[GRASS-SVN] r39622 - in grass/trunk: . general/g.version
include/Make lib/init
svn_grass at osgeo.org
Sun Oct 25 11:27:53 EDT 2009
Author: martinl
Date: 2009-10-25 11:27:52 -0400 (Sun, 25 Oct 2009)
New Revision: 39622
grass/trunk/configure
grass/trunk/configure.in
grass/trunk/general/g.version/Makefile
grass/trunk/general/g.version/main.c
grass/trunk/include/Make/Platform.make.in
grass/trunk/lib/init/Makefile
report svn revision (using svnversion) - works only for local
repository copies
Modified: grass/trunk/configure
--- grass/trunk/configure 2009-10-23 14:51:43 UTC (rev 39621)
+++ grass/trunk/configure 2009-10-25 15:27:52 UTC (rev 39622)
@@ -1285,8 +1285,43 @@
LIB_VER=`echo ${GRASS_VERSION_NUMBER} | sed 's/^\([0-9.]*\).*$/\1/'`
+GRASS_VERSION_SVN=
+# Extract the first word of "svnversion", so it can be a program name with args.
+set dummy svnversion; ac_word=$2
+echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
+echo "configure:1293: checking for $ac_word" >&5
+case "$SVN_VERSION" in
+ ac_cv_path_SVN_VERSION="$SVN_VERSION" # Let the user override the test with a path.
+ ac_cv_path_SVN_VERSION="$SVN_VERSION" # Let the user override the test with a dos path.
+ IFS="${IFS= }"; ac_save_ifs="$IFS"; IFS=":"
+ ac_dummy="$PATH"
+ for ac_dir in $ac_dummy; do
+ test -z "$ac_dir" && ac_dir=.
+ if test -f $ac_dir/$ac_word; then
+ ac_cv_path_SVN_VERSION="$ac_dir/$ac_word"
+ break
+ fi
+ done
+ IFS="$ac_save_ifs"
+ test -z "$ac_cv_path_SVN_VERSION" && ac_cv_path_SVN_VERSION="no"
+esac
+SVN_VERSION="$ac_cv_path_SVN_VERSION"
+if test -n "$SVN_VERSION"; then
+ echo "$ac_t""$SVN_VERSION" 1>&6
+else
+ echo "$ac_t""no" 1>&6
+fi
+if test "$SVN_VERSION" != "no" ; then
+ GRASS_VERSION_SVN=`$SVN_VERSION`
+fi
@@ -1294,6 +1329,10 @@
# Check for MacOSX App
# Check whether --enable-macosx-app or --disable-macosx-app was given.
@@ -1306,7 +1345,7 @@
echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1310: checking for MacOSX App" >&5
+echo "configure:1349: checking for MacOSX App" >&5
case "$enable_macosx_app" in
yes) MACOSX_APP=1 ;;
no) MACOSX_APP= ;;
@@ -1318,7 +1357,7 @@
# Check for MacOSX archs
echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1322: checking for MacOSX architectures" >&5
+echo "configure:1361: checking for MacOSX architectures" >&5
MACOSX_ARCHS=
@@ -1347,7 +1386,7 @@
# Check for MacOSX SDK
echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1351: checking for MacOSX SDK" >&5
+echo "configure:1390: checking for MacOSX SDK" >&5
MACOSX_SDK=
@@ -1357,7 +1396,7 @@
ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1361: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1400: checking for $with_macosx_sdk/SDKSettings.plist" >&5
if test "$cross_compiling" = yes; then
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1401,7 +1440,7 @@
echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1405: checking how to build libraries" >&5
+echo "configure:1444: checking how to build libraries" >&5
# Check whether --enable-shared or --disable-shared was given.
if test "${enable_shared+set}" = set; then
enableval="$enable_shared"
@@ -1444,7 +1483,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:1448: checking for $ac_word" >&5
+echo "configure:1487: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1469,7 +1508,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1473: checking how to run the C preprocessor" >&5
+echo "configure:1512: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -1482,13 +1521,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
cat > conftest.$ac_ext <<EOF
-#line 1486 "configure"
+#line 1525 "configure"
#include "confdefs.h"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1492: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1531: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -1499,13 +1538,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 1503 "configure"
+#line 1542 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1509: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1548: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1516,13 +1555,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 1520 "configure"
+#line 1559 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1526: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1565: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1550,7 +1589,7 @@
# Step 0.a: Enable 64 bit support?
echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1554: checking if 64bit support is requested" >&5
+echo "configure:1593: checking if 64bit support is requested" >&5
# Check whether --enable-64bit or --disable-64bit was given.
if test "${enable_64bit+set}" = set; then
enableval="$enable_64bit"
@@ -1570,7 +1609,7 @@
# Step 0.b: Enable Solaris 64 bit VIS support?
echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1574: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1613: checking if 64bit Sparc VIS support is requested" >&5
# Check whether --enable-64bit-vis or --disable-64bit-vis was given.
if test "${enable_64bit_vis+set}" = set; then
enableval="$enable_64bit_vis"
@@ -1594,7 +1633,7 @@
# there are a few systems, like Next, where this doesn't work.
echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1598: checking system version (for dynamic loading)" >&5
+echo "configure:1637: checking system version (for dynamic loading)" >&5
if test -f /usr/lib/NextStep/software_version; then
system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
else
@@ -1620,13 +1659,13 @@
# Linux can use either -ldl or -ldld for dynamic loading.
echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1624: checking for dlopen in -ldl" >&5
+echo "configure:1663: checking for dlopen in -ldl" >&5
ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ldl $LIBS"
-#line 1630 "configure"
+#line 1669 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -1637,7 +1676,7 @@
dlopen()
; return 0; }
EOF
-if { (eval echo configure:1641: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1680: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -1684,7 +1723,7 @@
# Extract the first word of "ar", so it can be a program name with args.
set dummy ar; ac_word=$2
-echo "configure:1688: checking for $ac_word" >&5
+echo "configure:1727: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1813,13 +1852,13 @@
# known GMT value.
echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1817: checking for gettimeofday in -lbsd" >&5
+echo "configure:1856: checking for gettimeofday in -lbsd" >&5
ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
LIBS="-lbsd $LIBS"
-#line 1823 "configure"
+#line 1862 "configure"
@@ -1830,7 +1869,7 @@
gettimeofday()
; return 0; }
EOF
-if { (eval echo configure:1834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1871,13 +1910,13 @@
# is always linked to, for compatibility.
echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1875: checking for inet_ntoa in -lbind" >&5
+echo "configure:1914: checking for inet_ntoa in -lbind" >&5
ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-lbind $LIBS"
-#line 1881 "configure"
+#line 1920 "configure"
@@ -1888,7 +1927,7 @@
inet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:1892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1949,13 +1988,13 @@
SHLIB_SUFFIX=".sl"
echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1953: checking for shl_load in -ldld" >&5
+echo "configure:1992: checking for shl_load in -ldld" >&5
ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
LIBS="-ldld $LIBS"
-#line 1959 "configure"
+#line 1998 "configure"
@@ -1966,7 +2005,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:1970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -2031,13 +2070,13 @@
HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
SHLIB_SUFFIX=".sl"
-echo "configure:2035: checking for shl_load in -ldld" >&5
+echo "configure:2074: checking for shl_load in -ldld" >&5
LIBS="-ldld $LIBS"
-#line 2041 "configure"
+#line 2080 "configure"
@@ -2048,7 +2087,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:2052: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2091: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -2170,15 +2209,15 @@
else
ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2174: checking for dld.h" >&5
+echo "configure:2213: checking for dld.h" >&5
-#line 2177 "configure"
+#line 2216 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2182: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2221: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2238,15 +2277,15 @@
else
-echo "configure:2242: checking for dld.h" >&5
+echo "configure:2281: checking for dld.h" >&5
-#line 2245 "configure"
+#line 2284 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2250: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2289: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2343,9 +2382,9 @@
CC_SEARCH_FLAGS=""
LD_SEARCH_FLAGS=""
echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2347: checking for ELF" >&5
+echo "configure:2386: checking for ELF" >&5
-#line 2349 "configure"
+#line 2388 "configure"
