[GRASS-SVN] r38955 - grass/trunk/lib/vector
Thu Sep 3 05:53:30 EDT 2009
Author: martinl
Date: 2009-09-03 05:53:30 -0400 (Thu, 03 Sep 2009)
New Revision: 38955
   grass/trunk/lib/vector/vectorlib.dox
vectorlib.dox cosmetics (internal link)
Modified: grass/trunk/lib/vector/vectorlib.dox
--- grass/trunk/lib/vector/vectorlib.dox	2009-09-03 09:42:23 UTC (rev 38954)
+++ grass/trunk/lib/vector/vectorlib.dox	2009-09-03 09:53:30 UTC (rev 38955)
@@ -4,55 +4,55 @@
 <b>Table of contents</b>
-- \subpage background
-- \subpage intro
- - \subpage vector_map
-  - \subpage vector_map_levels
-  - \subpage directory_structure
-  - \subpage head_file_format
- - \subpage categories_layers
- - \subpage attributes
-  - \subpage dbln_file_format
+- \subpage vlibBackground
+- \subpage vlibIntro
+ - \subpage vlibVectorMap
+  - \subpage vlibVectorLevels
+  - \subpage vlibDirectoryStructure
+  - \subpage vlibHeadFileFormat
+ - \subpage vlibCategoriesLayers
+ - \subpage vlibAttributes
+  - \subpage vlibDblnFileFormat
 - \subpage vlibs
- - \subpage vlib_history
-- \subpage vlib_structures
- - \subpage Map_info
- - \subpage Plus_head
- - \subpage dig_head
-- \subpage feature_geom
- - \subpage ftypes
- - \subpage coor_file_format
-  - \subpage coor_file_head
-  - \subpage coor_file_body
-- \subpage topology_management
- - \subpage topo_file_format
-  - \subpage topo_file_header
-  - \subpage topo_file_body
- - \subpage topo_levels
- - \subpage topo_examples
- - \subpage topo_memory
-- \subpage spidx
- - \subpage sidx_file_format
-- \subpage cidx
- - \subpage cidx_file_format
-  - \subpage cidx_file_head
-- \subpage tin
-- \subpage ogr_iface
- - \subpage frmt_file_format
- - \subpage fidx_file_format
-- \subpage grassdglib
-- \subpage ascii
+ - \subpage vlibHistory
+- \subpage vlibStructures
+ - \subpage vlibMap_info
+ - \subpage vlibPlus_head
+ - \subpage vlibDig_head
+- \subpage vlibGeometry
+ - \subpage vlibFeatureTypes
+ - \subpage vlibCoorFileFormat
+  - \subpage vlibCoorFileHead
+  - \subpage vlibCoorFileBody
+- \subpage vlibTopoManagement
+ - \subpage vlibTopoFileFormat
+  - \subpage vlibTopoFileHead
+  - \subpage vlibTopoFileBody
+ - \subpage vlibTopoLevels
+ - \subpage vlibTopoExamples
+ - \subpage vlibTopoMemory
+- \subpage vlibSpidx
+ - \subpage vlibSidxFileFormat
+- \subpage vlibCidx
+ - \subpage vlibCidxFileFormat
+  - \subpage vlibCidxFileHead
+- \subpage vlibTin
+- \subpage vlibOgrIface
+ - \subpage vlibFrmtFileFormat
+ - \subpage vlibFidxFileFormat
+- \subpage vlibDglib
+- \subpage vlibAscii
-- \subpage vlibfunc
+- \subpage vlibFunc
-- \subpage authors
+- \subpage vlibAuthors
-- \subpage references
+- \subpage vlibReferences
-- \subpage seealso
+- \subpage vlibSeealso
-\section background Background
+\section vlibBackground Background
 Generally, the vector data model is used to describe geographic
 phenomena which may be represented by geometric entities like points,
@@ -65,7 +65,7 @@
 vector data maintenance.
-\section intro Introduction
+\section vlibIntro Introduction
 The GRASS 6/7 vector format is very similar to the previous GRASS 4.x
 (5.0/5.3) vector format.
@@ -99,7 +99,7 @@
       library and drivers (\ref attributes);
-\subsection vector_map Vector map
+\subsection vlibVectorMap Vector map
 GRASS vector maps are stored in an <em>arc-node</em> representation,
 consisting of curves called arcs. An arc is stored as a series of
@@ -134,7 +134,7 @@
 touching the boundaries of the outer area. Isles consist of one or more areas
 and are used internally by the vector libraries to maintain correct topology of areas.
