[GRASS-SVN] r39105 - grass/branches/develbranch_6/vector/v.edit
svn_grass at osgeo.org
Thu Sep 10 04:10:33 EDT 2009
Author: martinl
Date: 2009-09-10 04:10:32 -0400 (Thu, 10 Sep 2009)
New Revision: 39105
grass/branches/develbranch_6/vector/v.edit/args.c
grass/branches/develbranch_6/vector/v.edit/main.c
revert r39094 (backward compatibility broken)
Modified: grass/branches/develbranch_6/vector/v.edit/args.c
--- grass/branches/develbranch_6/vector/v.edit/args.c 2009-09-10 07:48:53 UTC (rev 39104)
+++ grass/branches/develbranch_6/vector/v.edit/args.c 2009-09-10 08:10:32 UTC (rev 39105)
@@ -15,7 +15,7 @@
* Read the file COPYING that comes with GRASS
* for details.
- * TODO: 3D support (done for move and vertexmove)
+ * TODO: 3D support
#include "global.h"
@@ -104,12 +104,12 @@
params->move = G_define_option();
params->move->key = "move";
- params->move->key_desc = "x,y,z";
+ params->move->key_desc = "x,y";
params->move->type = TYPE_DOUBLE;
params->move->required = NO;
params->move->multiple = NO;
params->move->description =
- _("Difference in x,y,z direction for moving feature or vertex");
+ _("Difference in x,y direction for moving feature or vertex");
params->maxdist = G_define_option();
params->maxdist->key = "thresh";
Modified: grass/branches/develbranch_6/vector/v.edit/main.c
--- grass/branches/develbranch_6/vector/v.edit/main.c 2009-09-10 07:48:53 UTC (rev 39104)
+++ grass/branches/develbranch_6/vector/v.edit/main.c 2009-09-10 08:10:32 UTC (rev 39105)
@@ -15,7 +15,7 @@
* for details.
#include "global.h"
@@ -34,7 +34,7 @@
int i;
int move_first, snap;
int ret, print, layer;
- double move_x, move_y, move_z, thresh[3];
+ double move_x, move_y, thresh[3];
struct line_pnts *coord;
@@ -281,19 +281,18 @@
case MODE_MOVE:
move_x = atof(params.move->answers[0]);
move_y = atof(params.move->answers[1]);
- move_z = atof(params.move->answers[2]);
G_verbose_message(_("Threshold value for snapping is %.2f"),
thresh[THRESH_SNAP]);
- ret = Vedit_move_lines(&Map, BgMap, nbgmaps, List, move_x, move_y, move_z, snap, thresh[THRESH_SNAP]);
+ ret = Vedit_move_lines(&Map, BgMap, nbgmaps, List, move_x, move_y, 0.0, snap, thresh[THRESH_SNAP]); /* TODO: 3D */
G_message(_("%d features moved"), ret);
break;
case MODE_VERTEX_MOVE:
- ret = Vedit_move_vertex(&Map, BgMap, nbgmaps, List, coord, thresh[THRESH_COORDS], thresh[THRESH_SNAP], move_x, move_y, move_z, move_first, snap);
+ ret = Vedit_move_vertex(&Map, BgMap, nbgmaps, List, coord, thresh[THRESH_COORDS], thresh[THRESH_SNAP], move_x, move_y, 0.0, /* TODO: 3D */
+ move_first, snap);
G_message(_("%d vertices moved"), ret);
break;
case MODE_VERTEX_ADD:
