[GRASS-SVN] r38994 - grass/trunk/vector/v.info
Sat Sep 5 13:10:22 EDT 2009
Author: martinl
Date: 2009-09-05 13:10:21 -0400 (Sat, 05 Sep 2009)
New Revision: 38994
Added:
   grass/trunk/vector/v.info/level1.c
   grass/trunk/vector/v.info/local_proto.h
   grass/trunk/vector/v.info/parse.c
   grass/trunk/vector/v.info/print.c
   grass/trunk/vector/v.info/main.c
   grass/trunk/vector/v.info/v.info.html
v.info: major clean up
Added: grass/trunk/vector/v.info/level1.c
--- grass/trunk/vector/v.info/level1.c	                        (rev 0)
+++ grass/trunk/vector/v.info/level1.c	2009-09-05 17:10:21 UTC (rev 38994)
@@ -0,0 +1,88 @@
+#include <grass/glocale.h>
+#include "local_proto.h"
+/* code taken from Vect_build_nat() */
+int level_one_info(struct Map_info *Map)
+    struct Plus_head *plus;
+    int i, type, first = 1;
+    off_t offset;
+    struct line_pnts *Points;
+    struct line_cats *Cats;
+    struct bound_box box;
+    int n_primitives, n_points, n_lines, n_boundaries, n_centroids, n_kernels;
+    G_debug(1, "Count vector objects for level 1");
+    plus = &(Map->plus);
+    n_primitives = n_points = n_lines = n_boundaries = n_centroids = n_kernels = 0;
+    Points = Vect_new_line_struct();
+    Cats = Vect_new_cats_struct();
+    Vect_rewind(Map);
+    /* G_message(_("Registering primitives...")); */
+    i = 1;
+    while (1) {
+	/* register line */
+	type = Vect_read_next_line(Map, Points, Cats);
+	/* Note: check for dead lines is not needed, because they are skipped by V1_read_next_line_nat() */
+	if (type == -1) {
+	    G_warning(_("Unable to read vector map"));
+	    return 0;
+	else if (type == -2) {
+	    break;
+	/* count features */
+	n_primitives++;
+	if (type & GV_POINT)  /* probably most common */
+	    n_points++;
+	else if (type & GV_LINE)
+	    n_lines++;
+	else if (type & GV_BOUNDARY)
+	    n_boundaries++;
+	else if (type & GV_CENTROID)
+	    n_centroids++;
+	else if (type & GV_KERNEL)
+	    n_kernels++;
+	offset = Map->head.last_offset;
+	G_debug(3, "Register line: offset = %lu", (unsigned long)offset);
+	dig_line_box(Points, &box);
+	if (first == 1) {
+	    Vect_box_copy(&(plus->box), &box);
+	    first = 0;
+	else
+	    Vect_box_extend(&(plus->box), &box);
+	/* can't print progress, unfortunately */
+	if (G_verbose() > G_verbose_min() && i % 1000 == 0) {
+	    if (format == G_INFO_FORMAT_PLAIN)
+		fprintf(stderr, "%d..", i);
+	    else
+		fprintf(stderr, "%11d\b\b\b\b\b\b\b\b\b\b\b", i);
+	i++;
+    /* save result in plus */
+    plus->n_lines = n_primitives;
+    plus->n_plines = n_points;
+    plus->n_llines = n_lines;
+    plus->n_blines = n_boundaries;
+    plus->n_clines = n_centroids;
+    plus->n_klines = n_kernels;
+    return 1;
Property changes on: grass/trunk/vector/v.info/level1.c
___________________________________________________________________
Added: svn:mime-type
   + text/x-csrc
Added: svn:keywords
   + Author Date Id
Added: svn:eol-style
   + native
Added: grass/trunk/vector/v.info/local_proto.h
--- grass/trunk/vector/v.info/local_proto.h	                        (rev 0)
+++ grass/trunk/vector/v.info/local_proto.h	2009-09-05 17:10:21 UTC (rev 38994)
@@ -0,0 +1,16 @@
+#include <grass/vector.h>
+/* level1.c */
+int level_one_info(struct Map_info *);
+/* parse.c */
+void parse_args(int, char**,
+		char **, char**,
+		int *, int *, int *, int *, int *, int *);
+/* print.c */
+void format_double(double, char *);
+void print_region(const struct Map_info *);
+void print_topo(const struct Map_info *);
+void print_columns(const struct Map_info *, const char *, const char *);
+void print_info(const struct Map_info *);
Property changes on: grass/trunk/vector/v.info/local_proto.h
   + text/x-chdr
Added: svn:keywords
   + Author Date Id
   + native
Modified: grass/trunk/vector/v.info/main.c
--- grass/trunk/vector/v.info/main.c	2009-09-05 17:05:59 UTC (rev 38993)
+++ grass/trunk/vector/v.info/main.c	2009-09-05 17:10:21 UTC (rev 38994)
@@ -1,62 +1,36 @@
  * MODULE:       v.info
  * AUTHOR(S):    CERL, updated to 5.7 by Markus Neteler
+ *               Update to 7.0 by Martin Landa
+ *               Support for level 1 by Markus Metz (2009)
- * PURPOSE:      print vector map info
+ * PURPOSE:      Print vector map info
- * COPYRIGHT:    (C) 2002 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2002-2009 by the GRASS Development Team
- *               This program is free software under the
- *               GNU General Public License (>=v2).
