[GRASS-SVN] r39128 - grass/branches/develbranch_6/vector/v.out.ogr
svn_grass at osgeo.org
Fri Sep 11 11:54:29 EDT 2009
Author: benducke
Date: 2009-09-11 11:54:28 -0400 (Fri, 11 Sep 2009)
New Revision: 39128
grass/branches/develbranch_6/vector/v.out.ogr/main.c
Added code to automatically choose an appropriate geometry
type for output.
Modified: grass/branches/develbranch_6/vector/v.out.ogr/main.c
--- grass/branches/develbranch_6/vector/v.out.ogr/main.c 2009-09-11 09:01:31 UTC (rev 39127)
+++ grass/branches/develbranch_6/vector/v.out.ogr/main.c 2009-09-11 15:54:28 UTC (rev 39128)
@@ -79,6 +79,7 @@
unsigned int wkbtype = wkbUnknown; /* ?? */
OGRSpatialReferenceH Ogr_projection;
char **papszDSCO = NULL, **papszLCO = NULL;
+ int num_types;
G_gisinit(argv[0]);
@@ -91,10 +92,11 @@
in_opt = G_define_standard_option(G_OPT_V_INPUT);
type_opt = G_define_standard_option(G_OPT_V3_TYPE);
- type_opt->answer = "line,boundary";
+ type_opt->options = "point,line,boundary,centroid,area,face,kernel,auto";
+ type_opt->answer = "auto";
type_opt->description =
- _("Feature type. Combination of types is not supported "
- "by all output formats.");
+ _("Feature type(s). Combinations not supported "
+ "by all output formats. Default: first type found in input.");
type_opt->guisection = _("Input");
dsn_opt = G_define_option();
@@ -176,6 +178,82 @@
/* read options */
field = atoi(field_opt->answer);
+ /* open input vector */
+ if ((mapset = G_find_vector2(in_opt->answer, "")) == NULL) {
+ G_fatal_error(_("Vector map <%s> not found"), in_opt->answer);
+ Vect_set_open_level(2);
+ Vect_open_old(&In, in_opt->answer, "");
+ If no output type specified: determine one automatically.
+ Centroids, Boundaries and Kernels always have to be
+ exported explicitely, using the "type=" option.
+ if (!strcmp(type_opt->answer, "auto" )) {
+ G_debug(2, "Automatic type determination." );
+ type_opt->answers = G_malloc (sizeof(char*) * 100); /* should be big enough forever ;) */
+ for (i=0;i<100;i++) {
+ type_opt->answers[i] = NULL;
+ num_types = 0;
+ if ( Vect_get_num_primitives ( &In, GV_POINT ) > 0 ) {
+ type_opt->answers[num_types] = strdup ( "point" );
+ G_debug(3, "Adding points to export list." );
+ num_types ++;
+ if ( Vect_get_num_primitives ( &In, GV_LINE ) > 0 ) {
+ type_opt->answers[num_types] = strdup ( "line" );
+ G_debug(3, "Adding lines to export list." );
+ num_types ++;
+ if ( Vect_get_num_primitives ( &In, GV_BOUNDARY ) !=
+ Vect_get_num_areas ( &In ) )
+ G_warning(_("Skipping all boundaries that are not part of an area."));
+ if ( Vect_get_num_areas ( &In ) > 0 ) {
+ type_opt->answers[num_types] = strdup ( "area" );
+ G_debug(3, "Adding areas to export list." );
+ num_types ++;
+ /* Faces and volumes:
+ For now, volumes will just be exported as sets of faces.
+ if ( Vect_get_num_primitives ( &In, GV_FACE ) > 0 ) {
+ type_opt->answers[num_types] = strdup ( "face" );
+ G_debug(3, "Adding faces to export list." );
+ num_types ++;
+ /* this check HAS TO FOLLOW RIGHT AFTER check for GV_FACE! */
+ if ( Vect_get_num_volumes ( &In ) > 0 ) {
+ G_warning(_("Volumes will be exported as sets of faces."));
+ if ( num_types == 0 ) {
+ /* no other types yet? */
+ type_opt->answers[num_types] = strdup ( "volume" );
+ G_debug(3, "Adding volumes to export list." );
+ num_types ++;
+ } else {
+ if ( strcmp ( type_opt->answers[num_types-1], "face" ) ) {
+ /* only put faces on export list if that's not the case already */
+ num_types ++;
+ G_fatal_error(_("Could not determine input map's feature type(s)."));
/* Check output type */
otype = Vect_option_to_types(type_opt);
@@ -205,15 +283,24 @@
if (((GV_POINTS & otype) && (GV_LINES & otype)) ||
((GV_POINTS & otype) && (GV_AREA & otype)) ||
((GV_POINTS & otype) && (GV_FACE & otype)) ||
+ ((GV_POINTS & otype) && (GV_KERNEL & otype)) ||
+ ((GV_POINTS & otype) && (GV_VOLUME & otype)) ||
((GV_LINES & otype) && (GV_AREA & otype)) ||
- ((GV_LINES & otype) && (GV_FACE & otype))
+ ((GV_LINES & otype) && (GV_FACE & otype)) ||
+ ((GV_LINES & otype) && (GV_KERNEL & otype)) ||
+ ((GV_LINES & otype) && (GV_VOLUME & otype)) ||
+ ((GV_KERNEL & otype) && (GV_POINTS & otype)) ||
+ ((GV_KERNEL & otype) && (GV_LINES & otype)) ||
+ ((GV_KERNEL & otype) && (GV_AREA & otype)) ||
+ ((GV_KERNEL & otype) && (GV_FACE & otype)) ||
+ ((GV_KERNEL & otype) && (GV_VOLUME & otype))
G_warning(_("The combination of types is not supported"
" by all formats."));
if (cat_flag->answer)
donocat = 0;
else
@@ -222,14 +309,6 @@
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
- /* open input vector */
- if ((mapset = G_find_vector2(in_opt->answer, "")) == NULL) {
- G_fatal_error(_("Vector map <%s> not found"), in_opt->answer);
- Vect_set_open_level(2);
- Vect_open_old(&In, in_opt->answer, mapset);
if (Vect_get_num_islands(&In) > 0 && !cat_flag->answer)
G_warning(_("The map contains islands. To preserve them in the output map, use the -c flag"));