#ifdef __ELF__
@@ -2375,15 +2414,15 @@
# Not available on all versions: check for include file.
ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2379: checking for dlfcn.h" >&5
+echo "configure:2418: checking for dlfcn.h" >&5
-#line 2382 "configure"
+#line 2421 "configure"
#include <dlfcn.h>
EOF
-{ (eval echo configure:2387: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2426: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2407,9 +2446,9 @@
CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2411: checking for ELF" >&5
+echo "configure:2450: checking for ELF" >&5
-#line 2413 "configure"
+#line 2452 "configure"
#ifdef __ELF__
@@ -2733,17 +2772,17 @@
# that don't grok the -Bexport option. Test that it does.
hold_ldflags=$LDFLAGS
echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2737: checking for ld accepts -Bexport flag" >&5
+echo "configure:2776: checking for ld accepts -Bexport flag" >&5
LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2740 "configure"
+#line 2779 "configure"
int main() {
int i;
; return 0; }
EOF
-if { (eval echo configure:2747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
found=yes
else
@@ -3539,7 +3578,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3543: checking for additional include dirs" >&5
+echo "configure:3582: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3562,7 +3601,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3566: checking for additional library dirs" >&5
+echo "configure:3605: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3596,7 +3635,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3600: checking for a BSD compatible install" >&5
+echo "configure:3639: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -3649,7 +3688,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
-echo "configure:3653: checking for $ac_word" >&5
+echo "configure:3692: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3680,13 +3719,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3684: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3723: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
LIBS="-l$ac_lib $LIBS"
-#line 3690 "configure"
+#line 3729 "configure"
@@ -3697,7 +3736,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:3701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3740: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3722,7 +3761,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:3726: checking for $ac_word" >&5
+echo "configure:3765: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -3762,7 +3801,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:3766: checking for $ac_word" >&5
+echo "configure:3805: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3793,7 +3832,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:3797: checking for $ac_word" >&5
+echo "configure:3836: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -3831,7 +3870,7 @@
-echo "configure:3835: checking for $ac_word" >&5
+echo "configure:3874: checking for $ac_word" >&5
@@ -3860,7 +3899,7 @@
-echo "configure:3864: checking for $ac_word" >&5
+echo "configure:3903: checking for $ac_word" >&5
@@ -3891,7 +3930,7 @@
-echo "configure:3895: checking for $ac_word" >&5
+echo "configure:3934: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3920,7 +3959,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:3924: checking for $ac_word" >&5
+echo "configure:3963: checking for $ac_word" >&5
case "$PERL" in
@@ -3951,10 +3990,10 @@
fi
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3955: checking for ANSI C header files" >&5
+echo "configure:3994: checking for ANSI C header files" >&5
-#line 3958 "configure"
+#line 3997 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -3962,7 +4001,7 @@
#include <float.h>
EOF
-{ (eval echo configure:3966: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4005: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3979,7 +4018,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 3983 "configure"
+#line 4022 "configure"
#include <string.h>
EOF
@@ -3997,7 +4036,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 4001 "configure"
+#line 4040 "configure"
#include <stdlib.h>
EOF
@@ -4018,7 +4057,7 @@
else
-#line 4022 "configure"
+#line 4061 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -4029,7 +4068,7 @@
exit (0); }
EOF
-if { (eval echo configure:4033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -4056,15 +4095,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:4060: checking for $ac_hdr" >&5
+echo "configure:4099: checking for $ac_hdr" >&5
-#line 4063 "configure"
+#line 4102 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4068: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4107: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4093,15 +4132,15 @@
do
-echo "configure:4097: checking for $ac_hdr" >&5
+echo "configure:4136: checking for $ac_hdr" >&5
-#line 4100 "configure"
+#line 4139 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4105: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4144: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4130,15 +4169,15 @@
do
-echo "configure:4134: checking for $ac_hdr" >&5
+echo "configure:4173: checking for $ac_hdr" >&5
-#line 4137 "configure"
+#line 4176 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4142: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4181: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4167,15 +4206,15 @@
do
-echo "configure:4171: checking for $ac_hdr" >&5
+echo "configure:4210: checking for $ac_hdr" >&5
-#line 4174 "configure"
+#line 4213 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4179: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4218: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4204,15 +4243,15 @@
do
-echo "configure:4208: checking for $ac_hdr" >&5
+echo "configure:4247: checking for $ac_hdr" >&5
-#line 4211 "configure"
+#line 4250 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4216: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4255: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4238,10 +4277,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4242: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4281: checking whether time.h and sys/time.h may both be included" >&5
-#line 4245 "configure"
+#line 4284 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -4250,7 +4289,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:4254: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4293: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -4270,10 +4309,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4274: checking for off_t" >&5
+echo "configure:4313: checking for off_t" >&5
-#line 4277 "configure"
+#line 4316 "configure"
#if STDC_HEADERS
@@ -4300,10 +4339,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4304: checking for uid_t in sys/types.h" >&5
+echo "configure:4343: checking for uid_t in sys/types.h" >&5
-#line 4307 "configure"
+#line 4346 "configure"
EOF
@@ -4331,10 +4370,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4335: checking return type of signal handlers" >&5
+echo "configure:4374: checking return type of signal handlers" >&5
-#line 4338 "configure"
+#line 4377 "configure"
#include <signal.h>
@@ -4351,7 +4390,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:4355: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4394: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -4369,10 +4408,10 @@
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:4373: checking for Cygwin environment" >&5
+echo "configure:4412: checking for Cygwin environment" >&5
-#line 4376 "configure"
+#line 4415 "configure"
int main() {
@@ -4383,7 +4422,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:4387: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4426: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -4401,10 +4440,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4405: checking for $ac_func" >&5
+echo "configure:4444: checking for $ac_func" >&5
-#line 4408 "configure"
+#line 4447 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -4427,7 +4466,7 @@
; return 0; }
EOF
-if { (eval echo configure:4431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4470: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -4453,10 +4492,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:4457: checking for $ac_func" >&5
+echo "configure:4496: checking for $ac_func" >&5
-#line 4460 "configure"
+#line 4499 "configure"
@@ -4479,7 +4518,7 @@
; return 0; }
EOF
-if { (eval echo configure:4483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4505,10 +4544,10 @@
for ac_func in drand48
do
-echo "configure:4509: checking for $ac_func" >&5
+echo "configure:4548: checking for $ac_func" >&5
-#line 4512 "configure"
+#line 4551 "configure"
@@ -4531,7 +4570,7 @@
; return 0; }
EOF
-if { (eval echo configure:4535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4574: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4557,10 +4596,10 @@
for ac_func in putenv setenv
do
-echo "configure:4561: checking for $ac_func" >&5
+echo "configure:4600: checking for $ac_func" >&5
-#line 4564 "configure"
+#line 4603 "configure"
@@ -4583,7 +4622,7 @@
; return 0; }
EOF
-if { (eval echo configure:4587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4626: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4609,10 +4648,10 @@
for ac_func in nanosleep
do
-echo "configure:4613: checking for $ac_func" >&5
+echo "configure:4652: checking for $ac_func" >&5
-#line 4616 "configure"
+#line 4655 "configure"
@@ -4635,7 +4674,7 @@
; return 0; }
EOF
-if { (eval echo configure:4639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4660,13 +4699,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4664: checking whether setpgrp takes no argument" >&5
+echo "configure:4703: checking whether setpgrp takes no argument" >&5
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 4670 "configure"
+#line 4709 "configure"
#ifdef HAVE_UNISTD_H
@@ -4686,7 +4725,7 @@
EOF
-if { (eval echo configure:4690: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -4714,16 +4753,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4718: checking for long long int" >&5
+echo "configure:4757: checking for long long int" >&5
-#line 4720 "configure"
+#line 4759 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:4727: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4766: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
@@ -4743,7 +4782,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4747: checking for W11" >&5
+echo "configure:4786: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -4771,7 +4810,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4775: checking for X" >&5
+echo "configure:4814: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -4831,12 +4870,12 @@
