[GRASS-SVN] r39620 - in grass/trunk: include lib/vector/Vlib
svn_grass at osgeo.org
Fri Oct 23 10:48:50 EDT 2009
Author: martinl
Date: 2009-10-23 10:48:49 -0400 (Fri, 23 Oct 2009)
New Revision: 39620
grass/trunk/include/vector.h
grass/trunk/lib/vector/Vlib/field.c
grass/trunk/lib/vector/Vlib/read.c
vlib: Vect_get_field_number() added
Modified: grass/trunk/include/vector.h
--- grass/trunk/include/vector.h 2009-10-23 14:40:32 UTC (rev 39619)
+++ grass/trunk/include/vector.h 2009-10-23 14:48:49 UTC (rev 39620)
@@ -112,6 +112,7 @@
struct field_info *Vect_get_field(const struct Map_info *, int);
struct field_info *Vect_get_field_by_name(const struct Map_info *, const char *);
struct field_info *Vect_get_field2(const struct Map_info *, const char *);
+int Vect_get_field_number(const struct Map_info *, const char *);
void Vect_set_db_updated(struct Map_info *);
const char *Vect_get_column_names(const struct Map_info *, int);
const char *Vect_get_column_types(const struct Map_info *, int);
Modified: grass/trunk/lib/vector/Vlib/field.c
--- grass/trunk/lib/vector/Vlib/field.c 2009-10-23 14:40:32 UTC (rev 39619)
+++ grass/trunk/lib/vector/Vlib/field.c 2009-10-23 14:48:49 UTC (rev 39620)
@@ -479,6 +479,29 @@
+ \brief Get field number of given field
+ \param Map pointer to Map_info structure
+ \param field layer name
+ \return layer number
+ \return 0 if layer not found
+int Vect_get_field_number(const struct Map_info *Map, const char *field)
+ struct field_info *fi;
+ G_debug(1, "Vect_get_field_number(): field = %s", field);
+ fi = Vect_get_field2(Map, field);
+ if (fi)
+ return fi->number;
+ return 0;
\brief Read dblinks to existing structure.
Variables are not substituted by values.
Modified: grass/trunk/lib/vector/Vlib/read.c
--- grass/trunk/lib/vector/Vlib/read.c 2009-10-23 14:40:32 UTC (rev 39619)
+++ grass/trunk/lib/vector/Vlib/read.c 2009-10-23 14:48:49 UTC (rev 39620)
@@ -99,7 +99,7 @@
struct line_pnts *line_p, struct line_cats *line_c, int line)
- G_debug(3, "Vect_read_line()");
+ G_debug(3, "Vect_read_line() line=%d", line);
if (!VECT_OPEN(Map))
G_fatal_error("Vect_read_line(): %s", _("vector map is not opened"));
