pointer to dbHandle (db name and schema)
int db__driver_open_database(dbHandle * handle)
const char *name;
@@ -42,7 +55,7 @@
hDs = OGROpen(name, FALSE, NULL);
if (hDs == NULL) {
- append_error("Cannot open OGR data source");
+ append_error(_("Unable to open OGR data source"));
report_error();
return DB_FAILED;
@@ -52,6 +65,12 @@
return DB_OK;
+ \brief Close open database
int db__driver_close_database()
G_debug(3, "db_driver_close_database()");
Modified: grass/trunk/db/drivers/ogr/describe.c
--- grass/trunk/db/drivers/ogr/describe.c 2009-10-22 21:12:05 UTC (rev 39615)
+++ grass/trunk/db/drivers/ogr/describe.c 2009-10-23 10:17:52 UTC (rev 39616)
@@ -4,10 +4,11 @@
@@ -24,15 +25,25 @@
#include "proto.h"
+ \brief Describe table using driver
+ \param table_name table name (as dbString)
+ \param table[out] pointer to dbTable
int db__driver_describe_table(dbString * table_name, dbTable ** table)
int i, nlayers;
OGRLayerH hLayer = NULL;
OGRFeatureDefnH hFeatureDefn;
- /* Find data source */
+ /* get number of OGR layers in the datasource */
nlayers = OGR_DS_GetLayerCount(hDs);
+ /* find OGR layer */
for (i = 0; i < nlayers; i++) {
hLayer = OGR_DS_GetLayer(hDs, i);
hFeatureDefn = OGR_L_GetLayerDefn(hLayer);
@@ -45,7 +56,7 @@
if (hLayer == NULL) {
- append_error("Table '%s' does not exist\n",
+ append_error(_("OGR layer <%s> does not exist\n"),
db_get_string(table_name));
report_error();
return DB_FAILED;
@@ -53,7 +64,7 @@
G_debug(3, "->>");
if (describe_table(hLayer, table, NULL) == DB_FAILED) {
- append_error("Cannot describe table\n");
+ append_error(_("Unable to describe table\n"));
report_error();
return DB_FAILED;
@@ -61,8 +72,15 @@
return DB_OK;
-/* describe table, if c is not NULL cur->cols and cur->ncols is also set
- * cursor may be null
+ If c is not NULL cur->cols and cur->ncols is also set
+ cursor may be null
+ \param hLayer OGR layer
+ \param[put] table pointer to dbTable
int describe_table(OGRLayerH hLayer, dbTable **table, cursor *c)
Modified: grass/trunk/db/drivers/ogr/driver.c
--- grass/trunk/db/drivers/ogr/driver.c 2009-10-22 21:12:05 UTC (rev 39615)
+++ grass/trunk/db/drivers/ogr/driver.c 2009-10-23 10:17:52 UTC (rev 39616)
@@ -4,27 +4,43 @@
* for details.
#include "proto.h"
+ \brief Initialize driver
+ \param argc number of arguments
+ \param argv array of arguments
int db__driver_init(int argc, char *argv[])
init_error();
return DB_OK;
+ \brief Finish driver
+ \return DB_OK
int db__driver_finish()
return DB_OK;
Modified: grass/trunk/db/drivers/ogr/error.c
--- grass/trunk/db/drivers/ogr/error.c 2009-10-22 21:12:05 UTC (rev 39615)
+++ grass/trunk/db/drivers/ogr/error.c 2009-10-23 10:17:52 UTC (rev 39616)
@@ -4,26 +4,33 @@
* for details.
#include <stdlib.h>
#include <stdio.h>
#include <stdarg.h>
+#include <grass/gis.h>
-#include <grass/gis.h>
#include "proto.h"
-/* init error message */
+ \brief Init error message
void init_error(void)
if (!errMsg) {
@@ -31,10 +38,14 @@
db_init_string(errMsg);
- db_set_string(errMsg, "DBMI-OGR driver error:\n");
+ db_set_string(errMsg, _("DBMI-OGR driver error:\n"));
-/* append error message */
+ \brief Append error message
+ \param fmt formatted string
void append_error(const char *fmt, ...)