# First, try using that file with no special directory specified.
-#line 4835 "configure"
+#line 4874 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:4840: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4879: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4905,14 +4944,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 4909 "configure"
+#line 4948 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:4916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4955: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -5017,17 +5056,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:5021: checking whether -R must be followed by a space" >&5
+echo "configure:5060: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 5024 "configure"
+#line 5063 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:5031: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -5043,14 +5082,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 5047 "configure"
+#line 5086 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:5054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -5082,13 +5121,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:5086: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:5125: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 5092 "configure"
+#line 5131 "configure"
@@ -5099,7 +5138,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:5103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5120,13 +5159,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:5124: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:5163: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 5130 "configure"
+#line 5169 "configure"
@@ -5137,7 +5176,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:5141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5165,10 +5204,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5169: checking for gethostbyname" >&5
+echo "configure:5208: checking for gethostbyname" >&5
-#line 5172 "configure"
+#line 5211 "configure"
which can conflict with char gethostbyname(); below. */
@@ -5191,7 +5230,7 @@
; return 0; }
EOF
-if { (eval echo configure:5195: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5234: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -5211,13 +5250,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5215: checking for gethostbyname in -lnsl" >&5
+echo "configure:5254: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5221 "configure"
+#line 5260 "configure"
@@ -5228,7 +5267,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:5232: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5257,10 +5296,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5261: checking for connect" >&5
+echo "configure:5300: checking for connect" >&5
-#line 5264 "configure"
+#line 5303 "configure"
which can conflict with char connect(); below. */
@@ -5283,7 +5322,7 @@
; return 0; }
EOF
-if { (eval echo configure:5287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -5303,13 +5342,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5307: checking for connect in -lsocket" >&5
+echo "configure:5346: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5313 "configure"
+#line 5352 "configure"
@@ -5320,7 +5359,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:5324: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5343,10 +5382,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5347: checking for remove" >&5
+echo "configure:5386: checking for remove" >&5
-#line 5350 "configure"
+#line 5389 "configure"
which can conflict with char remove(); below. */
@@ -5369,7 +5408,7 @@
; return 0; }
EOF
-if { (eval echo configure:5373: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5412: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -5389,13 +5428,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5393: checking for remove in -lposix" >&5
+echo "configure:5432: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 5399 "configure"
+#line 5438 "configure"
@@ -5406,7 +5445,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:5410: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5449: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5429,10 +5468,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5433: checking for shmat" >&5
+echo "configure:5472: checking for shmat" >&5
-#line 5436 "configure"
+#line 5475 "configure"
which can conflict with char shmat(); below. */
@@ -5455,7 +5494,7 @@
; return 0; }
EOF
-if { (eval echo configure:5459: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -5475,13 +5514,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5479: checking for shmat in -lipc" >&5
+echo "configure:5518: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 5485 "configure"
+#line 5524 "configure"
@@ -5492,7 +5531,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:5496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5524,13 +5563,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5528: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5567: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5534 "configure"
+#line 5573 "configure"
@@ -5541,7 +5580,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:5545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5581,12 +5620,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5585: checking for library containing cuserid" >&5
+echo "configure:5624: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 5590 "configure"
+#line 5629 "configure"
@@ -5597,7 +5636,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:5601: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -5608,7 +5647,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 5612 "configure"
+#line 5651 "configure"
@@ -5619,7 +5658,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:5623: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5662: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -5645,10 +5684,10 @@
# Note: -lxdr -liberty -lws2_32 is for MinGW
echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5649: checking for xdrmem_create" >&5
+echo "configure:5688: checking for xdrmem_create" >&5
-#line 5652 "configure"
+#line 5691 "configure"
which can conflict with char xdrmem_create(); below. */
@@ -5671,7 +5710,7 @@
; return 0; }
EOF
-if { (eval echo configure:5675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_xdrmem_create=yes"
else
@@ -5689,13 +5728,13 @@
echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:5693: checking for xdrmem_create in -lsun" >&5
+echo "configure:5732: checking for xdrmem_create in -lsun" >&5
ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lsun $LIBS"
-#line 5699 "configure"
+#line 5738 "configure"
@@ -5706,7 +5745,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5710: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5749: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5725,13 +5764,13 @@
echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:5729: checking for xdrmem_create in -lnsl" >&5
+echo "configure:5768: checking for xdrmem_create in -lnsl" >&5
ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5735 "configure"
+#line 5774 "configure"
@@ -5742,7 +5781,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5761,13 +5800,13 @@
echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:5765: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:5804: checking for xdrmem_create in -lrpclib" >&5
ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lrpclib $LIBS"
-#line 5771 "configure"
+#line 5810 "configure"
@@ -5778,7 +5817,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5797,13 +5836,13 @@
echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:5801: checking for xdrmem_create in -lxdr" >&5
+echo "configure:5840: checking for xdrmem_create in -lxdr" >&5
ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lxdr -liberty -lws2_32 $LIBS"
-#line 5807 "configure"
+#line 5846 "configure"
@@ -5814,7 +5853,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5818: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5848,10 +5887,10 @@
for ac_func in asprintf
do
-echo "configure:5852: checking for $ac_func" >&5
+echo "configure:5891: checking for $ac_func" >&5
-#line 5855 "configure"
+#line 5894 "configure"
@@ -5874,7 +5913,7 @@
; return 0; }
EOF
-if { (eval echo configure:5878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5917: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5901,10 +5940,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:5905: checking for atan" >&5
+echo "configure:5944: checking for atan" >&5
-#line 5908 "configure"
+#line 5947 "configure"
which can conflict with char atan(); below. */
@@ -5927,7 +5966,7 @@
; return 0; }
EOF
-if { (eval echo configure:5931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -5945,13 +5984,13 @@
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:5949: checking for atan in -lm" >&5
+echo "configure:5988: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 5955 "configure"
+#line 5994 "configure"
@@ -5962,7 +6001,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:5966: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6005: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5989,10 +6028,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:5993: checking for dlsym" >&5
+echo "configure:6032: checking for dlsym" >&5
-#line 5996 "configure"
+#line 6035 "configure"
which can conflict with char dlsym(); below. */
@@ -6015,7 +6054,7 @@
; return 0; }
EOF
-if { (eval echo configure:6019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -6033,13 +6072,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6037: checking for dlsym in -ldl" >&5
+echo "configure:6076: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 6043 "configure"
+#line 6082 "configure"
@@ -6050,7 +6089,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:6054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6077,10 +6116,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6081: checking for iconv" >&5
+echo "configure:6120: checking for iconv" >&5
-#line 6084 "configure"
+#line 6123 "configure"
which can conflict with char iconv(); below. */
@@ -6103,7 +6142,7 @@
; return 0; }
EOF
-if { (eval echo configure:6107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6146: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -6121,13 +6160,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6125: checking for iconv in -liconv" >&5
+echo "configure:6164: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 6131 "configure"
+#line 6170 "configure"
@@ -6138,7 +6177,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6157,13 +6196,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6161: checking for iconv in -lgiconv" >&5
+echo "configure:6200: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 6167 "configure"
+#line 6206 "configure"
@@ -6174,7 +6213,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6193,10 +6232,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6197: checking for libiconv" >&5
+echo "configure:6236: checking for libiconv" >&5
-#line 6200 "configure"
+#line 6239 "configure"
which can conflict with char libiconv(); below. */
@@ -6219,7 +6258,7 @@
; return 0; }
EOF
-if { (eval echo configure:6223: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6262: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -6237,13 +6276,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6241: checking for libiconv in -liconv" >&5
+echo "configure:6280: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6247 "configure"
+#line 6286 "configure"
@@ -6254,7 +6293,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6258: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6273,13 +6312,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6277: checking for libiconv in -lgiconv" >&5
+echo "configure:6316: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6283 "configure"
+#line 6322 "configure"
@@ -6290,7 +6329,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6294: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6327,10 +6366,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6331: checking for socket" >&5
+echo "configure:6370: checking for socket" >&5
-#line 6334 "configure"
+#line 6373 "configure"
which can conflict with char socket(); below. */
@@ -6353,7 +6392,7 @@
; return 0; }
EOF
-if { (eval echo configure:6357: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6396: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -6371,13 +6410,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6375: checking for socket in -lsocket" >&5
+echo "configure:6414: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 6381 "configure"
+#line 6420 "configure"
@@ -6388,7 +6427,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:6392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6436,7 +6475,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6440: checking for location of zlib includes" >&5
+echo "configure:6479: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6462,15 +6501,15 @@
do
-echo "configure:6466: checking for $ac_hdr" >&5
+echo "configure:6505: checking for $ac_hdr" >&5
-#line 6469 "configure"
+#line 6508 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6474: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6513: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6504,7 +6543,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6508: checking for location of zlib library" >&5
+echo "configure:6547: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6529,13 +6568,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6533: checking for deflate in -lz" >&5
+echo "configure:6572: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 6539 "configure"
+#line 6578 "configure"
@@ -6546,7 +6585,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:6550: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6589: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6594,7 +6633,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6598: checking for location of External PROJ.4 includes" >&5
+echo "configure:6637: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6620,15 +6659,15 @@
do
-echo "configure:6624: checking for $ac_hdr" >&5
+echo "configure:6663: checking for $ac_hdr" >&5
-#line 6627 "configure"
+#line 6666 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6632: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6671: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6665,7 +6704,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6669: checking External PROJ.4 version" >&5
+echo "configure:6708: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6673,7 +6712,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 6677 "configure"
+#line 6716 "configure"
#include <stdio.h>
@@ -6685,7 +6724,7 @@
EOF
-if { (eval echo configure:6689: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:6728: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -6710,7 +6749,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:6714: checking for location of External PROJ.4 library" >&5
+echo "configure:6753: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -6735,13 +6774,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:6739: checking for pj_get_def in -lproj" >&5
+echo "configure:6778: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 6745 "configure"
+#line 6784 "configure"
@@ -6752,7 +6791,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:6756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6795: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6786,7 +6825,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:6790: checking for location of External PROJ.4 data files" >&5
+echo "configure:6829: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -6810,14 +6849,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:6814: checking for epsg" >&5
+echo "configure:6853: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:6821: checking for $PROJSHARE/epsg" >&5
+echo "configure:6860: checking for $PROJSHARE/epsg" >&5
