[GRASS-SVN] r39648 - grass/trunk/lib/segment
svn_grass at osgeo.org
Fri Oct 30 09:25:02 EDT 2009
Author: mmetz
Date: 2009-10-30 09:25:01 -0400 (Fri, 30 Oct 2009)
New Revision: 39648
grass/trunk/lib/segment/address.c
grass/trunk/lib/segment/pagein.c
grass/trunk/lib/segment/put.c
grass/trunk/lib/segment/rbtree.c
grass/trunk/lib/segment/release.c
grass/trunk/lib/segment/seek.c
grass/trunk/lib/segment/setup.c
format and clean up code
Modified: grass/trunk/lib/segment/address.c
--- grass/trunk/lib/segment/address.c 2009-10-30 12:17:45 UTC (rev 39647)
+++ grass/trunk/lib/segment/address.c 2009-10-30 13:25:01 UTC (rev 39648)
@@ -14,41 +14,47 @@
#include <grass/segment.h>
-int segment_address_fast(const SEGMENT * SEG, int row, int col, int *n, int *index)
+int segment_address_fast(const SEGMENT * SEG, int row, int col, int *n,
+ int *index)
if (row) {
- int seg_r = row >> SEG->srowbits;
- int seg_c = col >> SEG->scolbits;
- *n = seg_r * SEG->spr + seg_c;
- *index = ((row - (seg_r << SEG->srowbits)) << SEG->scolbits) + col - (seg_c << SEG->scolbits);
+ int seg_r = row >> SEG->srowbits;
+ int seg_c = col >> SEG->scolbits;
+ *n = seg_r * SEG->spr + seg_c;
+ *index =
+ ((row - (seg_r << SEG->srowbits)) << SEG->scolbits) + col -
+ (seg_c << SEG->scolbits);
/* for simple arrays */
else {
- *n = col >> SEG->scolbits;
- *index = col - ((*n) << SEG->scolbits);
+ *n = col >> SEG->scolbits;
+ *index = col - ((*n) << SEG->scolbits);
if (SEG->slow_seek == 0)
- *index = *index << SEG->lenbits;
+ *index = *index << SEG->lenbits;
else
- *index *= SEG->len;
+ *index *= SEG->len;
return 0;
-int segment_address_slow(const SEGMENT * SEG, int row, int col, int *n, int *index)
+int segment_address_slow(const SEGMENT * SEG, int row, int col, int *n,
+ int *index)
if (row) {
- int seg_r = row / SEG->srows;
- int seg_c = col / SEG->scols;
+ int seg_r = row / SEG->srows;
+ int seg_c = col / SEG->scols;
- *index = (row - seg_r * SEG->srows) * SEG->scols + col - seg_c * SEG->scols;
+ *index =
+ (row - seg_r * SEG->srows) * SEG->scols + col -
+ seg_c * SEG->scols;
else {
- *n = col / SEG->scols;
- *index = col - *n * SEG->scols;
+ *n = col / SEG->scols;
+ *index = col - *n * SEG->scols;
*index *= SEG->len;
@@ -56,8 +62,7 @@
static int (*segment_adrs[2]) () = {
- segment_address_fast, segment_address_slow
+segment_address_fast, segment_address_slow};
* \fn int segment_address (SEGMENT *SEG, int row, int col, int *n, int *index)
@@ -75,12 +80,12 @@
int segment_address(const SEGMENT * SEG, int row, int col, int *n, int *index)
/* old code
- *n = row / SEG->srows * SEG->spr + col / SEG->scols;
- *index = (row % SEG->srows * SEG->scols + col % SEG->scols) * SEG->len;
+ *n = row / SEG->srows * SEG->spr + col / SEG->scols;
+ *index = (row % SEG->srows * SEG->scols + col % SEG->scols) * SEG->len;
/* this function is called at least once every time data are accessed in SEG
* avoid very slow modulus and divisions, modulus was the main time killer */
- return (*segment_adrs[SEG->slow_adrs])(SEG, row, col, n, index);
+ return (*segment_adrs[SEG->slow_adrs]) (SEG, row, col, n, index);
Modified: grass/trunk/lib/segment/pagein.c
--- grass/trunk/lib/segment/pagein.c 2009-10-30 12:17:45 UTC (rev 39647)
