[GRASS-SVN] r39093 - grass/trunk/vector/v.edit
svn_grass at osgeo.org
Wed Sep 9 11:39:37 EDT 2009
Author: martinl
Date: 2009-09-09 11:39:35 -0400 (Wed, 09 Sep 2009)
New Revision: 39093
grass/trunk/vector/v.edit/args.c
grass/trunk/vector/v.edit/main.c
v.edit: enable 3D for 'move' (thanks to Harri Kiiskinen for the patch)
Modified: grass/trunk/vector/v.edit/args.c
--- grass/trunk/vector/v.edit/args.c 2009-09-09 15:17:14 UTC (rev 39092)
+++ grass/trunk/vector/v.edit/args.c 2009-09-09 15:39:35 UTC (rev 39093)
@@ -15,7 +15,7 @@
* Read the file COPYING that comes with GRASS
* for details.
- * TODO: 3D support
+ * TODO: 3D support (done for move and vertexmove)
#include "global.h"
@@ -104,12 +104,12 @@
params->move = G_define_option();
params->move->key = "move";
- params->move->key_desc = "x,y";
+ params->move->key_desc = "x,y,z";
params->move->type = TYPE_DOUBLE;
params->move->required = NO;
params->move->multiple = NO;
params->move->description =
- _("Difference in x,y direction for moving feature or vertex");
+ _("Difference in x,y,z direction for moving feature or vertex");
params->maxdist = G_define_option();
params->maxdist->key = "thresh";
Modified: grass/trunk/vector/v.edit/main.c
--- grass/trunk/vector/v.edit/main.c 2009-09-09 15:17:14 UTC (rev 39092)
+++ grass/trunk/vector/v.edit/main.c 2009-09-09 15:39:35 UTC (rev 39093)
@@ -15,7 +15,7 @@
* for details.
#include "global.h"
@@ -33,7 +33,7 @@
int i;
int move_first, snap;
int ret, print, layer;
- double move_x, move_y, thresh[3];
+ double move_x, move_y, move_z, thresh[3];
struct line_pnts *coord;
@@ -261,18 +261,19 @@
case MODE_MOVE:
move_x = atof(params.move->answers[0]);
move_y = atof(params.move->answers[1]);
+ move_z = atof(params.move->answers[2]);
G_verbose_message(_("Threshold value for snapping is %.2f"),
thresh[THRESH_SNAP]);
- ret = Vedit_move_lines(&Map, BgMap, nbgmaps, List, move_x, move_y, 0.0, snap, thresh[THRESH_SNAP]); /* TODO: 3D */
+ ret = Vedit_move_lines(&Map, BgMap, nbgmaps, List, move_x, move_y, move_z, snap, thresh[THRESH_SNAP]);
G_message(_("%d features moved"), ret);
break;
case MODE_VERTEX_MOVE:
- ret = Vedit_move_vertex(&Map, BgMap, nbgmaps, List, coord, thresh[THRESH_COORDS], thresh[THRESH_SNAP], move_x, move_y, 0.0, /* TODO: 3D */
- move_first, snap);
+ ret = Vedit_move_vertex(&Map, BgMap, nbgmaps, List, coord, thresh[THRESH_COORDS], thresh[THRESH_SNAP], move_x, move_y, move_z, move_first, snap);
G_message(_("%d vertices moved"), ret);
break;
case MODE_VERTEX_ADD:
