[GRASS-SVN] r39164 - grass/trunk/raster/r.colors
svn_grass at osgeo.org
Sat Sep 12 23:28:03 EDT 2009
Author: glynn
Date: 2009-09-12 23:28:02 -0400 (Sat, 12 Sep 2009)
New Revision: 39164
Added:
grass/trunk/raster/r.colors/thumbnails.py
Removed:
grass/trunk/raster/r.colors/thumbnails/
grass/trunk/raster/r.colors/Makefile
Generate thumbnails for r.colors HTML file during build
Modified: grass/trunk/raster/r.colors/Makefile
--- grass/trunk/raster/r.colors/Makefile 2009-09-13 03:26:35 UTC (rev 39163)
+++ grass/trunk/raster/r.colors/Makefile 2009-09-13 03:28:02 UTC (rev 39164)
@@ -10,9 +10,17 @@
default: cmd
# Insert thumbnail previews
-# Try overriding the default rule with:
-#r.colors.tmp.html: $(HTMLSRC)
-# $(call htmldesc,$<,$@)
-# sed 's!^<DD><b>\([a-z0-9.]*\)</b>:!<DD><img width="80" height="12" \
-# src="Colortable_\1_i.png"><b>\1</b>:!' $@ > $@.tmp
-# mv -f $@.tmp $@
+r.colors.tmp.html: $(HTMLSRC) thumbnails.py
+ $(call htmldesc,$<,$@)
+ sed 's!^<DD><b>\([a-z0-9.]*\)</b>:!<DD><img width="80" height="12" src="Colortable_\1.png"><b>\1</b>:!' $@ > $@.tmp
+ mv -f $@.tmp $@
+ $(MAKE) thumbnails
+thumbnails: $(BIN)/r.mapcalc$(EXE)
+ $(call run_grass, ./thumbnails.py)
+$(BIN)/r.mapcalc$(EXE):
+ $(MAKE) -C ../r.mapcalc
+.PHONY: thumbnails
Added: grass/trunk/raster/r.colors/thumbnails.py
--- grass/trunk/raster/r.colors/thumbnails.py (rev 0)
+++ grass/trunk/raster/r.colors/thumbnails.py 2009-09-13 03:28:02 UTC (rev 39164)
@@ -0,0 +1,151 @@
+#!/usr/bin/env python
+import sys
+import os
+import atexit
+import string
+import array
+import grass.script as grass
+tmp_img = None
+tmp_grad_abs = None
+tmp_grad_rel = None
+height = 85
+width = 15
+def cleanup():
+ if tmp_img:
+ grass.try_remove(tmp_img)
+ if tmp_grad_rel:
+ grass.run_command('g.remove', rast = tmp_grad_rel, quiet = True)
+ if tmp_grad_abs:
+ grass.run_command('g.remove', rast = tmp_grad_abs, quiet = True)
+# def rotate(src, dst):
+# grass.call(["convert", "-rotate", "90", src, dst])
+def read_ppm(src):
+ fh = open(src, "rb")
+ text = fh.read()
+ fh.close()
+ i = 0
+ j = text.find('\n', i)
+ if text[i:j] != 'P6':
+ raise IOError
+ i = j + 1
+ w, h = text[i:j].split()
+ if int(w) != width or int(h) != height:
+ raise IOError
+ i = j + 1
+ maxval = text[i:j]
+ if int(maxval) != 255:
+ raise IOError
+ i = j + 1
+ return array.array('B', text[i:])
+def write_ppm(dst, data):
+ w = height
+ h = width
+ fh = open(dst, "wb")
+ fh.write("P6\n%d %d\n%d\n" % (w, h, 255))
+ data.tofile(fh)
+ fh.close()
+def rotate_ppm(srcd):
+ dstd = array.array('B', len(srcd) * '\0')
+ for y in xrange(height):
+ for x in xrange(width):
+ for c in xrange(3):
+ dstd[(x * height + (height - 1 - y)) * 3 + c] = srcd[(y * width + x) * 3 + c]
+ return dstd
+def ppmtopng(dst, src):
+ fh = open(dst, 'wb')
+ grass.call(["pnmtopng", tmp_img], stdout = fh)
+ fh.close()
+def convert_and_rotate(src, dst):
+ if grass.find_program("convert"):
+ grass.call(["convert", "-rotate", "90", src, dst])
+ elif grass.find_program("pnmtopng"):
+ srcd = read_ppm(src)
+ dstd = rotate_ppm(srcd)
+ write_ppm(tmp_img, dstd)
+ ppmtopng(dst, tmp_img)
+ else:
+ grass.fatal(_("Cannot find either convert or pnmtopng"))
+def main():
+ global tmp_img, tmp_grad_abs, tmp_grad_rel
+ os.environ['GRASS_OVERWRITE'] = '1'
+ color_dir = os.path.join(os.environ['GISBASE'], "etc", "colors")
+ output_dir = os.path.join(os.environ['GISBASE'], "docs", "html")
+ if not os.path.exists(output_dir):
+ os.makedirs(output_dir)
+ pid = os.getpid()
+ tmp_grad_abs = "tmp_grad_abs_%d" % pid
+ tmp_grad_rel = "tmp_grad_rel_%d" % pid
+ tmp_img = grass.tempfile() + ".ppm"
+ os.environ['GRASS_WIDTH'] = '%d' % width
+ os.environ['GRASS_HEIGHT'] = '%d' % height
+ os.environ['GRASS_FRAME'] = '%f,%f,%f,%f' % (0,height,0,width)
+ os.environ['GRASS_PNGFILE'] = tmp_img
+ os.environ['GRASS_TRUECOLOR'] = 'TRUE'
+ os.environ['GRASS_PNG_READ'] = 'FALSE'
+ os.environ['GRASS_PNG_MAPPED'] = 'FALSE'
+ os.environ['GRASS_TRANSPARENT'] = 'FALSE'
+ os.environ['GRASS_BACKGROUNDCOLOR'] = 'ffffff'
+ grass.use_temp_region()
+ grass.run_command('g.region', rows = 100, cols = 100)
+ grass.mapcalc("$grad = row()/1.0", grad = tmp_grad_rel)
+ for table in os.listdir(color_dir):
+ path = os.path.join(color_dir, table)
+ fh = open(path)
+ text = fh.read()
+ fh.close()
+ lines = text.splitlines()
+ records = [line.split() for line in lines]
+ records = [record for record in records if record[0] != 'nv']
+ relative = False
+ absolute = False
+ for record in records:
+ if record[0].endswith("%"):
+ relative = True
+ record[0] = record[0].rstrip("%")
+ else:
+ absolute = True
+ if absolute:
+ if relative:
+ minval = -0.04
+ maxval = 0.04
+ else:
+ minval = float(records[0][0])
+ maxval = float(records[-1][0])
+ maxval = min(maxval, 2500000)
+ grad = tmp_grad_abs
+ grass.mapcalc("$grad = if(row()==1, float($min), float($max))",
+ grad = tmp_grad_abs, min = minval, max = maxval)
+ else:
+ grad = tmp_grad_rel
+ grass.run_command("r.colors", map = grad, color = table, quiet = True)
+ grass.run_command("d.colortable", flags = 'n', map = grad)
+ outfile = os.path.join(output_dir, "Colortable_%s.png" % table)
+ convert_and_rotate(tmp_img, outfile)
+if __name__ == "__main__":
+ atexit.register(cleanup)
+ main()
Property changes on: grass/trunk/raster/r.colors/thumbnails.py
___________________________________________________________________
Added: svn:executable