- *               Read the file COPYING that comes with GRASS
- *               for details.
+ *               This program is free software under the GNU General
+ *               Public License (>=v2).  Read the file COPYING that
+ *               comes with GRASS for details.
-#include <string.h>
-#include <stdlib.h>
 #include <grass/gis.h>
-#include <grass/dbmi.h>
-#define printline(x) fprintf (stdout, " | %-74.74s |\n", x)
-#define divider(x) \
-	fprintf (stdout, " %c", x); \
-	for (i = 0; i < 76; i++ ) \
-		fprintf ( stdout, "-" ); \
-	fprintf (stdout, "%c\n", x)
-/* the vector header is here:
-   include/vect/dig_structs.h
-   the vector API is here:
-   lib/vector/Vlib/level_two.c
-void format_double(double, char *);
-int level_one_info(struct Map_info *);
 int main(int argc, char *argv[])
     struct GModule *module;
-    struct Option *in_opt, *fieldopt;
-    struct Flag *histf, *columns, *gflag, *tflag, *mflag, *lflag;
-    struct Map_info Map;
-    struct bound_box box;
-    char line[200], buf[1001];
-    int i;
-    int with_z;
-    struct field_info *fi;
-    dbDriver *driver = NULL;
-    dbHandle handle;
-    dbString table_name;
-    dbTable *table;
-    int field, num_dblinks, ncols, col;
-    char tmp1[100], tmp2[100];
+    char *input_opt, *field_opt;
+    int hist_flag, col_flag, reg_flag, topo_flag, title_flag, level1_flag;
+    struct Map_info Map;
     G_gisinit(argv[0]);
     module = G_define_module();
@@ -64,282 +38,53 @@
     G_add_keyword(_("metadata"));
     G_add_keyword(_("history"));
     module->description =
-	_("Outputs basic information about a user-specified vector map.");
+	_("Outputs basic information about a vector map.");
-    /* get G_OPT_ from include/gis.h */
-    in_opt = G_define_standard_option(G_OPT_V_MAP);
+    parse_args(argc, argv,
+	       &input_opt, &field_opt,
+	       &hist_flag, &col_flag, &reg_flag, &topo_flag, &title_flag, &level1_flag);
-    fieldopt = G_define_standard_option(G_OPT_V_FIELD);
-    histf = G_define_flag();
-    histf->key = 'h';
-    histf->description = _("Print vector history instead of info");
-    histf->guisection = _("Print");
-    columns = G_define_flag();
-    columns->key = 'c';
-    columns->description =
-	_("Print types/names of table columns for specified layer instead of info");
-    columns->guisection = _("Print");
-    gflag = G_define_flag();
-    gflag->key = 'g';
-    gflag->description = _("Print map region only");
-    gflag->guisection = _("Print");
-    mflag = G_define_flag();
-    mflag->key = 'm';
-    mflag->description = _("Print map title only");
-    mflag->guisection = _("Print");
-    tflag = G_define_flag();
-    tflag->key = 't';
-    tflag->description = _("Print topology information only");
-    tflag->guisection = _("Print");
-    lflag = G_define_flag();
-    lflag->key = 'l';
-    lflag->description = _("Open Vector without topology (level 1)");
-    if (G_parser(argc, argv))
-	exit(EXIT_FAILURE);
-    if (lflag->answer) {
+    if (level1_flag) {
 	Vect_set_open_level(1); /* no topology */
-	tflag->answer = 0;
+	if (topo_flag)
+	    G_warning(_("Vector map requested on level1 (flag -t ignored)"));
+	topo_flag = 0;
     else
 	Vect_set_open_level(2); /* topology requested */
-	Vect_open_old(&Map, in_opt->answer, "");
+	Vect_open_old(&Map, input_opt, "");      /* level 1 */
 	level_one_info(&Map);
     else
-	Vect_open_old_head(&Map, in_opt->answer, "");
+	Vect_open_old_head(&Map, input_opt, ""); /* level 2 */
-    with_z = Vect_is_3d(&Map);
-    if (histf->answer) {
+    if (hist_flag) {
+	char buf[1001];
 	Vect_hist_rewind(&Map);
 	while (Vect_hist_read(buf, 1000, &Map) != NULL) {
 	    fprintf(stdout, "%s\n", buf);
-    else if (mflag->answer) {
+    else if (title_flag) {
 	fprintf(stdout, "%s\n", Vect_get_map_name(&Map));
-    else if (gflag->answer || tflag->answer) {
-	if (gflag->answer) {
-	    Vect_get_map_box(&Map, &box);
-	    G_format_northing(box.N, tmp1, Vect_get_proj(&Map));
-	    G_format_northing(box.S, tmp2, Vect_get_proj(&Map));
-	    fprintf(stdout, "north=%s\n", tmp1);
