[GRASS-SVN] r39190 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Sep 14 04:39:15 EDT 2009
Author: martinl
Date: 2009-09-14 04:39:14 -0400 (Mon, 14 Sep 2009)
New Revision: 39190
grass/trunk/gui/wxpython/gui_modules/menuform.py
Direct OGR support (wxGUI dialog updated)
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2009-09-14 02:38:46 UTC (rev 39189)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2009-09-14 08:39:14 UTC (rev 39190)
@@ -25,7 +25,7 @@
The XML stream is read from executing the command given in the
command line, thus you may call it for instance this way:
- python <this file.py> r.basins.fill
+ python menuform.py r.basins.fill
Or you set an alias or wrap the call up in a nice shell script, GUI
environment ... please contribute your idea.
@@ -1255,17 +1255,72 @@
multiple=multiple, mapsets=mapsets)
if p.get('value','') != '':
selection.SetValue(p['value']) # parameter previously set
- which_sizer.Add(item=selection, proportion=0,
- flag=wx.ADJUST_MINSIZE| wx.BOTTOM | wx.LEFT | wx.RIGHT, border=5)
# A select.Select is a combobox with two children: a textctl and a popupwindow;
# we target the textctl here
- p['wxId'] = selection.GetChildren()[0].GetId()
+ p['wxId'] = [selection.GetChildren()[0].GetId(), ]
selection.GetChildren()[0].Bind(wx.EVT_TEXT, self.OnSetValue)
if p.get('prompt', '') == 'vector':
selection.Bind(wx.EVT_TEXT, self.OnUpdateSelection)
+ if p.get('age', '') == 'old':
+ # OGR supported (read-only)
+ hsizer = wx.GridBagSizer(vgap=5, hgap=5)
+ hsizer.Add(item=selection,
+ flag=wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT | wx.RIGHT | wx.TOP | wx.ALIGN_TOP,
+ border=5,
+ pos = (0, 0))
+ # format (native / ogr)
+ rbox = wx.RadioBox(parent = which_panel, id = wx.ID_ANY,
+ label = " %s " % _("Format"),
+ style = wx.RA_SPECIFY_ROWS,
+ size = (100, -1),
+ choices = [_("Native"), _("OGR")])
+ rbox.Bind(wx.EVT_RADIOBOX, self.OnVectorFormat)
+ hsizer.Add(item=rbox,
+ flag=wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT | wx.RIGHT | wx.ALIGN_TOP,
+ pos = (0, 1),
+ span = (3, 1),
+ border=5)
+ ogrSelection = filebrowse.DirBrowseButton(parent = which_panel, id = wx.ID_ANY,
+ size = globalvar.DIALOG_GSELECT_SIZE,
+ labelText = '',
+ dialogTitle = _('Choose OGR data source'),
+ buttonText = _('Browse'),
+ startDirectory = os.getcwd())
+ ogrSelection.SetName('OgrSelect')
+ ogrSelection.Enable(False)
+ ogrSelection.Bind(wx.EVT_TEXT, self.OnSetValue)
+ hsizer.Add(item=wx.StaticText(parent = which_panel, id = wx.ID_ANY,
+ label = _("Name of OGR data source:")),
+ flag=wx.ALIGN_BOTTOM | wx.LEFT,
+ pos = (1, 0),
+ border=5)
+ hsizer.Add(item=ogrSelection,
+ pos = (2, 0),
+ border=5)
+ which_sizer.Add(item = hsizer, proportion = 0)
+ p['wxId'].append(rbox.GetId())
+ p['wxId'].append(ogrSelection.GetId())
+ p['wxId'].append(ogrSelection.GetChildren()[1].GetId()) # fix
+ else:
+ which_sizer.Add(item=selection, proportion=0,
+ flag=wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT | wx.RIGHT | wx.TOP | wx.ALIGN_CENTER_VERTICAL,
+ border=5)
+ else:
+ border=5)
# layer, dbdriver, dbname, dbcolumn, dbtable entry
elif p.get('prompt', '') in ('dbdriver',
'dbname',
@@ -1499,6 +1554,37 @@
self.Bind(EVT_DIALOG_UPDATE, self.OnUpdateDialog)
+ def OnVectorFormat(self, event):
+ """!Change vector format (native / ogr)"""
+ sel = event.GetSelection()
+ idEvent = event.GetId()
+ p = self.task.get_param(value = idEvent, element = 'wxId', raiseError = False)
+ if not p:
+ return # should not happen
+ winNative = None
+ winOGR = None
+ for id in p['wxId']:
+ if id == idEvent:
+ continue
+ name = self.FindWindowById(id).GetName()
+ if name == 'Select':
+ winNative = self.FindWindowById(id + 1) # fix the mystery (also in nviz_tools.py)
+ elif name == 'OgrSelect':
+ winOgr = self.FindWindowById(id)
+ # enable / disable widgets & update values
+ if sel == 0: # -> native
+ winOgr.Enable(False)
+ winNative.Enable(True)
+ p['value'] = winNative.GetValue()
+ elif sel == 1: # -> OGR
+ winNative.Enable(False)
+ winOgr.Enable(True)
+ p['value'] = winOgr.GetValue()
+ self.OnUpdateValues()
def OnUpdateDialog(self, event):
for fn, kwargs in event.data.iteritems():
fn(**kwargs)
@@ -1598,20 +1684,33 @@
def OnSetValue(self, event):
- Retrieve the widget value and set the task value field accordingly.
+ Retrieve the widget value and set the task value field
+ accordingly.
- Use for widgets that have a proper GetValue() method, i.e. not for selectors.
+ Use for widgets that have a proper GetValue() method, i.e. not
+ for selectors.
myId = event.GetId()
me = wx.FindWindowById( myId )
for porf in self.task.params + self.task.flags:
- if 'wxId' in porf and type( porf[ 'wxId' ] ) == type( 1 ) and porf['wxId'] == myId:
- if porf.has_key('wxGetValue') and porf['wxGetValue']:
- porf['value'] = porf['wxGetValue']()
- else:
- porf['value'] = me.GetValue()
+ if 'wxId' in porf:
+ found = False
+ porf['wxId']
+ if type(porf['wxId']) == types.IntType:
+ if porf['wxId'] == myId:
+ found = True
+ else: # -> list
+ for id in porf['wxId']:
+ if id == myId:
+ found = True
+ break
+ if found:
+ if porf.has_key('wxGetValue') and porf['wxGetValue']:
+ porf['value'] = porf['wxGetValue']()
+ else:
+ porf['value'] = me.GetValue()
