[GRASS-SVN] r39651 -
grass/branches/releasebranch_6_3/vector/lidar/v.lidar.edgedetection
svn_grass at osgeo.org
Sat Oct 31 08:37:47 EDT 2009
Author: neteler
Date: 2009-10-31 08:37:46 -0400 (Sat, 31 Oct 2009)
New Revision: 39651
grass/branches/releasebranch_6_3/vector/lidar/v.lidar.edgedetection/description.html
grass/branches/releasebranch_6_3/vector/lidar/v.lidar.edgedetection/edgedetection.c
backport correction for numbering of terrain classification
Modified: grass/branches/releasebranch_6_3/vector/lidar/v.lidar.edgedetection/description.html
--- grass/branches/releasebranch_6_3/vector/lidar/v.lidar.edgedetection/description.html 2009-10-30 20:09:53 UTC (rev 39650)
+++ grass/branches/releasebranch_6_3/vector/lidar/v.lidar.edgedetection/description.html 2009-10-31 12:37:46 UTC (rev 39651)
@@ -28,10 +28,11 @@
threshold. Other points are classified as TERRAIN.
<br>
<br>
-The output eill be a vector map in which points has been classified as
+The output will be a vector map in which points has been classified as
TERRAIN, EDGE or UNKNOWN. This vector map should be the input of
<em>v.lidar.growing</em> module.
<h2>NOTES</h2>
In this module, an external table will be created which will be useful for
@@ -40,10 +41,11 @@
in the output vector map will be classified as:
<br>
<br>
-EDGE (cat = 1, layer = 1)
+TERRAIN (cat = 1, layer = 1)
<br>
-TERRAIN (cat = 2, layer = 1)
+EDGE (cat = 2, layer = 1)
<br>
+UNKNOWN (cat = 3, layer = 1)
<br>
The final result of the whole procedure (v.lidar.edgedetection,
v.lidar.growing, v.lidar.correction) will be a point classification in
Modified: grass/branches/releasebranch_6_3/vector/lidar/v.lidar.edgedetection/edgedetection.c
--- grass/branches/releasebranch_6_3/vector/lidar/v.lidar.edgedetection/edgedetection.c 2009-10-30 20:09:53 UTC (rev 39650)
+++ grass/branches/releasebranch_6_3/vector/lidar/v.lidar.edgedetection/edgedetection.c 2009-10-31 12:37:46 UTC (rev 39651)
@@ -35,9 +35,9 @@
int edge_detection (struct Cell_head elaboration_reg, BOUND_BOX Overlap_Box, double *parBilin, double obsX, double obsY, \
double *partial, double alpha, double residual, double gradHigh, double gradLow)
- /* 0 = PRE_TERRAIN */
- /* 1 = PRE_EDGE */
- /* 2 = UNKNOWN */
+ /* 1 = PRE_TERRAIN */
+ /* 2 = PRE_EDGE */
+ /* 3 = UNKNOWN */
int c1, c2;
double g[9][2], *gradient, gradPto, dirPto;