-	    fprintf(stdout, "south=%s\n", tmp2);
-	    G_format_easting(box.E, tmp1, Vect_get_proj(&Map));
-	    G_format_easting(box.W, tmp2, Vect_get_proj(&Map));
-	    fprintf(stdout, "east=%s\n", tmp1);
-	    fprintf(stdout, "west=%s\n", tmp2);
-	    fprintf(stdout, "top=%f\n", box.T);
-	    fprintf(stdout, "bottom=%f\n", box.B);
+    else if (reg_flag || topo_flag) {
+	if (reg_flag) {
+	    print_region(&Map);
-	if (tflag->answer) {
-	    long int nprimitives = 0;
-	    nprimitives += (long)Vect_get_num_primitives(&Map, GV_POINT);
-	    nprimitives += (long)Vect_get_num_primitives(&Map, GV_LINE);
-	    nprimitives += (long)Vect_get_num_primitives(&Map, GV_BOUNDARY);
-	    nprimitives += (long)Vect_get_num_primitives(&Map, GV_FACE);
-	    nprimitives += (long)Vect_get_num_primitives(&Map, GV_CENTROID);
-	    nprimitives += (long)Vect_get_num_primitives(&Map, GV_KERNEL);
-	    fprintf(stdout, "nodes=%ld\n", (long)Vect_get_num_nodes(&Map));
-	    fflush(stdout);
-	    fprintf(stdout, "points=%ld\n",
-		    (long)Vect_get_num_primitives(&Map, GV_POINT));
-	    fflush(stdout);
-	    fprintf(stdout, "lines=%ld\n",
-		    (long)Vect_get_num_primitives(&Map, GV_LINE));
-	    fflush(stdout);
-	    fprintf(stdout, "boundaries=%ld\n",
-		    (long)Vect_get_num_primitives(&Map, GV_BOUNDARY));
-	    fflush(stdout);
-	    fprintf(stdout, "centroids=%ld\n",
-		    (long)Vect_get_num_primitives(&Map, GV_CENTROID));
-	    fflush(stdout);
-	    fprintf(stdout, "areas=%ld\n", (long)Vect_get_num_areas(&Map));
-	    fflush(stdout);
-	    fprintf(stdout, "islands=%ld\n",
-		    (long)Vect_get_num_islands(&Map));
-	    fflush(stdout);
-	    fprintf(stdout, "faces=%ld\n",
-		    (long)Vect_get_num_primitives(&Map, GV_FACE));
-	    fflush(stdout);
-	    fprintf(stdout, "kernels=%ld\n",
-		    (long)Vect_get_num_primitives(&Map, GV_KERNEL));
-	    fflush(stdout);
-	    fprintf(stdout, "primitives=%ld\n", nprimitives);
-	    fflush(stdout);
-	    fprintf(stdout, "map3d=%d\n", Vect_is_3d(&Map));
-	    fflush(stdout);
+	if (topo_flag) {
+	    print_topo(&Map);
     else {
-	if (columns->answer) {
-	    num_dblinks = Vect_get_num_dblinks(&Map);
-	    if (num_dblinks <= 0) {
-		G_fatal_error(_("Database connection for map <%s> is not defined in DB file"),
-			      in_opt->answer);
-	    else {		/* num_dblinks > 0 */
-		field = atoi(fieldopt->answer);
-		G_message(_("Displaying column types/names for database connection of layer %d:"),
-			  field);
-		if ((fi = Vect_get_field(&Map, field)) == NULL)
-		    G_fatal_error(_("Database connection not defined for layer %d"),
-				  field);
-		driver = db_start_driver(fi->driver);
-		if (driver == NULL)
-		    G_fatal_error(_("Unable to open driver <%s>"),
-				  fi->driver);
-		db_init_handle(&handle);
-		db_set_handle(&handle, fi->database, NULL);
-		if (db_open_database(driver, &handle) != DB_OK)
-		    G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
-			fi->database, fi->driver);
-		db_init_string(&table_name);
-		db_set_string(&table_name, fi->table);
-		if (db_describe_table(driver, &table_name, &table) != DB_OK)
-		    G_fatal_error(_("Unable to describe table <%s>"),
-				  fi->table);
-		ncols = db_get_table_number_of_columns(table);
-		for (col = 0; col < ncols; col++)
-		    fprintf(stdout, "%s|%s\n",
-			    db_sqltype_name(db_get_column_sqltype
-					    (db_get_table_column
-					     (table, col))),
-			    db_get_column_name(db_get_table_column
-					       (table, col)));
-		db_close_database(driver);
-		db_shutdown_driver(driver);
+	if (col_flag) {
+	    print_columns(&Map, input_opt, field_opt);
 	else {
-	    divider('+');
-	    sprintf(line, _("Layer:           %s"), Vect_get_name(&Map));
-	    printline(line);
-	    sprintf(line, _("Mapset:          %s"), Vect_get_mapset(&Map));
-	    printline(line);
-	    sprintf(line, _("Location:        %s"), G_location());
-	    printline(line);
-	    sprintf(line, _("Database:        %s"), G_gisdbase());
-	    printline(line);
-	    sprintf(line, _("Title:           %s"), Vect_get_map_name(&Map));
-	    printline(line);