-\subsubsection vector_map_levels Levels of read access
+\subsubsection vlibVectorLevels Levels of read access
 There are two levels of read access to the vector data:
@@ -166,7 +166,7 @@
 level at which you need access. This allows for future levels to work
 without need for module change.
-\subsubsection directory_structure Directory structure
+\subsubsection vlibDirectoryStructure Directory structure
 Vector map is stored in a number of data files. Vector map directory
 structure and file names were changed in GRASS 6 with respect to
@@ -189,7 +189,7 @@
 - <b>frmt</b> - text file, format description (external format only)
 - <b>fidx</b> - binary file, feature index (OGR format only)
-\subsubsection head_file_format Head file format specification
+\subsubsection vlibHeadFileFormat Head file format specification
 The header contains historical information, a description of the
 vector map and many other information. The file is an unordered list
@@ -208,7 +208,7 @@
 <tr><td>MAP THRESH</td><td>digitizing threshold</td></tr>
 </table>
-\subsection categories_layers Categories and layers
+\subsection vlibCategoriesLayers Categories and layers
 <i>Note: "layer" was called "field" in earlier version.</i>
@@ -238,7 +238,7 @@
 Categories start with 1 (category '0' is allowed for OGR
 layers). Categories do not have to be continuous.
-\subsection attributes Attributes
+\subsection vlibAttributes Attributes
 The old GRASS 4.x 'dig_cats' files are not used any more and vectors'
 attributes are stored in external database. Connection with the
@@ -271,7 +271,7 @@
 The general DBMI settings are defined in the '$MAPSET/VAR' text file
 (maintained with <tt>db.connect</tt> command at user level).
-\subsection dbln_file_format Dbln file format specification
+\subsection vlibDblnFileFormat Dbln file format specification
 Each vector maps has its own DBMI settings stored in the
 '$MAPSET/vector/vector_name/dbln' text file. For each pair <b>vector map +
@@ -417,7 +417,7 @@
 <i>Note: For details please read Blazek et al. 2002 (see below) as
 well as the references in this document.</i>
-\subsection vlib_history Historical notes
+\subsection vlibHistory Historical notes
 The vector library in GRASS 4.0 changed significantly from the
 <b>Digit Library</b> (diglib) used in GRASS 3.1. Below is an overview
@@ -463,9 +463,9 @@
-\section vlib_structures Vector library structures
+\section vlibStructures Vector library structures
-\subsection Map_info Map_info structure
+\subsection vlibMap_info Map_info structure
 The token that is used to identify each vector map is the Map_info
 structure. It maintains all information about an individual open
@@ -545,7 +545,7 @@
 \endcode
-\subsection Plus_head Plus_head structure
+\subsection vlibPlus_head Plus_head structure
 <tt>Plus_head</tt> holds basic topology-related information about vector map.
@@ -689,7 +689,7 @@
 \endcode
-\subsection dig_head dig_head structure
+\subsection vlibDig_head dig_head structure
 <tt>dig_head</tt> holds header data of vector map (see \ref Map_info).
@@ -730,7 +730,7 @@
 \endcode
-\section feature_geom Vector library feature geometry
+\section vlibGeometry Vector library feature geometry
 \subsection ftypes Feature types
@@ -753,13 +753,13 @@
 couple of modules including NVIZ to visualize 3D buildings and other
 volumetric figures.
-\subsection coor_file_format Coor file format specification
+\subsection vlibCoorFileFormat Coor file format specification
 In the coor file the following is stored: 'line' (element) type,
 number of attributes and layer number for each category. Coordinates
 in binary file are stored as double (8 bytes).
-\subsubsection coor_file_head Header
+\subsubsection vlibCoorFileHead Header
 <table border="1" style="border-collapse: collapse">
 <tr><td>Name</td><td>Type</td><td>Number</td><td>Description</td></tr>
@@ -782,7 +782,7 @@
 </table>
-\subsubsection coor_file_body Body
+\subsubsection vlibCoorFileBody Body
 The body consists of line records:
@@ -829,7 +829,7 @@
 <tr><td>C</td><td>Char  </td><td>1</td></tr>
 </table>
-\section topology_management Vector library topology management
+\section vlibTopoManagement Vector library topology management
 Topology general characteristics:
@@ -868,11 +868,11 @@
 Vector map topology can be cleaned at user level by <tt>v.clean</tt>
 command.
