[GRASS-SVN] r39654 - grass/trunk/gui/wxpython/docs
svn_grass at osgeo.org
Sat Oct 31 16:05:03 EDT 2009
Author: glynn
Date: 2009-10-31 16:05:02 -0400 (Sat, 31 Oct 2009)
New Revision: 39654
grass/trunk/gui/wxpython/docs/wxGUI.html
Fix broken HTML
Modified: grass/trunk/gui/wxpython/docs/wxGUI.html
--- grass/trunk/gui/wxpython/docs/wxGUI.html 2009-10-31 18:56:57 UTC (rev 39653)
+++ grass/trunk/gui/wxpython/docs/wxGUI.html 2009-10-31 20:05:02 UTC (rev 39654)
@@ -135,32 +135,32 @@
<em>Add various raster-based map layers</em></dt>
<dd>Opens a dropdown menu that allows user to select to:<br>
- <ul>
- <li><dt><img src="icons/grass2/layer-shaded-relief-add.png">
+ <dl>
+ <dt><img src="icons/grass2/layer-shaded-relief-add.png">
<em>Add shaded relief raster map layer </em></dt>
<dd>Adds shaded relief raster map layer,
- see <em><a href="d.shadedmap.html">d.shadedmap</a></em></li>
- <li><dt><img src="icons/grass2/layer-rgb-add.png">
+ see <em><a href="d.shadedmap.html">d.shadedmap</a></em>
+ <dt><img src="icons/grass2/layer-rgb-add.png">
<em>Add RGB raster layer</em></dt>
<dd>Combines and displays three raster maps defined as red, green,
and blue channels to create an RGB color map,
- see <em><a href="d.rgb.html">d.rgb</a></em>.</dd></li>
- <li><dt><img src="icons/grass2/layer-his-add.png">
+ see <em><a href="d.rgb.html">d.rgb</a></em>.</dd>
+ <dt><img src="icons/grass2/layer-his-add.png">
<em>Add HIS raster layer</em></dt>
<dd>Combines and displays two or three raster maps defined as hue,
intensity, and (optionally) saturation channels to create a color map,
- see <em><a href="d.his.html">d.his</a></em>.</dd></li>
- <li><dt><img src="icons/grass2/layer-cell-cats-add.png">
+ see <em><a href="d.his.html">d.his</a></em>.</dd>
+ <dt><img src="icons/grass2/layer-cell-cats-add.png">
<em>Add raster arrows layer</em></dt>
<dd>Adds map of raster cells with directional arrows drawn. Arrow
direction and length are determined by separate aspect/directional map
and (optional) slope/intensity map,
- see <em><a href="d.rast.arrow.html">d.rast.arrow</a></em>.</dd></li>
+ see <em><a href="d.rast.arrow.html">d.rast.arrow</a></em>.</dd>
<em>Add raster numbers layer</em></dt>
<dd>Adds map of raster cells with numbers representing the cell values,
- see <em><a href="d.rast.num.html">d.rast.num</a></em>.</dd></li>
- </ul>
+ see <em><a href="d.rast.num.html">d.rast.num</a></em>.</dd>
+ </dl>
<dt><img src="icons/grass2/layer-vector-add.png">
<em>Add vector map layer</em></dt>
@@ -171,8 +171,8 @@
<em>Add various vector-based map layers </em></dt>
- <ul>
- <li><dt><img src="icons/grass2/layer-vector-thematic-add.png">
+ <dl>
+ <dt><img src="icons/grass2/layer-vector-thematic-add.png">
<em>Add thematic map layer
(for all vector types)</em></dt>
<dd>Adds layer for thematic display values from a numeric attribute
@@ -183,17 +183,17 @@
color schemes, creation of legend for thematic map, and saving the
results of thematic mapping to a ps.map instructions file for later
printing,
- see <em><a href="d.vect.thematic.html">d.vect.thematic</a></em>.</dd></li>
+ see <em><a href="d.vect.thematic.html">d.vect.thematic</a></em>.</dd>
- <li><dt><img src="icons/grass2/layer-vector-chart-add.png">
+ <dt><img src="icons/grass2/layer-vector-chart-add.png">
<em>Add thematic charts layer (for vector points)</em></dt>
