[GRASS-SVN] r39054 - grass/branches/develbranch_6/gui/wxpython/docs
svn_grass at osgeo.org
Mon Sep 7 00:15:03 EDT 2009
Author: helena
Date: 2009-09-07 00:15:03 -0400 (Mon, 07 Sep 2009)
New Revision: 39054
grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html
lists added to represent drop down menus in layer manager
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html 2009-09-07 03:26:42 UTC (rev 39053)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html 2009-09-07 04:15:03 UTC (rev 39054)
@@ -122,7 +122,7 @@
<dt><img src="icons/grass2/save.png">
<img src="icons/grass/file-save.gif">
-Save workspace file</em></dt>
+<em>Save workspace file</em></dt>
<dd>Saves current set of layers and their options to a workspace
file.</dd>
@@ -134,37 +134,39 @@
<dt><img src="icons/grass2/layer-shaded-relief-add.png">
<img src="icons/grass/module-d.shadedmap.gif">
-<em>Add miscelaneous raster-based map layers</em></dt>
-<dd>opens a dropdown menu that allows user to select to add:<br>
+<em>Add various raster-based map layers</em></dt>
+<dd>opens a dropdown menu that allows user to select to:<br>
- <dt><img src="icons/grass2/layer-shaded-relief-add.png">
+ <UL>
+ <LI><dt><img src="icons/grass2/layer-shaded-relief-add.png">
- <em>shaded relief raster map layer </em></dt>
- see <em><a href="d.shadedmap.html">d.shadedmap</a></em>, or <br>
- <dt><img src="icons/grass2/layer-rgb-add.png">
+ <em>Add shaded relief raster map layer </em></dt>
+ <dd>Adds shaded relief raster map layer,
+ see <em><a href="d.shadedmap.html">d.shadedmap</a></em>
+ <LI><dt><img src="icons/grass2/layer-rgb-add.png">
<img src="icons/grass/channel-rgb.gif">
- <em>RGB raster layer</em></dt>
+ <em>Add RGB raster layer</em></dt>
<dd>Combines and displays three raster maps defined as red, green, and blue
channels, see <em><a href="d.rgb.html">d.rgb</a></em>.</dd>
- <dt><img src="icons/grass2/layer-his-add.png">
+ <LI><dt><img src="icons/grass2/layer-his-add.png">
<img src="icons/grass/channel-his.gif">
- <em>HIS raster layer</em></dt>
+ <em>Add HIS raster layer</em></dt>
<dd>Combines and displays two or three raster maps defined as hue,
intensity, and (optionally) saturation channels,
see <em><a href="d.his.html">d.his</a></em>.</dd>
- <dt><img src="icons/grass2/layer-cell-cats-add.png">
+ <LI><dt><img src="icons/grass2/layer-cell-cats-add.png">
<img src="icons/grass/module-d.rast.arrow.gif">
- <em>raster arrows layer</em></dt>
+ <em>Add raster arrows layer</em></dt>
<dd>Adds map of raster cells with directional arrows drawn. Arrow
direction and length are determined by separate aspect/directional map
and (optional) slope/intensity map,
see <em><a href="d.rast.arrow.html">d.rast.arrow</a></em>.</dd>
<img src="icons/grass/module-d.rast.num.gif">
- <em>raster numbers layer</em></dt>
+ <em>Add raster numbers layer</em></dt>
<dd>Adds map of raster cells with numbers representing the cell values,
see <em><a href="d.rast.num.html">d.rast.num</a></em>.</dd>
-</dd>
+ </UL>
<dt><img src="icons/grass2/layer-vector-add.png">
<img src="icons/grass/element-vector.gif">
@@ -174,6 +176,12 @@
<dt><img src="icons/grass2/layer-vector-thematic-add.png">
<img src="icons/grass/module-d.vect.thematic.gif">
+<em>Add various vector-based map layers </em></dt>
+<UL>
+<LI><dt><img src="icons/grass2/layer-vector-thematic-add.png">
+ <img src="icons/grass/module-d.vect.thematic.gif">
<em>Add thematic map layer