-\subsection topo_file_format Topo file format specification
+\subsection vlibTopoFileFormat Topo file format specification
 Topo file is read by Vect_open_topo().
-\subsubsection topo_file_header Header
+\subsubsection vlibTopoFileHead Header
 Note: <tt>plus</tt> is instance of <tt>Plus_head</tt> structure.
@@ -908,7 +908,7 @@
 <tr><td>plus->coor_size</td><td>L</td><td>1</td><td>File size</td></tr>
 </table>
-\subsubsection topo_file_body Body (nodes, lines, areas, isles)
+\subsubsection vlibTopoFileBody Body (nodes, lines, areas, isles)
 <b>Nodes</b>
@@ -1058,7 +1058,7 @@
 \endcode
-\subpage topo_levels Topology levels
+\subpage vlibTopoLevels Topology levels
 The vector library defines more <i>topology levels</i> (only for level
 of access 2):
@@ -1075,9 +1075,9 @@
 GV_BOUNDARY contains geometry and it is used to build areas.
 GV_LINE cannot form an area.
-\subsection topo_examples Topology examples
+\subsection vlibTopoExamples Topology examples
-\subsubsection Topology_Example_1 Topology Example 1
+\subsubsection vlibTopoExample1 Topology Example 1
 A polygon may be formed by many boundaries (more primitives but connected).
 One boundary is shared by adjacent areas.
@@ -1094,7 +1094,7 @@
 \endverbatim
-\subsubsection Topology_Example_2 Topology Example 2
+\subsubsection vlibTopoExample2 Topology Example 2
 This is handled correctly in GRASS: A can be filled, B filled differently.
@@ -1115,7 +1115,7 @@
 only 2 areas A and B and no island.
-\subsubsection Topology_Example_3 Topology Example 3
+\subsubsection vlibTopoExample3 Topology Example 3
 This is handled correctly in GRASS: Areas A1, A2, and A3 can be filled differently.
@@ -1138,7 +1138,7 @@
 above can be exported from GRASS as polygon A1 with inner ring I1.
-\subsubsection Topology_Example_4 Topology Example 4
+\subsubsection vlibTopoExample4 Topology Example 4
 v.in.ogr/v.clean can identify dangles and change the type from boundary
 to line (in TIGER data for example).
@@ -1162,7 +1162,7 @@
 area/centroid, instead of 4 which would be necessary in TIGER.
-\subsection topo_memory Topology memory management
+\subsection vlibtopoMemory Topology memory management
 Topology is generated for all kinds of vector types.  Memory is not
 released by default. The programmer can force the library to release
@@ -1181,7 +1181,7 @@
 spatial index without topology.
-\section spidx Vector library spatial index management
+\section vlibSpidx Vector library spatial index management
 Spatial index (based on R-tree) is created with topology.
@@ -1249,11 +1249,11 @@
 \endcode
-\subsection sidx_file_format Sidx file format specification
+\subsection vlibSidxFileFormat Sidx file format specification
 Spatial index file ('sidx') is read by Vect_open_sidx().
-\subsubsection sidx_file_header Header
+\subsubsection vlibSidxFileHead Header
@@ -1333,7 +1333,7 @@
 </table>
-\section cidx Vector library category index management
+\section vlibSidx Vector library category index management
 The category index (stored in the cidx file) improves the performance of all
 selections by cats/attributes (SQL, e.g. 'd.vect cats=27591', 'v.extract list=20000-21000').
@@ -1371,11 +1371,11 @@
 To create category index, it will be necessary to rebuild topology for all existing vectors.
 This is an opportunity to make (hopefully) last changes in 'topo', 'cidx' formats.
-\subsection cidx_file_format Cidx file format specification
+\subsection vlibCidxFileFormat Cidx file format specification
 Category index file ('cidx') is read by Vect_cidx_open().
-\subsubsection cidx_file_head Header
+\subsubsection vlibCidxFileHead Header
@@ -1410,15 +1410,15 @@
 </table>
-\section tin Vector TINs
+\section vlibTin Vector TINs
 TINs are simply created as 2D/3D vector polygons consisting of
 3 vertices. See Vect_tin_get_z().
-\section ogr_iface OGR interface
+\section vlibOgrIface OGR interface
-\subsection frmt_file_format Frmt file format specification
+\subsection vlibFrmtFileFormat Frmt file format specification
 Frmt is a plain text file which contains basic information about
 external format of linked vector map. Each line contains key, value
@@ -1443,7 +1443,7 @@
 file ('sidx') and category index file ('cidx'). Additionally also
 feature index file (see \ref fidx_file_format) is created.
-\subsection fidx_file_format Fidx file format specification
+\subsection vlibFidxFileFormat Fidx file format specification
 Note: <tt>finfo</tt> is an instance of <tt>Format_info</tt> structure.
@@ -1468,7 +1468,7 @@
 </table>
-\section grassdglib DGLib (Directed Graph Library)
+\section vlibDglib DGLib (Directed Graph Library)
 <b>The Directed Graph Library</b> or DGLib (Micarelli 2002, \ref dglib ,
 http://grass.osgeo.org/dglib/) provides functionality for vector network
@@ -1498,7 +1498,7 @@
  Vect_net_shortest_path_coor().
-\section ascii Vector ASCII Format Specifications
+\section vlibAscii Vector ASCII Format Specifications
 The GRASS ASCII vector map format may contain a mix of primitives
 including points, lines, boundaries, centroids, faces, and
@@ -1610,7 +1610,7 @@
 boundary and the centroid form an area with category number 2. All
 vector feature mentioned above are located in layer 1.
-\section vlibfunc List of vector library functions
+\section vlibFunc List of vector library functions
 The vector library provides the GRASS programmer with routines to
 process vector data. The routines in the vector library are presented
@@ -1628,55 +1628,55 @@
 The Vect_*() functions are the programmer's API for GRASS vector
 programming. The programmer should use only routines with this prefix.
-- \subpage area
-- \subpage array
-- \subpage box
-- \subpage break_lines
-- \subpage break_polygons
-- \subpage bridges
-- \subpage buffer
-- \subpage build
-- \subpage build_nat
-- \subpage build_ogr
-- \subpage cats
-- \subpage cindex
-- \subpage clean_nodes
-- \subpage close
-- \subpage constraint
-- \subpage dangles
-- \subpage dbcolumns
-- \subpage error
-- \subpage field
-- \subpage find
-- \subpage graph
-- \subpage header
-- \subpage hist
-- \subpage init_head
-- \subpage intersect
-- \subpage legal_vname
-- \subpage level
-- \subpage level_two
-- \subpage line
-- \subpage list
-- \subpage map
-- \subpage net
-- \subpage open
-- \subpage overlay
-- \subpage vpoly
-- \subpage read
-- \subpage remove_areas
-- \subpage remove_duplicates
-- \subpage rewind
-- \subpage select
-- \subpage sindex
-- \subpage snap
-- \subpage tin
-- \subpage type
-- \subpage delete
-- \subpage write
+- \subpage vlibArea
+- \subpage vlibArray
+- \subpage vlibBox
+- \subpage vlibBreakLines
+- \subpage vlibBreakPolygons
+- \subpage vlibBridges
+- \subpage vlibBuffer
+- \subpage vlibBuild
+- \subpage vlibBuildNat
+- \subpage vlibBuildOgr
+- \subpage vlibCats
+- \subpage vlibCindex
+- \subpage vlibCleanNodes
+- \subpage vlibClose
+- \subpage vlibConstraint
+- \subpage vlibDangles
+- \subpage vlibDbcolumns
+- \subpage vlibError
+- \subpage vlibField
+- \subpage vlibFind
+- \subpage vlibGraph
+- \subpage vlibHeader
+- \subpage vlibHist
+- \subpage vlibInit_head
+- \subpage vlibIntersect
+- \subpage vlibLegalVname
+- \subpage vlibLevel
+- \subpage vlibLevelTwo
+- \subpage vlibLine
+- \subpage vlibList
+- \subpage vlibMap
+- \subpage vlibNet
+- \subpage vlibOpen
+- \subpage vlibOverlay
+- \subpage vlibVpoly
+- \subpage vlibRead
+- \subpage vlibRemoveAreas
+- \subpage vlibRemoveDuplicates
+- \subpage vlibRewind
+- \subpage vlibSelect
+- \subpage vlibSindex
+- \subpage vlibSnap
+- \subpage vlibTin
+- \subpage vlibType
+- \subpage vlibDelete
+- \subpage vlibWrite
-\section area Vector area functions
+\section vlibArea Vector area functions
  - Vect_get_area_area()
@@ -1701,7 +1701,7 @@
  - Vect_point_in_area()
-\section array Vector array functions
+\section vlibArray Vector array functions
  - Vect_new_varray()
@@ -1712,7 +1712,7 @@
  - Vect_set_varray_from_db()
-\section box Vector bounding box functions
+\section vlibBox Vector bounding box functions
  - Vect_box_copy()
@@ -1735,33 +1735,33 @@
  - Vect_region_box()
-\section break_lines Vector break lines functions
+\section vlibBreakLines Vector break lines functions