<dd>Adds layer in which pie or bar charts can be automatically created
at vector point locations. Charts display values from selected columns
in the associated attribute table. Options include: chart type, layer
and attributes to chart, chart colors, and chart size (fixed or based
on attribute column),
- see <em><a href="d.vect.chart.html">d.vect.chart</a></em>.</dd></li>
- </ul>
+ see <em><a href="d.vect.chart.html">d.vect.chart</a></em>.</dd>
+ </dl>
<dt><img src="icons/grass2/layer-command-add.png">
<em>Add command layer</em></dt>
@@ -220,29 +220,29 @@
<em>Add grid or vector labels overlay</em></dt>
- <ul>
- <li><dt><img src="icons/grass2/layer-grid-add.png">
+ <dl>
+ <dt><img src="icons/grass2/layer-grid-add.png">
<em>Add overlay grids and lines</em></dt>
<dd>Adds layer to display regular grid (for all locations)
- see <em><a href="d.grid.html">d.grid</a></em></dd></li>
+ see <em><a href="d.grid.html">d.grid</a></em></dd>
- <li><dt><img src="icons/grass2/layer-label-add.png">
+ <dt><img src="icons/grass2/layer-label-add.png">
<em>Add labels layer for vector objects (from existing labels file)</em></dt>
<dd>Add a layer of text from a labels file for vector objects
created with the <em><a href="v.label.html">v.label</a></em> module.
A labels file can also be created with a text editor,
- see <em><a href="d.labels.html">d.labels</a></em>.</dd></li>
+ see <em><a href="d.labels.html">d.labels</a></em>.</dd>
- <li><dt><img src="icons/grass/module-d.geodesic.gif">
+ <dt><img src="icons/grass/module-d.geodesic.gif">
<em>Add geodesic line layer</em></dt>
<dd>Add layer to display geodesic line for latitude/longitude locations only,
- see <em><a href="d.geodesic.html">d.geodesic</a></em></dd></li>
+ see <em><a href="d.geodesic.html">d.geodesic</a></em></dd>
<em>Add rhumbline layer</em>
<dd>Add layer to display rhumblines (for latitude/longitude locations only),
- see <em><a href="d.rhumbline.html">d.rhumbline</a></em>.</dd></li>
- </ul>
+ see <em><a href="d.rhumbline.html">d.rhumbline</a></em>.</dd>
+ </dl>
<dt><img src="icons/grass2/layer-remove.png">
<em>Delete selected layer</em></dt>
@@ -342,14 +342,14 @@
<em>Query raster/vector maps</em></dt>
<ul>
- <li><dd>Query selected raster, RGB raster (all three map channels will be
+ <li>Query selected raster, RGB raster (all three map channels will be
queried), or vector map(s) using the mouse. Map(s) must be selected
before query. Vector charts and thematic vector maps cannot be
queried. The results of the query will be displayed in the console window,
-see <em><a href="r.what.html">r.what</a>, <a href="v.what.html">v.what</a></em>.</dd></li>
- <li><dd>Query selected vector map in edit mode. The results of the query
+see <em><a href="r.what.html">r.what</a>, <a href="v.what.html">v.what</a></em>.</li>
+ <li>Query selected vector map in edit mode. The results of the query
will be displayed in a form that permits editing of the queried vector
- attributes.</dd></li>
+ attributes.</li>
</ul>
<dt><img src="icons/grass2/pan.png">
@@ -401,7 +401,7 @@
<li>Zoom to match the extents of a saved region</li>
<li>Set computational region (the mapset's <tt>WIND</tt> file) to match the
current display extents (does not change the resolution),
- see <em><a href="g.region.html">g.region</a></em>.</dd>
+ see <em><a href="g.region.html">g.region</a></em>.
