[GRASS-SVN] r39043 - in grass/branches/develbranch_6/mswindows: . osgeo4w
Sun Sep 6 09:18:27 EDT 2009
Author: neteler
Date: 2009-09-06 09:18:26 -0400 (Sun, 06 Sep 2009)
New Revision: 39043
Added:
   grass/branches/develbranch_6/mswindows/osgeo4w/grass65.bat.tmpl
   grass/branches/develbranch_6/mswindows/osgeo4w/grass65.tmpl
Removed:
   grass/branches/develbranch_6/mswindows/osgeo4w/grass64.bat.tmpl
   grass/branches/develbranch_6/mswindows/osgeo4w/grass64.tmpl
   grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi
   grass/branches/develbranch_6/mswindows/GRASS-Packager.bat
   grass/branches/develbranch_6/mswindows/README.html
   grass/branches/develbranch_6/mswindows/osgeo4w/ini.bat.tmpl
   grass/branches/develbranch_6/mswindows/osgeo4w/package.cmd
   grass/branches/develbranch_6/mswindows/osgeo4w/package.sh
   grass/branches/develbranch_6/mswindows/osgeo4w/postinstall.bat
   grass/branches/develbranch_6/mswindows/osgeo4w/preremove.bat
cleanup version mixture: all 65/6.5.svn now
Modified: grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi
--- grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi	2009-09-06 10:58:05 UTC (rev 39042)
+++ grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi	2009-09-06 13:18:26 UTC (rev 39043)
@@ -21,7 +21,7 @@
 ;Version variables
-!define RELEASE_VERSION_NUMBER "6.4.0RC4"
+!define RELEASE_VERSION_NUMBER "6.4.0RC5"
 !define RELEASE_SVN_REVISION "36599"
 !define RELEASE_BINARY_REVISION "1"
 !define RELEASE_GRASS_COMMAND "grass64"
@@ -513,7 +513,7 @@
 	"$INSTALL_DIR\icons\GRASS_MSys.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with the new wxPython GUI and a MSYS UNIX terminal"
 ; FIXME: ship the WinGrass release notes .html file instead of URL
-; http://trac.osgeo.org/grass/browser/grass-web/trunk/grass64/binary/mswindows/native/README.html?format=raw
+; http://trac.osgeo.org/grass/browser/grass-web/trunk/grass65/binary/mswindows/native/README.html?format=raw
 ; probably ship with devel versions too? ie Release Notes, not the Release Announcement press release.
 	!if ${INSTALLER_TYPE} == "Release"
 		CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\Release Notes.lnk" "$INSTALL_DIR\WinGRASS-README.url" ""\
Modified: grass/branches/develbranch_6/mswindows/GRASS-Packager.bat
--- grass/branches/develbranch_6/mswindows/GRASS-Packager.bat	2009-09-06 10:58:05 UTC (rev 39042)
+++ grass/branches/develbranch_6/mswindows/GRASS-Packager.bat	2009-09-06 13:18:26 UTC (rev 39043)
@@ -10,7 +10,7 @@
 set OSGEO4W_DIR=c:\osgeo4w
-set GRASS_RELEASE_INSTALL_FOLDER=%OSGEO4W_DIR%\apps\grass\grass-6.4.0RC4
+set GRASS_RELEASE_INSTALL_FOLDER=%OSGEO4W_DIR%\apps\grass\grass-6.4.0RC5
 set GRASS_6_DEV_INSTALL_FOLDER=%OSGEO4W_DIR%\apps\grass\grass-6.5.svn
 set GRASS_7_DEV_INSTALL_FOLDER=%OSGEO4W_DIR%\apps\grass\grass-7.0.svn
Modified: grass/branches/develbranch_6/mswindows/README.html
--- grass/branches/develbranch_6/mswindows/README.html	2009-09-06 10:58:05 UTC (rev 39042)
+++ grass/branches/develbranch_6/mswindows/README.html	2009-09-06 13:18:26 UTC (rev 39043)
@@ -203,7 +203,7 @@
 <p>Edit lines 11-15 in the file <code>c:\temp\GRASS-Packager.bat</code> to
 reflect the paths to your OSGeo4W tree (eg. <code>c:\OSGeo4W</code>) and
-the GRASS version being packaged (eg. <code>grass-6.4.0RC4</code>).</p>
+the GRASS version being packaged (eg. <code>grass-6.5.svn</code>).</p>
 <p>Launch the file <code>c:\temp\GRASS-Packager.bat</code> and select
 the option number 1.</p>
@@ -211,7 +211,7 @@
 <p>When finished, you should have a GRASS self-contained release package
 in <code>c:\temp\GRASS-Release-Package</code>.</p>
-<p>Download README.html from <a href="http://trac.osgeo.org/grass/browser/grass-web/trunk/grass64/binary/mswindows/native/README.html?format=raw">here</a>,
+<p>Download README.html from <a href="http://trac.osgeo.org/grass/browser/grass-web/trunk/grass65/binary/mswindows/native/README.html?format=raw">here</a>,
 place in <code>c:\temp\GRASS-Release-Package</code> (update version numbers as necessary).</p>
 </div>
@@ -275,7 +275,7 @@
 <p>At line 13 set the <code>DEMOLOCATION_PATH</code> varibale to the
 demolocation folder in the source tree.