  - Vect_break_lines()
  - Vect_break_lines_list()
-\section break_polygons Vector break polygons functions
+\section vlibBreakPolygons Vector break polygons functions
  - Vect_break_polygons()
-\section bridges Vector bridges functions
+\section vlibBridges Vector bridges functions
  - Vect_chtype_bridges()
  - Vect_remove_bridges()
-\section buffer Vector buffer functions
+\section vlibBuffer Vector buffer functions
  - Vect_line_buffer()
  - Vect_line_parallel()
-\section build Vector build functions
+\section vlibBuild Vector build functions
  - Vect_build()
@@ -1782,7 +1782,7 @@
  - Vect_topo_dump()
-\subsection build_nat Vector build (native) functions
+\subsection vlibBuildNat Vector build (native) functions
  - Vect_attach_centroids()
@@ -1797,12 +1797,12 @@
  - Vect_isle_find_area()
-\subsection build_ogr Vector build (OGR) functions
+\subsection vlibBuildOgr Vector build (OGR) functions
  - Vect_build_ogr()
-\section cats Vector categories functions
+\section vlibCats Vector categories functions
  - Vect_array_to_cat_list()
@@ -1837,7 +1837,7 @@
  - Vect_str_to_cat_list()
-\section cindex Vector category index functions
+\section vlibCindex Vector category index functions
 (note: vector layer is historically called "field")
@@ -1872,17 +1872,17 @@
  - Vect_set_category_index_update()
-\section clean_nodes Vector clean nodes functions
+\section vlibCleanNodes Vector clean nodes functions
  - Vect_clean_small_angles_at_nodes()
-\section close Vector close functions
+\section vlibClose Vector close functions
  - Vect_close()
-\section constraint Vector constraint functions
+\section vlibConstraint Vector constraint functions
  - Vect_get_constraint_box()
@@ -1893,7 +1893,7 @@
  - Vect_set_constraint_type()
-\section dangles Vector dangles functions
+\section vlibDangles Vector dangles functions
  - Vect_chtype_dangles()
@@ -1902,7 +1902,7 @@
  - Vect_select_dangles()
-\section dbcolumns Vector dbcolumns functions
+\section vlibDbcolumns Vector dbcolumns functions
  - Vect_get_column_names()
@@ -1911,14 +1911,14 @@
  - Vect_get_column_types()
-\section error Vector error functions
+\section vlibError Vector error functions
  - Vect_get_fatal_error()
  - Vect_set_fatal_error()
-\section field Vector field functions
+\section vlibField Vector field functions
@@ -1953,7 +1953,7 @@
  - Vect_write_dblinks()
-\section find Vector find functions
+\section vlibFind Vector find functions
  - Vect_find_area()
@@ -1966,7 +1966,7 @@
  - Vect_find_node()
-\section graph Vector graph functions
+\section vlibGraph Vector graph functions
  - Vect_graph_add_edge()
@@ -1979,7 +1979,7 @@
  - Vect_graph_shortest_path()
-\section header Vector header functions
+\section vlibHeader Vector header functions
  - Vect_get_comment()
@@ -2038,7 +2038,7 @@
  - Vect_write_header()
-\section hist Vector history functions
+\section vlibHist Vector history functions
  - Vect_hist_command()
@@ -2051,12 +2051,12 @@
  - Vect_hist_write()
-\section init_head Vector header functions
+\section vlibInitHead Vector header functions
  - Vect_copy_head_data()
-\section intersect Vector intersection functions
+\section vlibIntersect Vector intersection functions
  - Vect_line_check_intersection()
@@ -2065,19 +2065,19 @@
  - Vect_segment_intersection()
-\section legal_vname Vector valid map name functions
+\section vlibLegalVname Vector valid map name functions
  - Vect_check_input_output_name()
  - Vect_legal_filename()
-\section level Vector level functions
+\section vlibLevel Vector level functions
  - Vect_level()
-\section level_two Vector topological (level 2) functions
+\section vlibLevelTwo Vector topological (level 2) functions
  - Vect_get_centroid_area()
@@ -2118,7 +2118,7 @@
  - Vect_set_release_support()
-\section line Vector feature functions
+\section vlibLine Vector feature functions