@@ -6849,7 +6888,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
-echo "configure:6853: checking for $ac_word" >&5
+echo "configure:6892: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -6889,7 +6928,7 @@
echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:6893: checking whether to use regex" >&5
+echo "configure:6932: checking whether to use regex" >&5
echo "$ac_t"""$with_regex"" 1>&6
case "$with_regex" in
"no") USE_REGEX= ;;
@@ -6909,7 +6948,7 @@
echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:6913: checking for location of regex includes" >&5
+echo "configure:6952: checking for location of regex includes" >&5
case "$with_regex_includes" in
{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -6935,15 +6974,15 @@
do
-echo "configure:6939: checking for $ac_hdr" >&5
+echo "configure:6978: checking for $ac_hdr" >&5
-#line 6942 "configure"
+#line 6981 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6947: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6986: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6977,7 +7016,7 @@
echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:6981: checking for location of regex library" >&5
+echo "configure:7020: checking for location of regex library" >&5
case "$with_regex_libs" in
{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -7002,10 +7041,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:7006: checking for regcomp" >&5
+echo "configure:7045: checking for regcomp" >&5
-#line 7009 "configure"
+#line 7048 "configure"
which can conflict with char regcomp(); below. */
@@ -7028,7 +7067,7 @@
; return 0; }
EOF
-if { (eval echo configure:7032: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_regcomp=yes"
else
@@ -7055,13 +7094,13 @@
echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:7059: checking for regcomp in -lregex" >&5
+echo "configure:7098: checking for regcomp in -lregex" >&5
ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
LIBS="-lregex $LIBS"
-#line 7065 "configure"
+#line 7104 "configure"
@@ -7072,7 +7111,7 @@
regcomp()
; return 0; }
EOF
-if { (eval echo configure:7076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7115: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7122,7 +7161,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7126: checking whether to use Readline" >&5
+echo "configure:7165: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -7143,7 +7182,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7147: checking for location of Readline includes" >&5
+echo "configure:7186: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7169,15 +7208,15 @@
do
-echo "configure:7173: checking for $ac_hdr" >&5
+echo "configure:7212: checking for $ac_hdr" >&5
-#line 7176 "configure"
+#line 7215 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7181: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7220: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7213,15 +7252,15 @@
do
-echo "configure:7217: checking for $ac_hdr" >&5
+echo "configure:7256: checking for $ac_hdr" >&5
-#line 7220 "configure"
+#line 7259 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7225: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7264: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7255,7 +7294,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7259: checking for location of Readline library" >&5
+echo "configure:7298: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7280,13 +7319,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7284: checking for readline in -lreadline" >&5
+echo "configure:7323: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 7290 "configure"
+#line 7329 "configure"
@@ -7297,7 +7336,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:7301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7332,13 +7371,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7336: checking for add_history in -lhistory" >&5
+echo "configure:7375: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 7342 "configure"
+#line 7381 "configure"
@@ -7349,7 +7388,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:7353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7392,7 +7431,7 @@
echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7396: checking whether to use JPEG" >&5
+echo "configure:7435: checking whether to use JPEG" >&5
echo "$ac_t"""$with_jpeg"" 1>&6
case "$with_jpeg" in
"no") USE_JPEG= ;;
@@ -7412,7 +7451,7 @@
echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7416: checking for location of JPEG includes" >&5
+echo "configure:7455: checking for location of JPEG includes" >&5
case "$with_jpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7438,15 +7477,15 @@
do
-echo "configure:7442: checking for $ac_hdr" >&5
+echo "configure:7481: checking for $ac_hdr" >&5
-#line 7445 "configure"
+#line 7484 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7450: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7489: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7480,7 +7519,7 @@
echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7484: checking for location of JPEG library" >&5
+echo "configure:7523: checking for location of JPEG library" >&5
case "$with_jpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7507,13 +7546,13 @@
echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7511: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7550: checking for jpeg_start_compress in -ljpeg" >&5
ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
LIBS="-ljpeg $LIBS"
-#line 7517 "configure"
+#line 7556 "configure"
@@ -7524,7 +7563,7 @@
jpeg_start_compress()
; return 0; }
EOF
-if { (eval echo configure:7528: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7567: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7543,13 +7582,13 @@
-echo "configure:7547: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7586: checking for jpeg_start_compress in -ljpeg" >&5
LIBS="-ljpeg $ZLIB $LIBS"
-#line 7553 "configure"
+#line 7592 "configure"
@@ -7560,7 +7599,7 @@
; return 0; }
EOF
-if { (eval echo configure:7564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7609,7 +7648,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7613: checking whether to use GDAL" >&5
+echo "configure:7652: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -7627,7 +7666,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7631: checking for $ac_word" >&5
+echo "configure:7670: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -7682,14 +7721,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 7686 "configure"
+#line 7725 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:7693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
echo "configure: failed program was:" >&5
@@ -7698,14 +7737,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 7702 "configure"
+#line 7741 "configure"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:7709: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -7737,7 +7776,7 @@
# GEOS option
echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:7741: checking whether to use GEOS" >&5
+echo "configure:7780: checking whether to use GEOS" >&5
GEOS_LIBS=
GGEOS_CFLAGS=
@@ -7754,7 +7793,7 @@
# Extract the first word of "geos-config", so it can be a program name with args.
set dummy geos-config; ac_word=$2
-echo "configure:7758: checking for $ac_word" >&5
+echo "configure:7797: checking for $ac_word" >&5
case "$GEOS_CONFIG" in
@@ -7802,15 +7841,15 @@
do
-echo "configure:7806: checking for $ac_hdr" >&5
+echo "configure:7845: checking for $ac_hdr" >&5
-#line 7809 "configure"
+#line 7848 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7814: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7853: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7845,13 +7884,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:7849: checking for initGEOS in -lgeos_c" >&5
+echo "configure:7888: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 7855 "configure"
+#line 7894 "configure"
#include "confdefs.h"
@@ -7862,7 +7901,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:7866: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7905: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7905,7 +7944,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7909: checking whether to use TIFF" >&5
+echo "configure:7948: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -7925,7 +7964,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7929: checking for location of TIFF includes" >&5
+echo "configure:7968: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7951,15 +7990,15 @@
do
-echo "configure:7955: checking for $ac_hdr" >&5
+echo "configure:7994: checking for $ac_hdr" >&5
-#line 7958 "configure"
+#line 7997 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7963: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8002: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -7993,7 +8032,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7997: checking for location of TIFF library" >&5
+echo "configure:8036: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -8024,13 +8063,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:8028: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8067: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 8034 "configure"
+#line 8073 "configure"
@@ -8041,7 +8080,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8084: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8060,13 +8099,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:8064: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8103: checking for TIFFOpen in -ltiff" >&5
ac_save_LIBS="$LIBS"
LIBS="-ltiff $MATHLIB $LIBS"
-#line 8070 "configure"
+#line 8109 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -8077,7 +8116,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -8096,13 +8135,13 @@
-echo "configure:8100: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8139: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 8106 "configure"
+#line 8145 "configure"
@@ -8113,7 +8152,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8132,13 +8171,13 @@
-echo "configure:8136: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8175: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8142 "configure"
+#line 8181 "configure"
@@ -8149,7 +8188,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8168,13 +8207,13 @@
-echo "configure:8172: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8211: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8178 "configure"
+#line 8217 "configure"
@@ -8185,7 +8224,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8204,13 +8243,13 @@
-echo "configure:8208: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8247: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8214 "configure"
+#line 8253 "configure"
@@ -8221,7 +8260,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8264: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8240,13 +8279,13 @@
-echo "configure:8244: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8283: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8250 "configure"
+#line 8289 "configure"
@@ -8257,7 +8296,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8276,13 +8315,13 @@
-echo "configure:8280: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8319: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8286 "configure"
+#line 8325 "configure"
@@ -8293,7 +8332,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8391,7 +8430,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8395: checking whether to use PNG" >&5
+echo "configure:8434: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -8410,7 +8449,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8414: checking for location of PNG includes" >&5
+echo "configure:8453: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8436,15 +8475,15 @@
do
-echo "configure:8440: checking for $ac_hdr" >&5
+echo "configure:8479: checking for $ac_hdr" >&5
-#line 8443 "configure"
+#line 8482 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8448: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8487: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8478,7 +8517,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8482: checking for location of PNG library" >&5
+echo "configure:8521: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8503,13 +8542,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8507: checking for png_read_image in -lpng" >&5
+echo "configure:8546: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8513 "configure"
+#line 8552 "configure"
@@ -8520,7 +8559,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:8524: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8563: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8562,7 +8601,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:8566: checking whether to use PostgreSQL" >&5
+echo "configure:8605: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -8589,7 +8628,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:8593: checking for location of PostgreSQL includes" >&5
+echo "configure:8632: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -8615,15 +8654,15 @@
do
-echo "configure:8619: checking for $ac_hdr" >&5
+echo "configure:8658: checking for $ac_hdr" >&5
-#line 8622 "configure"
+#line 8661 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8627: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8666: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8661,7 +8700,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:8665: checking for location of PostgreSQL library" >&5
+echo "configure:8704: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -8690,13 +8729,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:8694: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8733: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 8700 "configure"
+#line 8739 "configure"
@@ -8707,7 +8746,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:8711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8750: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8726,13 +8765,13 @@
-echo "configure:8730: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8769: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 8736 "configure"
+#line 8775 "configure"
@@ -8743,7 +8782,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:8747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8762,13 +8801,13 @@
-echo "configure:8766: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8805: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 8772 "configure"
+#line 8811 "configure"
@@ -8779,7 +8818,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:8783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8798,13 +8837,13 @@
-echo "configure:8802: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8841: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 8808 "configure"
+#line 8847 "configure"
@@ -8815,7 +8854,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:8819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8858: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8872,13 +8911,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:8876: checking for PQcmdTuples in -lpq" >&5
+echo "configure:8915: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 8882 "configure"
+#line 8921 "configure"
@@ -8889,7 +8928,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:8893: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8911,13 +8950,13 @@
-echo "configure:8915: checking for PQcmdTuples in -lpq" >&5
+echo "configure:8954: checking for PQcmdTuples in -lpq" >&5
-#line 8921 "configure"
+#line 8960 "configure"
@@ -8928,7 +8967,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:8932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8971,7 +9010,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:8975: checking whether to use MySQL" >&5
+echo "configure:9014: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -8991,7 +9030,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:8995: checking for location of MySQL includes" >&5
