[GRASS-SVN] r39126 - grass/branches/develbranch_6/gui/wxpython/xml
svn_grass at osgeo.org
Fri Sep 11 04:12:50 EDT 2009
Author: martinl
Date: 2009-09-11 04:12:49 -0400 (Fri, 11 Sep 2009)
New Revision: 39126
grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
wxGUI menu updated
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2009-09-11 08:11:24 UTC (rev 39125)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2009-09-11 08:12:49 UTC (rev 39126)
@@ -743,8 +743,8 @@
<items>
<menuitem>
<label>Manage projections</label>
- <help>Converts co-ordinate system descriptions (i.e. projection information) between various formats (including GRASS format). Can also be used to create GRASS locations.</help>
- <keywords>general</keywords>
+ <help>Converts co-ordinate system descriptions (i.e. projection information) between various formats (including GRASS format).</help>
+ <keywords>general,projection</keywords>
<handler>self.OnMenuCmd</handler>
<command>g.proj</command>
</menuitem>
@@ -956,7 +956,7 @@
</menuitem>
<menuitem>
<label>Mask</label>
- <help>Create a MASK for limiting raster operation</help>
+ <help>Creates a mask for limiting raster operation.</help>
<keywords>raster,mask</keywords>
<command>r.mask</command>
@@ -1448,7 +1448,7 @@
<menuitem>
<label>Recode using rules file</label>
<help>r.recode.rules - Use ascii rules file to recode categories in raster map</help>
- <handler>self.OnMenuCmd</handler>
+ <keywords /><handler>self.OnMenuCmd</handler>
<command>r.recode.file</command>
</menuitem>
<separator />
@@ -2659,7 +2659,7 @@
<items>
<menuitem>
<label>Query any table</label>
- <help>Selects data from table.</help>
+ <help>Selects data from attribute table (performs SQL query statement(s)).</help>
<keywords>database,attribute table,SQL</keywords>
<command>db.select</command>
@@ -2707,14 +2707,14 @@
<items>
<menuitem>
<label>GRASS help</label>
- <help>Display the manual pages of GRASS</help>
+ <help>Display the HTML man pages of GRASS</help>
<keywords>general,manual,help</keywords>
<handler>self.RunMenuCmd</handler>
<command>g.manual -i</command>
</menuitem>
<menuitem>
<label>GUI help</label>
- <help>Display the manual pages of wxGUI</help>
<command>g.manual wxGUI</command>
@@ -2734,4 +2734,4 @@
</items>
</menu>
</menubar>
-</menudata>
+</menudata>
\ No newline at end of file