-For example, <code>c:\msys\local\src\grass-6.4.0RC4\demolocation</code>
+For example, <code>c:\msys\local\src\grass-6.5.svn\demolocation</code>
 <p>At line 18 set the <code>INSTALLER_TYPE</code> variable to <code>"Release"</code>,
 then, at lines 24-26, set the <code>RELEASE_VERSION_NUMBER</code>, the
Deleted: grass/branches/develbranch_6/mswindows/osgeo4w/grass64.bat.tmpl
--- grass/branches/develbranch_6/mswindows/osgeo4w/grass64.bat.tmpl	2009-09-06 10:58:05 UTC (rev 39042)
+++ grass/branches/develbranch_6/mswindows/osgeo4w/grass64.bat.tmpl	2009-09-06 13:18:26 UTC (rev 39043)
@@ -1,3 +0,0 @@
- at echo off
-call @osgeo4w@\bin\o4w_env.bat
-"%WINGISBASE%"\etc\init.bat %*
Deleted: grass/branches/develbranch_6/mswindows/osgeo4w/grass64.tmpl
--- grass/branches/develbranch_6/mswindows/osgeo4w/grass64.tmpl	2009-09-06 10:58:05 UTC (rev 39042)
+++ grass/branches/develbranch_6/mswindows/osgeo4w/grass64.tmpl	2009-09-06 13:18:26 UTC (rev 39043)
@@ -1,25 +0,0 @@
-#! /bin/sh
-# MODULE:   	GRASS Initialization
-# AUTHOR(S):	Justin Hickey - Thailand - jhickey at hpcc.nectec.or.th
-# PURPOSE:  	The source file for this shell script is in
-#   	    	lib/init/grass.src and is the grass startup script. It
-#   	    	requires a source file because the definition of GISBASE
-#   	    	is not known until compile time and is substituted from the
-#   	    	Makefile. Any command line options are passed to Init.sh.
-# COPYRIGHT:    (C) 2000-2005 by the GRASS Development Team
-#               This program is free software under the GNU General Public
-#   	    	License (>=v2). Read the file COPYING that comes with GRASS
-#   	    	for details.
-trap "echo 'User break!' ; exit" 2 3 9 15
-# Set the GISBASE variable
-GISBASE=@osgeo4w_msys@
-export GISBASE
-exec "$GISBASE/etc/Init.sh" "$@"
Copied: grass/branches/develbranch_6/mswindows/osgeo4w/grass65.bat.tmpl (from rev 38987, grass/branches/develbranch_6/mswindows/osgeo4w/grass64.bat.tmpl)
--- grass/branches/develbranch_6/mswindows/osgeo4w/grass65.bat.tmpl	                        (rev 0)
+++ grass/branches/develbranch_6/mswindows/osgeo4w/grass65.bat.tmpl	2009-09-06 13:18:26 UTC (rev 39043)
@@ -0,0 +1,3 @@
+ at echo off
+call @osgeo4w@\bin\o4w_env.bat
+"%WINGISBASE%"\etc\init.bat %*
Copied: grass/branches/develbranch_6/mswindows/osgeo4w/grass65.tmpl (from rev 38987, grass/branches/develbranch_6/mswindows/osgeo4w/grass64.tmpl)
--- grass/branches/develbranch_6/mswindows/osgeo4w/grass65.tmpl	                        (rev 0)
+++ grass/branches/develbranch_6/mswindows/osgeo4w/grass65.tmpl	2009-09-06 13:18:26 UTC (rev 39043)
@@ -0,0 +1,25 @@
+#! /bin/sh
+# MODULE:   	GRASS Initialization
+# AUTHOR(S):	Justin Hickey - Thailand - jhickey at hpcc.nectec.or.th
+# PURPOSE:  	The source file for this shell script is in
+#   	    	lib/init/grass.src and is the grass startup script. It
+#   	    	requires a source file because the definition of GISBASE
+#   	    	is not known until compile time and is substituted from the
+#   	    	Makefile. Any command line options are passed to Init.sh.
+# COPYRIGHT:    (C) 2000-2005 by the GRASS Development Team
+#               This program is free software under the GNU General Public
+#   	    	License (>=v2). Read the file COPYING that comes with GRASS
+#   	    	for details.
+trap "echo 'User break!' ; exit" 2 3 9 15
+# Set the GISBASE variable
+GISBASE=@osgeo4w_msys@
+export GISBASE
+exec "$GISBASE/etc/Init.sh" "$@"
Modified: grass/branches/develbranch_6/mswindows/osgeo4w/ini.bat.tmpl
--- grass/branches/develbranch_6/mswindows/osgeo4w/ini.bat.tmpl	2009-09-06 10:58:05 UTC (rev 39042)
+++ grass/branches/develbranch_6/mswindows/osgeo4w/ini.bat.tmpl	2009-09-06 13:18:26 UTC (rev 39043)
@@ -1,5 +1,5 @@
-set GISBASE=%OSGEO4W_ROOT%\apps\grass\grass-6.4.0svn
-set WINGISBASE=%OSGEO4W_ROOT%\apps\grass\grass-6.4.0svn
+set GISBASE=%OSGEO4W_ROOT%\apps\grass\grass-6.5.svn
+set WINGISBASE=%OSGEO4W_ROOT%\apps\grass\grass-6.5.svn
 set GRASS_SH=%OSGEO4W_ROOT%\apps\msys\bin\sh.exe
 set GRASS_WISH=%OSGEO4W_ROOT%\bin\wish.exe
 set GRASS_PYTHON=%OSGEO4W_ROOT%\bin\python.exe
Modified: grass/branches/develbranch_6/mswindows/osgeo4w/package.cmd
--- grass/branches/develbranch_6/mswindows/osgeo4w/package.cmd	2009-09-06 10:58:05 UTC (rev 39042)
+++ grass/branches/develbranch_6/mswindows/osgeo4w/package.cmd	2009-09-06 13:18:26 UTC (rev 39043)
@@ -1,7 +1,7 @@
 path %PATH%;%OSGEO4W_ROOT%\apps\swig
 set WXWIN=h:\windows\wxPython-src-2.8.9.1
-set GRASS_HOME=%OSGEO4W_ROOT%\apps\grass\grass-6.4.0RC3
+set GRASS_HOME=%OSGEO4W_ROOT%\apps\grass\grass-6.5.svn
 set GRASS_INC=%GRASS_HOME%\include
 set GRASS_LPATH=%GRASS_HOME%\lib
Modified: grass/branches/develbranch_6/mswindows/osgeo4w/package.sh
--- grass/branches/develbranch_6/mswindows/osgeo4w/package.sh	2009-09-06 10:58:05 UTC (rev 39042)
+++ grass/branches/develbranch_6/mswindows/osgeo4w/package.sh	2009-09-06 13:18:26 UTC (rev 39043)
@@ -76,7 +76,7 @@
 mv $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/include/grass/config.h $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/include/grass/config.h.mingw
 cp mswindows/osgeo4w/config.h.switch $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/include/grass/config.h
 cp mswindows/osgeo4w/config.h.vc $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/include/grass
-cp mswindows/osgeo4w/grass64.bat.tmpl $OSGEO4W_ROOT_MSYS/bin/grass64.bat.tmpl
+cp mswindows/osgeo4w/grass65.bat.tmpl $OSGEO4W_ROOT_MSYS/bin/grass65.bat.tmpl
 cp mswindows/osgeo4w/ini.bat.tmpl $OSGEO4W_ROOT_MSYS/etc/ini/grass.bat.tmpl
 cp mswindows/osgeo4w/postinstall.bat $OSGEO4W_ROOT_MSYS/etc/postinstall/grass.bat
 cp mswindows/osgeo4w/preremove.bat $OSGEO4W_ROOT_MSYS/etc/preremove/grass.bat
@@ -88,7 +88,7 @@
 P=${P//\//\\\\}\\\\dist.i686-pc-mingw32