<li>Save display geometry (current extents) to a named region file</li>
</ul>
@@ -409,53 +409,53 @@
<em>Analyze menu</em></dt>
<dd>Opens a dropdown menu with:<br>
- <ul>
- <li> <dt><img src="icons/grass2/measure-length.png">
+ <dl>
+ <dt><img src="icons/grass2/measure-length.png">
<em>Distance measurement tool</em></dt>
<dd>Interactive measurement of lengths defined with the mouse. The
length of each segment and the cumulative length of all segments
measuered is displayed in the command output window frame. Lengths are
measured in the current measurement unit,
- see <em><a href="d.measure.html">d.measure</a></em>.</dd></li>
+ see <em><a href="d.measure.html">d.measure</a></em>.</dd>
- <li><dt><img src="icons/grass2/layer-raster-profile.png">
+ <dt><img src="icons/grass2/layer-raster-profile.png">
<em>Profile tool</em></dt>
<dd>Interactively create profile of a raster map. Profile transect is
drawn with the mouse in map display. The profile may be of the
displayed map or a different map. Up to three maps can be profiled
simultaneously,
- see <em><a href="gm_profile.html">Profile Tool help page</a></em>.</dd></li>
+ see <em><a href="gm_profile.html">Profile Tool help page</a></em>.</dd>
- <li><dt><img src="icons/grass2/layer-raster-histogram.png">
+ <dt><img src="icons/grass2/layer-raster-histogram.png">
<em>Histogram tool</em></dt>
<dd>Displays histogram of selected raster map or image in new window,
- see <em><a href="d.histogram.html">d.histogram</a></em>.</dd></li>
- </ul>
+ see <em><a href="d.histogram.html">d.histogram</a></em>.</dd>
+ </dl>
<dt><img src="icons/grass2/overlay-add.png">
<em>Add overlay</em></dt>
<dd>opens a dropdown menu that allows user to:<br>
- <ul>
- <li> <dt><img src="icons/grass2/scalebar-add.png">
+ <dl>
+ <dt><img src="icons/grass2/scalebar-add.png">
<em>Add scalebar and north arrow</em></dt>
<dd>Adds layer to display a combined scalebar and north arrow. Options
include scalebar placement (using screen coordinates or a mouse),
scalebar format, and scalebar colors,
- see <em><a href="d.barscale.html">d.barscale</a></em>.</dd></li>
+ see <em><a href="d.barscale.html">d.barscale</a></em>.</dd>
- <li><dt><img src="icons/grass2/legend-add.png">
+ <dt><img src="icons/grass2/legend-add.png">
<em>Add raster map legend</em></dt>
<dd>Adds layer to display with legend of selected raster map,
- see <em><a href="d.legend.html">d.legend</a></em>.</dd></li>
+ see <em><a href="d.legend.html">d.legend</a></em>.</dd>
- <li><dt><img src="icons/grass2/text-add.png">
+ <dt><img src="icons/grass2/text-add.png">
<em>Add text layer</em></dt>
<dd>Adds layer to display a line of text using default GRASS font
(selected with <em><a href="d.font.html">d.font</a></em>). Options
include: text placement (screen coordinates); and text size, bolding,
- and color, see <em><a href="d.text.html">d.text</a></em>.</dd></li>
- </ul>
+ and color, see <em><a href="d.text.html">d.text</a></em>.</dd>
+ </dl>
<dt><img src="icons/grass2/map-export.png">
<em>Save display to graphic file</em></dt>
@@ -466,28 +466,26 @@
<dd>Prints map on system native printer or PostScript device;
saves visible map display (including PostScript text and labels) to PDF
or EPS file.</dd>
-<br>
<dt><em>Map display mode</em></dt>
<dd>Opens a dropdown menu for selecting different display mode<br>
- <ul>
- <li><dt><em>2D view mode</em></dt>
+ <dl>
+ <dt><em>2D view mode</em></dt>
<dd>Normal GIS display. All active layers are composited and displayed
- in 2D mode.</dd></li>
+ in 2D mode.</dd>
- <li><dt><em>3D view mode</em></dt>
+ <dt><em>3D view mode</em></dt>
<dd>Experimental replacement for NVIZ. Displays all active layers in
3D perspective using OpenGL. A new control panel opens to manage the
3D view. 3D view can be zoomed, panned, rotated, and tilted. The
vertical exaggeration of rasters and 3D vectors can be set. Various
color and lighten settings are possible. Not yet functional for
- Windows platforms</dd></li>
+ Windows platforms</dd>
- <li><dt><em>Digitize mode</em></dt>
+ <dt><em>Digitize mode</em></dt>
<dd>Puts display into vector digitizing mode and opens a new digitizing
toolbar. The user can digitize a new map or edit an existing
- map. Not yet functional for Windows platforms</dd></li>
- </ul>
+ map. Not yet functional for Windows platforms</dd>
+ </dl>
</dl>
<h2>CONFIGURATION</h2>
