[GRASS-SVN] r38967 - grass/branches/develbranch_6/lib/vector/Vlib
Fri Sep 4 10:19:24 EDT 2009
Author: benducke
Date: 2009-09-04 10:19:24 -0400 (Fri, 04 Sep 2009)
New Revision: 38967
   grass/branches/develbranch_6/lib/vector/Vlib/level_two.c
Added implementations for API functions to get number of kernels, volumes and holes for a vector map
Modified: grass/branches/develbranch_6/lib/vector/Vlib/level_two.c
--- grass/branches/develbranch_6/lib/vector/Vlib/level_two.c	2009-09-04 14:16:54 UTC (rev 38966)
+++ grass/branches/develbranch_6/lib/vector/Vlib/level_two.c	2009-09-04 14:19:24 UTC (rev 38967)
@@ -84,6 +84,19 @@
+   \brief Fetch number of kernels in vector map
+   \param map vector map
+   \return number of kernels
+int Vect_get_num_kernels(struct Map_info *map)
+    return (map->plus.n_klines);
    \brief Get number of faces in vector map
@@ -95,7 +108,21 @@
     return (map->plus.n_flines);
+   \brief Fetch number of volumes in vector map
+   \return number of volumes
+int Vect_get_num_volumes(struct Map_info *map)
+    return (map->plus.n_volumes);
    \brief Get number of islands in vector map
@@ -107,7 +134,21 @@
     return (map->plus.n_isles);
+   \brief Fetch number of holes in vector map
+   \return number of holes
+int Vect_get_num_holes(struct Map_info *map)
+    return (map->plus.n_holes);
    \brief Get number of defined dblinks
