[GRASS-SVN] r39184 - grass/branches/develbranch_6/gui/wxpython/docs
svn_grass at osgeo.org
Sun Sep 13 15:31:38 EDT 2009
Author: helena
Date: 2009-09-13 15:31:38 -0400 (Sun, 13 Sep 2009)
New Revision: 39184
grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html
Map display toolbar update
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html 2009-09-13 19:30:39 UTC (rev 39183)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html 2009-09-13 19:31:38 UTC (rev 39184)
@@ -378,66 +378,71 @@
<dt><img src="icons/grass2/zoom-more.png">
<em>Zoom menu</em></dt>
-<dd>Automatic zoom settings menu. Zoom to match the extents of a selected
-map, zoom to match the computational region (set with
-<em>g.region</em>), zoom to match the extents of a saved region or
-save the current extents to a named region file, or to set
-computational region (the mapset's <tt>WIND</tt> file) to match the
-current display extents (does not change the resolution).
-See <em><a href="g.region.html">g.region</a></em>.</dd>
+<dd>opens a dropdown menu that allows user to:<br>
+ <ul>
+ <li>Zoom to match the extents of a selected map</li>
+ <li>Zoom to match the computational region (set with <em>g.region</em>)</li>
+ <li>Zoom to match the extents of a saved region or
+ save the current extents to a named region file</li>
+ <li>Set computational region (the mapset's <tt>WIND</tt> file) to match the
+ current display extents (does not change the resolution).
+ See <em><a href="g.region.html">g.region</a></em>.</dd>
+ </ul>
<dt><img src="icons/grass2/layer-raster-analyze.png">
<em>Analyze menu</em></dt>
-<dd>Contains functions for distance measurement, creating histogram or
-profile tool.</dd>
+<dd>opens a dropdown menu with:<br>
-<dt><img src="icons/grass2/measure-length.png">
- <em>Distance measurement tool</em></dt>
-<dd>Interactive measurement of lengths defined with the mouse. The
-length of each segment and the cumulative length of all segments
-measuered is displayed in the command output window frame. Lengths are
-measured in the current measurement unit,
-see <em><a href="d.measure.html">d.measure</a></em>.</dd>
+ <ul>
+ <li> <dt><img src="icons/grass2/measure-length.png">
+ <em>Distance measurement tool</em></dt>
+ <dd>Interactive measurement of lengths defined with the mouse. The
+ length of each segment and the cumulative length of all segments
+ measuered is displayed in the command output window frame. Lengths are
+ measured in the current measurement unit,
+ see <em><a href="d.measure.html">d.measure</a></em>.</dd></li>
-<dt><img src="icons/grass2/layer-raster-profile.png">
- <em>Profile tool</em></dt>
-<dd>Interactively create profile of a raster map. Profile transect is
-drawn with the mouse in map display. The profile may be of the
-displayed map or a different map,
-see <em><a href="gm_profile.html">Profile Tool help
-page</a></em>.</dd>
+ <li><dt><img src="icons/grass2/layer-raster-profile.png">
+ <em>Profile tool</em></dt>
+ <dd>Interactively create profile of a raster map. Profile transect is
+ drawn with the mouse in map display. The profile may be of the
+ displayed map or a different map,
+ see <em><a href="gm_profile.html">Profile Tool help page</a></em>.</dd></li>
-<dt><img src="icons/grass2/layer-raster-histogram.png">
- Display histogram of selected raster map</dt>
-<dd>Displays histogram of selected raster map or image in new window,
-see <em><a href="d.histogram.html">d.histogram</a></em>.</dd>
+ <li><dt><img src="icons/grass2/layer-raster-histogram.png">
+ <em>Histogram tool</em></dt>
+ <dd>Displays histogram of selected raster map or image in new window,
+ see <em><a href="d.histogram.html">d.histogram</a></em>.</dd></li>
+ </ul>
<dt><img src="icons/grass2/element-add.png">
- Add overlay</dt>
-<dd>Adds overlay to map display like barscale, north arrow, text.</dd>
+ <em>Add overlay</em></dt>
+ <dd>opens a dropdown menu that allows user to:<br>
-<dt><img src="icons/grass2/scalebar-add.png">
- <em>Add scalebar and north arrow</em></dt>
-<dd>Adds layer to display a combined scalebar and north arrow. Options
-include scalebar placement (using screen coordinates or a mouse),
-scalebar format, and scalebar colors,
-see <em><a href="d.barscale.html">d.barscale</a></em>.</dd>
+ <ul>
+ <li> <dt><img src="icons/grass2/scalebar-add.png">
+ <em>Add scalebar and north arrow</em></dt>
+ <dd>Adds layer to display a combined scalebar and north arrow. Options
+ include scalebar placement (using screen coordinates or a mouse),
+ scalebar format, and scalebar colors,
+ see <em><a href="d.barscale.html">d.barscale</a></em>.</dd></li>
-<dt><img src="icons/grass2/legend-add.png">
- <em>Add raster map legend</em></dt>
-<dd>Adds layer to display with legend of selected raster map,
-see <em><a href="d.legend.html">d.legend</a></em>.</dd>
+ <li><dt><img src="icons/grass2/legend-add.png">
+ <em>Add raster map legend</em></dt>
+ <dd>Adds layer to display with legend of selected raster map,
+ see <em><a href="d.legend.html">d.legend</a></em>.</dd></li>
-<dt><img src="icons/grass2/text-add.png">
- <em>Add text layer</em></dt>
-<dd>Adds layer to display a line of text using default GRASS font
-(selected with <em><a href="d.font.html">d.font</a></em>). Options
-include: text placement (screen coordinates); and text size, bolding,
-and color, see <em><a href="d.text.html">d.text</a></em>.</dd>
+ <li><dt><img src="icons/grass2/text-add.png">
+ <em>Add text layer</em></dt>
+ <dd>Adds layer to display a line of text using default GRASS font
+ (selected with <em><a href="d.font.html">d.font</a></em>). Options
+ include: text placement (screen coordinates); and text size, bolding,
+ and color, see <em><a href="d.text.html">d.text</a></em>.</dd></li>
+ </ul>
<dt><img src="icons/grass2/map-export.png">
- <em>Export map display</em></dt>
-<dd>Exports visible map display to different raster graphic formats.</dd>
+ <em>Save display to PNG file</em></dt>
+<dd>Save the visible image in map display to different raster graphic formats.</dd>
<dt><img src="icons/grass2/print.png">
<em>Print map</em></dt>