+++ grass/trunk/lib/segment/pagein.c 2009-10-30 13:25:01 UTC (rev 39648)
@@ -43,7 +43,7 @@
/* is n the current segment? */
if (n == SEG->scb[SEG->cur].n)
return SEG->cur;
/* search the in memory segments */
seg_search.i = 0;
seg_search.n = n;
@@ -63,34 +63,37 @@
/* make it youngest */
SEG->youngest = SEG->scb[cur].age;
return SEG->cur = cur;
/* find a slot to use to hold segment */
- if (SEG->nfreeslots) { /* any free slots left ? */
- cur = SEG->freeslot[--SEG->nfreeslots];
- else { /* find oldest segment */
+ if (!SEG->nfreeslots) {
+ /* use oldest segment */
SEG->oldest = SEG->oldest->younger;
cur = SEG->oldest->cur;
SEG->oldest->cur = -1;
- SEG->scb[cur].age = NULL;
- /* if slot is used, write it out, if dirty */
- if (SEG->scb[cur].n >= 0 && SEG->scb[cur].dirty) {
- if (segment_pageout(SEG, cur) < 0)
- return -1;
+ /* unload segment (remove from search tree) */
+ if (SEG->scb[cur].n >= 0) {
+ seg_search.n = SEG->scb[cur].n;
+ if (rbtree_remove(SEG->loaded, &seg_search) == 0)
+ G_fatal_error("could not remove segment");
+ seg_search.n = n;
+ /* write it out if dirty */
+ if (SEG->scb[cur].dirty) {
+ if (segment_pageout(SEG, cur) < 0)
+ return -1;
- if (SEG->scb[cur].n >= 0) {
- seg_search.n = SEG->scb[cur].n;
- if (rbtree_remove(SEG->loaded, &seg_search) == 0)
- G_fatal_error("could not remove segment");
- seg_search.n = n;
+ else {
+ /* free slots left */
+ cur = SEG->freeslot[--SEG->nfreeslots];
/* read in the segment */
SEG->scb[cur].n = n;
SEG->scb[cur].dirty = 0;
@@ -113,9 +116,6 @@
return -1;
- if (cur < 0 || n < 0)
- G_fatal_error("segment not loaded");
/* remember loaded segment */
seg_search.i = cur;
if (rbtree_insert(SEG->loaded, &seg_search) == 0)
@@ -125,6 +125,6 @@
SEG->youngest = SEG->youngest->younger;
SEG->scb[cur].age = SEG->youngest;
SEG->youngest->cur = cur;
Modified: grass/trunk/lib/segment/put.c
--- grass/trunk/lib/segment/put.c 2009-10-30 12:17:45 UTC (rev 39647)
+++ grass/trunk/lib/segment/put.c 2009-10-30 13:25:01 UTC (rev 39648)
@@ -47,8 +47,8 @@
segment_address(SEG, row, col, &n, &index);
if ((i = segment_pagein(SEG, n)) < 0) {
- G_warning("segment lib: put: pagein failed");
- return -1;
+ G_warning("segment lib: put: pagein failed");
+ return -1;
SEG->scb[i].dirty = 1;
Modified: grass/trunk/lib/segment/rbtree.c
--- grass/trunk/lib/segment/rbtree.c 2009-10-30 12:17:45 UTC (rev 39647)
+++ grass/trunk/lib/segment/rbtree.c 2009-10-30 13:25:01 UTC (rev 39648)
@@ -47,7 +47,7 @@
/* create new tree and initialize
* returns pointer to new tree, NULL for memory allocation error
-struct RB_TREE *rbtree_create(rb_compare_fn *compare, size_t rb_datasize)
+struct RB_TREE *rbtree_create(rb_compare_fn * compare, size_t rb_datasize)
struct RB_TREE *tree = G_malloc(sizeof(*tree));
@@ -64,7 +64,7 @@
tree->root = NULL;
return tree;
/* add an item to a tree
* non-recursive top-down insertion
@@ -74,7 +74,7 @@
int rbtree_insert(struct RB_TREE *tree, void *data)
assert(tree && data);
if (tree->root == NULL) {
/* create a new root node for tree */
tree->root = rbtree_make_node(tree->datasize, data);
@@ -82,10 +82,12 @@
return 0;
else {
- struct RB_NODE head = {0}; /* False tree root */
+ struct RB_NODE head = { 0 }; /* False tree root */
- struct RB_NODE *g, *t; /* Grandparent & parent */