  - Vect_append_point()
@@ -2163,7 +2163,7 @@
  - Vect_reset_line()
-\section list Vector list functions
+\section vlibList Vector list functions
  - Vect_destroy_list()
@@ -2182,7 +2182,7 @@
  - Vect_val_in_list()
-\section map Vector map functions
+\section vlibMap Vector map functions
  - Vect_copy()
@@ -2199,7 +2199,7 @@
  - Vect_rename()
-\section net Vector network functions
+\section vlibNet Vector network functions
  - Vect_net_build_graph()
@@ -2214,7 +2214,7 @@
  - Vect_net_shortest_path_coor()
-\section open Vector open functions
+\section vlibOpen Vector open functions
  - Vect_coor_info()
@@ -2238,16 +2238,14 @@
  - Vect_set_open_level()
+\section vlibOverlay Vector overlay functions
-\section overlay Vector overlay functions
  - Vect_overlay()
  - Vect_overlay_str_to_operator()
-\section vpoly Vector polygon functions
+\section vlibVpoly Vector polygon functions
  - Vect_find_poly_centroid()
@@ -2262,13 +2260,13 @@
  - Vect_get_point_in_poly_isl()
-\section read Vector read functions
+\section vlibRead Vector read functions
-\subsection read1_2 Level 1 and 2
+\subsection vlibread1_2 Level 1 and 2
  - Vect_read_next_line()
-\subsection read2 Level 2 only
+\subsection vlibRead2 Level 2 only
  - Vect_area_alive()
@@ -2281,24 +2279,24 @@
  - Vect_read_line()
-\section remove_areas Vector remove areas functions
+\section vlibRemoveAreas Vector remove areas functions
  - Vect_remove_small_areas()
-\section remove_duplicates Vector remove duplicates functions
+\section vlibRemoveDuplicates Vector remove duplicates functions
  - Vect_line_check_duplicate()
  - Vect_remove_duplicates()
-\section rewind Vector rewind functions
+\section vlibRewind Vector rewind functions
  - Vect_rewind()
-\section sindex Vector spatial index functions
+\section vlibSindex Vector spatial index functions
  - Vect_select_areas_by_box()
@@ -2313,7 +2311,7 @@
  - Vect_select_nodes_by_box()
-\section select custom spatial index functions
+\section vlibSelect custom spatial index functions
  - Vect_spatial_index_add_item()
@@ -2326,40 +2324,40 @@
  - Vect_spatial_index_select()
-\section snap Vector snap functions
+\section vlibSnap Vector snap functions
  - Vect_snap_lines()
  - Vect_snap_lines_list()
-\section tin Vector TIN functions
+\section vlibTin Vector TIN functions
  - Vect_tin_get_z()
-\section type Vector type option functions
+\section vlibType Vector type option functions
  - Vect_option_to_types()
-\section delete Vector delete functions
+\section vlibDelete Vector delete functions
-\subsection delete2 Level 2 only
+\subsection vlibDelete2 Level 2 only
  - Vect_delete_line()
-\section write Vector write functions
+\section vlibWrite Vector write functions
-\subsection write1_2 Level 1 and 2
+\subsection vlibWrite1_2 Level 1 and 2
  - Vect_write_line()
-\subsection write2 Level 2 only
+\subsection vlibWrite2 Level 2 only
  - Vect_rewrite_line()
-\section geos GEOS support
+\section vlibGeos GEOS support
 Note: The functions are available only if GRASS is compiled with
 <tt>--with-geos</tt> switch.
@@ -2375,21 +2373,21 @@
  - Vect_get_isle_points_geos()
-\section authors Authors
+\section vlibAuthors Authors
  Radim Blazek (vector architecture) <radim.blazek gmail.com>
  Roberto Micarelli (DGLib) <mi.ro iol.it>
-\section references References
+\section vlibReferences References
 Text based on: R. Blazek, M. Neteler, and R. Micarelli. The new GRASS 5.1
  vector architecture. In Open source GIS - GRASS users conference 2002,
  Trento, Italy, 11-13 September 2002. University of Trento, Italy, 2002.
  <a href="http://www.ing.unitn.it/~grass/conferences/GRASS2002/proceedings/proceedings/pdfs/Blazek_Radim.pdf">http://www.ing.unitn.it/~grass/conferences/GRASS2002/proceedings/proceedings/pdfs/Blazek_Radim.pdf</a>
-\section seealso See Also
+\section vlibSeealso See Also
  - \ref dglib
