[GRASS-SVN] r39079 - grass/trunk/tools
svn_grass at osgeo.org
Mon Sep 7 16:05:48 EDT 2009
Author: hamish
Date: 2009-09-07 16:05:47 -0400 (Mon, 07 Sep 2009)
New Revision: 39079
grass/trunk/tools/module_synopsis.sh
replace sed goop with a call to Martin's nice new python menu tree dump
Modified: grass/trunk/tools/module_synopsis.sh
--- grass/trunk/tools/module_synopsis.sh 2009-09-07 19:12:56 UTC (rev 39078)
+++ grass/trunk/tools/module_synopsis.sh 2009-09-07 20:05:47 UTC (rev 39079)
@@ -58,36 +58,23 @@
XML_MENU="$GISBASE/etc/wxpython/xml/menudata.xml"
+# generate menu hierarchy
+MDPY="$GISBASE/etc/wxpython/gui_modules/menudata.py"
+# python menudata.py commands
+# python menudata.py tree
+# python menudata.py strings
+python "$MDPY" commands | sed -e 's/ | /|/' -e 's/[ -].*|/|/' \
+ | sort -u > "$TMP.menu_hierarchy"
# work in progress -- still rather buggy.
find_menu_hierarchy()
-unset MODULE_COUNT MODULE_LABEL MODULE_MENU1 MODULE_MENU2
+ MODL=$1
+ PLACEMENT=`grep "^$MODL|" "$TMP.menu_hierarchy" | cut -f2 -d'|'`
-MODULE_COUNT=`grep -c -w "$MODULE" "$XML_MENU"`
-if [ "$MODULE_COUNT" -ge 1 ] ; then
- MODULE_LABEL=`xml2 < "$XML_MENU" | grep -w -B5 "$MODULE" | \
- grep 'label=' | cut -f2 -d= | tr '\n' '>' | \
- sed -e 's/>$//' -e 's/[^ ]>/ > /'`
- MODULE_MENU1=`xml2 < "$XML_MENU" | grep -w -B5000 "$MODULE" | \
- sed -e 's+^/menudata/menubar/menu/++' | tac | \
- grep '/label=\|^label=' | grep -B1000 '^label=' -m 1 | \
- grep -v menuitem | tail -n 1 | cut -f2 -d=`
- MODULE_MENU2=`xml2 < "$XML_MENU" | grep -w -B5000 "$MODULE" | \
- grep -v menuitem | head -n 1 | cut -f2 -d= | tr '\n' ' ' | \
- sed -e 's/ $//'`
- if [ "$MODULE_COUNT" -eq 1 ] ; then
- echo "$MODULE|$MODULE_MENU1 > $MODULE_MENU2 > $MODULE_LABEL"
- else
- # "*" indicates module appears more than once
- echo "$MODULE*|$MODULE_MENU1 > $MODULE_MENU2 > $MODULE_LABEL"
- fi
-fi
+ echo "$PLACEMENT"
for DIR in bin scripts ; do
@@ -109,7 +96,7 @@
# echo "mod=[$MODULE] desc=[$desc]"
-# find_menu_hierarchy
+# find_menu_hierarchy $MODULE
if [ -z "$label" ] && [ -z "$desc" ] ; then
continue