FILE *fp = NULL;
@@ -56,6 +67,9 @@
va_end(ap);
+ \brief Report errors
void report_error(void)
db_append_string(errMsg, "\n");
Modified: grass/trunk/db/drivers/ogr/fetch.c
--- grass/trunk/db/drivers/ogr/fetch.c 2009-10-22 21:12:05 UTC (rev 39615)
+++ grass/trunk/db/drivers/ogr/fetch.c 2009-10-23 10:17:52 UTC (rev 39616)
@@ -4,10 +4,11 @@
@@ -16,20 +17,32 @@
#include <stdlib.h>
#include <string.h>
#include "proto.h"
-#include <grass/glocale.h>
+ \brief Fetch record
+ \param cn pointer to dbCursor
+ \param position position indicator (DB_NEXT, DB_FIRST, DB_LAST, etc)
+ \param[out] more 0 for no record fetched otherwise 1
+ \return DB_FAILED on error
int db__driver_fetch(dbCursor * cn, int position, int *more)
cursor *c;
dbToken token;
dbTable *table;
int i, col;
G_debug(3, "db_driver_fetch()");
/* get cursor token */
@@ -37,7 +50,7 @@
/* get the cursor by its token */
if (!(c = (cursor *) db_find_token(token))) {
- append_error("Cursor not found");
+ append_error(_("Cursor not found"));
report_error();
return DB_FAILED;
@@ -53,7 +66,7 @@
case DB_CURRENT:
break;
case DB_PREVIOUS:
- append_error("DB_PREVIOUS not supported");
+ append_error(_("DB_PREVIOUS not supported"));
report_error();
return DB_FAILED;
break;
@@ -64,7 +77,7 @@
c->hFeature = OGR_L_GetNextFeature(c->hLayer);
break;
case DB_LAST:
- append_error("DB_LAST not supported");
+ append_error(_("DB_LAST not supported"));
report_error();
return DB_FAILED;
break;
@@ -79,13 +92,12 @@
/* get the data out of the descriptor into the table */
table = db_get_cursor_table(cn);
col = -1;
for (i = 0; i < c->ncols; i++) {
int ogrType, sqlType;
dbColumn *column;
dbValue *value;
if (!(c->cols[i])) {
continue;
} /* unknown type */
@@ -134,6 +146,14 @@
return DB_OK;
+ \brief Get number of rows (i.e. features) in open cursor
+ \return number of rows
int db__driver_get_num_rows(dbCursor * cn)
cursor *c;
@@ -146,7 +166,7 @@
report_error();
return DB_FAILED;
Modified: grass/trunk/db/drivers/ogr/globals.h
--- grass/trunk/db/drivers/ogr/globals.h 2009-10-22 21:12:05 UTC (rev 39615)
+++ grass/trunk/db/drivers/ogr/globals.h 2009-10-23 10:17:52 UTC (rev 39616)
@@ -4,10 +4,11 @@
@@ -19,11 +20,11 @@
typedef struct
dbToken token;
- OGRLayerH hLayer; /* results */
+ OGRLayerH hLayer; /* current OGR layer */
OGRFeatureH hFeature; /* current feature */
int type; /* type of cursor: SELECT, UPDATE, INSERT */
int *cols; /* 1 type is known, 0 type is unknown */
- int ncols; /* num columns */
+ int ncols; /* num columns (without fid column) */
} cursor;
extern OGRDataSourceH hDs;
Modified: grass/trunk/db/drivers/ogr/listtab.c
--- grass/trunk/db/drivers/ogr/listtab.c 2009-10-22 21:12:05 UTC (rev 39615)
+++ grass/trunk/db/drivers/ogr/listtab.c 2009-10-23 10:17:52 UTC (rev 39616)
@@ -4,22 +4,36 @@
* for details.
#include "proto.h"
+ \brief List tables
+ \param[out] tlist list of tables
+ \param[out] tcount number of tables
+ \param system list also system tables
int db__driver_list_tables(dbString ** tlist, int *tcount, int system)
int i, nlayers;
@@ -37,7 +51,7 @@
list = db_alloc_string_array(nlayers);
if (list == NULL) {
- append_error("Cannot db_alloc_string_array()");
+ append_error(_("Unable to db_alloc_string_array()"));
report_error();
return DB_FAILED;
Modified: grass/trunk/db/drivers/ogr/main.c
--- grass/trunk/db/drivers/ogr/main.c 2009-10-22 21:12:05 UTC (rev 39615)
+++ grass/trunk/db/drivers/ogr/main.c 2009-10-23 10:17:52 UTC (rev 39616)
@@ -4,10 +4,11 @@
@@ -16,7 +17,9 @@
#include <stdlib.h>
#include "dbdriver.h"
Modified: grass/trunk/db/drivers/ogr/proto.h
--- grass/trunk/db/drivers/ogr/proto.h 2009-10-22 21:12:05 UTC (rev 39615)
+++ grass/trunk/db/drivers/ogr/proto.h 2009-10-23 10:17:52 UTC (rev 39616)
@@ -4,20 +4,17 @@
* for details.
-/* error.c */
-void init_error(void);
-void append_error(const char *fmt, ...);
-void report_error(void);
/* cursor.c */
cursor *alloc_cursor();
@@ -25,3 +22,8 @@
/* describe.c */
int describe_table(OGRLayerH, dbTable **, cursor *);
+/* error.c */
+void init_error(void);
+void append_error(const char *, ...);
+void report_error(void);
Modified: grass/trunk/db/drivers/ogr/select.c
--- grass/trunk/db/drivers/ogr/select.c 2009-10-22 21:12:05 UTC (rev 39615)
+++ grass/trunk/db/drivers/ogr/select.c 2009-10-23 10:17:52 UTC (rev 39616)
@@ -4,22 +4,36 @@
* for details.
#include "proto.h"
+ \brief Open select cursor
+ \param sel select statement (given as dbString)
+ \param[out] dbc pointer to dbCursor
+ \param mode open mode
int db__driver_open_select_cursor(dbString * sel, dbCursor * dbc, int mode)
cursor *c;
@@ -38,7 +52,7 @@
c->hLayer = OGR_DS_ExecuteSQL(hDs, db_get_string(sel), NULL, NULL);
if (c->hLayer == NULL) {
- append_error("Cannot select: \n");
+ append_error(_("Unable to select: \n"));
append_error(db_get_string(sel));
append_error("\n");
report_error();
@@ -46,7 +60,7 @@
if (describe_table(c->hLayer, &table, c) == DB_FAILED) {
report_error();
OGR_DS_ReleaseResultSet(hDs, c->hLayer);
return DB_FAILED;