- struct RB_NODE *p, *q; /* Iterator & parent */
+ struct RB_NODE *g, *t; /* Grandparent & parent */
+ struct RB_NODE *p, *q; /* Iterator & parent */
int dir = 0, last = 0;
/* Set up helpers */
@@ -94,7 +96,7 @@
q = t->link[1] = tree->root;
/* Search down the tree */
- for ( ; ; ) {
+ for (;;) {
if (q == NULL) {
/* Insert new node at the bottom */
p->link[dir] = q = rbtree_make_node(tree->datasize, data);
@@ -154,15 +156,15 @@
int rbtree_remove(struct RB_TREE *tree, const void *data)
- struct RB_NODE *q, *p, *g; /* Helpers */
- struct RB_NODE *f = NULL; /* Found item */
+ struct RB_NODE *q, *p, *g; /* Helpers */
+ struct RB_NODE *f = NULL; /* Found item */
int dir = 1, removed = 0;
- return 0; /* empty tree, nothing to remove */
+ return 0; /* empty tree, nothing to remove */
@@ -193,8 +195,7 @@
struct RB_NODE *s = p->link[!last];
if (s != NULL) {
- if (!is_red(s->link[!last]) &&
- !is_red(s->link[last])) {
+ if (!is_red(s->link[!last]) && !is_red(s->link[last])) {
/* Color flip */
p->red = 0;
s->red = 1;
@@ -232,7 +233,7 @@
/* Update root and make it black */
tree->root = head.link[1];
- if ( tree->root != NULL)
+ if (tree->root != NULL)
tree->root->red = 0;
return removed;
@@ -251,7 +252,7 @@
while (curr_node != NULL) {
cmp = tree->rb_compare(curr_node->data, data);
if (cmp == 0)
- return curr_node->data; /* found */
+ return curr_node->data; /* found */
else {
curr_node = curr_node->link[cmp < 0];
@@ -283,7 +284,7 @@
void *rbtree_traverse(struct RB_TRAV *trav)
assert(trav);
if (trav->curr_node == NULL) {
if (trav->first)
G_debug(1, "RB tree: empty tree");
@@ -292,7 +293,7 @@
return NULL;
if (!trav->first)
return rbtree_next(trav);
else {
@@ -322,7 +323,7 @@
return NULL;
if (!trav->first)
@@ -343,13 +344,13 @@
* largest item is smaller than search template */
if (trav->curr_node->link[dir] == NULL)
return trav->curr_node->data;
trav->up[trav->top++] = trav->curr_node;
trav->curr_node = trav->curr_node->link[dir];
- return NULL; /* should not happen */
+ return NULL; /* should not happen */
/* two functions needed to fully traverse the tree: initialize and continue
@@ -371,7 +372,7 @@
trav->curr_node = trav->curr_node->link[0];
- return trav->curr_node->data; /* return smallest item */
+ return trav->curr_node->data; /* return smallest item */
/* continue traversing the tree in ascending order
@@ -393,6 +394,7 @@
else {
/* at smallest item in this branch, go back up */
struct RB_NODE *last;
do {
if (trav->top == 0) {
trav->curr_node = NULL;
@@ -406,12 +408,13 @@
if (trav->curr_node != NULL) {
- else
- return NULL; /* finished traversing */
+ else
+ return NULL; /* finished traversing */
/* destroy the tree */
-void rbtree_destroy(struct RB_TREE *tree) {
+void rbtree_destroy(struct RB_TREE *tree)
rbtree_destroy2(tree->root);
G_free(tree);
@@ -430,7 +433,7 @@
int rbtree_debug(struct RB_TREE *tree, struct RB_NODE *root)
int lh, rh;
if (root == NULL)
return 1;
else {
@@ -452,7 +455,7 @@
if (ln) {
lcmp = tree->rb_compare(ln->data, root->data);
if (rn) {
rcmp = tree->rb_compare(rn->data, root->data);
@@ -460,8 +463,8 @@
/* Invalid binary search tree:
* left node >= parent or right node <= parent */
if ((ln != NULL && lcmp > -1)
- || (rn != NULL && rcmp < 1)) {