+echo "configure:9034: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9017,15 +9056,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:9021: checking for $ac_hdr" >&5
+echo "configure:9060: checking for $ac_hdr" >&5
-#line 9024 "configure"
+#line 9063 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9029: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9068: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9062,7 +9101,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9066: checking for location of MySQL library" >&5
+echo "configure:9105: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9093,13 +9132,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9097: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9136: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 9103 "configure"
+#line 9142 "configure"
@@ -9110,7 +9149,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9114: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9129,13 +9168,13 @@
-echo "configure:9133: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9172: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9139 "configure"
+#line 9178 "configure"
@@ -9146,7 +9185,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9165,13 +9204,13 @@
-echo "configure:9169: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9208: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9175 "configure"
+#line 9214 "configure"
@@ -9182,7 +9221,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9186: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9201,13 +9240,13 @@
-echo "configure:9205: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9244: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9211 "configure"
+#line 9250 "configure"
@@ -9218,7 +9257,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9222: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9237,13 +9276,13 @@
-echo "configure:9241: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9280: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9247 "configure"
+#line 9286 "configure"
@@ -9254,7 +9293,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9258: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9273,13 +9312,13 @@
-echo "configure:9277: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9316: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9283 "configure"
+#line 9322 "configure"
@@ -9290,7 +9329,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9294: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9309,13 +9348,13 @@
-echo "configure:9313: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9352: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9319 "configure"
+#line 9358 "configure"
@@ -9326,7 +9365,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9330: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9345,13 +9384,13 @@
-echo "configure:9349: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9388: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9355 "configure"
+#line 9394 "configure"
@@ -9362,7 +9401,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9405: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9452,7 +9491,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
-echo "configure:9456: checking for $ac_word" >&5
+echo "configure:9495: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -9501,10 +9540,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:9505: checking for mysql_server_init" >&5
+echo "configure:9544: checking for mysql_server_init" >&5
-#line 9508 "configure"
+#line 9547 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -9530,7 +9569,7 @@
; return 0; }
EOF
-if { (eval echo configure:9534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9573: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -9582,7 +9621,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:9586: checking whether to use SQLite" >&5
+echo "configure:9625: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -9602,7 +9641,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:9606: checking for location of SQLite includes" >&5
+echo "configure:9645: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -9628,15 +9667,15 @@
do
-echo "configure:9632: checking for $ac_hdr" >&5
+echo "configure:9671: checking for $ac_hdr" >&5
-#line 9635 "configure"
+#line 9674 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9640: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9679: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9679,7 +9718,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:9683: checking for location of SQLite library" >&5
+echo "configure:9722: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -9706,13 +9745,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:9710: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9749: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 9716 "configure"
+#line 9755 "configure"
@@ -9723,7 +9762,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:9727: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9766: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9742,13 +9781,13 @@
-echo "configure:9746: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9785: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 9752 "configure"
+#line 9791 "configure"
@@ -9759,7 +9798,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:9763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9812,7 +9851,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:9816: checking whether to use FFMPEG" >&5
+echo "configure:9855: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -9832,7 +9871,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:9836: checking for location of FFMPEG includes" >&5
+echo "configure:9875: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -9858,15 +9897,15 @@
do
-echo "configure:9862: checking for $ac_hdr" >&5
+echo "configure:9901: checking for $ac_hdr" >&5
-#line 9865 "configure"
+#line 9904 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9870: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9909: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9902,15 +9941,15 @@
do
-echo "configure:9906: checking for $ac_hdr" >&5
+echo "configure:9945: checking for $ac_hdr" >&5
-#line 9909 "configure"
+#line 9948 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9914: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9953: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9946,15 +9985,15 @@
do
-echo "configure:9950: checking for $ac_hdr" >&5
+echo "configure:9989: checking for $ac_hdr" >&5
-#line 9953 "configure"
+#line 9992 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9958: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9997: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9997,7 +10036,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10001: checking for location of FFMPEG library" >&5
+echo "configure:10040: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10024,13 +10063,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10028: checking for av_free in -lavutil" >&5
+echo "configure:10067: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 10034 "configure"
+#line 10073 "configure"
@@ -10041,7 +10080,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10084: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10060,13 +10099,13 @@
-echo "configure:10064: checking for av_free in -lavutil" >&5
+echo "configure:10103: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 10070 "configure"
+#line 10109 "configure"
@@ -10077,7 +10116,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10122,13 +10161,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10126: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10165: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 10132 "configure"
+#line 10171 "configure"
@@ -10139,7 +10178,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10143: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10182: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10158,13 +10197,13 @@
-echo "configure:10162: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10201: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10168 "configure"
+#line 10207 "configure"
@@ -10175,7 +10214,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10218: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10220,13 +10259,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10224: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10263: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 10230 "configure"
+#line 10269 "configure"
@@ -10237,7 +10276,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10280: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10256,13 +10295,13 @@
-echo "configure:10260: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10299: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10266 "configure"
+#line 10305 "configure"
@@ -10273,7 +10312,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10316: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10332,7 +10371,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10336: checking whether to use OpenGL" >&5
+echo "configure:10375: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -10366,7 +10405,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10370: checking for location of OpenGL includes" >&5
+echo "configure:10409: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10392,15 +10431,15 @@
do
-echo "configure:10396: checking for $ac_hdr" >&5
+echo "configure:10435: checking for $ac_hdr" >&5
-#line 10399 "configure"
+#line 10438 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10404: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10443: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10434,7 +10473,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10438: checking for location of OpenGL library" >&5
+echo "configure:10477: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -10463,13 +10502,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:10467: checking for glBegin in -lGL" >&5
+echo "configure:10506: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 10473 "configure"
+#line 10512 "configure"
@@ -10480,7 +10519,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10484: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10499,13 +10538,13 @@
-echo "configure:10503: checking for glBegin in -lGL" >&5
+echo "configure:10542: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 10509 "configure"
+#line 10548 "configure"
@@ -10516,7 +10555,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10535,13 +10574,13 @@
-echo "configure:10539: checking for glBegin in -lGL" >&5
+echo "configure:10578: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 10545 "configure"
+#line 10584 "configure"
@@ -10552,7 +10591,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10571,13 +10610,13 @@
-echo "configure:10575: checking for glBegin in -lGL" >&5
+echo "configure:10614: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 10581 "configure"
+#line 10620 "configure"
@@ -10588,7 +10627,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10650,13 +10689,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:10654: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10693: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 10660 "configure"
+#line 10699 "configure"
@@ -10667,7 +10706,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:10671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10710: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10686,13 +10725,13 @@
-echo "configure:10690: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10729: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 10696 "configure"
+#line 10735 "configure"
@@ -10703,7 +10742,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:10707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10750,10 +10789,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:10754: checking for glXCreatePbuffer" >&5
+echo "configure:10793: checking for glXCreatePbuffer" >&5
-#line 10757 "configure"
+#line 10796 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -10776,7 +10815,7 @@
; return 0; }
EOF
-if { (eval echo configure:10780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -10813,10 +10852,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:10817: checking for glXCreateGLXPixmap" >&5
+echo "configure:10856: checking for glXCreateGLXPixmap" >&5
-#line 10820 "configure"
+#line 10859 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -10839,7 +10878,7 @@
; return 0; }
EOF
-if { (eval echo configure:10843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10882: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -10882,7 +10921,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:10886: checking for location of OpenGL framework" >&5
+echo "configure:10925: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -10906,15 +10945,15 @@
do
-echo "configure:10910: checking for $ac_hdr" >&5
+echo "configure:10949: checking for $ac_hdr" >&5
-#line 10913 "configure"
+#line 10952 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10918: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10957: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10950,10 +10989,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:10954: checking for glBegin" >&5
+echo "configure:10993: checking for glBegin" >&5
-#line 10957 "configure"
+#line 10996 "configure"
which can conflict with char glBegin(); below. */
@@ -10976,7 +11015,7 @@
; return 0; }
EOF
-if { (eval echo configure:10980: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -11013,10 +11052,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11017: checking for gluBeginCurve" >&5
+echo "configure:11056: checking for gluBeginCurve" >&5
-#line 11020 "configure"
+#line 11059 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -11039,7 +11078,7 @@
; return 0; }
EOF
-if { (eval echo configure:11043: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11082: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -11087,7 +11126,7 @@
-echo "configure:11091: checking for location of OpenGL includes" >&5
+echo "configure:11130: checking for location of OpenGL includes" >&5
@@ -11113,15 +11152,15 @@
do
-echo "configure:11117: checking for $ac_hdr" >&5
+echo "configure:11156: checking for $ac_hdr" >&5
-#line 11120 "configure"
+#line 11159 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11125: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11164: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11155,7 +11194,7 @@
-echo "configure:11159: checking for location of OpenGL library" >&5
+echo "configure:11198: checking for location of OpenGL library" >&5
@@ -11180,18 +11219,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11184: checking for OpenGL library" >&5
+echo "configure:11223: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 11188 "configure"
+#line 11227 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:11195: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11234: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -11215,18 +11254,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11219: checking for GLU library" >&5
+echo "configure:11258: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 11223 "configure"
+#line 11262 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:11230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11269: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11275,7 +11314,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:11279: checking whether to use Tcl/Tk" >&5
+echo "configure:11318: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -11295,7 +11334,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:11299: checking for location of Tcl/Tk includes" >&5
+echo "configure:11338: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -11321,15 +11360,15 @@
do
-echo "configure:11325: checking for $ac_hdr" >&5
