[GRASS-SVN] r39039 - in grass/trunk/gui/wxpython: docs xml
svn_grass at osgeo.org
Sun Sep 6 02:58:34 EDT 2009
Author: martinl
Date: 2009-09-06 02:58:34 -0400 (Sun, 06 Sep 2009)
New Revision: 39039
grass/trunk/gui/wxpython/docs/wxGUI.html
grass/trunk/gui/wxpython/xml/menudata.xml
wxGUI: document key shortcuts & cosmetics in menu
Modified: grass/trunk/gui/wxpython/docs/wxGUI.html
--- grass/trunk/gui/wxpython/docs/wxGUI.html 2009-09-06 06:51:21 UTC (rev 39038)
+++ grass/trunk/gui/wxpython/docs/wxGUI.html 2009-09-06 06:58:34 UTC (rev 39039)
@@ -228,6 +228,30 @@
</dl>
+<h4>Key shortcuts</h4>
+<b>Menu</b>
+<dl>
+ <dt>Ctrl+N</dt>
+ <dd>Create new workspace</dd>
+ <dt>Ctrl+O</dt>
+ <dd>Load workspace from file</dd>
+ <dt>Ctrl+S</dt>
+ <dd>Save workspace</dd>
+ <dt>Ctrl+C</dt>
+ <dd>Close workspace</dd>
+ <dt>Ctrl+Q</dt>
+ <dd>Quit GUI</dd>
+</dl>
+<b>Global</b>
+<dl>
+ <dt>Alt+R</dt>
+ <dd>Add raster map layer</dd>
+ <dt>Alt+V</dt>
+ <dd>Add vector map layer</dd>
+</dl>
<h3>Map Display Window</h3>
This component includes toolbar area (set of toolbars), map canvas
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml 2009-09-06 06:51:21 UTC (rev 39038)
+++ grass/trunk/gui/wxpython/xml/menudata.xml 2009-09-06 06:58:34 UTC (rev 39039)
@@ -20,7 +20,7 @@
</menuitem>
<menuitem>
<label>Save</label>
- <help>Save workspace to open file</help>
+ <help>Save workspace</help>
<handler>self.OnWorkspaceSave</handler>
<shortcut>Ctrl+S</shortcut>
</menuitem>
@@ -31,7 +31,7 @@
</menuitem>
<menuitem>
<label>Close</label>
- <help>Close loaded workspace</help>
+ <help>Close workspace file</help>
<handler>self.OnWorkspaceClose</handler>
<shortcut>Ctrl+C</shortcut>
</menuitem>
@@ -645,7 +645,7 @@
<separator />
<menuitem>
<label>E&xit</label>
- <help>Exit GUI</help>
+ <help>Quit GUI</help>
<handler>self.OnCloseWindow</handler>
<shortcut>Ctrl+Q</shortcut>
</menuitem>
