[GRASS-SVN] r39067 - grass/trunk/gui/wxpython/docs
svn_grass at osgeo.org
Mon Sep 7 11:31:46 EDT 2009
Author: martinl
Date: 2009-09-07 11:31:46 -0400 (Mon, 07 Sep 2009)
New Revision: 39067
grass/trunk/gui/wxpython/docs/wxGUI.html
show just grass2 icons
Modified: grass/trunk/gui/wxpython/docs/wxGUI.html
--- grass/trunk/gui/wxpython/docs/wxGUI.html 2009-09-07 15:28:44 UTC (rev 39066)
+++ grass/trunk/gui/wxpython/docs/wxGUI.html 2009-09-07 15:31:46 UTC (rev 39067)
@@ -307,34 +307,29 @@
<dl>
<dt><img src="icons/grass2/show.png">
- <img src="icons/grass/gui-display.gif">
- <img src="icons/silk/map_go.png"> <em>Display active layers (current region)</em></dt>
+ <em>Display active layers (current region)</em></dt>
<dd>Displays all active layers from layer tree at current resolution
and region extents for that map display window.</dd>
<dt><img src="icons/grass2/layer-redraw.png">
- <img src="icons/grass/gui-redraw.gif">
- <img src="icons/silk/arrow_refresh.png"> <em>Re-render and display all active
+ <em>Re-render and display all active
layers and zoom to current region</em></dt>
<dd>Resets the region to the display resolution and extents and forces
re-display and re-rendering all active layers.</dd>
<dt><img src="icons/grass2/erase.png">
- <img src="icons/grass/gui-erase.gif">
- <img src="icons/silk/cross.png"> <em>Erase display content</em></dt>
+ <em>Erase display content</em></dt>
<dd>Erases the currently selected map display to a white background;
also removes all frames,
see <em><a href="d.erase.html">d.erase</a>, <a href="d.frame.html">d.frame
-e</a></em>.</dd>
<dt><img src="icons/grass2/pointer.png">
- <img src="icons/grass/gui-pointer.gif">
- <img src="icons/silk/cursor.png"> <em>Arrow cursor</em></dt>
+ <em>Arrow cursor</em></dt>
<dd>Select arrow cursor for map display.</dd>
<dt><img src="icons/grass2/info.png">
- <img src="icons/grass/gui-query.gif">
- <img src="icons/silk/information.png"> <em>Query tool (select a map first)</em></dt>
+ <em>Query tool (select a map first)</em></dt>
<dd>Query selected raster, RGB raster (all three map channels will be
queried), or vector map(s) using the mouse. Map(s) must be selected
before query. Vector charts and thematic vector maps cannot be
@@ -343,8 +338,7 @@
see <em><a href="r.what.html">r.what</a>, <a href="v.what.html">v.what</a></em>.</dd>
<dt><img src="icons/grass2/pan.png">
- <img src="icons/grass/gui-pan.gif">
- <img src="icons/silk/arrow_out.png"> <em>Pan</em></dt>
+ <em>Pan</em></dt>
<dd>Interactive selection of a new center of view in the active
display monitor. Drag the pan cursor while pressing the left mouse
button to pan. Panning changes the location of the region displayed
@@ -353,8 +347,7 @@
processes, see <em><a href="g.region.html">g.region</a></em>.</dd>
<dt><img src="icons/grass2/zoom-in.png">
- <img src="icons/grass/gui-zoom_in.gif">
- <img src="icons/silk/zoom_in.png"> <em>Zoom in</em></dt>
+ <em>Zoom in</em></dt>
<dd>Interactive zooming with the mouse in the active display monitor.