+echo "configure:11364: checking for $ac_hdr" >&5
-#line 11328 "configure"
+#line 11367 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11333: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11372: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11366,15 +11405,15 @@
do
-echo "configure:11370: checking for $ac_hdr" >&5
+echo "configure:11409: checking for $ac_hdr" >&5
-#line 11373 "configure"
+#line 11412 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11378: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11417: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11408,7 +11447,7 @@
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:11412: checking Tcl version" >&5
+echo "configure:11451: checking Tcl version" >&5
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -11416,7 +11455,7 @@
else
-#line 11420 "configure"
+#line 11459 "configure"
#include <stdio.h>
@@ -11428,7 +11467,7 @@
EOF
-if { (eval echo configure:11432: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -11446,7 +11485,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:11450: checking Tk version" >&5
+echo "configure:11489: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -11454,7 +11493,7 @@
else
-#line 11458 "configure"
+#line 11497 "configure"
#include <stdio.h>
@@ -11466,7 +11505,7 @@
EOF
-if { (eval echo configure:11470: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -11495,7 +11534,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:11499: checking for location of Tcl/Tk library" >&5
+echo "configure:11538: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -11535,13 +11574,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:11539: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11578: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 11545 "configure"
+#line 11584 "configure"
@@ -11552,7 +11591,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11571,13 +11610,13 @@
-echo "configure:11575: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11614: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 11581 "configure"
+#line 11620 "configure"
@@ -11588,7 +11627,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11615,13 +11654,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11619: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11658: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 11625 "configure"
+#line 11664 "configure"
@@ -11632,7 +11671,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11636: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11651,13 +11690,13 @@
-echo "configure:11655: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11694: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 11661 "configure"
+#line 11700 "configure"
@@ -11668,7 +11707,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11695,13 +11734,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:11699: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:11738: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 11705 "configure"
+#line 11744 "configure"
@@ -11712,7 +11751,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11716: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11731,13 +11770,13 @@
-echo "configure:11735: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:11774: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 11741 "configure"
+#line 11780 "configure"
@@ -11748,7 +11787,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11752: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11826,13 +11865,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:11830: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:11869: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 11836 "configure"
+#line 11875 "configure"
@@ -11843,7 +11882,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:11847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11862,13 +11901,13 @@
-echo "configure:11866: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:11905: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 11872 "configure"
+#line 11911 "configure"
@@ -11879,7 +11918,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:11883: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11906,13 +11945,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11910: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:11949: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 11916 "configure"
+#line 11955 "configure"
@@ -11923,7 +11962,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:11927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11966: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11942,13 +11981,13 @@
-echo "configure:11946: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:11985: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 11952 "configure"
+#line 11991 "configure"
@@ -11959,7 +11998,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:11963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12002: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11986,13 +12025,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:11990: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12029: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 11996 "configure"
+#line 12035 "configure"
@@ -12003,7 +12042,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12007: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12022,13 +12061,13 @@
-echo "configure:12026: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12065: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12032 "configure"
+#line 12071 "configure"
@@ -12039,7 +12078,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12043: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12082: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12129,13 +12168,13 @@
do
# add only if in MACOSX_ARCHS
echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:12133: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:12172: checking for Tcl_Init in -l$tlib" >&5
ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 12139 "configure"
+#line 12178 "configure"
@@ -12146,7 +12185,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12195,7 +12234,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12199: checking whether to use ODBC" >&5
+echo "configure:12238: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -12214,7 +12253,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12218: checking for location of ODBC includes" >&5
+echo "configure:12257: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12240,15 +12279,15 @@
do
-echo "configure:12244: checking for $ac_hdr" >&5
+echo "configure:12283: checking for $ac_hdr" >&5
-#line 12247 "configure"
+#line 12286 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12252: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12291: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12282,7 +12321,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12286: checking for location of ODBC library" >&5
+echo "configure:12325: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12307,13 +12346,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12311: checking for SQLConnect in -lodbc" >&5
+echo "configure:12350: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 12317 "configure"
+#line 12356 "configure"
@@ -12324,7 +12363,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12328: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12367: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12349,13 +12388,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12353: checking for SQLConnect in -liodbc" >&5
+echo "configure:12392: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 12359 "configure"
+#line 12398 "configure"
@@ -12366,7 +12405,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12391,11 +12430,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12395: checking for ODBC library" >&5
+echo "configure:12434: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 12399 "configure"
+#line 12438 "configure"
#include <windows.h>
#include <sql.h>
@@ -12403,7 +12442,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:12407: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -12452,7 +12491,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12456: checking whether to use FFTW" >&5
+echo "configure:12495: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -12471,7 +12510,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12475: checking for location of FFTW includes" >&5
+echo "configure:12514: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12497,15 +12536,15 @@
do
-echo "configure:12501: checking for $ac_hdr" >&5
+echo "configure:12540: checking for $ac_hdr" >&5
-#line 12504 "configure"
+#line 12543 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12509: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12548: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12533,15 +12572,15 @@
do
-echo "configure:12537: checking for $ac_hdr" >&5
+echo "configure:12576: checking for $ac_hdr" >&5
-#line 12540 "configure"
+#line 12579 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12545: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12584: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12569,15 +12608,15 @@
do
-echo "configure:12573: checking for $ac_hdr" >&5
+echo "configure:12612: checking for $ac_hdr" >&5
-#line 12576 "configure"
+#line 12615 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12581: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12620: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12623,7 +12662,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12627: checking for location of FFTW library" >&5
+echo "configure:12666: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12648,13 +12687,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12652: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12691: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12658 "configure"
+#line 12697 "configure"
@@ -12665,7 +12704,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:12669: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12690,13 +12729,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12694: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12733: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 12700 "configure"
+#line 12739 "configure"
@@ -12707,7 +12746,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12750: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12732,13 +12771,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12736: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12775: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12742 "configure"
+#line 12781 "configure"
@@ -12749,7 +12788,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12753: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12792: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12806,7 +12845,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12810: checking whether to use BLAS" >&5
+echo "configure:12849: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -12827,7 +12866,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12831: checking for location of BLAS includes" >&5
+echo "configure:12870: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12847,7 +12886,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12851: checking for location of BLAS library" >&5
+echo "configure:12890: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12873,15 +12912,15 @@
do
-echo "configure:12877: checking for $ac_hdr" >&5
+echo "configure:12916: checking for $ac_hdr" >&5
-#line 12880 "configure"
+#line 12919 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12885: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12924: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12916,13 +12955,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12920: checking for dnrm2_ in -lblas" >&5
+echo "configure:12959: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 12926 "configure"
+#line 12965 "configure"
@@ -12933,7 +12972,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12937: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12952,13 +12991,13 @@
-echo "configure:12956: checking for dnrm2_ in -lblas" >&5
+echo "configure:12995: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 12962 "configure"
+#line 13001 "configure"
#include "confdefs.h"
@@ -12969,7 +13008,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13013,13 +13052,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:13017: checking for ATL_xerbla in -latlas" >&5
+echo "configure:13056: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 13023 "configure"
+#line 13062 "configure"
@@ -13030,7 +13069,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:13034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13045,13 +13084,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13049: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13088: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 13055 "configure"
+#line 13094 "configure"
@@ -13062,7 +13101,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13077,13 +13116,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13081: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13120: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13087 "configure"
+#line 13126 "configure"
@@ -13094,7 +13133,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:13098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13140,16 +13179,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13144: checking for sgemm in $vlib_flags" >&5
+echo "configure:13183: checking for sgemm in $vlib_flags" >&5
-#line 13146 "configure"
+#line 13185 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:13153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -13167,13 +13206,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13171: checking for sgemm_ in -lblas" >&5
+echo "configure:13210: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lblas $LIBS"
-#line 13177 "configure"
+#line 13216 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -13184,7 +13223,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13227: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -13199,13 +13238,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13203: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13242: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 13209 "configure"
+#line 13248 "configure"
@@ -13216,7 +13255,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:13220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13259: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13231,13 +13270,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13235: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13274: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 13241 "configure"
+#line 13280 "configure"
@@ -13248,7 +13287,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13252: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13282,13 +13321,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13286: checking for acosp in -lsunmath" >&5
+echo "configure:13325: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 13292 "configure"
+#line 13331 "configure"
@@ -13299,7 +13338,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:13303: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13314,13 +13353,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13318: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13357: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 13324 "configure"
+#line 13363 "configure"
@@ -13331,7 +13370,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13335: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13374: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13361,13 +13400,13 @@
# Generic BLAS library
-echo "configure:13365: checking for sgemm_ in -lblas" >&5
+echo "configure:13404: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 13371 "configure"
+#line 13410 "configure"