-	    sprintf(line, _("Map scale:       1:%d"), Vect_get_scale(&Map));
-	    printline(line);
-	    sprintf(line, _("Map format:      %s"), Vect_maptype_info(&Map));
-	    printline(line);
-	    sprintf(line, _("Name of creator: %s"), Vect_get_person(&Map));
-	    printline(line);
-	    sprintf(line, _("Organization:    %s"),
-		    Vect_get_organization(&Map));
-	    printline(line);
-	    sprintf(line, _("Source date:     %s"), Vect_get_map_date(&Map));
-	    printline(line);
-	    divider('|');
-	    sprintf(line, _("  Type of Map:  %s (level: %i)        "),
-		    _("vector"), Vect_level(&Map));
-	    printline(line);
-	    if (Vect_level(&Map) > 0) {
-		printline("");
-		sprintf(line,
-			_("  Number of points:       %-9ld       Number of areas:      %-9ld"),
-			(long)Vect_get_num_primitives(&Map, GV_POINT),
-			(long)Vect_get_num_areas(&Map));
-		printline(line);
-		sprintf(line,
-			_("  Number of lines:        %-9ld       Number of islands:    %-9ld"),
-			(long)Vect_get_num_primitives(&Map, GV_LINE),
-		printline(line);
-		sprintf(line,
-			_("  Number of boundaries:   %-9ld       Number of faces:      %-9ld"),
-			(long)Vect_get_num_primitives(&Map, GV_BOUNDARY),
-		printline(line);
-		sprintf(line,
-			_("  Number of centroids:    %-9ld       Number of kernels:    %-9ld"),
-			(long)Vect_get_num_primitives(&Map, GV_CENTROID),
-		printline(line);
-		printline("");
-		sprintf(line, _("  Map is 3D:              %s"),
-			Vect_is_3d(&Map) ? "Yes" : "No");
-		printline(line);
-		sprintf(line, _("  Number of dblinks:      %-9ld"),
-			(long)Vect_get_num_dblinks(&Map));
-		printline(line);
-	    printline("");
-	    /* this differs from r.info in that proj info IS taken from the map here, not the location settings */
-	    /* Vect_get_proj_name() and _zone() are typically unset?! */
-	    if (G_projection() == PROJECTION_UTM)
-		sprintf(line, _("        Projection: %s (zone %d)"),
-			Vect_get_proj_name(&Map), Vect_get_zone(&Map));
-	    else
-		sprintf(line, _("        Projection: %s"),
-			Vect_get_proj_name(&Map));
-	    printline(line);
-	    G_format_northing(box.N, tmp1, G_projection());
-	    G_format_northing(box.S, tmp2, G_projection());
-	    sprintf(line, "              N: %17s    S: %17s", tmp1, tmp2);
-	    printline(line);
-	    G_format_easting(box.E, tmp1, G_projection());
-	    G_format_easting(box.W, tmp2, G_projection());
-	    sprintf(line, "              E: %17s    W: %17s", tmp1, tmp2);
-	    printline(line);
-	    if (Vect_is_3d(&Map)) {
-		format_double(box.B, tmp1);
-		format_double(box.T, tmp2);
-		sprintf(line, "              B: %17s    T: %17s", tmp1, tmp2);
-		printline(line);
-	    printline("");
-	    format_double(Vect_get_thresh(&Map), tmp1);
-	    sprintf(line, _("  Digitization threshold: %s"), tmp1);
-	    printline(line);
-	    sprintf(line, _("  Comments:"));
-	    printline(line);
-	    sprintf(line, "    %s", Vect_get_comment(&Map));
-	    printline(line);
-	    divider('+');
-	    fprintf(stdout, "\n");
+	    print_info(&Map);
@@ -348,95 +93,3 @@
     return (EXIT_SUCCESS);
-/* cloned from lib/gis/wind_format.c */
-void format_double(double value, char *buf)
-    sprintf(buf, "%.8f", value);
-    G_trim_decimal(buf);
-/* code taken from Vect_build_nat() */
-int level_one_info(struct Map_info *Map)
-    struct Plus_head *plus;
-    int i, type, first = 1;
-    off_t offset;
-    struct line_pnts *Points;
-    struct line_cats *Cats;
-    int n_primitives, n_points, n_lines, n_boundaries, n_centroids, n_kernels;
-    G_debug(1, "Count vector objects for level 1");
-    plus = &(Map->plus);
-    n_primitives = n_points = n_lines = n_boundaries = n_centroids = n_kernels = 0;
-    Points = Vect_new_line_struct();
-    Cats = Vect_new_cats_struct();
-    Vect_rewind(Map);
-    /* G_message(_("Registering primitives...")); */
-    i = 1;
-    while (1) {
-	/* register line */
-	type = Vect_read_next_line(Map, Points, Cats);
-	/* Note: check for dead lines is not needed, because they are skipped by V1_read_next_line_nat() */
-	if (type == -1) {
