[GRASS-SVN] r38944 - grass/trunk/lib/vector
svn_grass at osgeo.org
Wed Sep 2 05:01:04 EDT 2009
Author: martinl
Date: 2009-09-02 05:01:03 -0400 (Wed, 02 Sep 2009)
New Revision: 38944
grass/trunk/lib/vector/vectorlib.dox
vectorlib.dox: some more info merged from GRASS 5 PM
Modified: grass/trunk/lib/vector/vectorlib.dox
--- grass/trunk/lib/vector/vectorlib.dox 2009-09-02 06:28:32 UTC (rev 38943)
+++ grass/trunk/lib/vector/vectorlib.dox 2009-09-02 09:01:03 UTC (rev 38944)
@@ -7,12 +7,14 @@
- \subpage background
- \subpage intro
- \subpage vector_map
+ - \subpage vector_map_levels
- \subpage directory_structure
- \subpage head_file_format
- \subpage categories_layers
- \subpage attributes
- \subpage dbln_file_format
- \subpage vlibs
+ - \subpage vlib_history
- \subpage vlib_structures
- \subpage Map_info
- \subpage Plus_head
@@ -132,6 +134,38 @@
touching the boundaries of the outer area. Isles consist of one or more areas
and are used internally by the vector libraries to maintain correct topology of areas.
+\subsubsection vector_map_levels Levels of read access
+There are two levels of read access to the vector data:
+- <i>Level One</i> provides simple access to the vector feature
+ information. There is no access to topology information at this
+ level.
+- <i>Level Two</i> provides full access to all the information
+ including topology information. This level requires more from the
+ programmer, more momory, and longer startup time.
+Level of access is retured by Vect_open_old().
+Note: Higher level of access are planned, so when checking success
+return codes for a particular level of access (when calling
+Vect_open_old() for example), the programmer should use >= instead of
+== for compatibility with future releases.
+An existing vector map can be open for reading by Vect_open_old(). New
+vector map can be created (or open for writing) by
+Vect_open_new(). Vect_open_old() attempts to open a vector map at the
+highest possible level of access. It will return the number of the
+level at which it opened. Vect_open_new() always opens at level 1
+only. If you require that a vector map be opened at a lower level
+(e.g. one), you can call the routine Vect_set_open_level(1);
+Vect_open_old() will then either open at level one or fail. If you
+instead require the highest level access possible, you should not use
+Vect_set_open_level(), but instead check the return value of
+Vect_open_old() to make sure it is greater than or equal to the lowest
+level at which you need access. This allows for future levels to work
+without need for module change.
\subsubsection directory_structure Directory structure
Vector map is stored in a number of data files. Vector map directory
@@ -383,11 +417,60 @@
<i>Note: For details please read Blazek et al. 2002 (see below) as
well as the references in this document.</i>
+\subsection vlib_history Historical notes
+The vector library in GRASS 4.0 changed significantly from the
+<b>Digit Library</b> (diglib) used in GRASS 3.1. Below is an overview
+of why the changes were made.
+The Digit Library was a collage of subroutines created for developing
+the map development programs. Few of these subroutines were actually
+designed as a user access library. They required individuals to assume
+too much responsibility and control over what happened to the data
+file. Thus when it came time to change vector data file formats for
+GRASS 4.0, many modules also required modification. The two different
+access levels for 3.0 vector files provided very different ways of
+calling the library; they offered little consistency for the user.
+The Digit Library was originally designed to only have one file open
+for read or write at a time. Although it was possible in some cases to
+get around this, one restriction was the global head structure. Since
+there was only one instance of this, there could only be one copy of
+that information, and thus, only one open vector file.
+The solution to these problems was to design a new user library as an
+interface to the vector data files. This new library was designed to
+provide a simple consistent interface, which hides as much of the
+details of the data format as possible. It also could be extended for
+future enhancements without the need to change existing programs.
+The new vector library in GRASS 4 provided routines for opening,
+closing, reading, and writing vector files, as well as several support
+functions. The Digit Library has been replaced, so that all existing
+modules was converted to use the new library. Those routines that
+existed in the Digit Library and were not affected by these changes
+continue to exist in unmodified form, and were included in the vector
+library. Most of the commonly used routines have been discarded, and
+replaced by the new vector routines.
+Instead the global head structure was used own local version of
+it. The structure that replaced struct head is struct dig_head. There
+were still two levels of interface to the vector files (future
+releases may include more). Level one provided access only to arc
+(i.e. polyline) information and to the type of line (AREA, LINE,
+DOT). Level two provided access to polygons (areas), attributes, and
+network topology.
\section vlib_structures Vector library structures
\subsection Map_info Map_info structure
-<tt>Map_info</tt> structure holds basic information about open vector map.
+The token that is used to identify each vector map is the Map_info
+structure. It maintains all information about an individual open
+vector map. The structure must be passed to the mosy vector library
+routines.
\code
struct Map_info
@@ -975,8 +1058,11 @@
\endcode
-\subsection topo_levels Topology levels
+\subpage topo_levels Topology levels
+The vector library defines more <i>topology levels</i> (only for level
+of access 2):
\code
#define GV_BUILD_NONE 0
#define GV_BUILD_BASE 1