@@ -13378,7 +13417,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13382: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13421: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13417,7 +13456,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13421: checking whether to use LAPACK" >&5
+echo "configure:13460: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -13442,7 +13481,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13446: checking for location of LAPACK includes" >&5
+echo "configure:13485: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13462,7 +13501,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13466: checking for location of LAPACK library" >&5
+echo "configure:13505: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13488,15 +13527,15 @@
do
-echo "configure:13492: checking for $ac_hdr" >&5
+echo "configure:13531: checking for $ac_hdr" >&5
-#line 13495 "configure"
+#line 13534 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13500: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13539: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -13528,10 +13567,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13532: checking for dsegv_" >&5
+echo "configure:13571: checking for dsegv_" >&5
-#line 13535 "configure"
+#line 13574 "configure"
which can conflict with char dsegv_(); below. */
@@ -13554,7 +13593,7 @@
; return 0; }
EOF
-if { (eval echo configure:13558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13597: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -13581,13 +13620,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13585: checking for desgv_ in -llapack" >&5
+echo "configure:13624: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 13591 "configure"
+#line 13630 "configure"
@@ -13598,7 +13637,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:13602: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13641: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13630,13 +13669,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13634: checking for dgesv_ in -llapack" >&5
+echo "configure:13673: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 13640 "configure"
+#line 13679 "configure"
@@ -13647,7 +13686,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13651: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13690: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13666,13 +13705,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:13670: checking for dgesv_ in -llapack" >&5
+echo "configure:13709: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13676 "configure"
+#line 13715 "configure"
@@ -13683,7 +13722,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13687: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13739,7 +13778,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13743: checking whether to use Cairo" >&5
+echo "configure:13782: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -13765,7 +13804,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:13769: checking for location of cairo includes" >&5
+echo "configure:13808: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -13791,15 +13830,15 @@
do
-echo "configure:13795: checking for $ac_hdr" >&5
+echo "configure:13834: checking for $ac_hdr" >&5
-#line 13798 "configure"
+#line 13837 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13803: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13842: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13835,7 +13874,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:13839: checking for location of cairo library" >&5
+echo "configure:13878: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -13855,7 +13894,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:13859: checking for cairo linking flags" >&5
+echo "configure:13898: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -13871,10 +13910,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13875: checking for cairo_create" >&5
+echo "configure:13914: checking for cairo_create" >&5
-#line 13878 "configure"
+#line 13917 "configure"
which can conflict with char cairo_create(); below. */
@@ -13897,7 +13936,7 @@
; return 0; }
EOF
-if { (eval echo configure:13901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13940: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -13931,10 +13970,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:13935: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:13974: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 13938 "configure"
+#line 13977 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -13957,7 +13996,7 @@
; return 0; }
EOF
-if { (eval echo configure:13961: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -13990,10 +14029,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:13994: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:14033: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 13997 "configure"
+#line 14036 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -14016,7 +14055,7 @@
; return 0; }
EOF
-if { (eval echo configure:14020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14059: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -14058,7 +14097,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14062: checking whether to use FreeType" >&5
+echo "configure:14101: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -14077,7 +14116,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14081: checking for location of FreeType includes" >&5
+echo "configure:14120: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14103,15 +14142,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14107: checking for $ac_hdr" >&5
+echo "configure:14146: checking for $ac_hdr" >&5
-#line 14110 "configure"
+#line 14149 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14115: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14154: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14145,7 +14184,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14149: checking for location of FreeType library" >&5
+echo "configure:14188: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14170,13 +14209,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14174: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:14213: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 14180 "configure"
+#line 14219 "configure"
@@ -14187,7 +14226,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:14191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14228,7 +14267,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14232: checking whether to use NLS" >&5
+echo "configure:14271: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -14248,10 +14287,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14252: checking for gettext" >&5
+echo "configure:14291: checking for gettext" >&5
-#line 14255 "configure"
+#line 14294 "configure"
which can conflict with char gettext(); below. */
@@ -14274,7 +14313,7 @@
; return 0; }
EOF
-if { (eval echo configure:14278: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14317: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -14292,13 +14331,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14296: checking for gettext in -lintl" >&5
+echo "configure:14335: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 14302 "configure"
+#line 14341 "configure"
@@ -14309,7 +14348,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:14313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14352: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14344,7 +14383,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14348: checking whether to use C++" >&5
+echo "configure:14387: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -14360,7 +14399,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14364: checking for $ac_word" >&5
+echo "configure:14403: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14389,7 +14428,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14393: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14432: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14400,12 +14439,12 @@
cat > conftest.$ac_ext << EOF
-#line 14404 "configure"
+#line 14443 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:14409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14448: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -14431,19 +14470,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14435: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14474: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14440: checking whether we are using GNU C++" >&5
+echo "configure:14479: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14447: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14486: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -14461,7 +14500,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14465: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14504: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14502,7 +14541,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14506: checking whether to use openDWG" >&5
+echo "configure:14545: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -14522,7 +14561,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14526: checking for location of openDGW includes" >&5
+echo "configure:14565: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14548,15 +14587,15 @@
do
-echo "configure:14552: checking for $ac_hdr" >&5
+echo "configure:14591: checking for $ac_hdr" >&5
-#line 14555 "configure"
+#line 14594 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14560: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14599: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14590,7 +14629,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14594: checking for location of openDWG library" >&5
+echo "configure:14633: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14631,7 +14670,7 @@
echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:14635: checking whether to use POSIX threads" >&5
+echo "configure:14674: checking whether to use POSIX threads" >&5
echo "$ac_t"""$with_pthread"" 1>&6
case "$with_pthread" in
"no") USE_PTHREAD= ;;
@@ -14651,7 +14690,7 @@
echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:14655: checking for location of POSIX threads includes" >&5
+echo "configure:14694: checking for location of POSIX threads includes" >&5
case "$with_pthread_includes" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -14677,15 +14716,15 @@
do
-echo "configure:14681: checking for $ac_hdr" >&5
+echo "configure:14720: checking for $ac_hdr" >&5
-#line 14684 "configure"
+#line 14723 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14689: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14728: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14719,7 +14758,7 @@
echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:14723: checking for location of POSIX threads library" >&5
+echo "configure:14762: checking for location of POSIX threads library" >&5
case "$with_pthread_libs" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -14744,10 +14783,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:14748: checking for pthread_create" >&5
+echo "configure:14787: checking for pthread_create" >&5
-#line 14751 "configure"
+#line 14790 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char pthread_create(); below. */
@@ -14770,7 +14809,7 @@
; return 0; }
EOF
-if { (eval echo configure:14774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_pthread_create=yes"
else
@@ -14797,13 +14836,13 @@
echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:14801: checking for pthread_create in -lpthread" >&5
+echo "configure:14840: checking for pthread_create in -lpthread" >&5
ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
LIBS="-lpthread $LIBS"
-#line 14807 "configure"
+#line 14846 "configure"
@@ -14814,7 +14853,7 @@
pthread_create()
; return 0; }
EOF
-if { (eval echo configure:14818: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14870,7 +14909,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14874: checking for special C compiler options needed for large files" >&5
+echo "configure:14913: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -14878,7 +14917,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 14882 "configure"
+#line 14921 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -14894,7 +14933,7 @@
; return 0; }
EOF
-if { (eval echo configure:14898: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14937: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -14903,7 +14942,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 14907 "configure"
+#line 14946 "configure"
@@ -14919,7 +14958,7 @@
; return 0; }
EOF
-if { (eval echo configure:14923: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14962: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -14939,11 +14978,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14943: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14982: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 14947 "configure"
+#line 14986 "configure"
@@ -14959,14 +14998,14 @@
; return 0; }
EOF
-if { (eval echo configure:14963: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15002: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 14970 "configure"
+#line 15009 "configure"
#define _FILE_OFFSET_BITS 64
@@ -14984,7 +15023,7 @@
; return 0; }
EOF
-if { (eval echo configure:14988: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15027: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -15003,11 +15042,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15007: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15046: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 15011 "configure"
+#line 15050 "configure"
@@ -15023,14 +15062,14 @@
; return 0; }
EOF
-if { (eval echo configure:15027: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15066: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15034 "configure"
+#line 15073 "configure"
#define _LARGE_FILES 1
@@ -15048,7 +15087,7 @@
; return 0; }
EOF
-if { (eval echo configure:15052: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15091: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -15067,25 +15106,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15071: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15110: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 15075 "configure"
+#line 15114 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15082: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15121: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15089 "configure"
+#line 15128 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -15094,7 +15133,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15098: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15137: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -15115,10 +15154,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15119: checking if system supports Large Files at all" >&5
+echo "configure:15158: checking if system supports Large Files at all" >&5
-#line 15122 "configure"
+#line 15161 "configure"
#include <stdio.h>
@@ -15150,7 +15189,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:15154: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15193: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -15179,7 +15218,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:15183: checking whether to use Python" >&5
+echo "configure:15222: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -15200,7 +15239,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
-echo "configure:15204: checking for $ac_word" >&5
+echo "configure:15243: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -15242,15 +15281,15 @@
do
-echo "configure:15246: checking for $ac_hdr" >&5
+echo "configure:15285: checking for $ac_hdr" >&5
-#line 15249 "configure"
+#line 15288 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15254: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15293: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15298,7 +15337,7 @@