-	    G_warning(_("Unable to read vector map"));
-	    return 0;
-	else if (type == -2) {
-	    break;
-	/* count features */
-	n_primitives++;
-	if (type & GV_POINT)  /* probably most common */
-	    n_points++;
-	else if (type & GV_LINE)
-	    n_lines++;
-	else if (type & GV_BOUNDARY)
-	    n_boundaries++;
-	else if (type & GV_CENTROID)
-	    n_centroids++;
-	else if (type & GV_KERNEL)
-	    n_kernels++;
-	offset = Map->head.last_offset;
-	G_debug(3, "Register line: offset = %lu", (unsigned long)offset);
-	dig_line_box(Points, &box);
-	if (first == 1) {
-	    Vect_box_copy(&(plus->box), &box);
-	    first = 0;
-	else
-	    Vect_box_extend(&(plus->box), &box);
-	/* can't print progress, unfortunately */
-	if (G_verbose() > G_verbose_min() && i % 1000 == 0) {
-	    if (format == G_INFO_FORMAT_PLAIN)
-		fprintf(stderr, "%d..", i);
-	    else
-		fprintf(stderr, "%11d\b\b\b\b\b\b\b\b\b\b\b", i);
-	i++;
-    /* save result in plus */
-    plus->n_lines = n_primitives;
-    plus->n_plines = n_points;
-    plus->n_llines = n_lines;
-    plus->n_blines = n_boundaries;
-    plus->n_clines = n_centroids;
-    plus->n_klines = n_kernels;
-    return 1;
Added: grass/trunk/vector/v.info/parse.c
--- grass/trunk/vector/v.info/parse.c	                        (rev 0)
+++ grass/trunk/vector/v.info/parse.c	2009-09-05 17:10:21 UTC (rev 38994)
@@ -0,0 +1,59 @@
+#include <grass/gis.h>
+void parse_args(int argc, char** argv,
+		char** input, char** field,
+		int* history, int* columns, int* region, int* topo, int* title, int* level1)
+    struct Option *input_opt, *field_opt;
+    struct Flag *hist_flag, *col_flag, *region_flag, *topo_flag, *title_flag, *level1_flag;
+    input_opt = G_define_standard_option(G_OPT_V_MAP);
+    field_opt = G_define_standard_option(G_OPT_V_FIELD);
+    hist_flag = G_define_flag();
+    hist_flag->key = 'h';
+    hist_flag->description = _("Print vector history instead of info");
+    hist_flag->guisection = _("Print");
+    col_flag = G_define_flag();
+    col_flag->key = 'c';
+    col_flag->description =
+	_("Print types/names of table columns for specified layer instead of info");
+    col_flag->guisection = _("Print");
+    region_flag = G_define_flag();
+    region_flag->key = 'g';
+    region_flag->description = _("Print map region only");
+    region_flag->guisection = _("Print");
+    title_flag = G_define_flag();
+    title_flag->key = 'm';
+    title_flag->description = _("Print map title only");
+    title_flag->guisection = _("Print");
+    topo_flag = G_define_flag();
+    topo_flag->key = 't';
+    topo_flag->description = _("Print topology information only");
+    topo_flag->guisection = _("Print");
+    level1_flag = G_define_flag();
+    level1_flag->key = 'l';
+    level1_flag->description = _("Open Vector without topology (level 1)");
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    *input = G_store(input_opt->answer);
+    *field = G_store(field_opt->answer);
+    *history = hist_flag-> answer ? 1 : 0;
+    *columns = col_flag-> answer ? 1 : 0;
+    *region  = region_flag-> answer ? 1 : 0;
+    *title   = title_flag-> answer ? 1 : 0;
+    *topo    = topo_flag-> answer ? 1 : 0;
+    *level1  = level1_flag-> answer ? 1 : 0;
Property changes on: grass/trunk/vector/v.info/parse.c
   + text/x-csrc
Added: svn:keywords
   + Author Date Id
   + native
Added: grass/trunk/vector/v.info/print.c
--- grass/trunk/vector/v.info/print.c	                        (rev 0)
+++ grass/trunk/vector/v.info/print.c	2009-09-05 17:10:21 UTC (rev 38994)
@@ -0,0 +1,312 @@
+#include <stdlib.h>
+#include <string.h>
+#include <grass/dbmi.h>
+#define printline(x) fprintf (stdout, " | %-74.74s |\n", x)
+#define divider(x) \
+	fprintf (stdout, " %c", x); \
+	for (i = 0; i < 76; i++ ) \
+		fprintf ( stdout, "-" ); \
+	fprintf (stdout, "%c\n", x)
+/* cloned from lib/gis/wind_format.c */
+void format_double(double value, char *buf)
+    sprintf(buf, "%.8f", value);
+    G_trim_decimal(buf);
+void print_region(const struct Map_info *Map)
+    char tmp1[100], tmp2[100];
+    Vect_get_map_box(Map, &box);