Drawing a box or just click with the mouse (left button) and zoom-in
cursor causes the display to zoom in so that the area defined by the
@@ -366,8 +359,7 @@
<dt><img src="icons/grass2/zoom-out.png">
- <img src="icons/grass/gui-zoom_out.gif">
- <img src="icons/silk/zoom_out.png"> <em>Zoom out</em></dt>
+ <em>Zoom out</em></dt>
Drawing a box or just click with the mouse (left button) and zoom-out
cursor causes the display to zoom in so that the area displayed
@@ -380,14 +372,12 @@
<dt><img src="icons/grass2/zoom-last.png">
- <img src="icons/grass/gui-zoom_back.gif">
- <img src="icons/silk/zoom_back.png"> <em>Revert zoom</em></dt>
+ <em>Revert zoom</em></dt>
<dd>Returns to the previous zoom. Up to 10 levels of zoom back are
maintained, see <em><a href="g.region.html">g.region</a></em>.</dd>
<dt><img src="icons/grass2/zoom-more.png">
- <img src="icons/grass/gui-mapzoom.gif">
- <img src="icons/silk/zoom.png"> <em>Zoom menu</em></dt>
+ <em>Zoom menu</em></dt>
<dd>Automatic zoom settings menu. Zoom to match the extents of a selected
map, zoom to match the computational region (set with
<em>g.region</em>), zoom to match the extents of a saved region or
@@ -397,14 +387,12 @@
See <em><a href="g.region.html">g.region</a></em>.</dd>
<dt><img src="icons/grass2/layer-raster-analyze.png">
- <img src="icons/grass/gui-rastanalyze.gif">
- <img src="icons/silk/application_lightning.png"> <em>Analyze menu</em></dt>
+ <em>Analyze menu</em></dt>
<dd>Contains functions for distance measurement, creating histogram or
profile tool.</dd>
<dt><img src="icons/grass2/measure-length.png">
- <img src="icons/grass/gui-measure.gif">
- <img src="icons/silk/sum.png"> <em>Distance measurement tool</em></dt>
+ <em>Distance measurement tool</em></dt>
<dd>Interactive measurement of lengths defined with the mouse. The
length of each segment and the cumulative length of all segments
measuered is displayed in the command output window frame. Lengths are
@@ -412,8 +400,7 @@
see <em><a href="d.measure.html">d.measure</a></em>.</dd>
<dt><img src="icons/grass2/layer-raster-profile.png">
- <img src="icons/grass/gui-profile.gif">
- <img src="icons/silk/wand.png"> <em>Profile tool</em></dt>
+ <em>Profile tool</em></dt>
<dd>Interactively create profile of a raster map. Profile transect is
drawn with the mouse in map display. The profile may be of the
displayed map or a different map,
@@ -421,46 +408,39 @@
page</a></em>.</dd>
<dt><img src="icons/grass2/layer-raster-histogram.png">
- <img src="icons/silk/chart_bar.png">
- <img src="icons/grass/module-d.histogram.gif"> Display histogram of selected raster map</dt>
+ Display histogram of selected raster map</dt>
<dd>Displays histogram of selected raster map or image in new window,
see <em><a href="d.histogram.html">d.histogram</a></em>.</dd>
<dt><img src="icons/grass2/element-add.png">
- <img src="icons/silk/overlays.png">
- <img src="icons/grass/gui-rastanalyze.gif"> Add overlay</dt>
+ Add overlay</dt>
<dd>Adds overlay to map display like barscale, north arrow, text.</dd>
<dt><img src="icons/grass2/scalebar-add.png">
- <img src="icons/grass/module-d.barscale.gif">
- <img src="icons/silk/page_white_picture.png"> <em>Add scalebar and north arrow</em></dt>
+ <em>Add scalebar and north arrow</em></dt>
<dd>Adds layer to display a combined scalebar and north arrow. Options
include scalebar placement (using screen coordinates or a mouse),
scalebar format, and scalebar colors,
see <em><a href="d.barscale.html">d.barscale</a></em>.</dd>
<dt><img src="icons/grass2/legend-add.png">
- <img src="icons/grass/module-d.legend.gif">
- <img src="icons/silk/page_green.png"> <em>Add raster map legend</em></dt>
+ <em>Add raster map legend</em></dt>
<dd>Adds layer to display with legend of selected raster map,
see <em><a href="d.legend.html">d.legend</a></em>.</dd>
<dt><img src="icons/grass2/text-add.png">
- <img src="icons/grass/module-d.text.gif">
- <img src="icons/silk/textfield_add.png"> <em>Add text layer</em></dt>
+ <em>Add text layer</em></dt>
<dd>Adds layer to display a line of text using default GRASS font
(selected with <em><a href="d.font.html">d.font</a></em>). Options
include: text placement (screen coordinates); and text size, bolding,
and color, see <em><a href="d.text.html">d.text</a></em>.</dd>
<dt><img src="icons/grass2/map-export.png">
- <img src="icons/grass/file-save.gif">
- <img src="icons/silk/picture_save.png"> <em>Export map display</em></dt>
+ <em>Export map display</em></dt>
<dd>Exports visible map display to different raster graphic formats.</dd>
<dt><img src="icons/grass2/print.png">
- <img src="icons/grass/file-print.gif">
- <img src="icons/silk/printer.png"> <em>Print map</em></dt>
+ <em>Print map</em></dt>
<dd>Prints map on the UNIX <i>lpr</i> printer or PostScript device;
saves visible map display (including PostScript text and labels) to PDF
or EPS file. Requires <tt>ghostscript</tt> for all output except EPS.</dd>