(for all vector types)</em></dt>
<dd>Adds layer for thematic display values from a numeric attribute
@@ -186,7 +194,7 @@
printing,
see <em><a href="d.vect.thematic.html">d.vect.thematic</a></em>.</dd>
-<dt><img src="icons/grass2/layer-vector-chart-add.png">
+<LI><dt><img src="icons/grass2/layer-vector-chart-add.png">
<img src="icons/grass/module-d.vect.chart.gif">
<em>Add thematic charts layer (for vector points)</em></dt>
<dd>Adds layer in which pie or bar charts can be automatically created
@@ -195,6 +203,7 @@
and attributes to chart, chart colors, and chart size (fixed or based
on attribute column),
see <em><a href="d.vect.chart.html">d.vect.chart</a></em>.</dd>
+</UL>
<dt><img src="icons/grass2/layer-command-add.png">
<img src="icons/grass/gui-cmd.gif">
@@ -221,28 +230,45 @@
<dt><img src="icons/grass2/layer-grid-add.png">
<img src="icons/grass/module-d.grid.gif">
- <em>Add overlay grids and lines</em></dt>
-<dd>Adds layer to display regular grid (for all locations), or geodesic and
-rhumblines (for latitude/longitude locations only), see <em><a href="d.grid.html">d.grid</a>, <a href="d.geodesic.html">d.geodesic</a>, <a href="d.rhumbline.html">d.rhumbline</a></em>.</dd>
+ <em>Add grid or vector labels overlay</em></dt>
-<dt><img src="icons/grass2/layer-label-add.png">
- <img src="icons/grass/module-d.labels.gif">
- <em>Add labels layer for vector
-objects (from existing labels file)</em></dt>
-<dd>Add raster text layer from a labels file for vector objects
-created with the <em><a href="v.label.html">v.label</a></em> module
-(accessed from button in options panel). A labels file can also be
-created with a text editor,
-see <em><a href="d.labels.html">d.labels</a></em>.</dd>
+<UL>
+<LI><dt><img src="icons/grass2/layer-grid-add.png">
+ <img src="icons/grass/module-d.grid.gif">
+ <em>Add overlay grids and lines</em></dt>
+ <dd>Adds layer to display regular grid (for all locations)
+ see <em><a href="d.grid.html">d.grid</a></em></dd>
+<LI><dt><img src="icons/grass2/layer-label-add.png">
+ <img src="icons/grass/module-d.labels.gif">
+ <em>Add labels layer for vector objects (from existing labels file)</em></dt>
+ <dd>Add raster text layer from a labels file for vector objects
+ created with the <em><a href="v.label.html">v.label</a></em> module
+ (accessed from button in options panel). A labels file can also be
+ created with a text editor, see <em><a href="d.labels.html">d.labels</a></em>.</dd>
+ <em>Add geodesic line layer</em></dt>
+ <dd>Add layer to display geodesic line for latitude/longitude locations only,
+ see <em><a href="d.geodesic.html">d.geodesic</a></em></dd>
+ <em>Add rhumbline layer</em>
+ <dd>Add layer to display rhumblines (for latitude/longitude locations only),
+ see <em><a href="d.rhumbline.html">d.rhumbline</a></em>.</dd>
+</UL>
<dt><img src="icons/grass2/layer-remove.png">
<img src="icons/grass/edit-cut.gif">
- <em>Remove map layer from layer tree</em></dt>
+ <em>Delete selected layer</em></dt>
<dd>Removes selected map layer or map layer group from layer tree.</dd>
<dt><img src="icons/grass2/table.png">
<img src="icons/grass/db-values.gif">
- <em>Open <a href="wxGUI.Attribute_Table_Manager.html">Attribute Table Manager</a> for selected vector map</em></dt>
+ <em>Show <a href="wxGUI.Attribute_Table_Manager.html">Attribute Table Manager</a> for selected vector map</em></dt>
<dd>Displays attribute data of selected vector map.</dd>
</dl>