+    G_format_northing(box.N, tmp1, Vect_get_proj(Map));
+    G_format_northing(box.S, tmp2, Vect_get_proj(Map));
+    fprintf(stdout, "north=%s\n", tmp1);
+    fprintf(stdout, "south=%s\n", tmp2);
+    G_format_easting(box.E, tmp1, Vect_get_proj(Map));
+    G_format_easting(box.W, tmp2, Vect_get_proj(Map));
+    fprintf(stdout, "east=%s\n", tmp1);
+    fprintf(stdout, "west=%s\n", tmp2);
+    fprintf(stdout, "top=%f\n", box.T);
+    fprintf(stdout, "bottom=%f\n", box.B);
+void print_topo(const struct Map_info *Map)
+    int with_z;
+    long nprimitives;
+    nprimitives = 0;
+    with_z = Vect_is_3d(Map);
+    nprimitives += Vect_get_num_primitives(Map, GV_POINT);
+    nprimitives += Vect_get_num_primitives(Map, GV_LINE);
+    nprimitives += Vect_get_num_primitives(Map, GV_BOUNDARY);
+    nprimitives += Vect_get_num_primitives(Map, GV_CENTROID);
+    if (with_z) {
+	nprimitives += Vect_get_num_primitives(Map, GV_FACE);
+	nprimitives += Vect_get_num_primitives(Map, GV_KERNEL);
+    fprintf(stdout, "nodes=%ld\n",
+	    Vect_get_num_nodes(Map));
+    fflush(stdout);
+    fprintf(stdout, "points=%ld\n",
+	    Vect_get_num_primitives(Map, GV_POINT));
+    fflush(stdout);
+    fprintf(stdout, "lines=%ld\n",
+	    Vect_get_num_primitives(Map, GV_LINE));
+    fflush(stdout);
+    fprintf(stdout, "boundaries=%ld\n",
+	    Vect_get_num_primitives(Map, GV_BOUNDARY));
+    fflush(stdout);
+    fprintf(stdout, "centroids=%ld\n",
+	    Vect_get_num_primitives(Map, GV_CENTROID));
+    fflush(stdout);
+    fprintf(stdout, "areas=%ld\n", Vect_get_num_areas(Map));
+    fflush(stdout);
+    fprintf(stdout, "islands=%ld\n",
+	    Vect_get_num_islands(Map));
+    fflush(stdout);
+    if (with_z) {
+	fprintf(stdout, "faces=%ld\n",
+		Vect_get_num_primitives(Map, GV_FACE));
+	fflush(stdout);
+	fprintf(stdout, "kernels=%ld\n",
+		Vect_get_num_primitives(Map, GV_KERNEL));
+	fflush(stdout);
+	fprintf(stdout, "volumes=%ld\n",
+		Vect_get_num_primitives(Map, GV_VOLUME));
+	fflush(stdout);
+	fprintf(stdout, "holes=%ld\n",
+		Vect_get_num_holes(Map));
+	fflush(stdout);
+    fprintf(stdout, "primitives=%ld\n", nprimitives);
+    fflush(stdout);
+    fprintf(stdout, "map3d=%d\n", Vect_is_3d(Map));
+    fflush(stdout);
+void print_columns(const struct Map_info *Map, const char *input_opt, const char *field_opt)
+    int num_dblinks, field, col, ncols;
+    struct field_info *fi;
+    dbDriver *driver = NULL;
+    dbHandle handle;
+    dbString table_name;
+    dbTable *table;
+    num_dblinks = Vect_get_num_dblinks(Map);
+    if (num_dblinks <= 0) {
+	G_fatal_error(_("Database connection for map <%s> is not defined in DB file"),
+		      input_opt);
+    field = atoi(field_opt);
+    G_message(_("Displaying column types/names for database connection of layer %d:"),
+	      field);
+    if ((fi = Vect_get_field(Map, field)) == NULL)
+	G_fatal_error(_("Database connection not defined for layer %d"),
+		      field);
+    driver = db_start_driver(fi->driver);
+    if (driver == NULL)
+	G_fatal_error(_("Unable to open driver <%s>"),
+		      fi->driver);
+    db_init_handle(&handle);
+    db_set_handle(&handle, fi->database, NULL);
+    if (db_open_database(driver, &handle) != DB_OK)
+	G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+		      fi->database, fi->driver);
+    db_init_string(&table_name);
+    db_set_string(&table_name, fi->table);
+    if (db_describe_table(driver, &table_name, &table) != DB_OK)
+	G_fatal_error(_("Unable to describe table <%s>"),
+		      fi->table);
+    ncols = db_get_table_number_of_columns(table);
+    for (col = 0; col < ncols; col++)
+	fprintf(stdout, "%s|%s\n",
+		db_sqltype_name(db_get_column_sqltype
+				(db_get_table_column
+				 (table, col))),
+		db_get_column_name(db_get_table_column
+				   (table, col)));
+    db_close_database(driver);
+    db_shutdown_driver(driver);
+void print_info(const struct Map_info *Map)
+    int i;
+    char line[100];
+    divider('+');
+    sprintf(line, "%-17s%s", _("Name:"),
+	    Vect_get_name(Map));
+    printline(line);
+    sprintf(line, "%-17s%s", _("Mapset:"),