# Extract the first word of "swig", so it can be a program name with args.
set dummy swig; ac_word=$2
-echo "configure:15302: checking for $ac_word" >&5
+echo "configure:15341: checking for $ac_word" >&5
case "$SWIG" in
@@ -15360,7 +15399,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15364: checking whether to use wxWidgets" >&5
+echo "configure:15403: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -15381,7 +15420,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:15385: checking for $ac_word" >&5
+echo "configure:15424: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -15429,7 +15468,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15433: checking wxWidgets version" >&5
+echo "configure:15472: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -15452,15 +15491,15 @@
do
-echo "configure:15456: checking for $ac_hdr" >&5
+echo "configure:15495: checking for $ac_hdr" >&5
-#line 15459 "configure"
+#line 15498 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15464: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15503: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15639,12 +15678,14 @@
s%@ARCH@%$ARCH%g
s%@GISBASE@%$GISBASE%g
s%@GRASS_BIN@%$GRASS_BIN%g
+s%@SVN_VERSION@%$SVN_VERSION%g
s%@GRASS_VERSION_FILE@%$GRASS_VERSION_FILE%g
s%@GRASS_VERSION_MAJOR@%$GRASS_VERSION_MAJOR%g
s%@GRASS_VERSION_MINOR@%$GRASS_VERSION_MINOR%g
s%@GRASS_VERSION_RELEASE@%$GRASS_VERSION_RELEASE%g
s%@GRASS_VERSION_NUMBER@%$GRASS_VERSION_NUMBER%g
s%@GRASS_VERSION_DATE@%$GRASS_VERSION_DATE%g
+s%@GRASS_VERSION_SVN@%$GRASS_VERSION_SVN%g
s%@NAME_VER@%$NAME_VER%g
s%@LIB_VER@%$LIB_VER%g
s%@MACOSX_APP@%$MACOSX_APP%g
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2009-10-23 14:51:43 UTC (rev 39621)
+++ grass/trunk/configure.in 2009-10-25 15:27:52 UTC (rev 39622)
@@ -124,12 +124,19 @@
LIB_VER=`echo ${GRASS_VERSION_NUMBER} | sed 's/^\([0-9.]*\).*$/\1/'`
changequote([,])
+GRASS_VERSION_SVN=
+AC_PATH_PROG(SVN_VERSION, svnversion, no)
+if test "$SVN_VERSION" != "no" ; then
+ GRASS_VERSION_SVN=`$SVN_VERSION`
+fi
AC_SUBST(GRASS_VERSION_FILE)
AC_SUBST(GRASS_VERSION_MAJOR)
AC_SUBST(GRASS_VERSION_MINOR)
AC_SUBST(GRASS_VERSION_RELEASE)
AC_SUBST(GRASS_VERSION_NUMBER)
AC_SUBST(GRASS_VERSION_DATE)
+AC_SUBST(GRASS_VERSION_SVN)
AC_SUBST(NAME_VER)
AC_SUBST(LIB_VER)
Modified: grass/trunk/general/g.version/Makefile
--- grass/trunk/general/g.version/Makefile 2009-10-23 14:51:43 UTC (rev 39621)
+++ grass/trunk/general/g.version/Makefile 2009-10-25 15:27:52 UTC (rev 39622)
@@ -7,7 +7,9 @@
COPYING := $(shell cat $(MODULE_TOPDIR)/COPYING | sed -f sed.script | tr -d '\012')
GRASS_CONFIGURE_PARAMS := $(shell head -n 7 $(MODULE_TOPDIR)/config.status | tail -n 1 | tr -d '\012')
-EXTRA_CFLAGS=-DGRASS_VERSION_NUMBER=\"'$(GRASS_VERSION_NUMBER)'\" -DGRASS_VERSION_DATE=\"'$(GRASS_VERSION_DATE)'\" -DGRASS_VERSION_UPDATE_PKG=\"'$(GRASS_VERSION_UPDATE_PKG)'\" -DGRASS_CONFIGURE_PARAMS="\"$(GRASS_CONFIGURE_PARAMS)\"" -DCOPYING="\"$(COPYING)\""
+EXTRA_CFLAGS=-DGRASS_VERSION_NUMBER=\"'$(GRASS_VERSION_NUMBER)'\" -DGRASS_VERSION_DATE=\"'$(GRASS_VERSION_DATE)'\" \
+ -DGRASS_VERSION_SVN=\"'$(GRASS_VERSION_SVN)'\" -DGRASS_VERSION_UPDATE_PKG=\"'$(GRASS_VERSION_UPDATE_PKG)'\" \
+ -DGRASS_CONFIGURE_PARAMS="\"$(GRASS_CONFIGURE_PARAMS)\"" -DCOPYING="\"$(COPYING)\""
LIBES = $(GISLIB)
DEPENDENCIES = $(GISDEP)
Modified: grass/trunk/general/g.version/main.c
--- grass/trunk/general/g.version/main.c 2009-10-23 14:51:43 UTC (rev 39621)
+++ grass/trunk/general/g.version/main.c 2009-10-25 15:27:52 UTC (rev 39622)
@@ -16,6 +16,7 @@
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <grass/gis.h>
#include <grass/glocale.h>
@@ -50,11 +51,17 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- fprintf(stdout, "GRASS %s (%s) %s\n",
- GRASS_VERSION_NUMBER, GRASS_VERSION_DATE,
- GRASS_VERSION_UPDATE_PKG);
+ if (strlen(GRASS_VERSION_SVN) > 0) {
+ fprintf(stdout, "GRASS %s (%s) - r%s\n",
+ GRASS_VERSION_NUMBER, GRASS_VERSION_DATE,
+ GRASS_VERSION_SVN);
+ else {
+ fprintf(stdout, "GRASS %s (%s) %s\n",
+ GRASS_VERSION_UPDATE_PKG);
if (copyright->answer) {
fprintf(stdout, "\n");
fputs(COPYING, stdout);
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in 2009-10-23 14:51:43 UTC (rev 39621)
+++ grass/trunk/include/Make/Platform.make.in 2009-10-25 15:27:52 UTC (rev 39622)
@@ -47,6 +47,7 @@
GRASS_VERSION_MINOR = @GRASS_VERSION_MINOR@
GRASS_VERSION_RELEASE = @GRASS_VERSION_RELEASE@
GRASS_VERSION_DATE = @GRASS_VERSION_DATE@
+GRASS_VERSION_SVN = @GRASS_VERSION_SVN@
PLAT_OBJS = @PLAT_OBJS@
STRIPFLAG = @STRIPFLAG@
Modified: grass/trunk/lib/init/Makefile
--- grass/trunk/lib/init/Makefile 2009-10-23 14:51:43 UTC (rev 39621)
+++ grass/trunk/lib/init/Makefile 2009-10-25 15:27:52 UTC (rev 39622)
@@ -123,7 +123,11 @@
$(ETC)/VERSIONNUMBER:
rm -f $@
- echo "$(GRASS_VERSION_NUMBER)" > $@
+ @if [ -n "$(GRASS_VERSION_SVN)" ] ; then \
+ echo "$(GRASS_VERSION_NUMBER) r$(GRASS_VERSION_SVN)" > $@ ; \
+ else \
+ echo "$(GRASS_VERSION_NUMBER)" > $@ ; \
+ fi
chmod +r $@
$(ETC)/grass_intro $(ETC)/license $(ETC)/welcome: $(ETC)/%: %.txt version.sed
