[GRASS-SVN] r39151 - grass/trunk/vector/v.out.ascii
svn_grass at osgeo.org
Sat Sep 12 15:44:05 EDT 2009
Author: martinl
Date: 2009-09-12 15:44:04 -0400 (Sat, 12 Sep 2009)
New Revision: 39151
grass/trunk/vector/v.out.ascii/main.c
default standard output
Modified: grass/trunk/vector/v.out.ascii/main.c
--- grass/trunk/vector/v.out.ascii/main.c 2009-09-12 18:40:33 UTC (rev 39150)
+++ grass/trunk/vector/v.out.ascii/main.c 2009-09-12 19:44:04 UTC (rev 39151)
@@ -53,7 +53,8 @@
output->description =
_("Path to resulting ASCII file ('-' for standard output) "
"or ASCII vector name if '-o' is defined");
+ output->answer = "-";
format_opt = G_define_option();
format_opt->key = "format";
format_opt->type = TYPE_STRING;