+	    Vect_get_mapset(Map));
+    printline(line);
+    sprintf(line, "%-17s%s", _("Location:"),
+	    G_location());
+    printline(line);
+    sprintf(line, "%-17s%s", _("Database:"),
+	    G_gisdbase());
+    printline(line);
+    sprintf(line, "%-17s%s", _("Title:"),
+	    Vect_get_map_name(Map));
+    printline(line);
+    sprintf(line, "%-17s1:%d", _("Map scale:"),
+	    Vect_get_scale(Map));
+    printline(line);
+    sprintf(line, "%-17s%s", _("Map format:"),
+	    Vect_maptype_info(Map));
+    printline(line);
+    sprintf(line, "%-17s%s", _("Name of creator:"),
+	    Vect_get_person(Map));
+    printline(line);
+    sprintf(line, "%-17s%s", _("Organization:"),
+	    Vect_get_organization(Map));
+    printline(line);
+    sprintf(line, "%-17s%s", _("Source date:"),
+	    Vect_get_map_date(Map));
+    printline(line);
+    divider('|');
+    sprintf(line, "  %s: %s (%s: %i)",
+	    _("Type of map"), _("vector"), _("level"), Vect_level(Map));
+    printline(line);
+    if (Vect_level(Map) > 0) {
+	printline("");
+	sprintf(line,
+		"  %-24s%-9ld       %-22s%-9ld",
+		_("Number of points:"),
+		Vect_get_num_primitives(Map, GV_POINT),
+		_("Number of centroids:"),
+	printline(line);
+	sprintf(line,
+		_("Number of lines:"),
+		Vect_get_num_primitives(Map, GV_LINE),
+		_("Number of boundaries:"),
+	printline(line);
+	sprintf(line,
+		_("Number of areas:"),
+		Vect_get_num_areas(Map),
+		_("Number of islands:"),
+	printline(line);
+	if (Vect_is_3d(Map)) {
+	    sprintf(line,
+		    _("Number of faces:"),
+		    Vect_get_num_primitives(Map, GV_FACE),
+		    _("Number of kernels:"),
+	    printline(line);
+	    sprintf(line,
+		    _("Number of volumes:"),
+		    Vect_get_num_volumes(Map),
+		    _("Number of holes:"),
+	    printline(line);
+	printline("");
+	sprintf(line, "  %-24s%s",
+		_("Map is 3D:"),
+		Vect_is_3d(Map) ? _("Yes") : _("No"));
+	printline(line);
+	sprintf(line, "  %-24s%-9d",
+		_("Number of dblinks:"),
+		Vect_get_num_dblinks(Map));
+	printline(line);
+    printline("");
+    /* this differs from r.info in that proj info IS taken from the map here, not the location settings */
+    /* Vect_get_proj_name() and _zone() are typically unset?! */
+    if (G_projection() == PROJECTION_UTM)
+	sprintf(line, "  %s: %s (%s %d)",
+		_("Projection:"),
+		Vect_get_proj_name(Map),
+		_("zone"), Vect_get_zone(Map));
+    else
+	sprintf(line, "  %s: %s",
+		_("Projection"),
+		Vect_get_proj_name(Map));
+    printline(line);
+    printline("");
+    G_format_northing(box.N, tmp1, G_projection());
+    G_format_northing(box.S, tmp2, G_projection());
+    sprintf(line, "              %c: %17s    %c: %17s",
+	    'N', tmp1, 'S', tmp2);
+    printline(line);
+    G_format_easting(box.E, tmp1, G_projection());
+    G_format_easting(box.W, tmp2, G_projection());
+	    'E', tmp1, 'W', tmp2);
+    printline(line);
+	format_double(box.B, tmp1);
+	format_double(box.T, tmp2);
+		'B', tmp1, 'T', tmp2);
+	printline(line);
+    printline("");
+    format_double(Vect_get_thresh(Map), tmp1);
+    sprintf(line, "  %s: %s", _("Digitization threshold"), tmp1);
+    printline(line);
+    sprintf(line, "  %s:", _("Comment"));
+    printline(line);
+    sprintf(line, "    %s", Vect_get_comment(Map));
+    printline(line);
+    divider('+');
+    fprintf(stdout, "\n");
Property changes on: grass/trunk/vector/v.info/print.c
   + text/x-csrc
Added: svn:keywords
   + Author Date Id
   + native
Modified: grass/trunk/vector/v.info/v.info.html
--- grass/trunk/vector/v.info/v.info.html	2009-09-05 17:05:59 UTC (rev 38993)
+++ grass/trunk/vector/v.info/v.info.html	2009-09-05 17:10:21 UTC (rev 38994)
@@ -1,49 +1,57 @@
 <h2>DESCRIPTION</h2>
-<em>v.info</em> reports some basic information about a
-user-specified vector map layer and the topology status.
+<em>v.info</em> reports some basic information (metadata) about a
+user-specified vector map and its topology status.
 <p>
-Vector are opened without topology on level 1 when the <b>-l</b> flag is
-used. With the <b>-l</b> flag set, vector map extends and number of