 sed -e "s#$P#@osgeo4w@#" $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/etc/fontcap >$OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/etc/fontcap.tmpl
-sed -e "s#$P#@osgeo4w_msys@#" $OSGEO4W_ROOT_MSYS/apps/grass/bin/grass64 >$OSGEO4W_ROOT_MSYS/apps/grass/bin/grass64.tmpl
+sed -e "s#$P#@osgeo4w_msys@#" $OSGEO4W_ROOT_MSYS/apps/grass/bin/grass65 >$OSGEO4W_ROOT_MSYS/apps/grass/bin/grass65.tmpl
 rm $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/etc/fontcap
 echo $(date): STARTING building vc libraries
@@ -114,7 +114,7 @@
 	apps/grass/grass-$VERSION/lib/*.lib
 tar -cjf $PDIR/grass/grass-$VERSION-$PACKAGE.tar.bz2 \
-	apps/grass/bin/grass64.tmpl \
+	apps/grass/bin/grass65.tmpl \
 	apps/grass/grass-$VERSION/authors \
 	apps/grass/grass-$VERSION/bin/ \
 	apps/grass/grass-$VERSION/bwidget/ \
@@ -129,7 +129,7 @@
 	bin/libgnurx-0.dll \
 	bin/libiconv-2.dll \
 	bin/libintl-8.dll \
-	bin/grass64.bat.tmpl \
+	bin/grass65.bat.tmpl \
 	bin/libgrass_*.$VERSION.dll \
 	etc/ini/grass.bat \
 	etc/postinstall/grass.bat \
Modified: grass/branches/develbranch_6/mswindows/osgeo4w/postinstall.bat
--- grass/branches/develbranch_6/mswindows/osgeo4w/postinstall.bat	2009-09-06 10:58:05 UTC (rev 39042)
+++ grass/branches/develbranch_6/mswindows/osgeo4w/postinstall.bat	2009-09-06 13:18:26 UTC (rev 39043)
@@ -1,9 +1,9 @@
-set ICON=%OSGEO4W_ROOT%\apps\grass\grass-6.4.0svn\etc\gui\icons\grass.ico
-set BATCH=%OSGEO4W_ROOT%\bin\grass64.bat
+set ICON=%OSGEO4W_ROOT%\apps\grass\grass-6.5.svn\etc\gui\icons\grass.ico
+set BATCH=%OSGEO4W_ROOT%\bin\grass65.bat
-textreplace -std -t "%OSGEO4W_ROOT%"\bin\grass64.bat
-textreplace -std -t "%OSGEO4W_ROOT%"\apps\grass\grass-6.4.0svn\etc\fontcap
-textreplace -std -t "%OSGEO4W_ROOT%"\apps\grass\bin\grass64
+textreplace -std -t "%OSGEO4W_ROOT%"\bin\grass65.bat
+textreplace -std -t "%OSGEO4W_ROOT%"\apps\grass\grass-6.5.svn\etc\fontcap
+textreplace -std -t "%OSGEO4W_ROOT%"\apps\grass\bin\grass65
 mkdir "%OSGEO4W_STARTMENU%\GRASS GIS"
 xxmklink "%OSGEO4W_STARTMENU%\GRASS GIS\wxPython.lnk"   "%BATCH%" "-wxpython" \ "wxPython interface" 1 "%ICON%"
Modified: grass/branches/develbranch_6/mswindows/osgeo4w/preremove.bat
--- grass/branches/develbranch_6/mswindows/osgeo4w/preremove.bat	2009-09-06 10:58:05 UTC (rev 39042)
+++ grass/branches/develbranch_6/mswindows/osgeo4w/preremove.bat	2009-09-06 13:18:26 UTC (rev 39043)
@@ -10,6 +10,6 @@
 del "%ALLUSERSPROFILE%\Desktop\GRASS GIS (TclTk).lnk"
 del "%ALLUSERSPROFILE%\Desktop\GRASS GIS (Text).lnk"
-del "%OSGEO4W_ROOT%"\apps\grass\grass-6.4.0svn\etc\fontcap
-del "%OSGEO4W_ROOT%"\apps\grass\bin\grass64
-del "%OSGEO4W_ROOT%"\bin\grass64.bat
+del "%OSGEO4W_ROOT%"\apps\grass\grass-6.5.svn\etc\fontcap
+del "%OSGEO4W_ROOT%"\apps\grass\bin\grass65
+del "%OSGEO4W_ROOT%"\bin\grass65.bat