- G_warning("Red Black Tree debugging: Binary tree violation" );
+ || (rn != NULL && rcmp < 1)) {
+ G_warning("Red Black Tree debugging: Binary tree violation");
return 0;
@@ -496,9 +499,9 @@
new_node->data = G_malloc(datasize);
if (new_node->data == NULL)
G_fatal_error("RB Search Tree: Out of memory!");
memcpy(new_node->data, data, datasize);
- new_node->red = 1; /* 1 is red, 0 is black */
+ new_node->red = 1; /* 1 is red, 0 is black */
new_node->link[0] = NULL;
new_node->link[1] = NULL;
@@ -527,7 +530,7 @@
return newroot;
/* double rotation */
struct RB_NODE *rbtree_double(struct RB_NODE *root, int dir)
Modified: grass/trunk/lib/segment/release.c
--- grass/trunk/lib/segment/release.c 2009-10-30 12:17:45 UTC (rev 39647)
+++ grass/trunk/lib/segment/release.c 2009-10-30 13:25:01 UTC (rev 39648)
@@ -14,6 +14,7 @@
#include <stdlib.h>
+#include "rbtree.h"
@@ -43,6 +44,10 @@
free(SEG->scb[i].buf);
free(SEG->scb);
+ free(SEG->freeslot);
+ free(SEG->agequeue);
+ rbtree_destroy(SEG->loaded);
SEG->open = 0;
return 1;
Modified: grass/trunk/lib/segment/seek.c
--- grass/trunk/lib/segment/seek.c 2009-10-30 12:17:45 UTC (rev 39647)
+++ grass/trunk/lib/segment/seek.c 2009-10-30 13:25:01 UTC (rev 39648)
@@ -61,8 +61,7 @@
static int (*segment_seek_mode[2]) () = {
- segment_seek_fast, segment_seek_slow
+segment_seek_fast, segment_seek_slow};
int segment_seek(const SEGMENT * SEG, int n, int index)
Modified: grass/trunk/lib/segment/setup.c
--- grass/trunk/lib/segment/setup.c 2009-10-30 12:17:45 UTC (rev 39647)
+++ grass/trunk/lib/segment/setup.c 2009-10-30 13:25:01 UTC (rev 39648)
@@ -17,7 +17,6 @@
#include <math.h>
#include <grass/gis.h>
#include "rbtree.h"
@@ -81,7 +80,8 @@
/* adjust number of open segments if larger than number of total segments */
if (SEG->nseg > SEG->spr * ((SEG->nrows + SEG->srows - 1) / SEG->srows)) {
G_warning("segment: reducing number of open segments from %d to %d",
- SEG->nseg, SEG->spr * ((SEG->nrows + SEG->srows - 1) / SEG->srows));
+ SEG->nseg,
+ SEG->spr * ((SEG->nrows + SEG->srows - 1) / SEG->srows));
SEG->nseg = SEG->spr * ((SEG->nrows + SEG->srows - 1) / SEG->srows);
@@ -93,12 +93,13 @@
if ((SEG->freeslot = (int *)G_malloc(SEG->nseg * sizeof(int))) == NULL)
return -2;
- if ((SEG->agequeue = (struct aq *)G_malloc((SEG->nseg + 1) * sizeof(struct aq))) == NULL)
+ if ((SEG->agequeue =
+ (struct aq *)G_malloc((SEG->nseg + 1) * sizeof(struct aq))) == NULL)
return -2;
SEG->srowscols = SEG->srows * SEG->scols;
SEG->size = SEG->srowscols * SEG->len;
for (i = 0; i < SEG->nseg; i++) {
if ((SEG->scb[i].buf = G_malloc(SEG->size)) == NULL)
return -2;
@@ -117,16 +118,16 @@
SEG->agequeue[i].older = &(SEG->agequeue[i + 1]);
SEG->agequeue[SEG->nseg].cur = -1;
SEG->agequeue[SEG->nseg].younger = &(SEG->agequeue[SEG->nseg - 1]);
SEG->agequeue[SEG->nseg].older = &(SEG->agequeue[0]);
SEG->youngest = SEG->oldest = &(SEG->agequeue[SEG->nseg]);
SEG->nfreeslots = SEG->nseg;
SEG->cur = 0;
SEG->open = 1;
SEG->loaded = rbtree_create(segment_compare, sizeof(SEGID));
return 1;
@@ -135,14 +136,14 @@
int segment_compare(const void *sega, const void *segb)
SEGID *a, *b;
- a = (SEGID *)sega;
- b = (SEGID *)segb;
+ a = (SEGID *) sega;
+ b = (SEGID *) segb;
if (a->n > b->n)
return 1;
else if (a->n < b->n)
return -1;
return 0;