-features need to be counted on the fly which may take some time.
+Vector map is opened without topology (i.e., on level 1) when
+the <b>-l</b> flag is used. With the <b>-l</b> flag set, vector map
+extends and number of features need to be counted on the fly which may
+take some time.
 <h2>EXAMPLE</h2>
 <div class="code"><pre>
-v.info map=test
+v.info map=geology
- | Mapset:   PERMANENT                      Organization: GRASS Team          |
- | Layer:    test                           Source Date:                      |
- | Orig. Scale: 1:1                                                           |
- | Location: spearfish                      Name of creator: GRASSUSER        |
- | DataBase: /home/user/grassdata                                             |
- | Title:        |
- | Map format: native                                                         |
+ | Name:            geology                                                   |
+ | Mapset:          PERMANENT                                                 |
+ | Location:        nc_spm_08                                                 |
+ | Database:        /home/martin/grassdata                                    |
+ | Title:           North Carolina geology map (polygon map)                  |
+ | Map scale:       1:1                                                       |
+ | Map format:      native                                                    |
+ | Name of creator: helena                                                    |
+ | Organization:    NC OneMap                                                 |
+ | Source date:     Mon Nov  6 15:48:53 2006                                  |
- |   Type of Map:  Vector (level: 2)                                          |
- |                                          Number of points:     7           |
- |                                          Number of lines:      1386        |
- |                                          Number of centroids:  0           |
- |                                          Number of areas:      0           |
- |                                          Number of faces:      0           |
- |                                          Number of kernels:    0           |
- |                                          Number of islands:    0           |
- |                                          Map is 3D:            0           |
- |                                          Number of dblinks:    1           |
- |   Projection: Transverse Mercator (zone 0)                                 |
- |            N: 5945486.383    S: 5941117.075                                |
- |            E: 3573006.924    W: 3567822.941                                |
- |            B: 0.000     T: 0.000                                           |
+ |   Type of map: vector (level: 2)                                           |
- |   Digitize threshold: 0.00000                                              |
- |   Comments:        |
+ |   Number of points:       0               Number of centroids:  1832       |
+ |   Number of lines:        0               Number of boundaries: 3649       |
+ |   Number of areas:        1832            Number of islands:    907        |
+ |   Map is 3D:              No                                               |
+ |   Number of dblinks:      1                                                |
+ |   Projection: Lambert Conformal Conic                                      |
+ |               N:   318117.43741634    S:    10875.82723209                 |
+ |               E:   930172.31282271    W:   123971.19498978                 |
+ |   Digitization threshold: 0                                                |
+ |   Comment:        |
 </pre></div>
 <h2>AUTHOR</h2>
-Radim Blazek, ITC-Irst, Trento, Italy
+Original author CERL<br>
+Updated to GRASS 6 by Radim Blazek, ITC-Irst, Trento, Italy<br>
+Level 1 support by Markus Metz<br>
+Updated to GRASS 7 by Martin Landa, CTU in Prague, Czech Republic
-<p><i>Last changed: $Date$</i></p>
+<p>
+<i>Last changed: $Date$</i></p>
